- Supercharged Build
- fully bolted....cam ???
- After Market Audio
- Selling a lot of stuff
- Turbo Question Concerning Exhaust
- quick hubcap question
- GHOSTS build thread
- 2.2L Injector Harness
- 2.2 plastic manifold strength...
- You Think It Will Work
- Engine cover, it off now but...
- Finally Supercharged
- mandrel bent exhaust?
- 2007 Cams Install ?
- SS/SC rods and JE pistons?
- 10 Months in waiting...
- will the SS/SC exauhst work on a 2.2?
- Replacement Bumper
- Ignition Control Module?!
- A/C delete yay or nay?
- Quaife LSD differential 2.2ecotec m86tans
- apexi piggy back tuner
- Bloody hell, what screw drive is this..
- will our 2.2 clutch hold stage 2?
- turbo Q
- catless downpipe for 2.2 auto?
- tranny
- Ready to throw in the towel...
- jet maf sensor is awsome
- Gear oil change for 5 speed manual 2.2l
- Supercharger belt issue
- stage I cams.. how wants a set??
- obx header install
- anybody have...
- supercharger question?
- zzp question
- Thinkin About Port N Polish
- i need a smart one for this one
- 2.2 Head Gasket kit/set
- Intake Question
- Internals
- tune question?
- how easy is it to put a sc on a 2.2 stock?
- Help ASAP
- Down Pipe Suggestion
- tsudo exhaust questions
- zzp shorty vs zzp mid length
- Supercharged or Turbocharged
- head gasket
- Engine Swap
- Roughs starts NEEEEEED HELP!!!!!
- Whats my best choice.
- Seafoam..
- 2.4 intake manifold swap, do i need a new intake?
- What do you guys think?
- Tsudo exhaust w/ new muffler?
- transmission issues.
- Need Sum Help Asap!!!!
- new instrument cluster
- Going SC this summer: How much $?
- Please vote your opinions.
- can i put...
- Exhaust question
- This isn't good, is it?
- Best exhaust to get
- sparkplug suggestions!
- Xiled Turbo build Q&A's
- 40k Miles, what did I miss?
- Head Gasket
- cams for l61
- 2.4 VVT Head
- 2006 Pontiac Pursuit 2.2L build going supercharged...
- tsudo n1 extreme
- Is the L61 considered a strong engine?
- iat
- random /TC & ABS lights
- l61 vs lap
- Glass pack
- what exactly....
- Gutting The Balt.
- Do Times Die With Age?
- Slight difference in DP
- Whats better?
- Need more help
- drove an SS/SC today
- Do the gm stage2 injectors fit or not?
- bolt on to get as fast as 2.4 ss
- Injen dry filter..?
- 2.2 Fully Bolt'd And Tuned Only
- wideband sensor??
- DP install questions (help needed)
- Help Needed Quick
- Ok Guys, Now Tell Me
- Wonder whats next
- Question About Fuel Maps.
- New And Improved
- Need some help.
- Wtf!!!!!
- Just wondering if possible....
- crazy swap
- fujita 2.2 intake
- GM Performance Intake
- Help
- anybody with the magnaflow cat back?
- Automatic 2.2 07 LT
- tune
- Major tranny problem?
- auto tran and supercharger will it work
- Fuse Box problems?!
- Cleaned throttle body
- anyone for stage 2 cams
- 2.2 ls upgrades
- water feed?return lines
- spark plugs
- Need help deciding what to do next for power
- Will Bwoody's Fit an auto?
- will the k&n sri...
- Available tunes?
- Who Has The Lightest Cobalt
- Installing a 2.0L supercharger on 2.2L
- 2.4 manifold swap from 2.2 to 2.0?
- Tsudo Header
- Newbie wants to add F/I
- 2.4L mani swap problem
- gmparts
- most hp numbers out of 2.2l
- warranty s/c....
- m62 question
- Block strength??
- Procharger or LSJ swap
- DownPipe Solution
- Stage 3 Cams
- Finally Installed Catback But..
- highest safe rev limit.
- need some serious OPINNIONS
- 400WHP ( A Real Dream ??!?)
- 09 2.2 has vTAK!
- anybody have the GM Touring Exhaust?
- procharger
- What oil is good for a 2.2L?
- turbo automatic
- Bfaulk goes TURBO, the wait is over!!!! Pics inside
- New exhaust
- Header Help
- Wtb Header
- Having an issue but can't pin point it :(
- Stock SS spring or Sportlines?
- procharger?
- 2.2 Turbo cooling trouble
- ****needing some idvce pretty pretty please****
- Header Gains
- Garrett Turbo
- car is running...REALLY needs tuning
- 2.2's with Pacesetter header.
- Exedy Stage 2 Cerametallic Clutch Kit
- Check Engine light connection?
- What exhaust to get?
- Aftermarket Air Filter
- pin out sticky
- 07 Cobalt Lt Vs. Mustang & Supra (Personal Exp)
- Fuel problem
- Video
- Going supercharged, what other parts am I missing and...
- Ingalls w/ K&N SRI?
- 2.2 head question
- Suggestions
- Turboed 2.2's look here please!
- LS vs SS question
- K&N Help...
- keeping fans running all the time?
- 4th cylinder misfire.
- WTF I Did All Day...Don't Get Hopes Up
- back from track again.
- Just ordered Forged Pistons/eagle rods!!
- need help finding corsa exhaust
- Injector harness wiring
- Ruff Idle?
- Installed 2.4 Manifold on my 2008
- 2.2L supercharged with 2.9 pulley
- Meth Injection question?
- *update*
- B&M shiftplus
- WTF!!!! IS that NOISE
- Steering Wheel
- Exhaust Install?
- Dynoing an Auto?! HOW!
- EBC Sport Brake Rotors..anygood??
- New harness bar on its way
- I'm rich!!!
- Wheel hop
- would this give me any gains
- LSJ>L61 throttle body pin out
- Hypothetically....
- stage 3 cams
- 2.2 Head Internals
- New HO intake for 2.2 guys
- Seafoamed the Balt 2day w/vid
- MRZ Big Bore Question
- Car just DIED yesterday
- Finally Got Them In
- lowering my car
- My S/C Setup
- Downpipe question
- which exhaust is most functional
- Top speed
- Few questions about my exhaust
- Whats The Purpose...
- Turbo cost?
- Engine Stutter When Idle?
- 2.4 Mani on 2008 L61???
- Interesting Find
- 2008 2.2l look for hp adder
- tune? help.
- 2008 LE5 manifold revisited.
- Help With Exhaust
- why is adding a to a thread so hard
- Ebay Intake
- lsj cams
- HELP! O2 Sensor!!!!!!
- Turbo Build.
- tire problem
- Found out what my problem is...
- strange i guess..
- O2 sensor question
- supercharger questions
- SS shifter
- Ut Oh is this bad
- Header startup
- Gut The Catylitic Converter
- Dual air intake
- Cattless
- Just another 2.2L going turbo thread!!!!!
- transmission cooler......???
- 2.2 to 2.4 Throttle body help !!!!!
- cooling Ideas
- 2009 Cobalt LS Header Suggestions
- STS feedback
- can I only use injen filters?
- Has Anybody Used Their Warranty On A LS/LT
- Flywheel Help
- 2.4 mani
- If You Had To Compare
- Alright....
- Black It Out
- Dp Help...
- Did some porting(pix)
- list needed.
- need help
- SS clutch in an LS
- What is a good DP/Header combo?
