View Full Version : Tuning
Pages :
1]
- 93 octane timing and boost.
- AFR 18.0 at WOT
- How to richen it up?
- Anyone still remote tuning for the z54 ??
- Plain Janeing My Ecu
- Hptuners and unlocking new ecus
- GMPP tune with 2.5 bar sensor question
- Local tuner in reidsville/greensboro NC ?
- L61 turbo tuning
- Anyone have a 2.4L LE5 ZZP or Custom Bolt-ons Tune?
- Anybody using WinOLS on the LNF?
- 08 LNF. Switchable tune ECU locked?
- M62 lsj/le5 Frankenstein Malibu
- In need of cobalt SS 2008 stock tune file
- [LSJ] HPTuners to force IC pump to be always on?
- 2.4 + TVS Supercharger - Need Tuning
- L61 m62 base tune needed
- How to find a good reputable Dyno?
- Installed my PCM with ZZP tune
- Basic 2009 2.2 LAP Tuning
- Who's good at tuning?
- Universal standalone ecu wiring piggy back input signals grounding
- L61 MAF Tuning help
- Looking for LNF 09 ECU stock and GMS1 bin file
- Hp tuners question on credits
- Porting head requiring tune? 07 Cobalt SS sc
- Tuning software on a 2006 cobalt ss 2.4
- no cat overtemp in hp tuners.
- High Power Oil Consumption
- Need tune file for 09 Na
- 2.4NA LE5 getting SC, Help please!
- Looking for Tuner Oregon or Remote
- Running rich
- GM dealer Stage 1
- 22psi with stock timing???
- Looking for houston LNF tuner
- GMS1 tune file for 09 Cobalt
- Some HPTuners help.
- E85
- HP Tuner and The Tuning School .com
- Le5 tuning question
- Logs of well-running 2.4L wanted (turbo a plus)
- Clutch position switch question
- Pinout for “12605843” le5 ecm
- LSU 4.9 PreHeat in accessory mode
- Finally a proper dyno tune
- Canadian Tuner
- 2.4L Cobalt E67 Oval Track Racecar - Low Power Mode
- Calculating Horsepower in HPTuners
- LDK Opel Tuning Issues
- Tuner Recommendations?
- HPTuners Pro features needed?
- M62 Smaller Pulley search
- Tuner in Georgia or South east area
- F23 swap tuning help
- Eaton M62 max RPM with boost
- My first tune: idle
- Z54 Tuning
- 31L/100 km mileage
- 09 cobalt making more boost
- Tuner in Western PA or surrounding area
- Clean up tune??
- Tuner In FL
- zzp cam charts
- Hp tuner not allowing to connect
- Engine never runs correctly, 57mm turbo, opel injectors, etc.
- delivered engine torque
- MD tuner
- I think my car is making too much boost...please help!
- Engine breathing supercharged
- HPTuner
- Good Tuners?
- Tuning in CT
- How to tell if you have a tune?
- LTFT always positive while cruising
- Return back to stock tune
- Looking for new tuner of tuning help with k04+ lnf
- Stand Alone Tuner
- 2008 cobalt lnf tuning question
- Looking for a tuner Cali
- Tuner in Cleveland Ohio
- Tuning in S FL
- tuning torque management
- Tune in NYC area
- term2 tune here in IL=PASS!!!!
- New LNF owner, trifecta to stock tune
- LSJT Remote Tuner?
- Tuner in Washington state
- Help with ZZP 1.0 ECU
- 2009 lnf
- lsj idle tuning with a/c on
- Need a Tuner for my 08 Turbo
- Looking for a tuner for my 09 cobalt ss turbo
- hptuners helping friend out
- Tuner needed
- Hp Tuners question?
- Will i need to get tuned?
- Tuner Needed
- Need a Tuner near Detroit, MI 48044
- Tunner in Kansas or Oklahoma
- Can't find desired air load tables
- Gms1 sensor question!
- Cooling Fan Stays on all the time
- the HPTuner worth the $ ?? should I get one
- Is this a thing with Dynojets???
- HP tuners help!
- ZZP PCM/Tune causing SC bypass malfunction?
- Is a zzp tune worth the money?
- E67 turbo auto in need of some assistance
- Bad ZZP PCM, ZZP refusing to refund or fix
- advanced tuners please help
- Canned e85 tune lean? High Temps on LE5/K04
- Comparing max timing on 92
- Case Relearn??
- Engine Tuning 101 video, uses E67 and E78 examples
- Looking for tuner
- Hp tuners 3.0 config file
- ZZP or Trifecta Tune
- Finally tuned on HPT
- No longer a slowbalt
- HP Tuners help
- Any tuners in ontario?
- Need a tuner near me in Florida
- someone with HPT around NEPA?
- Squeezing Everything I can out of 60lb Injectors on E47
- Bench tune wiring
- Need to get the LNF tuned in the next few weeks.
- In Search Of A Tuner!
- 2010 lnf gms1
- trifecta tune on stock turbo and intake
- Can i swap intakes?
- Why does everyone think E85 is 105 octane
- need help to cofigure boost gauge using HPTuners
- Extreme MAF, airmass and Load% spike problem on big turbo LNF
- Tuning Help!!!
- Trifecta Tuning Cable
- HP Tuners Tire Size
- term2 remote tuned my car--- he IS the goto guy!
- Dyno tuning
- weird throttle issue
- Mod path help?
- tuning for S/C 2.4 auto?
- LNF rear O2 sensor dumping fuel to save cat with COT set to all to 1
- HP Tuners VCM Scanner MAP range question
- 60s a little rich on decel, throwing off trims, Normal?
- Tuning help
- Do you need o2 bung to tune lnf?
- MAF fail high 0Hz causing limp mode
- HP Tuners 3.0 Scanner
- Virginia, West Virginia, Maryland, North Carolina, Pennsylvania
- Oem lnf wastegate solenoid
- Is it ok to run #80 injectors on 93?
- For anyone trying to log your wideband on HPT 3.0
- Where to begin in Indiana?
- Term2's email needed .
- Different Tuning Stages
- Tuning in Milwaukee, WI Area
- closed loop question
- Beta 2.25?
- GM Stage 2 - Maxed Inj in Winter?
- Tuning Help
- Possible fasle kr or ?
- What are you guys using for pe mode ramp rate.....
- 09 LNF Knock retard and fuel level.
- Term2
- tuner in the California LA area???
- Tuning in winter?
- OTTP LNF tune question
- Need a good tune
- Using both
- What tune do i have?
- Factory 2007 ss/sc tune
- Bringing back that 'old-school' wonderful, vacuum advance, part-throttle feeling LNF
- Tune question
- boost logging and HPtuners HELP
- 26 psi on stock pully? 05 ss hp log
- Tuner in Ga
- Looking for a Tune in San Diego County
- looking for a tuner
- West Bend Auto Tuning
- The REAL How To: tuning VE (L61/LAP/LE5)
- How to: VE tuning your L61/LE5/LAP using Virtual VE.
- 2010 cobalt 2.2 lap tuning
- "All LNF's knock 3-4*" -Trifecta
- Recirc bov
- 08 LNF GMS1 Tune file
- HP setup file(s)
- hp tuners wont connect to car
- FID 1000's - anyone run them/tune for them?
- LSJ turbo tune
- LNF HP TUNER neededChicago near n/w 'burbs.
- Tune Advice
- Zzp canned tune psi?
- Knock on cyl 1
- 2.4? Bolt ons? Are you tuned?
- Specialty tuning?
- LSJ running rich
- LNF GMS1 back to stock base file from repository
- Looking for parts advice
- Looking for a remote tune for an 06 LSJ
- Another pulley down injector up thread(NC tuner?)
- Standalone / Piggyback ECU Options
- Tuning/Chips
- Lsj tune philly/southjersey
- Tune or no
- GM Stage 1 Tuning
- Best tune for 90 octane
- Help with Saturn Ion Redline
- looking for Bosch ev14 60# injector tables for lsj
- I need a ss/sc tune
- Wanted Tuner around treasure coast FL.
- A Cobalt SS Owner is Offering to Tune My SS/TC w/ HPT for $50. Too Good To Be True?
- EFR 6758 Tuning Help
- Advice needed!!!
- Automatic with part-throttle surging? Getting tuned soon? Read this first.
- gms1 tune? want e47. warranty issues?
- LNF E69 ECU Documentation
- Trifecta on a LSJ?
- Tuning Help
- GM Stage 3 PCM
- MI or OH Tuner needed
- MD LNF tuner
- Looking for base tune for 2.8 and 60's
- Avalible programmers
- Tuned or Not
- Tuner needed in Va
- Epic Return, Maybe a tune?
- HPTuners Dealer, GTA
- Looking for a Tuner in eastern PA
- BYT Tuning?
- ELM 327 OB2 not working because of Trifecta ?
- Tuning 05-07 LSJ's
- COT (Cat Over Temp) Protection for LNF Question
- Tuner needed NY
- tune up??
- Northern Virginia Tuning
- I need a tuner around the Toronto area!
- Quick PCM question
- tuning question.
- zfr6758
- LNF Tuning LE5 Throttle body
- Trifecta Black Box Cable Teardown
- High LTFT, need some advice
- Need Tuning Help - Middle TN, S. KY or N. AL
- Tuner in MN?!
- LNF Guys w/ HPT and MAF Relocate in here
- How many miles are too many miles to get tuned?
- E47/50 on 93 or 87
