- ZZP off road pipe installed ss sedan 2.4 auto
- High miles + forced induction question
- Cold Air Intake vs Ram Air
- E37 support coming from HPT
- meth gains...
- so i ordered the zzp off road down pipe ditching the nitrous going blown
- just ordered boost reference fuel pressure system
- Does GM honed exhaust manifold fit an Auto 2.4L?
- Help!
- 2.4L Bearing
- Highest Rev limit on LE5
- TC and ESC problems!!!
- Downpipe For an Auto
- What clutches you boosted2.4 running?
- 2.4L General Questions
- Tsudo Exhaust question from a n00b
- Anyone (2.4l) looking for injectors..?
- feels like im fighting with the brake
- How much torque for valve cover bolts?
- 2.4l injectors
- exhaust cam swap
- eagle rods and weisco pistons
- 2.7 pulley... how much boost?
- ottp over the axle pipe ?
- I need advice for a header/dp ( comparison list with specific concerns)
- Smaller pulley now that im on meth!?
- Looking for Parts for 08 cobalt sport 2.4l
- Header/Downpipe
- X2 chip
- Which exhaust
- LE5 sleeves
- ported head
- What is the weight of stock rims?
- Benefits Of Light-Mod 2.4 With Tune
- ZZP 2.4L turbo video
- TVS supercharged LE5....opinions, and ideas...
- WOT box install HELP
- Philips Xenon HID's, Jet Performance Modules
- Intake question
- ZZP - What happened to the 2.2/2.4 s/c kit?
- 2.4 tuned before/after
- CAI Vs. SRI
- Sup
- New guy with a LE5!
- 2.4L zzp turbo issue
- dex 3 or dex 6?
- Deuce's Progress Thread
- C'mon...
- questions for boosting a 2.4L
- Suggestions to make my balt better??
- Looking to hit 300 hp
- cold air intakes
- Need to know 2.4 SS computer code
- 2.4 internal suggestions
- Help!
- Question for boosted 2.4 autos
- Replacing speed sensor help
- can i add paddle shifters to my auto cobalt?
- High RPM Loss of Power???(2.4)
- lookin to turbo
- spark plugs
- Code! (P0446)
- Level Zero
- What should i do?
- Novice Supercharging alone?
- Quickest m62 2.4?
- P0107 Troubles
- car has KR at the top of pulls
- possible bottlekneck
- I want to turbo
- Lsj throttle body with adapter plate
- Help on Actuator
- More e85 questions
- Cobalt SS 2006, what is a 1/4 MILE time for stock?
- size of 2.4's exhaust pipe
- Well, Christine's at the dealer...
- couple quick questions
- Help with clutch torque specs
- Make my balt Look Better?
- TSB on LE5 Injectors (Lean)
- 2.4L wants boost, and more. throw me ideas!
- need plug for m62 map sensor?
- Forced induction tuning
- glowshift narrowband
- 07 computer
- Is the 2.4 the black sheep of the engines?
- Head gasket differences? Cometic?
- This random box showed up at my house?
- ugh where are the spark plugs...
- SC 2.4 vs SS/TC
- wheres a vacuum line to seafoam?
- Engine power issue
- Two step launch control
- Rattling noise
- K&N airbox filter vs SRI/CAI
- Cant F'ing win!
- Going to Seafoam tomorrow
- Saab 9-3 Turbo Set-Up?
- question on rotors!!
- Guy's who have the ZZP 2.4 M62 kit.. Enter..
- Good basic mods for 2.4..
- Just checking..
- Grounding
- GMPP header cracked!?
- injen causing cel
- confused about octane for my cobalt
- Hahn Intake manifold install
- SC vs TC
- willl this only fit lsj's?
- Gmpp exhaust??
- E85
- I need help connecting A/F Ratio Gauge and Oil Pressue
- primary o2 sensor part number
- solid engine mount required for zzp downpipe?
- Best turbo/sc for an automatic?
- 2.4 manual tranny
- Question about ZZP turbo kit
- is anyone running nitrous?
- No Drill Oil Turbo System
- 2.4 Breaking Point
- What's the Best Motor Oil?
- if s/c'ed, mod the block?
- Few Quick Questions..
- 1/4 times for 2.4 and ?'s
- need help tunning.....
- Best Header for a 2.4L
- Headers questions
- got a question
- Help: Problem with rpm in neutral or idle
- My first win since my swap..
- TVS Sport
- Please help!!!!!
- 2.4 ZZP turbo kit
- oil cap
- Stickers and what nots...
- Fake the 2.5 bar map for LE5?
- question regarding headgasket
- exhaust help!
- Cruise Control
- Oil cap breather
- Help: Want to hit 200hp.
- Boost on LE5 how do you wire the map sensor? which map to use?
- Help: Grounding a 2.4?
- 2.4 zzp sc ?
- Oil Filters
- Service engine light on P0300, P1174
- lnf head on 2.4?
- over the axle piping
- opinions? video
- hahn racecraft garrett turbo system 2.4l
- Brake question
- ZZP Turbo Kit
- check engine light, advice please
- How much juice will it take
- Plastic thing
- New Results with 2.4 ss/sc
- experience with fireball muffler?
- 2.4l Exhaust Manifold
- manifold bolts
- noob thread?
- Anyone else pull CEL with Full Exhaust
- can it be done?
- Jet Chips..
- auto to manual?
- intake painting question
- So I just ripped the INTAKE resonator out and...
- Help me boost my 2.4L
- 2.4L cam specs
- turbo problems, blowing oil past turbo rings
- JBP Lightweight crank pulley
- 2.4l Throttle Body Question
- what else can i do to get more HP
- question
- hitting a wall
- Runnin rich and random misfires
- When I installed my k&n short ram...
- K&n or injen for intake
- Superchargers
- HPT in michigan!!!!
- Official 2.4L Performance Modification List
- Oil Drain Plug Location?
- help
- Meth set up
- muffler question?
- a/c compressor on tvs
- CEL, Went to the stealership...
- Supercharging question
- water temp gauge hookup?
- injectors
- What's the Best Exhaust for a Cobalt SC 2008?
- went to the track again
- Finding A Turbo Kit
- air intake
- Cobalt SS 2.4 0-60MPH
- Chips??
- Question about the Jet Performance MAF
- anyone with a 2.4???
- slower than another 2.4?
- Short Ram Intake for 2008 Chevy Cobalt 2.4L
- rs4 Performace chip
- lip kit
- What do you want with a supercharger?
- LE5 turbo guys, I NEED YOUR HELP with crankcase pressure issues!
- HELP...Quick question about trans mounts.
- ZZP Turbo on a 2.4?!? help :)
- SSfamilywagon's Resurrection/Build thread
- Has anyone bought the ZZP SC kit yet?
- !help!
- sri vs cai..
- Radiator problemm help!
- different intakes = different noise..??
- my 2.4s short story so far! (56k warning)
- trifecta tuned 2.4
- ideal afr for turbo 2.4?
- just installed exedy stg 2. anyone else got it?
- Engine lags when hot?
- Rotors
- Cobalt 2,4 Intake same like Saturn ION?
- Octane
- Will I feel the difference if I installed a K&N typhoon SR intake?
- 2.4 SC/TC numbers...
- silencer for stock tip?
- tsudo exhaust
- 2.4 Auto Dyno
- shes gone :(
- bolt on 2.4 dyno numbers
- Engine swap
- a good exhaust for an 06 2.4l ?
- turbo ~need ideas~
- 2.4 SC swap build...how much whp???
- ppl with zzp turbo setup
- 2.4 auto shift points
- crankcase ventilation help
- your opinions needed
- Need Clutch Help ASAP!
- has any 2.4 or any cobalt period have a flowmaster muffler???
- Weak 15-100 AUTO!! haha
- Guess what numbers i put out!
- Sorry guys
- 8psi dyno numbers
- 2.4L Tranny HELP!!!
- a header question
- exhaust stinks
- question about ordering tune
- jbd cam on 2.4
- Valvesprings and Boost
- Turbo a 2.4l or buying a new 2.0l cobalt ss turbo?
- 2.4 exhaust
- I NEED a 2.4l Stock exhuast or muffler
- please help me understand...
