PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Ordered cams finally!!!
  2. Bosch 044 Fuel Pump
  3. Tips for insuring a good seal on down pipe
  4. cat or catless?
  5. is a wideband neccessary?
  6. need a tune
  7. Quietest/Deepest Exhaust Available?
  8. Thinking about OTTP stage 3 kit...
  9. WTF is going on with my brake lights
  10. would this exhaust fit on my 07 cobalt ss/sc?
  11. Temps going up with zzp heat exchanger?
  12. ported superchager?
  13. Spray Wash Engine Bay??
  14. Backup Lights Dont work! :|
  15. What do you guys think of this intake?
  16. Car won't start after TVS install
  17. combustion chamber volume on lsj?
  18. meth kit installed right?
  19. specter air filters junk?
  20. soo wats better ls4 or ported lsj tb
  21. Finally a TVS!
  22. This look normal?
  23. short throw ?
  24. questions about SRI vs CAI
  25. Ported head install?
  26. So I bought a vibrant header with cat-delete....
  27. boost
  28. stock or not??
  29. R1 Concept Brake Rotors
  30. quick yes or no quesiton
  31. Power Steering recall, and tranny problems
  32. vacuum test???
  33. turbo swap (noob)
  34. Patriot Valve Springs?
  35. What You Need to Know about Intake's for 05-07 Cobalts
  36. Need a part number.
  37. Harrop: Fuel Problems!
  38. 2nd gear pull
  39. Dynomax VT
  40. Just Curious!!!!!!!!
  41. Performance help needed.
  42. Hp tuner file?????help
  43. Starting issue
  44. Intercooler pump
  45. OTTP Stage One or OTTP Stage Two?
  46. duel paSS
  47. hopping issie still
  48. Step 2 Colder Spark Plugs
  49. Weird idle with AC on
  50. will zenn cobalt springs fit a redline
  51. Blow off valve on supercharger?!
  52. Twin Charged (for only $225)!
  53. new zzp cams anyone??
  54. wtb hptuners, i need tune badly
  55. Piping size
  56. obx header dp combo on ebay
  57. dp ?'s
  58. WHAT happens when I unplug coolant temp sensor ? ?
  59. Not boosting fast enough
  60. Strongest 2.9 M62 Car?
  61. Intercooler Pump Fail...Possible Culprit Found?????
  62. Is it possible to run a 2.5 on stock motor?
  63. Royal purple?
  64. wastegate provision on turbine housing
  65. cel 315
  66. PLX Devices *Scan Gauge*
  67. setting timing
  68. Camshaft
  69. Intermediate Shaft Removal Help
  70. I wanna go stage 2(noob)
  71. zzp stage 3
  72. will a zzp catless dp...
  73. Option "B", scratch that, "Option Pick-n-Pull"
  74. dual pass install help
  75. 2.5 pulley? advice needed.
  76. Car Ran Into and Moved While In Gear
  77. Car randomly died then revived
  78. dual pass install with heat exchanger.
  79. LSJ turbo guys....quick question....
  80. Stage 2 ???
  81. wideband questions
  82. downpipe for headers??
  83. Zzp or ott
  84. couple questions/ideas
  85. where is my car
  86. Putting Car on Ebay tomorrow..
  87. Internal Vacuum Leak Help
  88. question
  89. 1400 miles
  90. possible problems with intake
  91. Another Problem
  92. belt
  93. My Build thread lol
  94. supercharger gasket
  95. Turbo Tech motor mounts with Ingall ETD?
  96. Less boost after header/dp
  97. Option B with flowthrough tank vs expansion tank
  98. 3" or 2.5" cold air intake?
  99. squeeling
  100. What are the best shift points when racing?
  101. Ac fan problem
  102. o2 sensor question
  103. What's the difference between M6 and E6
  104. Tune Time Toms river NJ dyno tune
  105. ark n2 catback question?
  106. ebay obx header and downpipe
  107. Boost and Air/Fuel
  108. Stage 2
  109. tune?
  110. k&n
  111. aftermarket intake or stock airbox?
  112. fuel octane levels and boosters..
  113. tune
  114. Power Loss & Overboosting
  115. LSJ Refuel
  116. airbox mod?
  117. Well, I finally blew up... Need advice
  118. LSJ Compression Testing & Numbers Info
  119. LSJ Modification Guide
  120. meth heads, get in here!
  121. 07 ss/sc Clutch kit?
  122. Mbc
  123. 07 cobalt ss/sc boost and rev limiter questions
  124. Clutch Kit
  125. CUstom exhaust
  126. Guess the dyno numbers
  127. Squeak/rattle noise from engine
  128. Timing Chain
  129. synapse lnf manifold
  130. 02 Sensor Help
  131. Running Hot
  132. 2.8 ond 42lb injectors?
  133. low oil need help plz
  134. short throw ahifter
  135. He ?
  136. Shifting....Helppp
  137. Ic pump
  138. will i need
  139. idle problem
  140. OTTP over Axle exhaust section
  141. Ottp stage 3 problems parts not shipped!
  142. Weight of the lsj block
  143. dumb question, injectors
  144. Shift Light Point
  145. some help please
  146. exhaust leak or shotty workmanship? oh and pn?
  147. lag???
  148. Does OTTP Stage II come w/ P0420 delete standard?
  149. cat converter
  150. belt problem
  151. Car almsot stalls after header install
  152. gmpp exhaust
  153. is this intercooler pump the same as the stock one?
  154. ottp mount+track
  155. Small Build on my car
  156. Stage 3
  157. Seat Swap
  158. hotrod.com lsj article
  159. Antenna Chop
  160. 2.6 60's only 15 psi??
  161. HELP! how do you loosen the drive belt?
  162. 2 step
  163. New Exhuast option
  164. Too Many Exhaust Options...
  165. Just my luck...
  166. another P0172 code
  167. Wanting to Know what replacement parts i should Buy?
  168. GM drivetrian warranty
  169. Supercharger Intake Pressure.
  170. crankcase hole
  171. Piston research
  172. ok i decided
  173. P0103 MAF High Code
  174. another fuel pump question thread
  175. Sifting Problem
  176. Robbing Power
  177. Coopercharged Stage 3 Build
  178. problem bleeding clutch
  179. Supercharger muffler delete?
  180. boost ?'s bypass ?
  181. header question
  182. What Type Of HP Should I Expect ?!
  183. Need a new radiator...
  184. HELP: Case learn not working
  185. damn bumper has to many clips.
  186. zzp supercharger stage 3 kit?
  187. idle fluctuation
  188. zzp dp
  189. black coating on blades??? wtf
  190. Spark plugs
  191. Oil Catch Can
  192. oil pan?
  193. ?Mods that do not void warranty?
  194. Questions about cooling systems
  195. exhaust size?
  196. Need spark plugs!!!!!!
  197. What muffler would sound best with the stock exhaust???
  198. running rich on a tune
  199. E85 vs Gas
  200. Please help
  201. help for installing a HE
  202. HELP... need help with case relearn
  203. Weird Problem
  204. motor mount
  205. stage 2 belt tips
  206. Props to BlackBaltSW
  207. Spark plugs??
  208. LSJ Tranny Fluid Question
  209. methenol
  210. intake manifold options
  211. Questions on ZZP downpipe
  212. Motor Build Questions
  213. interceptor question
  214. problem when shifting my car
  215. never done this before
  216. Stage II 05 - Need Input
  217. i got a vibrant header only but need help
  218. crank relearn?
  219. Stock Catalytic
  220. Re-tune?
  221. Anyone with the CA downpipe?
  222. BYT is full of win =p
  223. high flow cat
  224. 2.0 lsj g5
  225. Adjusting Ingalls Torque Damper
  226. 1 step colder plugs
  227. Ottp stage ?
  228. exhaust help..
  229. Rebulding the motor
  230. intake question
  231. Radiator Replacement
  232. check engine light problem
  233. dont want to melt anything
  234. oil filter
  235. Cia header
  236. turbo
  237. how much is this worth?
  238. CA Tration Bars?
  239. trifecta vs hpt
  240. How do I change intercooler coolant?
  241. tires
  242. Vortech/Paxton Centri Kit
  243. ZZP Stage 3 Warning
  244. What is the Difference between OTTP S2 vs ZZP S3?
  245. Headers
  246. 55lb injectors?
  247. Trans fluid?
  248. CAI Installation (Injen, with pics)
  249. disassemble m-62? and plug ports?
  250. Cant trap over 100mph!WHY!?
