PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. A must have for EVERY LSJ
  2. Just Installed Custom Meth Kit PICS
  3. need ur opinions
  4. Header for 2.0 SS/SC
  5. Idling problems
  6. 2 degree colder spark plug thread
  7. Overheating issue
  8. brfps...problems
  9. Gm performance clutch limits
  10. Just installed header and catless downpipe
  11. I iz newbee
  12. Quick Wideband question
  13. LNF engine and trans mounts
  14. Changing My Clutch. Any Tricks To It?
  15. is there any problem with running non-synthetic oil in an lsj?
  16. Pulleys
  17. Stage 2 questions
  18. Question on ZZP Stage three.
  19. 2.8 to 2.5
  20. Check Gas Cap..Replaced...now what
  21. 2.7 on pump, meth needed?
  22. p203
  23. OTTP! Help me
  24. Help with map
  25. shifter issue??
  26. Cars acting weird?
  27. ZZP Stage 3 Heat Exchanger
  28. Supercharger Coolant over 200+ degrees
  29. Anyone running zzp DP with stock exhaust?
  30. want to make more power but not sure how
  31. Is stock horsepower really only 205?
  32. Mod Opinions
  33. Intercooler system dexcool levels(pics)
  34. Need a quick comparison to another SS S/C
  35. Need To Replace Part, Not Sure Of Exact Name (Pic Included)
  36. Option B install
  37. WANTED: 60's
  38. Question on ss/sc
  39. Boost only at 4 PSI max. Codes also. Need help please!
  40. Metal washers - laminovas
  41. names of engines
  42. what engine is the best for a 2006 cobalt ss message me with info fast
  43. lsj 3 bar? HELP!!!
  44. Boosting below 5psi (SC bad?)..
  45. ZZP LSJ belts
  46. short ram/cold air
  47. ZZP 3" catback, how loud is it?
  48. Smg twincharged rebuild project
  49. Cams and springs vs P&P
  50. Reduced Engine Power..Please help!
  51. quick question
  52. 3 bar map
  53. Anyone have a 2.7 That will fit a GM Hub for Sale?
  54. I love wi!
  55. Want to go to a 2.7
  56. Help! Running lean!
  57. Blew a hole in the flex pipe
  58. Aem cold air ?
  59. Which set up to go with?
  60. Lsj Longblock
  61. replaced piston, sounds like subaru :/
  62. tvs installed do i need fule pump
  63. 2.5 map?
  64. need help halfway threw turbo kit
  65. 2.4 manifold on a 2.0?
  66. bad mab/zzp downpipe problem
  67. How Hard is it to Convert to E 85?
  68. yellow foglight went out on my cobalt ss
  69. stage 3 and AC
  70. IAT1 Reading high
  71. LSD distinguishing?
  72. Road Magnet
  73. Intake Manifold Model/Cut-away
  74. Random misfire and misfire in cylinder 3
  75. Rust on intake valves?
  76. i need a tuner (LSJ)in the south florida area
  77. Whats the noise?
  78. Dyno numbers inside!
  79. Adjustable cam gears
  80. Guess my Dyno numbers!
  81. horror story
  82. What's wrong with my ltft's?
  83. help me decide
  84. Catless DP installed, but no CEL.
  85. T3 T04e vs. hahn super 16g
  86. Installing the phenolic spacer and upcoming review...
  87. Official Turbo LSJ thread!!!
  88. PCM Question
  89. Can't get belt back on!
  90. reviews on pacesetter catback
  91. how much whp?
  92. Boost ?
  93. Supercharger Coupler
  94. anyone got a exuast for sale?
  95. has anybody been tuned at westbend dyno and tuning?
  96. pulley swap ?'s/problem!
  97. when do you need to tune?
  98. Need Exhaust Help
  99. emissions on a turbo swap
  100. Option B 3/4" Hose
  101. Idle problem, plus two CEL's. Help Please!
  102. Help
  103. zzp stage 3
  104. what next??
  105. My Plans! Advice? Suggestions?
  106. Meth Hook up, Help!
  107. 15 afr?
  108. zzp downpipe
  109. Car not Boosting past 4-5psi
  110. 2.7" pulley and spark blow outs with a gap of 0.32 ???
  111. 2 questions
  112. Leaky header/dp !!!
  113. alternator pigtail?
  114. down pipe
  115. Epic Confused.
  116. Timing Chain/Timing Belt (Whatever they have)
  117. IAT2 PID for Androids Torque app?
  118. Belts And Hub Info
  119. LSJ with LNF axle back muffler - Sound Clip
  120. zzp header codes?
  121. ZZP exhaust sleeve
  122. is any nitrous safe with a 2.6 pully
  123. gm bolts tool
  124. Stage Kit Help
  125. Turbo LSJ Issue
  126. TVS tune
  127. which belt is best for me?
  128. 2.9" Gm pulley swap
  129. Bad compression
  130. Clutch job! Do I have it all? Tips and tricks?
  131. Blower spacer plate.
  132. clutch help
  133. Ported supercharger casing
  134. Potential timing chain problem
  135. Possibly Head Gasket Time *HELP*
  136. Poor gas milage
  137. Still having issues with the Balt. Help is needed.
  138. Bad Mad header PSI drop...
  139. stage 3?
  140. Ticking Under Load
  141. Oil Temp Bung
  142. Diamond Forged Pistons
  143. engine power reduced
  144. Torque Pattern for LSJ Valve Cover
  145. CEL's from intake
  146. I'm blown away by the performance of this nearly stock SS/SC. Need explanations!
  147. ZZP CAI Fitment Question
  148. Looking to go with meth
  149. Intercooler pump replaced and still not working
  150. ZZP Exhaust options.. NOW!
  151. tune on 80lbs injectors
  152. Rebuild kit dose it exist?
  153. Do i need a new gasket?
  154. Running rich question
  155. port and polished head cam install
  156. dynomax super turbo blown
  157. Anyone with zzp lk9 IM
  158. quick belt question?
  159. gmpp performance exhaust.
  160. how can i? intake question
  161. qtp cutout
  162. Exhaust is quiet now and supercharger can be heard!
  163. turbo greater than lysholm thread
  164. Decisions decisions
  165. Stage three wear and tear?
  166. Stage 2 kit Questions
  167. ZZP phenolic IM spacer
  168. Cleaned TB today Awesome!!!
  169. Help!!!
  170. getting a brand new engine!
  171. engine feels hesitant while cruising?
  172. exhaust question
  173. HELP! timing chain jumping links
  174. Turbo Swap
  175. turbo swap
  176. Modifications help!
  177. tsudo exhaust..need insight
  178. TVS boost?
  179. My car has a stage 2?
  180. Weird electrical issues
  181. Napa axles thread
  182. Do I need a tune with bad mab header?
  183. Cat or No Cat?
  184. Liquid Cooled Supercharger from KB
  185. flex pipe question
  186. Cruse Knock?
  187. 05 car issues..Need help.
  188. spraying meth with wotbox
  189. Need some help
  190. Engine power reduced
  191. What is the psi scale for smaller pullies on the TVS??
  192. zzp heat exchanger with dual pass and opt b hose routing
  193. ebay intake vs rebel intake
  194. HELP! info on diamond pistons and rings
  195. rattling noise at idle
  196. Since the dealer sucks....
  197. Was this anybodies?
  198. Does this look right? (Timing chain Tensioner bolt)
  199. ZZP stage 3 HE install question
  200. Another group buy on Bad Mab Headers
  201. zzp tune
  202. Eaton Vs. Harrop
  203. Anyone in Toronto that could tune me? Trifecta?
  204. ss/sc vacuum diagram
  205. Rattling sound from back of motor help
  206. low boost.. no whine??
  207. Interceptor install
  208. Wtb: stock lsj parts
  209. run meth stock/no tune possible?
  210. Plastic injector "guides" & inj. swap
  211. Lysholm 1.6 Twinscrew - En route to power!
  212. Turbo Removal
  213. Getting to 300 HP the right way...
  214. fuel pump module
  215. I need a new wiring harness..I think (aka help)
  216. Bosch XL3V-A9A Injectors
  217. Performance chip
  218. boost problems with a 2.8, need help.
  219. Rear bumper inserts???
  220. supercharger running hot!!!!
  221. can u just pulley swap (no tune) ?
  222. Couple questions about I/C pumps and tunes
  223. Hp tuner or Trifecta on S/C
  224. Part Number Please
  225. ZZP midlength Header and DP install.. how to?
  226. tvs
  227. 02 sensor question
  228. downpipe leak!!
  229. ported eaton
  230. Qustion regarding install on Wideband
  231. Need Some Ideas!
  232. bad-mab trouble
  233. this is no good :(
  234. Dual Pass Endplate O-Ring Part# Needed
  235. need help where do i plug it in ???
  236. Choosing a new catback...opinions?
  237. Turbo questions
  238. TVS question on stock motor..help!!
  239. Half tank or less! FML
  240. Vaccum
  241. can i?
  242. dynomax muffler.
  243. Exhaust leak affecting AFR/ Wideband?
  244. 05 turbo swap
  245. Need advice from the OG's
  246. noob flex pipe help!
  247. steering wheel swap
  248. another Knock question
  249. loss of boost, please help
  250. boost gauge quit working
