- Appearance How to Install LED lights into your reverse lights
- Appearance How to paint fuel rail cover and spark plug cover (56k=DEATH)
- Other/Misc How To: Make Your Car Whistle!
- Interior How to install Cling on tint!
- 2.0 LSJ Engine How To install Cobra Heat Exchanger! 56K=DEATH
- Interior Installing Rear Speakers and Removing Rear Deck
- Interior how to remove airbag decals
- Interior How-To Radio Button Color Change Now Online 56k Think Not
- Drivetrain How to Install Axles and CAB's (56k time to upgrade)
- Drivetrain How to: Changing F23 Transmission Fluid
- 2.4 LE5 Engine Making The GMPP Intake Functional
- 2.4 LE5 Engine Installing the GMPP Intake
- Drivetrain How to install B&M Shifter (56k beware)
- General Suspension Installing rear sway bar.
- 2.2 L61 Engine HOW-TO: Mod 2.2/2.4 AirBox
- Interior e-brake retrofit continued/done!
- Interior E brake Retrofit.... progress being made!
- Other/Misc HOW-TO: Mount a camera in your car.
- Appearance HOW TO: Install lower GM SS Grill on SS/SC
- Interior Pclears custom short throw shifter
- 2.2 L61 Engine How To: Install Injen CAI on 2.2 or 2.4L
- Other/Misc How To Post Pics
- Electrical Add-on courtesy lamps--solved!!! Not 56K friendly
- Appearance How-To: Headlight Fogging
- 2.0 LSJ Engine Co2 Sprayer The Back Yard Way
- Appearance How To: 3rd Brake Light LED Conversion!
- 2.2 L61 Engine HOW TO: CMD Intake
- Electrical How-To: Oil Pressure Install on 2006 Cobalt LS
- Electrical How-To: A/F Gauge Install on 2006 Cobalt LS & Supercharged
- Other/Misc This should be posted as the best how to
- Drivetrain Intense TransAxle Mount HoW-to (56k get a beer)
- Interior How To - Remove seabelt holder
- Drivetrain The impossible to bleed clutch...
- Interior How to: recover door inserts w/ new materials
- General Suspension rear spring install & bumpstop cut
- 2.0 LSJ Engine How to Install the ZZP Modular Pulley for your Cobalt SS/SC
- Wheels/Tires Tire Rotation How To
- Other/Misc How-to: Use of the SEARCH Button
- Detailing Car washing/waxing tips
- Interior auto shift light mod... another first, im on a role
- Interior HVAC mod...first one
- Interior Schroth Rallye 4 Harness install
- Interior Remove Back Seats (56 Mabye)
- 2.0 LSJ Engine How to install the "AEM intake" for your Cobalt SS/SC
- General Suspension Front strut and spring R&R
- Interior Diagram: Hardwire Radar Detector W/o Tools!
- 2.0 LSJ Engine How-To: Fuel Injectors
- All Engines Spark Plug Change How-To
- All Engines Oil Change How-To with picture!
- Electrical How to install an Interceptor.... :D
- All Engines how to remove and install valve cover
- Appearance How-to paint your factory 18's
- Interior removing automatic shift knob
- Interior How To: Paint your dash
- Appearance HOW TO: TINT YOUR LIGHTS in 10 steps
- Appearance How to Make a Custom Top Grill
- Interior How to fix the Sunroof Trim Ring
- 2.2 L61 Engine How To: Remove the Plastic Engine Cover!
- Appearance How to install RKsport kit
- Wheels/Tires How to: Painting your stock rims
- Appearance How To: Paint Yo Plastics (Pics)
- Interior Shifter Knob Removal & Factory Quality Replace w/Any Knob
- 2.0 LSJ Engine How to install the "INGALLS Engine Damper" for your Cobalt SS/SC
- Interior Remove rear head rests
- Appearance How to remove badges ( 56k = :( )
- Drivetrain How to Install Clutch/Flywheel
- Appearance How to attach a billet upper grille. TONS of pics 56k beware
- Interior SS/SC Shift Knob Removal
- Appearance How to make bumper plugs. 56k=bad
- Electrical MSD Digital Shift Light Install
- Appearance how to: paint ya ya ya grill
- Appearance How To: Paint YOur HeadLights (lots Of Pics) 56k (mabye)
- Appearance Paint Chip and Scratch Repair
- Interior How-To remove door panels
- 2.0 LSJ Engine Install pics mechanical boost gauge , to go with ExHondaMans write up
- Interior Those that have added autometer guages ....how I matched the bezel to our stock bezel
- Electrical How to hardwire a radar detector...
- Appearance How to install Projector Halos
- Exhaust How to Install the GMPP Exhaust. Video/sound clip lots of pics
- Other/Misc Trunk latch how to.
- Appearance DIY Rims
- 2.0 LSJ Engine Intense Kit Installed!!!! Lots of pics...
- Appearance How to: Paint your Calipers!! [56k BEWARE!!]
- Interior Steering wheel bowtie fix
- 2.0 LSJ Engine How To make your Fujita work !!!!!!
- Appearance Antenna Mod
- 2.0 LSJ Engine How to: Boost Bypass Mod
- Appearance Debadging the rear
- 2.0 LSJ Engine Injen intake installed (2.0 SS)
- All Engines Motor Mount Install Guide
- Appearance How to take off wing off a SS
- Read This Before Posting New How To Threads!!!!!!
- Appearance How to Make & Install Lower Grill
- Interior How to remove and install door speakers
- Other/Misc Tofu's 1/4 mile guide
- Appearance How to install CF trunk
- Interior How To - Custom A Pillar
- Electrical Utilize Factory Roof Mounted XM Antenna
- Electrical 12 volt power tap and grounding for accessories
- Interior Disassemble Dashboard - Radio and related panels
- 2.0 LSJ Engine SMS Throttle Body
- Appearance how to change fog lamp bulbs.
- Interior Installed Boost Gauge (Warning: Long Install Instructions)
- 2.2 L61 Engine 2.2 Ecotec cam install instructions
- Interior How To: Install LEDs In CupHolders (Tons of Pics 56K warning)
- Interior How to remove shift knob...(5 speed)
- Drivetrain TWM Short Shifter install
- Interior How to install GM Pedal Covers
- 2.0 LSJ Engine Pulley Swap Howto
- 2.0 LSJ Engine Airbox modification
- Interior How To Install An Armrset
