- LE5 Rebuild/Upgrade
- Performance mods for circle track
- 2.4 LE5 TVS1320 build...in a miata
- LE5 Turbo Build
- LE5 Build
- 3 Port Controller Solenoid Pin Out for ECM HELP!!!
- Making le5 lnf
- Engine information
- Turboing with a Saab 14T
- 08 Sport Turbo questions
- Anyone have —>ZZP N/A bolt-on’s Tune?
- 2.4 LE5 Questions
- Does 50/50 water meth makes a difference?
- BEST. NANG. FOR. YOUR. BUCK. turbo build for the LE5?
- all out 2.4 build
- HELP: 2008 2.4 S Code issues after clutch replacement
- Supercharger Kit
- 08 2.4l Chevy Cobalt sport N/A, A/T
- LE5 injector length too short
- LE5 M62 Saturn Sky Build
- ZZP Goofy LE5 pistons or are they Crank Swap Pistons?
- Best source for new or reman 2.4?
- 2.4 LE5 overhaul time
- 2.4 problems
- E85 conversion parts list
- zzp 2.4 turbo kit
- 2.4L le5 tune
- 2.4 l auto ss sedan
- Quick mods while my engine is out?
- eBay turbo kit
- 06 cobalt 2.4 ss NA/mod SC eaton, I need to go faster?
- 2.4L LE5 Hesitation
- LE9 throttle problems
- Need help with and 06 cobalt 2.4 SUPERCHARGED idle high revolutions
- 2.4lt Rebuild?
- 2.4 Internals
- Connecting rod to piston orientation
- I need help 2007 lt swap with 2008 2.4
- Crank journal measurements
- C2 Ecm connector for 2008 cobalt sport
- Cobalt Lt swap with le5 HHRss motor
- Balance shaft chain tension check
- G5 GT turbo issues
- Gauging interests, LAP head in a LE5 block
- Steelmesh Rules 😲
- Optimal exhaust size
- Je pistions
- Bottom end rattle?
- LE5 to LDK?
- RPM performance tune Stage 2
- 2007 Cobalt SS 2.4L Turbo Build
- Mega Mad LE5 2.4 on the dyno
- Decision point
- Zzp turbo kit
- LE5 to turbo suspension springs
- Torque limits on LE5 gearbox
- Relearn throttle body
- Upgraded axles for F23?
- Performance Ecotec Collapsing Lash Adjusters - Solid vs. Hydraulic
- Saturn ION 2.4L in Cobalt SS 2.4L?
- LE5 to LSJ manifold threads and PCV port
- thicker 2.4 head gasket suppliers
- LE5 OEM head gasket thickness
- Can the LEA block be re-sleeved?
- 2.4L LE5 Internals HELP!!!!
- Help please. LSJ supercharger kit on 2.4L
- Best way to VVT delete?
- Zzp cams
- M62 to TVS 1320
- Snout machining tool
- Possibly Very Stupid Question (ECM, PCM, ICM)
- What a beautiful sight.
- Sodium filled LNF exhaust valves in LE5 head?
- RPD and HPT accuracy
- 06 supercharged build
- Valve Spring Compressor
- Swapping a Ldk into lsj or Saturn ion redline
- 06 pursuit gt sedan.. throttle body sticking?
- False knock problems
- Will 08 le5 work with lap ecu??
- Option b without stock hx?
- Dynomax super turbo
- Engine swap question
- LE5 all the same?
- LE5 Kappa
- Supercharged LE5 Questions
- Normal high mileage engine noises
- Guess what smashed this plug gap shut
- Savvy 4T45E tuners
- 2.2 & 2.4 Supercharged
- Random PE
- tuner in fl? other questions
- Is this the correct intake gasket?
- Manifold bolt size question
- Supercharger Swap on LE5 in Volkswagen Baja Buggy
- 2.4l ss sedan
- 2.4l
- Need some help with questions on an engine build
- 2.4L Supercharged pics?
- Cobalt Head gasket now idling and running hard.
- Bucking or Cutting Out or Both
- Head gasket replaced now have a p0315.
- ABS brake pipes
- Another Supercharged 2.4L LE5
- Chain noise from engine
- Broken fuel line
- JBP Triflow CamShafts
- [Build Thread- Twincharged LE5] Brand new engine has milky gunk inside
- Port and Polish Help and Tips
- pull a part 2.4 questions
- Side trunk lights
- 2.4L LE5 supercharged
- Directional Help K04? NA? Move On? 2.4L
- Lightweight flywheel for auto
- Piston Damage Opinion
- Exhaust manifold
- Anybody have an LE5 and K04? Need plumbing info
- Different Intake Manifolds for 2.4L?
- K&N Typhoon SRI
- Grinding in 3rd and 4th
- 2.4l LE5 supercharger 2272 MV jet boat build
- LE5 Tuning
- torque question
- EcotecFTW's 2.4 Supercharged build!
- Help Car shifting hard
- LE5 gen3 block info
- Idle Surge & Fan Issue!
- High idle after cleaning throttle body
- 2.4 ION Key Getting Stuck in Ignition
- Mystery Misfires 2.4l LE5 Supercharged
- Found some junk in the oil pan.
- Saab turboed ion build/question thread
- 2.2l ECM flashed with 2.4l factory settings
- Please help!
- Possible Radio swap on my 06 Ss 2.4
- 2.4 engine swap
- Quaife ATB LSD
- Battery Sparking, Crackling and Hot!
- eng pwr deduced/disabled
- 2007 2.0l SC Swap into a 2006 Ss 2.4l Sedan
- Exhaust Fitment Question
- Supercharge a 2.4l
- Slowbalt2000's s257 Stock Engine LE5 Build
- LE5 Forged Internals and Turbo Build
- Roxanne Gets Built
- 2.4 LE5 automatic tran Supercharge?
- Does this look complete? SC kit
- Piston/ Something Hitting Spark Plug???
- Coba Gets Built, Build Thread 2.4 s256
- ecm-bcm tuning
- Help asap!!! Please thx
- Clutch Help
- Clutch?
- Help with CEL codes
- 2007 2.4 sc results..???
- 2.2 2.4 engine swap
- sc question??
- Crank shaft position sensor
- turbo???
- Coolant Temp Sensor Problems
- Help
- To TC or SC...
- Please help!!
- 2.2 wire harness to 2.4
- 2.4L 4T45E Transmission Adaptive Pressure Shifting Corrupt?
- Transmission Fluid Leaking
- 2.2 to 2.4 interchange
- LE5 turbo setup
- 2.4 ecotec to 2.2 ecotec swap
- 2.4 w/oil cooler to 2.4 w/o oil cooler
- Belt position LSJ SC on a LE5
- Quick question on catback system
- 2.4L VVT supercharging
- Anybody have some more feedback on the Stage 2 256ET turbo?
- your average gains tuned n/a
- Using LCV 2.5L DI Gen3 Block as Swap for LE5 Gen2
- werid noise please help
- Whats a good turbo setup for the LE5? sorry newbie
- Needing new spark plugs
- 2.4l vin b need help
- injectors ???
- Spark Plugs for 2.4 SS
- Rattling Noise, timing chain?
- Engine Revs up when I Press the clutch in?
- P2A01 help
- Throttle Body wiring to LSJ
- Squeak under valve cover
- Cracked my Flex Pipe - Info on Fixing?
- electrical 2.4 problems
- Dynoed the cobalt today N/A
- Performance Questions
- m62 SC instal
- Manual Shifter Question
- Need Details for Engine swap
- Coolant temperature
- Sensor fails?
- HP Tuning
- Sputtering help!!
- LE5 turbo feeds and drains
- Code PO172 Help
- Downpipe help.
- Fuel Injector Replacement
- I need some help badly ASAP!
- nitrous or water/methanol
- old code
- Megan Exhaust?
- Idle hunting and Cruising AFR
- Cobalt SS 2.4l to 2.0l engine swap?
- When the 2.4 gets sluggish
- Chaos Six TURBO Build!
- Anyone with aftermarket slotted rotors?
- Quick question on engine removal
- 06-07 LE5 engine swap
- 2.4 Engine swap! :D
- if I wanted to go e85
- LE5 350Hp build requirements?
- How hard is it to pull just the motor from the cobalt sports?
- just got this s/c now what?
- How's your clutch?
- Who knows anyone that can s/c and tune??????
- Possible start malfunction?
- can anyone tell me what this is please?
- supecharging and building kit help?
- Oil cooler
- supercharged or turbo or just buy a new engine?
- Building 08 LE5 engine
- ermahgerd my supercharger parts are here
- couple questions regarding supercharger install
- zzp 2.5" catback installed
- anyone use them for regrinding cams
- misfire??
- Boosted 08 LE5s
- Supercharger swap Qs
- Le5 intake manifold map sensor
- Le5 Oil return
- Boosted LE5 1/4 Mile Record?
- Camshaft position center problems
- A/C engine rev problem and sound
- OEM shift lights question
- jbp cams question
- LE5 exhaust help
- supercharge pr turbocharge?
- cobalt 2.4 sc
- n/a intake manifold?
- Supercharging Solstice LE5
- 2.4L downpipe help
- Saab Turbo Kit
- afi tune anybody???
- Updated Timing Chain Tensioner
- 2.4 engine mods
