- ARK/GRIP Exhaust
- Exhaust leak
- Saab Valves for LSJ?
- Cobalt SS Vibrant 1637 StreetPower Exhaust
- General Maintenance after 100k
- boost problem?
- A few problems with the ss
- High rpm issues! Help!
- n2mb WOT box
- Devil own Satge 2 meth kit?
- help car not boosting past 1 psi
- Engine/Tranny mounts
- Stage 2 Supercharger Upgrade
- 14.5 with ZZP Stage 3
- Bad Mab Header Terrible Weld!
- CX Racing Heat Exchanger???
- Option B and IATs
- Quick Question.
- coca-cola in gas tank
- Zzp downpipe
- timing chain kit question
- supercharger oil?
- car shut off
- Silencer holes/Air leakage ports
- going tvs what pully do i need to order
- New car need some insite
- Brembo Kit for LSJ
- Wierd Ticking sound coming form pully
- Spraying Pre-TVS ???
- Pacesetter Header/ZZP Downpipe
- Exhaust
- 05 ss/sc 3.1 pulley stock injectors, safe?
- Oil Under Spark Plug
- engine power reduced!
- Oil leak from the front axle
- zzp lsj axle
- Tvs question.
- Hahn 3" Catback Question
- Springless rear main seal?
- Aeroforce Problems......help please
- Codes!!! Plus limp mode
- is there a catch can for the injen lsj intake??
- Question for water/meth users
- Chirping/Grinding Noise at Idle
- Lsj rpd unit?
- How does it work
- Car only runs with CPS unplugged. Why?
- Trying to keep up with my buddy!
- Lsj turbo swap
- anyone else experiance this?!?
- Hp tuner
- Zzp
- Map issues
- Need info
- Tax $ in,...click proceed to checkout?
- TVS Set-up Suggestions??
- zzp stage 3 w/ griffin stage 2 he
- 2.5 map vs. 3.0 map
- ls4 injen
- what oil brand do you use?
- zzp 3in exh no cat
- LSJ Clutch Advise
- Oil breather?
- phenolic spacer and zzp s/c spacer.
- wiring new boost gauge
- ottp dual pass
- BRAKE pads and ROTORS>
- Pistons Options for the LSJ..Gimme your opinions and reviews
- Fking Axles
- White smoke
- check gas cap
- Engine light on! P0171 and P2261
- Spark Plug Inquiry
- Check Engine Codes
- just noticed a slight problem
- My Ride let me know what you think ?
- help little box left of steering wheel
- Does my frame look bent?....
- Terrible day for the Cobalt
- Lightweight Rotors for Eaton Superchargers
- Snout Cooler
- Knock Sensor Location ???
- Clutch/Brake Fluid
- Crazy iat2's
- supercharger wear....
- What is this leak ?
- Timing Chain Tensioner reuse?
- Cleaning the blower
- New intake ideas?
- LSJ issues and need some tissues.
- JBP header?
- just picked up my balt today! proud new owner
- Stage 2 setup
- mass airflow help please
- 2 issues (clutch and throttle)
- stock boost?
- Tell me what yout think about this setup.
- e85 m62
- My wishlist build
- remflex gasket?
- Exhaust system
- agency powered cat-back
- 07 ss cam chain tensioner/noise
- tvs 85 or meth
- Limp Mode
- Siemens 50lbs Fuel Injectors on Harrop TVS ?
- lsj build complete
- Can't keep this car running.... Can't keep fuel pressure/Randomly won't start
- OBDII Not working
- Brake fluid problem
- ls4 spacer plate?
- interceptor questions
- Not runnin so good..
- p0172
- Do I have a Bad Mab Header??
- ZZP S3 only - bleed?
- Cooling mod questions
- Spent $200, gained 20 hp.
- Advice on what to do. Please help.
- Recommend me a porting person
- Whats your LTFT and O21B1...Post em up
- recent belt squeak...
- 06 SS/SC boost problem at WOT
- Spark Plugs
- Max boost with no tune
- Finally doing a stage kit. Have some ?'s for you guys.
- upgrade trottle body
- pulling timing
- Installing Axles
- Max gearing speed?
- stainless works muffler vs wot shift=fail
- Ethanol injection?
- ZZP stage 2 with GM tune?
- Burning Oil smell after DP install
- Exhaust Opinions
- Lash adjusters
- GM stage 3 question
- why's my car getting bad MPG
- Stock resonator length...
- help with codes
- Axles and more...
- transmission issues?
- Why are my brake rotors warping so quickly?
- need to vent crank case pressure !!
- possible exhaust leak?
- int vs. exh cam profiles
- Cold Start Tap video
- ZZP Intake
- p-0171 and 1101 lean codes??
- Oil in intake manifold and PO171
- Part number
- My turbo LSJ dyno
- zzp H/E
- Too much heat!! Iat2s and coolant temps
- resonator size
- intercooler pump question
- Exhaust Vendor Help
- pulley size, with full bolt on's/meth
- so...
- LSJ ECU/PCM and wiring harness year compatibility
- HELP!!! limp mode
- surgery on tsuno muffler help!
- Finally!!! idle prob.
- gm stage 3 nitrous control
- Help!!!! Throttle body
- LSJ Tensioner Shock
- ZZP clutch
- Part Number Help
- spark plugs for cobalt ss/sc
- Review of: Revised Shifter Bracket for LSJ
- Tvs 1900 lsj build
- Baby Kittens in Intake Manifold
- lsj balance shafts
- zzp engine (with pics)
- e85 specialists please chime in
- turbo LSJ help please
- Header Question Help Please
- Little Advise On Mods
- Need help with muffler decision
- Badmab or zzp mid combo?
- Car just randomly started running like crap
- Traction Control and ESC on LSJ
- What would happen...?
- Got a Problem
- Why am I running richer?
- OTTP or Over Kill Engineering Motorsports Spherical Control Arm Bushings
- 2006 SS/SC LSJ TVS Build - Questions
- Trans mounts
- Stage 2 questions (couldn't find in other posts)
- ls4 throttle body
- LNF Turbo to LSJ?
- Camshaft position sensor housing - knocking
- LSJ Fuel Pump Part #
- 2.4 Malibu LSJ swap
- Machine gun fire at WOT
- question about the lsj
- Feint Sound
- Max Boost
- Help Hydrolock?!?
- diamond pistons
- mufffler pop and gas gauge messed up
- Arm rest?
- LSJ Running to Lean to be Driven
- spark plugs
- ZZP Dual Gauge Pod Pillar
- Cobalt SS blew engine, what now??
- Causes of random cylinder misfire
- (MD) Passing emissions without cat
- Guess my numbers
- ls4 tb and cat delete dyno results.
- piece fell in manifold
- Why am I less then GMS2?
- Where to get items chromed?
- ZZP Turbo Adapter plate and charge pipes question
- questions aout zzp 3" cai
- Dip stick issue with phelonic spacer
- Exhaust help!!!
- header leak?!?
- 06 Cobalt SS Clutch Problem
- Idle Issues ... HELP!
- belt tensioner pulley bolt ss/sc
- meth sprays but light does not come on.
- need opinions on pricing of used parts.
- updating. your interceptor?
- need some help
- Big build
- ZZP S3 finished.....idle probs no power HELP
- M62 rebuild kit
- 02 Bung Question
- valve springs
- OTTP HE Extra Bung ??
- My cobalt (LSJ)
- Glowshift
- AIS stage 1 meth kit install, boost port fitting.
- Need tensioner pulley bolt......
- LSJ on E85 Questions BRAND NEW MOTOR
- Fuel Pressure gauge question
- how do i install my heat exchanger?
- i know I'm probably gonna get a lot of shit for this but......
- Gas smell
- cry02 intercooler sprayer
- Need a tuner
- NEW AND IMPROVED my damn noise is still there thread......
- What to look for when buying an LSJ
- Did a clutch swap over the holidays
- car's running weird.. again
- help please!!05 cobalt ss
- shift bracker removal
- car help
- crankshaft relearn Q
