- what should i upgrade after the intake and exhaust?
- Clutch Pedal Switch 2
- Intercooler
- just wanna get everyones opinion.
- Header question
- S/C part list
- Piston/Rod combo
- Buddy needs help. Where does cable go from Alternator?
- Difference between 2.4 intake manifolds
- header or cat
- Allgood Customs Supercharge Build
- turbo ls new build
- Fuel rail help
- Straight pipe
- 2.4 Mani swap DONE!!
- Horsepower list
- fIANL .4 MANI QUESTION BEFORE INSTALL!!!!
- e brake issue
- 2.4 mani/tb upgrade worth it??
- Whrrr
- Odered my 2.4 mani got a TB question though.
- Vid Req: Tsudo Exhaust with header and DP
- Questions about ZZP Header/DP
- transmission coolant line
- any idea what this is?
- Comp cams question
- confirm please
- confusion-07 2.4 install
- 2.4 Manifold shopping list!!!
- Speedometer Lag
- 2.4l manifold brake booster connect??
- Auto
- Full bolt on 0-60
- Options For a Dash Computer?
- ecotechincal's 2.2 sc build thread/ wtb?
- SAI delete & headers?
- most powerful n/a l61?
- Exhaust options
- LT to SS?
- zzp stg 2
- 3.0 and 2.5in open?
- e85 or meth?
- wideband install ?
- ported m62
- E85 thoughts
- How often do you seafoam?
- hhr turbo
- Need Help
- Weight to HP?
- Klutch's Turbo build
- 07ish Cobalt
- 2007 cobalt LT
- HP Tuners in Texas area/Central preffered????
- warped rotors?
- 05 build help
- Aem
- turbo charged
- CAI or Short-Ram?
- throwout bearing?
- 2.2 SC running a 2.5''
- Checklist of upgrades
- Silicon hoses
- Plastic seems to suck
- SAI killer of exhaust upgrades?
- Next step!
- 120k miles
- the supercharger is in
- High Miles, Low Power
- Cooling fan quit working
- Red's K04 Turbo Build
- All the gas options?!
- Gotta Start Somewhere
- CAI Intake question
- 2.4 Manifold Question!!!
- Removing headliner?
- Would I have problems with my downpipe if....
- Auto Trans
- Site taht has a 2.2 to 2.4 intake manifold kit??(That works)
- upgrading the 2.2
- About to do cams
- Engine Rebuild Parts
- + and - of a tune???
- Is there a cobalt with all black stock interior?
- buying after market racing seats?
- To supercharge or turbocharge?
- build question
- 07 SS cluster on 07 LS?
- Ported LSJ Header
- engine sputter
- Engine mounts
- Opinions on Motor Build
- LNF suspension on LS
- got the balt dynoed ;)
- O2 Sensor Question
- SAI delete on my 08 2.2
- IonNinja Build
- Few questions...
- Dealership Info
- hydrolocked cobalt
- SAI delete 2.2?
- so tell me im dumb stupid or retarded
- 2.2l ZZPerformance Built-on Supercharger Kit
- p0481 fan problem
- exhaust question
- bolt ons - what do you recommend
- got the car fixed
- 2.2 supercharge build?
- Ls4
- twincharge
- Lowering with new tires??
- **taerae86 goes supercharged!**
- Oil pressure low
- Tinny sound when cold.
- new brake shoes. problem
- Help
- ok sooooo dyno question
- Clunking Noise
- Timing Chain Tensioner
- 2.4 mani swap problem plz help
- 2.4 mani swap
- Few Tune Questions
- 07 g5 BIG PROBLEM
- 2.2L Cooling System Help!!
- spark plugs?
- Purge Valve
- Need advice on easy AC disabling
- ITB development a big possibility. Have some questions.
- running lean???
- sc'd 2.2 IAT2 wiring
- alteative to oem brake booster hose
- oil pressure sending unit
- has anyone...?
- cobalt rebulid fan issue
- Before and after Tune? im lost
- Finally bought HP Tuners
- F35 swap
- Internals
- i need a motor
- where can i get just this part???
- Help with a link
- Want new exhaust, no ricer exhaust...
- 2006 L61 2.2L surging 1500-2000rpm
- breather filter
- Lnf swap
- Help my 2.2 bogging down on me!!!!!!
- Injen CAI, question, help?
- building the motor!
- slugging
- Will this fit?
- New wheel question
- I was wondering
- my cobalt took a poop
- L61 block/Lsj Head...
- Tuning Questions
- Plz help me or correct me =)
- low oil pressure
- Supercharger Build!
- 08 2.2 stock downpipe with new header?
- 2.2 motor
- u
- is this a good deal/price?
- Lnf manifold
- Would a k@n typhoon seris fit?
- E-brake and knob
- transmission
- Smoke coming from exhaust
- Short Throw
- would this be a good set up?
- need some info, thanks
- need help ASAP B&M shift plus install
- Cobalt HEADERS Question
- Is it possible?
- clean engine bay
- Headers
- help with tranny converter size for automatic
- Are pedder springs/TC shock combo still the best deal?
- U0101 :~/
- ls turbo???
- Custom L61 intake manifold fabrication
- supercharged 2.2 CEL p2270
- 2.2Ecotec LS Question
- 05 2.2 Supercharged question
- Cold air intake question need answerd
- oil leaking
- Will a 2.0 header work on my 2.2??
- Bad motor or cat?
- Exhaust Combo Question
- Head Differences/Issues
- How to secondary air injection pump??
- TMC Help
- 4x114 Hub Conversion
- Question about cams for my 2.2
- l61 turbo ls cobalt vs twin turbo 350z
- aftermarket gauges
- 250hp or 250whp?
- Cisco2.2build
- 160 degree thermostat
- 07cobaltguy's Re-Re-Build Thread!!!
- oil pressure gauge 06 2.2
- Build
- Cleaned throttle body - high idle
- 2.2 supercharger part list
- SS motor and tranny swap or build internals
- So I need spark plug help
- Where to buy intake manifold for Supercharger?
- HELP!!!! Installing header and PURPLE LIQUID is now dripping from pipe under header!!
- 2.2 ecotec finally blew
- supercharger build question
- info
- Best way to build power without forced induction
- Murdy81's Build Thread
- OTTP header fitment?
- SC or TC
- Need diag. experts(vid inside)
- Effffff
- Ignition Coil pack
- Fart can gone
- emissions warranty
- Drumrush's build thread
- 2005 LS issue
- ZZP long tube header problem
- Rear Main Went Boom
- Spark plug seals
- H/E Help
- Supercharged auto
- stock ls injector?
- reflash over trifecta
- Mis fire
- all you 2.2 guys, check this out for parts
- info
- L61 S/C questions
- 2.2 and a Cruze Rs
- Tune....
- What exactly does this do?
- Engine and trany questions?
- Loud Rattle on startup
- Here's some theory
- Crankhelp
- Using an 04 cavalier engine to build for my 06 l61
- Intake gaskets? I don't understand.
- Built Head
- best intake?
- These are supposed to be like this right?
- turbo manifold question
- pully
- Brands
- info
