PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. opt b w/o dual pass
  2. Exhaust cam sensor question.
  3. This is my goal, help me reach it!
  4. Problems. Looking for suggestions.
  5. Need some advice
  6. What upgrades/mods to get
  7. How to tell if the top engine mount needs to be replaced?
  8. side exhaust help
  9. Everytime it rains
  10. JBP vortex header
  11. Clutch HELP!!!
  12. ottp stage 1
  13. pistons and rods lets discuss
  14. Part # For Map Sensor
  15. exhaust help
  16. HPT and the intercooler pump, input welcome!
  17. Iat2
  18. ARP Head Studs and Main Studs?
  19. no group buys lately
  20. Need a new 2.0 block and head
  21. does anyone else?
  22. Help me choose.
  23. Key fob low????
  24. Two pod gauge pillar...
  25. Can't get rid of CEL
  26. 2007 ss/sc tuning questions
  27. Shimmy/shake under WOT
  28. ZZP Cutch Rod???
  29. Check engine light
  30. Dyno Day
  31. Transmission is leaking. Anybody else have this?
  32. Catch Can
  33. Stage 2 install LIMP MODE HELP!!
  34. injector sizing....?
  35. 2.6 pulley question
  36. ZZP 3" CAI Installed *2 days later CEL*
  37. Did I end up getting the wrong fuel filter?
  38. I need help ASAP, removing fuse box
  39. ERROR po172
  40. please help
  41. need exhaust advice
  42. misfire and no CEL????
  43. pcv hose delete
  44. engine disabled/engine reduced power
  45. shaved head... anyone?
  46. CA header, feels slower?
  47. Header rasp?
  48. GM stage 2 pulley bolt
  49. Need some injector help
  50. weird noise
  51. a little problem installing my lucas 42lb injectors
  52. RPM hold
  53. Option B install
  54. LS4 TB Help
  55. backfiring.
  56. fuel pump?
  57. tune question.
  58. Another E85 question?
  59. cjeck engine light on
  60. Zzp PCM and 60lbs??
  61. Need tuner in pa!!
  62. exhaust ?
  63. Cat Delete/ Resonator
  64. Exhaust?
  65. hid help
  66. dead I/C pump
  67. **TVS DYNO numbers**
  68. P0496: EVAP Canister Purge System High Purge Flow helpp??
  69. Replacement Hoses Supercharger Bypass Valve
  70. quick/cheap hp,torque,sound mod
  71. LS4 Throttle Body
  72. Part number for K&N Filter...
  73. Intercooler pump RPM dependent?
  74. Brembos
  75. AEM wideband problem
  76. Apexi Neo opinions?
  77. Harrop----ls4?
  78. m62 pulley removal
  79. lsj intake mani gasket
  80. crank case relearn
  81. Intercooler Pump failed
  82. Oil In Vacuum Line
  83. Picking the right mount.
  84. Need help
  85. Wide Band
  86. ZZP Single Pass Intake manifold?
  87. Need a Chevy Tech's Help
  88. stage 2 with out injectors
  89. throtle body problem!!
  90. IAT 2 down track
  91. Alternatives to MSD ignition box?
  92. LSJ swappable for Saab 207R 2.0T?
  93. HELP! Need a gift idea for cousins SS/SC
  94. Fuel Level screw up
  95. Ppl with OTTP Stage 2 Chime In...
  96. gm stage2, where to buy?
  97. Injector size
  98. Just hit 30,000 miles.....
  99. Spark Plugs With Stage 2
  100. Harrop help!
  101. Lean Code P0171
  102. HELP! Supercharger noise during boost, coupler?
  103. got a code....
  104. Before and after ported head dyno on a tvs
  105. OTTP 3" Intake on a 07
  106. What the f**ks wrong with my car
  107. injectors
  108. OTTP 3" Intake
  109. Which Option B tank?
  110. Can any one tell me???
  111. oil on my 1st and 4th sparkplug
  112. just finished install on ottp reverse trans mount
  113. how Hard is it?
  114. wot box
  115. 07 Cobalt Ss/SC looking to upgrade without voiding warranties.
  116. got a code
  117. does neone know...
  118. smaller pulley
  119. Engine swap question
  120. Megan Exhaust
  121. new owner with questions and sales
  122. 2-step, shutter box, launch control Questions??? (tryin to build??)
  123. me vs 07 eclipse gt 5 speed
  124. OTTP stage 2 tips
  125. injen cold air intake
  126. Long Term Fuel Trem
  127. Cylinder SIX Misfire???
  128. new converter
  129. Bungs for dual passes
  130. ported blower worth it?
  131. Any One need a tune?
  132. Supercharger Bolt
  133. Injen Typhoon CAI
  134. short shifter
  135. Air/fuel
  136. 2.6 pulley question
  137. GM Warranty Parts
  138. Sporadic Idle, Won't Start, Then Everything's Fine...
  139. Aftermarket downpipe
  140. Tvs !/4 mile?!?!?!
  141. What is wrong with this thing!?
  142. pulley bolts keep getting loose
  143. zzp s3 HE
  144. so what could be wrong here?
  145. CA V1 again..
  146. Best way to bleed.
  147. DCSport Cold air Intake
  148. What Pulley ?
  149. Killer Chiller install
  150. K&n cai cel?
  151. P2176 and p0300
  152. rotor bearing removal
  153. 2.0 zzp turbo kit
  154. stage 2 ughhh at last
  155. Supercharger coupler
  156. what stage is good?
  157. E85 Tune
  158. Who makes best Heat Exchanger
  159. install help
  160. exhaust set up
  161. Supercharged parts
  162. cooling trouble.
  163. exhaust?
  164. Average boost drop with header?
  165. Motor is shot..need some help//
  166. What Mods are on my car?!
  167. NEED HELP, with some wiring!!!!!!!!!!
  168. 06 ss/sc dyno with injen CAI only!!!
  169. cooling question
  170. Help!!
  171. Torque management?
  172. quick question
  173. zzp header dp combo o2 sensor question
  174. sedan ss/sc??
  175. E-85 Dyno Skatinboarding
  176. Corsa Touring Catback Install/Review
  177. WTB : Front Rotors/Pads
  178. Mass Air Flow Sensor/meter
  179. weird ticking noise/oil drip
  180. Friends clutch feels toast and i dont know what to tell him
  181. heat exchang
  182. need help
  183. boost problem
  184. lsj turbo kit?
  185. Gmpp stages?
  186. Injen OR RD Fabs?...
  187. light flywheel vs stock flywheel in these cars worth it?
  188. CA V1 header. Help?
  189. GM Stage 2 Pulley sizes
  190. CIA Header/DP Install ...
  191. The ZZP 3 inch CAI for the Cobalt
  192. Downpipe that will fit stock exhuast
  193. stage 2 question
  194. 3.06" pulley/42lb's no BS dyno results!
  195. single pass!
  196. LS4 throttle body
  197. Bypass valve question
  198. Weird problem.
  199. interCEPTOR GAUGE scanner
  200. Ottp stage 3 kit
  201. recalls..
  202. Spring Mods, What to do next?
  203. New grill?
  204. ZZP 3" CAI. Anyone got it?
  205. Blower pulley
  206. option b and dual pass.
  207. Injector install
  208. How to get to Heater COre??
  209. Taking motor out??? need HOW TO
  210. ottp stage 2 vs. ZZP stage 3
  211. Temperature reading on speedometer...HELP
  212. Something wrong with my Wideband
  213. security lamp
  214. idle problem
  215. suggestions for mods
  216. Pulley size ?
  217. E85 and NOS = NO ????!!?!?!??!?!
  218. clutch linkage adjustment??
  219. header thread
  220. how to tell if
  221. door wont close right
  222. resURFACEING A flywheel
  223. boost hoes
  224. nervous.....
  225. Clutch Spring Pressure Q's
  226. Sputtering and power loss @ 3500 rpm
  227. Fidanza Lightweight Flywheel LSJ
  228. avg. WHP gain on ported head?
  229. OTT Rear Sway Bar Street, Koni Struts/Shocks, SSC Springs....
  230. lack of power , bad idle , maf related?
  231. some CEL codes
  232. AEM wideband install
  233. Meth or nitrous
  234. Who gave me their E85 tune?
  235. Problem Earlier Today
  236. Tb?
  237. Turbo Build
  238. What Exhaust Should I Go With ?
  239. Repairs
  240. maf sensor
  241. dual pass leak
  242. got some gauges
  243. Which turbo I should buy? 360-380
  244. Need Help: Meth Install
  245. boost gauge actin up
  246. Has any body tried or done this?
  247. nee dimput on pulley swap
  248. Broken Flex Pipe. Where I can get it?
  249. How to find out if I have an upgraded pulley?
  250. will this fit?
