PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. question about wot afr
  2. Dual Pass plumbing help
  3. Lsj cooling mod
  4. harrop tvs s/c with stage 3. possible??
  5. Wiring situation
  6. reverse lights not working!!!
  7. Upgrading to the 2.9
  8. metal grinding sound
  9. LSJ Limitations
  10. zzp pcm tweak tune for meth, with AIS trunk mount
  11. dead battery
  12. 2,000 dollars later...
  13. supercharger snout question
  14. Exhaust help
  15. Need clutch ideas..
  16. AIT2's
  17. break in
  18. finally ordered my parts!!!
  19. Car running rich/P0172 help!!
  20. wingless?
  21. 3" downpipe to 2.5" catback
  22. Stage Kit Questions
  23. dipstick keeps popping out.
  24. Cyl #4 Dead
  25. CEL Aem short intake Tune??
  26. I need a quick source for a steering wheel coil/clock thing?
  27. piecing together a stage kit
  28. Gauges
  29. Time to rebuild
  30. LSJ tear down
  31. will zzp's heat exchanger help me?
  32. new parts
  33. instrument cluster back lights out
  34. Anyone like a challenge?
  35. zzp stage one cams
  36. Clunking problem solved.
  37. P0068 problem
  38. Stained recaros?
  39. erratic idle, car died, now it runs fine
  40. Anyone know where to find an experienced LSJ tuner shop in the Midwest?
  41. bad mab header install
  42. Help.....cel p0502
  43. Need ideas on mods.
  44. E available in my area! convert time?
  45. winter build
  46. LSJ w/LNF parts
  47. Wideband sensor placement
  48. My custom 3" CAI (composite, not aluminum) with video!
  49. System Too Rich
  50. Spark plug gap
  51. putting together a stage 3
  52. Tbandit's Build Thread!!!!!!
  53. SS (super short) ram intake for your SS
  54. Pulley puller
  55. H/E Question
  56. Cel p0128??
  57. Really shafted
  58. A Christmas wish
  59. Heavy steering
  60. i just need help getting it running, maybe some advice too
  61. Time attack cobalt Motor
  62. What Would Cause This??
  63. devils own meth
  64. Stupid question about a noisey s/c coupler
  65. ZZP Stage 3 Axle ABS Light Turn Off Option
  66. 5W-40? Liqui Moly
  67. ZZP Built F35 Transmission
  68. Tune??
  69. H E L P !! Water on Filter??
  70. All TVS owners!
  71. Few Pics Of My Cobalt
  72. what are you stage 2 lsj's dynoing/tracking?
  73. New to the seen have some questions
  74. Clutch/Power-Steering problem
  75. Rough Cold Start
  76. engine finally gave
  77. Cant Decide on an exhaust
  78. Please help, engine noise. Not a tensioner...
  79. Limp mode?
  80. New clutch suggestions
  81. cooling mods
  82. P0365 and P1184
  83. IC question?
  84. 07 ss s/c build
  85. New M62 Build Questions
  86. clutch slip, belt slip, or something else?
  87. ChevyCobaltSS3 Review/My Current Setup
  88. ice possible??
  89. new clutch engages early
  90. LSJ turbo Adapter plate questions??
  91. LSJ Rebuild Questions
  92. installing a clutch need help with components
  93. Cobalt SS Lucas 42lbs Fuel Injector Good or Bad ?
  94. ZZP Stage Kits Fuel Injectors
  95. LSJ vacuum hose connector
  96. Steering recall on our cars?
  97. gm stage 2 tune
  98. Slp loud mouth exhaust
  99. Injectors ?
  100. GMR Cams
  101. Changed bpv, still boosting 3 psi
  102. starter going bad?
  103. I feel stupid.....
  104. cheapest, best dp that sounds close to stock?
  105. stock tune
  106. Hopefully a simple LSJ/LNF T-Chain Tensioner question...Please?
  107. What mods shall I do now?
  108. Wheel-Hop Kit 19211782
  109. just joined the stage 2 club! might need tuner near chicago
  110. could use some help picking an exhaust
  111. Good Bye 42# Injectors, Hello 60# Injectors
  112. Help?!
  113. Longtube Header Installed Today, "Review" :)
  114. TVS Pulley Question
  115. whp guestimate?
  116. est. 1/4 mile, what other mods do i need???
  117. bypass valve
  118. I need a 2007 SS Cobalt Manual
  119. Mods going on tuesday
  120. Injectors...
  121. A/C delete kit?
  122. Exhaust Suggestions! Help!
  123. bad vibrations with ottp stg 2 mounts? solution!
  124. Stock Header VS GM performance Header
  125. So what will fit???
  126. Still on your factory clutch? Come on in.
  127. How Often you change your plugs On LsJ
  128. where to tune in deep south texas
  129. brought the gm performance header to be installed
  130. where to get good rotors... cross drilled?
  131. block alternative for the LSJ?
  132. Help me decide ZZP mods
  133. Rainy day Problem
  134. Aem ugeo or Innovative wideband?
  135. 3" Downpipe on stock exhaust?
  136. Car not boosting over 12lbs
  137. ZZP Stage 3 Injector Question
  138. OTTP stage 2 kit
  139. Badmab header, quality or not?
  140. Bent exhaust system. Any pipes will do?
  141. Yet Another P0315 Problem/Suggestion?
  142. zzp stage 2 sc cams questions
  143. Oil on the spark plug..
  144. Tuning
  145. overheating..stuck..help!
  146. Part Number for this?
  147. Cams Options?
  148. How much coolant after putting in IC pump?
  149. Okay so, this is probably a repost, but...
  150. What you take??
  151. Striped coolent bolt.
  152. compression vs pulley?
  153. What tires to get
  154. porting the intake mani?
  155. tune ?
  156. Engine Start problems
  157. who does 2.5
  158. Anyone ever race a Jeep SRT-8?
  159. No more cobalt.
  160. What are you running for PE (Stage 2)
  161. Ported Head and WOT Box Questions
  162. exhaust setup
  163. Maximum Oil Pressure
  164. Cruise Control Top Speed
  165. new problem! yayyy!....
  166. 2007 lsj with TVS
  167. Power Stop Brake Pad
  168. My amazing dyno numbers!!! Not!
  169. Trans fluid?
  170. Headwork Help
  171. My Upgraded Clutch Install
  172. Anyone using this??
  173. Intake manifold / Cylinder Head Question
  174. Single pass vs Dual pass
  175. Laminova core removal
  176. oil pressure port
  177. mp 62 blower
  178. blower dimentions
  179. spoiler?
  180. beating on ur car vs. longevity v1.0
  181. 3in downpipe vs 2.5in downpipe
  182. lsjs - does anyones power feel.. not so linear?
  183. What happens if you NLS a LSJ?
  184. Tsudo N-1 Cat back
  185. Drainplug
  186. Noisey belt tensioner
  187. Header and DP
  188. Bigger pulley??
  189. how bad (ottpstg2)
  190. Clutch assistrance for the n00b??
  191. Royal Purple?
  192. Jpb header ?
  193. Name of Go Kart car with 2.0 LSJ motor
  194. What to tap into to read boost..
  195. Red Recaro's
  196. Few Problems with my Cobalt
  197. CED Big Brake Kit
  198. for those thwould like to put a eco in a rwd
  199. gmpp/lnf clutch tob question
  200. clutch shudder when cold
  201. Best Mod Iv Done So Far!
  202. P0171
  203. tylerjclance's build thread
  204. TVS 1320 Ported vs Non-Ported (DYNO)
  205. Where to get a New Motor
  206. engine build, need opinions/input
  207. fuel mileage-dont know what to do!!!!!!!
  208. bates sleeved blocks
  209. Eco revised tensioner
  210. pwer locks wont work after snow.
  211. Some Help To a Hopeful New Owner??
  212. cavalier fuel rail
  213. I need help ASAP. .!Starter!.
  214. Downpipe??
  215. help with piston selection
  216. Fluid question.
  217. wideband install?
  218. Gas Mileage sucks..!
  219. Shaking in 1st an 2nd
  220. Calling all vendors and opinions of members
  221. Throw out bearing problem I think
  222. LSJ tuning
  223. HELP!!! "Engine Disabled" on DIC
  224. Car making a popping noise
  225. LSJ: Lost power, won't run, no codes, Cannot pinpoint cause
  226. new forged pistons in the mail
  227. Mahle Forged pistons
  228. hp tuners scanner
  229. Another Interceptor post
  230. Undersize Pulley/Belt Question
  231. 07 lsj tuning
  232. Longtube VS Shortys
  233. intercooler pump fixed
  234. problem with new header. can anyone help?
  235. Interceptor question
  236. HP Tuners Special 4th quarter offer
  237. 9's what!
  238. Intermediate shaft bearing
  239. leaking coolant
  240. part number for chain guide hardware
  241. cx racing heat exchanger
  242. Fail at the track today
  243. Pop sound when downshifting/help with muffler
  244. Bad downpipe lead to a bad idle?
  245. help cel flashing!!!!
  246. LSJ Turbo dyno SMG Tuned
  247. quick question
  248. bleeding air from stock cooling system
  249. New looking for a little help.
  250. Different motors
