PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. AMMFAB race ported lsj head (n/a application)
  2. Pistonssss
  3. M62 oil bolt replacement
  4. LSJ Build Book
  5. How Restrictive Is The Stock Muffler?
  6. which header and dp combo?
  7. Since I am running so rich with the OTTP Stage 2 tune...can I?
  8. coolant mixture question help
  9. Suspension problem!!
  10. New to lsj
  11. Fuel pressure 2.0 supercharged
  12. interceptor
  13. whats couls be next?
  14. pacesetter?
  15. would it benfit me?
  16. Aftercooler/Innter cooler
  17. gauge
  18. HELP clutch will not engage!!!!
  19. should i switch to 2.8 pulley
  20. badmab header
  21. oil?
  22. LC-1 question
  23. 2 broke pistons
  24. stock dp hurt?
  25. Another one of them dang pulley questions!
  26. what kinda power am i making???
  27. polyurthane or zzp?
  28. good clutch???
  29. Hot Side and Cold Side Charge Piping
  30. Anyone know anything about this car?
  31. LSJ Oil Filter Problem
  32. Which Down Pipe?
  33. Cheap cooling mods?
  34. Custom Megan Catback
  35. no intercooler advice?????
  36. Front End Squeaking Sounds
  37. ZZP or OTTP trans mounts
  38. Busted Radiator Help!
  39. How do I know if my car is stock?
  40. Interceptor install help?
  41. check engine light help
  42. GM LSJ Clutch Upgrade Installed. Why is my new clutch not bleeding??? Help.
  43. piecing together a kit
  44. thermostat
  45. zzp axles
  46. heat exchanger and exhaust question
  47. Bent heat exchanger
  48. Zzp pcm
  49. gm s2 clutch
  50. engine temp
  51. meth re location
  52. WTF problem?
  53. p0171 code issues
  54. question/
  55. no a.c
  56. made up my mind
  57. Downpipe to rear-section exhaust problem.
  58. Muffler packing around silencer?
  59. Looking for an Exhaust
  60. 2.6 Boost?
  61. ottp?
  62. TB Engine power reduced Dilema & Advice please
  63. how do install a Mechanical oil gauge??
  64. 60lbs of santas lovee
  65. gm stage 2 + stock
  66. my buddies ss
  67. Some stupid help
  68. Header and ehxaust?
  69. Interceptor installed
  70. rpd
  71. supercharged or not
  72. too rich
  73. Dual Pass STU
  74. Help! My ecu is locked
  75. What would you do with $500
  76. 2 questions
  77. clunk still there
  78. Engine temp very low.
  79. good iat?
  80. Got the wrong interceptors
  81. fuel milage
  82. physical differnce between GM exhaust
  83. autometer cobalt mechanical boost gauge
  84. header/ dp conversion
  85. Heat Exchanger Question
  86. When do you change your oil?
  87. blown engine
  88. few questions
  89. Help asap
  90. ball joints
  91. Downstream O2 sensor replacement?
  92. ployurthane??
  93. p420
  94. Timing Chain Tensioner Install
  95. p0304 misfire code
  96. ZZP Healights. What gen are these?
  97. Bought a new Ride (BYT Tune)
  98. Rod bolts
  99. Ls7 maf
  100. Just received an HID kit but im stumped big time.
  101. OneCOLDBIZL272'S Fuel Return Line and Feed Line Kit
  102. is this working right
  103. Got money.
  104. timming chain tensioner
  105. which turboo.
  106. which way would u do it
  107. No introduce yourself thread, so thought i'd do it here... New guy with ?'s
  108. remove the intake
  109. which wire and sensor
  110. Stage 3 h/e Help
  111. 2.5" or 3" Exhaust With 2.6" Pulley
  112. Custom catback questions
  113. what size pulley should I run?
  114. 3.5" Oversized Tensioner Pulley
  115. My misfire situation
  116. Bad MPG and a couple codes
  117. New guy with ?'s
  118. Hitting 20Psi at 7k, Is this a little high?
  119. supertech valves
  120. tune ?'s
  121. water in gas misfire
  122. Dear Engineer who designed our car's Oil Filter location
  123. does the 2.4 N/A Header and DP fit the 2.0 SC?
  124. ZZP 3inch exhaust installed! (video)
  125. Anyone want some holiday $$$?
  126. interceptor
  127. af narrow band
  128. zzp downpipe
  129. removing trunk latch/key hole on trunk
  130. Aeroforce Interceptor question
  131. Car At Wot
  132. Idling bad on car??
  133. 2.7 pulley hp?
  134. Stage 3 Trifecta Tune
  135. gm stg 1?
  136. did i get the wron gone
  137. up in the air which one
  138. Intercooler fluid going low
  139. Demonic Cobalt
  140. Weird Missfire Cycles to 100 and Repeats Itself
  141. Turbo Swap guys ... Opinions wanted
  142. How the car sounds with cams!
  143. corsa exhaust
  144. Meth into Intake Manifold?
  145. Cobalt without belt?
  146. Pulley swap question
  147. aem dry flow question
  148. which exhaust should i get???
  149. another spark gap ?... this is an interesting one.
  150. Exhaust Header CEL question.
  151. $310 to change a thermostat? wtf
  152. exhaust hits cross member.. any fix?
  153. exhaust
  154. P0171 after hard rain
  155. CobaltSS.net's 2010 Holiday Charity Drive!
  156. wiring light for meth kit
  157. Problems??
  158. welds vs.clamps?
  159. wonderful discovery!
  160. Brembo package
  161. bad supercharger?
  162. studder at wot
  163. ZZP Pulley Press
  164. couple questions for turbo conversion on lsj
  165. really quick dual pass question
  166. Not good with electrical. Stumped on the ZZP Projector headlights....need help =D
  167. So I dropped a socket
  168. exhaust leak questoin
  169. Belt tension
  170. Blower to intake bolts
  171. bolt ons
  172. HELP me in CT (ss/sc pulley issues)
  173. Alcohol injection
  174. tvs guy's
  175. a bad rear o2??
  176. dual exhaust sound level
  177. Should I take it to the dealership
  178. GM Ecotec Bolt-Ons - 372hp/292tq
  179. Turbo Swap Clutch
  180. twincharged tvs
  181. Megan exhaust
  182. replacement motor!
  183. Went to the mustang dyno.
  184. 210lb/hr Injectors Will they Work
  185. SLP Exhaust?
  186. Idle problems on at start up!
  187. ZZP 2.6 Pulley
  188. shaky boost needle
  189. Is This Normal For a Throttle Body? (Pics)
  190. Tuning in NC
  191. ZZP Stage 3 or OTTP Stage 2
  192. Whats the best Cold Air intake?
  193. need help, how to get rear break piston to open
  194. Resonated or Non resonated ZZP Exhaust?
  195. Think my head gasket is blown
  196. help on exuast
  197. Straight Cut Gears
  198. which areoforce
  199. can it be done
  200. exhaust, yeah another exhaust thread. sorry
  201. Exhaust "too loud"
  202. help with trans!!!!
  203. Brutal sound from SC (Not Coupler..)
  204. what kind
  205. need a number
  206. clutch slipping
  207. Exhaust Flames?
  208. areoforce gauge
  209. boost gauge issue
  210. couple of questions
  211. intake valves rocker arms
  212. need some help asap( possible timing/valve issues)
  213. Ripped Off!!!! Help
  214. Safe set of rubbers??
  215. My transmission feels dry/rusty/frozen help?
  216. help me please
  217. clutch slipping at 45K miles???
  218. 80000 miles:(
  219. bad misfire in throttle
  220. 2.7 need help
  221. HE Question
  222. header to catback ?
  223. Ri concept oem sloted/ drilled rotors
  224. Supercharger whine at very low speed’s?
  225. Coil pack part #
  226. Need help with Cruise Control sensor on brake pedal
  227. p0128 code?
  228. stage 2 belt (HELP ME)
  229. 199 cat back exhaust on ebay
  230. quieter exhaust?
  231. Newb looking to install STG 3 ZZP with S3 h/e lf how to
  232. Finally tuning my Ecotec...
  233. looking into the zzp stage 3 kit
  234. Standalone ECU questions
  235. MSD Dash Hawk
  236. Results of first dyno after the build.
  237. continual coolant temperature fluctuation
  238. how to make homemade option b
  239. New Supercharger On The Market...Code TYPHOON
  240. having trouble pulling off the hub for the sc
  241. What should I do next?
  242. Probably stupid question - fuel injectors
  243. Meth injection
  244. broken mount
  245. Hydro Shield
  246. Single Pass vs Dual Pass?
  247. Possible Problem?..
  248. power loss at 6k rpm
  249. Price to install sleeves
  250. what other pulley?
