- Appearance how to cover trunk key hole
- 2.0 LSJ Engine LSJ Flexpipe repair/replacement
- 2.0 LNF Engine How-To: Repair LNF cylinder head oil leaks
- General Suspension How to change your SWAY BAR LINKS With PICS
- Electrical How To: Factory Cruise Control and Remote Radio Control Installation (2007- 2010)
- Interior How to Install Aftermarket Heated Seats
- Interior How To: Add Aux Input to pre '07 Cobalts
- A quick HOW TO on installing the RPD(UAF)
- General Suspension How To: Install OTTP Hardcore RSB
- Appearance How To: Chrome SS Badges
- Interior HOW TO: relocate back seat Release Poper
- Electrical How To: Install the UAF display to your 09 SS/TC
- Interior Front Door Speaker Install w/ PICS
- Interior Rear Speaker/ Read lid removal w/ PICS!!
- Interior How To: Replace shifter lights for automatics
- 2.2 L61 Engine How-To Install a Lower Deflector (2.2L)
- Appearance How to remove/smoke tail lights on a Sedan SS/TC
- Appearance How-To: Paint your reverse lights so you can see while you reverse.
- All Engines How To: Wire Your Fans To A Switch!
- All Engines mass air flow cleaning
- Interior door rattles anyone - How To, silencing door rattles.
- LNF Turbo Removal Procedure (No Pics)
- Appearance Fog Lamps as DRL's ('07+ only)
- Drivetrain Tranmission Removal Procedures?
- Interior How to: Fix your wiggling auto shifter
- 2.0 LSJ Engine How-To: GM's LSJ Build Up
- Interior Hinow41 led button mod
- Appearance How to install Halos Projectors and L.E.D. Lights
- 2.0 LSJ Engine How to install ZZP coupler
- General Suspension How-to: Adjusting the emergency - parking brake on 05-09 Cobalt w/ rear disc brakes
- Other/Misc How To Subscribe to a Thread Without Posting!
- 2.0 LNF Suspension How-to: Changing rear brake pads on 2009 SS/TC Coupe
- Interior How to: Easy+cheap fix for sticky door other latch issues
- 2.0 LSJ Engine Install Powell F35 Stage2 Mounts
- 2.0 LSJ Engine Hook up Optionb bleeder line to CXR H/E
- Drivetrain how to flush clutch/brake hydraulic system
- Detailing How to polish your valve cover
- 2.0 LSJ Engine How to remove your cone/filter for cleaning
- Interior How To: Wire/Install Pioneer Avic-F900BT/F90BT/F700BT - 2008 Cobalt SS
- 2.0 LSJ Engine How to Meziere Intercooler Pump
- Other/Misc How To: Fix locked key due to parking switch - Automatics only
- Interior How to install a 7" LCD H/U and Slim PS2 on 2007 Cobalt SS/SC
- Interior How to upgrade the stock Pioneer sub to sound awesome and look stock. (With Pics)
- 2.0 LNF Engine How to for CIA Down pipe...warning - big pics!
- All Engines How to port and polish a TB
- 2.0 LNF Suspension Attn: All Tc/brembo Diy Brakes!
- All Engines How-to Install header and downpipe
- Interior How to: Remove your passenger airbag
- All Engines [B][/B] how to change the alternator pulley(MRZ ALTERNATOR PULLEY)
- Appearance How to remove the headlights on a Cobalt/G5
- Electrical How to replace your power steering motor
- Interior 3 Gauge A Pillar Install w/ Dual Interceptors
- 2.0 LSJ Engine How to: Install OTTP Rotated Mount Stage 1
- 2.0 LSJ Engine how to: install vulcan turbo resevoir+lower hose tee
- 2.0 LNF Engine How to: Hahn Intake Install (56K no)
- Appearance PICS:my license plate holes fix
- 2.0 LNF Engine Hahn Charge Piping Install Instructions
- Electrical oil pressure gauge
- Interior Install an XM Radio
- 2.2 L61 Engine How To: Vulcan Turbo Intake Manifold
- Interior How to: Remove front seats and install aftermarket seats
- Other/Misc HOW TO: Antenna Mod
- Interior How To Paint your speedo bezel.
- Interior How-To: Install TWM short shifter in your SS T/C
- Electrical How to install an Auto Meter Voltmeter
- 2.2 LAP Engine 2.4 Intake Manifold install on 2008 2.2
- All Engines MRZ crank pulley install
- Appearance Install rear SS lip on LS bumper
- Interior how-to: Lower your locks.
- General Suspension 2006 Cobalt SS 2.4l Wheel Hub Bearing Assy R&R (pics)
- Electrical Change the horn!!!!!
- 2.2 L61 Engine Hunter's How to Install M62 on 2.2l Cobalt
- Appearance How to paint your supercharger
- 2.0 LSJ Engine How to Install CX Racing H/E w/ no fabrications
- Interior How To: Adjust your Hurst or B&M Shifter
- Appearance How to Swap to CCFL halos in 1st Gen Projectors
- How To: Install & Mount Big CX Heat Exchanger
- Interior Acoustic mat installation
- 2.0 LSJ Engine How To: Install Spark Boot Spring Upgrade Kits (2.0 LSJ)
- 2.0 LSJ Engine How to plug your SC silencer holes
- Interior How to install a dome light on a vehicle with a sunroof
- Electrical How to install Activation LED on a Meth Injection System
- Electrical How To: Install dual Interceptors
- 2.4 LE5 Engine How To: Make a nice CAI
- 2.2 L61 Engine How-to: Remove 05-06 2.2L Valve Cover
- 2.2 L61 Engine How-To: Remove 05-06 2.2L Valve Cover
- General Suspension How to do your rear brakes
- Interior Install a sirius radio
- Appearance How To: Install SS/SC Front and Rear Lip on ss/na!!!
- Interior How-To: Remove window switch bezels and paint them Lots of PICS
- Electrical How To: install gauges in your 2.2/2.4 to a switched source
- Appearance how to paint stock rims! (eurochevy edition) with pics
- Appearance How-To: Remove glare spots above cut-off line with 3rd Gen. Projectors
- Drivetrain How to Change SS/SC Transmission fluid
- 2.2 L61 Engine 2007 2.2L Oil Pressure Gauge Install How-to
- 2.0 LSJ Engine How to tune for return fuel system.
- 2.0 LSJ Engine How to Seafoam an SS/SC
- Interior How To: Interior Lights
- 2.0 LSJ Engine How to tune 60lb injectors - 56k = ZZzzzzz...
- Interior DIY custom gauges
- Other/Misc How To: ~Weight Reduction For Track~
- Electrical How To: PLX D100 Wideband and Sensor Module
- 2.0 LSJ Engine How to: CX Racing Heat Exchanger
- Appearance Front Facia removal and replacement
- Appearance CCFL 2nd internal Modifications! cut-off + aiming
- Interior Back seat Chirp or Squeak Fix
- All Engines How to: Defeat the rear 02 (those of you with High Flow Cats)
- Drivetrain How To: Install BWoody Solid Front Transmission Mount
- Interior Installing aftermarket Tacho on Redline (with pictures)
- Drivetrain HOW TO Fix Linkage Roll Pin on Transmission
- 2.0 LSJ Engine (How-to) Port & Polish your Supercharger!
- Appearance paint brake calipers (56k maybe?!?!)
- General Suspension How To install lowering Springs on a Ion Redline (56k Be weary)
- Appearance HOW TO: Flip Trunk
- 2.0 LSJ Engine how to change your S/C oil (pics)
- Electrical How To: Traction Control Switch
- Interior How To: 3rd Brake Light LED Retrofit
- Interior How to: Install Interior Neon Accent Lights for Wiring Noobs
- Interior How To: Cover A and C Pillars
- Interior How to: Install subs and amps with original H/U (with pics)
- Electrical How To: 5 minute LED in DoorHandles
- Exhaust HOW TO INSTALL header and down pipe TO A COBALT
- Airlift air bag install
- Appearance How to: HID installation
- 2.2 L61 Engine How To - Install the AEM fuel/ignition controller on an 05-06 2.2L
- Electrical How-To: Add Mirror Map Lights
- Appearance Make a Nice Affordable Lip
- Drivetrain How to: Reattach cable link to shifter
- 2.0 LSJ Engine Return-style fuel system for 2.0 LSJ
- Appearance How To: dim light deck lid smoked aftermarket lights
- Appearance How To : Chevy Skyline Tail Lights
- Appearance How To - Install and Aim NEW Projectors
- Interior Install Aftermarket Head Unit 06 LS(Lots O Pics)
- Appearance How to wire neons and LEDs
- 2.2 L61 Engine How to: 2.2L SAI / CAI easy fix!
- Drivetrain how to: install a new clutch on your 2.2 or 2.4 part one
- Interior How To: Install System on Stock Headunit!
- Interior how to swap clusters
- Appearance How to apply the cobaltSS.net window decals
- Interior HOW TO: remove bezels on steering wheel
- Interior How-to: Aftermarket seats and frames.
- Drivetrain Clutch Bleeding, Vacuum Method
- Interior how to remove center console [56k?]
- Interior how to: take apart your inner door handles
- 2.4 LE5 Engine How To: Beck’s 2.4L Supercharged Build Walkthrough
- Interior How to: Install an Infinity Basslink
- Other/Misc How to Launch With Stock Pirellis
- Detailing another "HOW TO" wash your car thread
- 2.4 LE5 Engine HOW TO: mount your coolant hose, important for 2.4 owners
- 2.0 LSJ Engine How To Install Big Bore Throttle Body For Cheap!
- Electrical How To: 'Correctly' tap fusebox
- Interior How To: Upgrade the rear sub
- Appearance How To: Install Smoked Tailights! Pics!
- Interior Making stock seats stiff like racing seats
- Interior Carbon Fiber Overlay How-to w/ pics
- Appearance Underglow kit install w/pics
- Appearance HOW TO: Remove the vinyl between the 2 side windows! (with pics)
- Interior So You Want To Remove Your Radio : A How-To Guide For Removing 05-07 Cobalt Radios
- Appearance How to get rid of the AVS logo, w/ pics (56k, heck no,GTFO!)
- All Engines Vaccum leak cheking how to
- Exhaust How-to: Megan Racing Catback Exhaust SS/SC
- Exhaust How To: GM Performance Parts Extrude Honed Exhaust Manifold Install
- Appearance How-To: Better color band/light output on projectors
- Wheels/Tires How To: Fix and polish your damaged wheel
- Appearance How To: Cap your Trunk lock for under a 3 bucks
- Appearance How-To: Replace a Burnt Out Halo
- 2.2 Suspension How-To: Replace Your Brake Pads
- Appearance How To: Custom Tint Your Tail Lights w/ Design(so their not illegal - at least in AB)
- Appearance how-to fog light on your SS bumper on your base Balt
- Appearance How To: Ultimate High Beams for Projectors
- 2.2 L61 Engine How To: Install CPP Front Poly Automatic Trans Mount
- All Engines another way to reset your oil life %
- Appearance Make a shorty antenna
- Appearance How-To: Paint your drums
- General Suspension k sport coilover install(56k get a beer)
- Appearance How-To: Paint Eyelids on Front Lights.
- 2.2 L61 Engine Intake Mod for 2.2L Cobalts with pictures!!
- Appearance How To: Change Fog Light Bulbs
- Interior Custom floor mat heel plate.
- Interior How To Remove Window Cranks!!!!!!
- Appearance How to: Change the color of the LED's on the Projectors
- Detailing HOW TO: fix a small scratch
- Drivetrain How To: Install CPP Rear Poly Trans Mount
- Appearance How-to: Paint your Bowtie
- Drivetrain How to: Hurst short throw shifter
- 2.0 LSJ Engine How To: change s/c oil
- 2.0 LSJ Engine HOW To - Flush after cooler and heat exchanger
- Appearance How to: Decals on brake calipers
- All Engines Make your own alcohol kit!
- General Suspension Bleeding the brakes
- Appearance Painting calipers with Duplicolor
- General Suspension Front Brake Job
- Other/Misc Jacking the car (Updated!)
- Appearance RK Sport Front Lip (detailed)
- Interior HOW TO: Vinyl Wrap Tim
- General Suspension How To: Koni Front Struts
- Interior How To: Ebay Armrest Installation
- Interior How to: Headliner Cover
- Exhaust How To Install An Aftermarket Downpipe
- Appearance Removing the Exterior Door Trim
- Drivetrain HowTo: 2.2l transmission mount inserts.
- All Engines How to: DIY alcohol injection
- All Engines DIY alcohol kit!
- 2.0 LSJ Engine How To Install Oil Pressure Gauge Into 2.0L LSJ
- Appearance How-To: Painted Headlights w/ CLEAR Corners
- Interior Rear Deck Makeover!
- 2.2 L61 Engine 2.4l/2.2l CAI install with PICS!!!!! (56K at your own risk)
- Interior Thread your stock ss/sc shifter/knob
- Detailing How-To: Clay Bar Your Car
- Interior How To: Fix sunroof bezel
- All Engines Fuel Filter Change How-To with pictures
- Interior another original retrofit: 3rd brake light relocation
- Appearance How-to make a Dual Cutout Rear Bumper
- Interior How-to:Door Panel Inserts
- General Suspension How to Install springs
- General Suspension How To: install DC sports strut bar
- All Engines How to install Turbo Tech Racing poly engine mount.
- 2.0 LSJ Engine How to port your blower
- Other/Misc How To: Not get scammed.
- Appearance How to: Retrofit True HID projectors in your cobalt
- Electrical Cruise Control LED how to
- 2.0 LSJ Engine How To: Dual Pass Endplate + Extra Coolant Resivor
- Interior (how-to) fiberglass...basic
- Drivetrain "How to" fill your motor/tranny mounts with polyurethane
- Interior How To Shorten Your B&M Shifter
- Appearance 1st Gen Projector Aiming
- Appearance How-To: Wire Up Halos For Projectors
- How-To: Remove Cobalt Front Bumper
- Exhaust how to install cat-back exhaust... lots off pics
- All Engines How to Oil change
- Electrical Spinner's LC1 Installation Guide with Pics! (no 56k)
- Detailing Polishing 101 (How-To)
- All Engines How-To install spark plugs
- Interior How TO: Gauge colors
- Electrical re-pin walm-mart wiring harness (05-06 only)
- Exhaust **HOW TO** Pacesetter Header (56K watch your step)
- Electrical How To Add Factory Power Windows and Factory Tweeters
- Appearance How To Swap Wings
- 2.0 LSJ Engine Howto remove and replace the drivebelt (EASY WAY)
- All Engines Howto Access Timing Case (Cam Install Also)
- Drivetrain How-To: Install B&M Shiftplus
- Drivetrain Howto Bleed the clutch way #2
- 2.0 LSJ Engine How to Guide Install GM Stage 2 Kit
- Interior How to install Heated Seat Kit
- Interior OEM Gas Pedal Modification! How_TO (Pics)
- Detailing Deatailing Your Car....
- Interior How to: Aftermarket Pedals
- All Engines how to install Pacesetter cat back with no cutting!!!!
