- AC Compressor
- Help! Loss if horsepower 2.4 NA
- supercharger kit 2.4
- Cranking engine by hand
- Cobalt SS NA bumper valence
- Idle RPM at 2500 after Supercharger swap
- Bolt pattern
- Opinion from the 2.4l sc guys
- 2.4 mild NA build
- LE5 Exhaust Gas Temperatures
- Tsudo exhaust
- Dyno numbers
- Alternator
- Boost Loss & Exhaust Sound Change
- supercharging help
- Stage 2/3 Kits for Naturally Aspirated
- Issues with wiring IAT2'S
- compression calculator?
- Header and DP Questions
- tranny problems.. need some help
- Cobalt 2006 N/A - SWAP TO BETTER ENGINE ????
- 02 sensor code
- SC build help!
- Downpipe
- Exhaust leak
- differences between 2.4ss and scss?
- Fuel System Problems
- Using the F35
- m62 stripped and repainted for swap
- question regarding belt length and pulley setup for 2.4 sc swap
- intake manifold
- 2008 Cobalt 2.4 RPM surges/Jerking
- high mileage turbo or SC
- 2007 2.4l
- 2.4 supercharged guys: few quick questions.
- BADMAB header warranty
- 2.4 N/A round track engine
- Please look!!! possibly buying ss
- Supercharging help...
- 02 sensor overheating
- TCC lockup?
- Ingalls Stiffy / 2.4
- Brembo Kit on 2.4?
- Broke college student wants to go faster!
- zzp header/downpipe advice
- 07 SS Sedan
- Exhaust Clips
- Cam sensor problems.
- LE5 head porting
- 2.4 Troublesome p0172 and Tc light/hard shifting
- hesitation under hard acceleration
- Chicky's "Girl-Powered" 2.4 S/C'd Adventures
- Supercharger kit to sell?
- ZZP 2.5 Exhaust Review
- Gasket Replacement Question!
- How to reach to 200~220 hp?
- Loudmouth 2 Cat back?
- Badmab + LSJ DOWNPIPE done!
- Depo headlights
- Best spark plugs for 2.4 Le5?
- 2.5 ZZP exhaust+Badmab header!
- 2.5 ZZP exhaust system YA!
- Header/Manifold gasket
- Anyone has this problem?
- Vacuum Leak? Hissing noise/front end Need help!!
- Want to put an exhaust system
- O2 sensor readings
- Odd rattling noise?
- Anybody runung Badmab+LSJ DP
- interchangeable radiators
- Stage 1 upgrade kit
- GM really, i hate you, i really do.
- back from dyno day at RSTECH
- What brakes to buy??
- interceptor and boost question
- LSJ throttle body swap, idle issues
- Replacing LE5 need help!
- 2 parter, Engine CAL, and Endlinks
- compression test results
- SC vs Bolt Ons
- Gas
- Hesitation Problems.
- new timing chain tensioner
- AEM Wideband
- turbo le5 breaking up around 6500 rpms
- Twin Charged LE5
- How many of you 2.4 guys are running MAF only?
- AEM CAI vs K&N SRI
- need help ASAP
- Help with codes.
- Need a tune.... anyone in indiana???
- Pistons for our 2.4s?
- Daily Driver Build?
- Why does my LE5 feel slow?
- 2009 turbo exhaust on 2007 NA cobalt
- Might buy a new M62, need some advice.
- Now that I'm SC'd, what's next?!
- Chaos Six SC Build!
- Advice
- GMPP cam vs ZZP (Comp) Cams
- Ranting on my own car.
- Exhaust Rasp
- To turbo or not to turbo...
- saab LK9 intake manifold as a upgrade?
- Powell F23 mounts with LNF rear??
- car wont start. with video
- Timken Wheel Bearing Part Number
- Traction Control Off???
- RPM problem
- Problem with Cooling fan
- Torque to yield/single use only LE5 IM bolts
- Radiator fan stopped working!...
- Stage kits.
- Stock Tune Needed
- Help with P0101-P0102
- radiator replacement
- OBX Mid length vs ZZP Mid length
- How to push more boost, and why.
- Support
- Why does my exhaust sound raspy???
- Maintenance 75,000 miles
- Motor Mount
- Couple quick pulls and testing GoPro mic
- TVS1320 automatic
- picking up a 2.4 auto, need some opinions
- Friends auto SS is faster than my GT?
- My experience installing zzp stage 3 turbo kit.
- 2.4 Dyno Tuner Needed Broward County
- Exhaust on a stock engine
- Best spark plugs to use ?
- What Dexron VI fluid to use?
- help with downpipe
- noorj's turbo "build"
- ZZP S252 Turbo 2.4 3 inch cat'd exhaust sound demo
- Sport Sedan
- "Heat Shield"
- 2.4 Backfire?
- le5 sleeves
- Dual exhaust?
- Please help. Need a good but simple Supercharger for G5
- after bolting up lsj throttlebody weird issue
- Exhaust options for the 2.4
- throttle body HELP!!!!
- 06 2.4 Auto limits?
- Max Rocker Ratio
- Photo Request: 2.4 Oil Cooler hose routing
- What HP has ecotec crankshaft failed at?
- What PSI have sleeves failed at?
- supercharger take off kit
- Beck's Latest Supercharged 2.4 Build
- Clutch problem?
- AEM CAI for my 2.4
- 200whp N/A automatic?
- Supercharging my 2.4,,, eventually
- Holy Miles
- 2.4 Idle Issues?
- zzp mid header and downpipe combo
- Clutch and Flywheel
- ZZP header primaries
- 2.4 cams !
- Cobalt is gone :(
- ZZP Preferred Exhaust Diameter?
- Would a LSJ injectors cover fit the 2.4???
- Rebuilding LE5 Turbo?
- Help! ZZP turbo kit guys, P0068, BOV, and MAF, Custom tune
- Coolant temps
- Future engine plans
- Help with P013f..
- Diagnosing AFR Issue
- Saab Intake Manifold
- 2.4L Year Interchangability
- Does the 2.4L have timing chain issues???
- ZZP header
- ZZP #33 Injectors
- Injectors question????
- Zero goes turbo
- Recommended computer programer for LE5?
- 2008 sport coupe LE5 50,000 miles $7,500 current bid on ebay!!!!
- exedy stage 2 clutch
- OBX Header and Downpipe
- Tach Signal
- Where to start.
- ZZP 2.5 cat-back
- Does badmab make a downpipe for the 2.4?
- What's next?! Looking for ideas!
- Why do these both sound so different?
- car running like crap
- rattle on car
- Engine Rattle on 2.4
- Plugs
- F23 transmission cold temps problem (fluid?)
- 06 block fit in 07??
- 2.25" magnaflow exhaust?
- stock injector replacement require a reflash?
- Downpipe header
- 2.4 SS auto transmission problems
- clutch bleeding problems, bad master cylinder?
- Exhaust pipeing length
- NACA duct?
- Timing chain looks off
- Anyone running forged internals at 9:1
- LeakyBalt Causing Issues?
- Problem shifting into first
- Badmab install
- Auto dimming rear view mirror
- New To Zex SafeShot
- 2006 4 door ss
- Cobalt mounts in 2.4 G5 GT
- 2.4L LE5 2008 SS Turbo
- How much faster IS a S/C'd 2.4 to stock?
- Exhaust Note
- My 2.4L Budget Turbo Build
- Pulley Down?
- Questions Before T-Charging
- Slave Cylinder Over extending
- My 2.4 Supercharger build and ZZP Cammed Head Swap.
- maf issue?
- M62 Supercharger Conversion
- Need answers! Plz help!
- Lol, One of THOSE threads
- Part number needed!
- new with specific questions
- Quick Question - Posting Pictures
- 2.4L intake manifold
- 3" Straight Thru Muffler?
- LSJ Throttle Body Swap
- Car dies randomly?
- GM stage 2 Hub and Belt Questions
- intrest thread for le5 sleeves
- About Time
- Does anyone have this 2.5" zzperformance exhaust?
- Traction Control Switch (E-Brake Mod)
- engine code p0014 camshaft sensor
- 4T45e Trans questions
- Compression value - please help
- run-on and now misfires
- Won't start! No crank!
- Need help with thermostat replacement
- zzp block
- Let the fun begin
- Water temp reading ---
- Engine Misfires hard Acceleration
- 2.4 L Supercharger Conversion
- Newfound
- Future race opinions? LOL
- Intake Fender Mod?
- 06 2.4 w/ 2.9 pulley?
- How To Replace Engine Coolant Sensor
- Sc swap for 2.4
- 2.4 turbo build (for the haters! )
