PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. ZZP Mid Length guys
  2. LNF on LSJ??
  3. pully sizes
  4. question
  5. Interceptor Misfires
  6. P0300 Random Misfire help! confused?
  7. So what does everyones headers look like?
  8. Another Meth question
  9. Pulse Dampener on fuel rail
  10. IDC's on stage two
  11. new zzp exhaust
  12. *****CINCINNATI, OHIO OR NEAR Dealer to install Stage 2
  13. Smaller pulley = less bottom end?
  14. dip stick stripped out of block
  15. turbo ???
  16. Sputter
  17. M62 Blower Bolts
  18. "DIY LSJ Turbo Kit" I vote to sticky this!
  19. Just hit 30k
  20. help
  21. red tip spark plug???
  22. clear image tuning
  23. exhaust manifold tightening pattern
  24. How much whp ya think??
  25. another reflash question....
  26. Engine power reduced
  27. Anyone throwing code for a meth kit?
  28. What all will i need?
  29. how important is it to get the crank checked
  30. GM ecu reflash number
  31. Totally confused help plz
  32. Too Rich Bank 1
  33. duty cycle of stock injectors
  34. brake problem
  35. Help I Need A Tune!!!!
  36. another exhaust related thread- resonators
  37. Putting on smaller pulleys
  38. turbo lsj issues, breaking up
  39. Whooo Hooooo!!!!!!
  40. Brakes/Rotors
  41. Clutch feels weird after hwy driving. any ideas?
  42. Hp tuners anyone?
  43. TVS 300WHP Wall
  44. Home made stage 3 (w/o nitrous)
  45. Help with a code???
  46. 20lbs of boost with a 2.8?
  47. finally got it
  48. injen question
  49. Worries or not?
  50. interesting exhaust question
  51. funny story, a little worried
  52. OBD2 scanner or aeroforce intercepter?
  53. Lean Code
  54. K&N Typhoon Intake
  55. Better power producing combo?
  56. Catless stock exhaust, sound?
  57. A few more questions.
  58. Stage 2.
  59. supercharger gasket
  60. IDC's with 60's on TC SS + meth
  61. Porting th SC
  62. ZZP/OTT/Hahn 3"
  63. WHP limits
  64. High octane.
  65. Remember The upgraded SPlug boot springs
  66. uneven surface make sounds
  67. whats the safest way to plug silencer holes???
  68. will this setup work 2.8, 60#, stage 2 tune
  69. case/crank relearn
  70. Anyone Have Flowmaster?
  71. serious problem. help
  72. e85 anyone
  73. Meth injection
  74. Help finding something
  75. How to reprogam throttle body
  76. how much hp ?
  77. Good Upgrade for $200
  78. PaceSetter?
  79. please help! grinding noise.
  80. PCM Under cover
  81. What would you do
  82. Asking for opinions (exahust)
  83. Seat bracket dimensions
  84. Get the whine back
  85. What to upgrade?
  86. Code help
  87. Where can I get a screw that holds spark plug cover on?
  88. help..... top bolt on starter
  89. Tapped TB spacer?
  90. m62 pulley sizes
  91. Change 02 sensor now i have 2 codes on
  92. Header Gaskets
  93. i need 72lb injectors
  94. car wont start
  95. Laminova core help
  96. Stage 2 6500 or 7000???
  97. Exhaust Warranty
  98. Quick M62 Oil Question From Experts! Please!
  99. Another Plug Question
  100. LSJ: Is this the filter for K&N?
  101. GMPP Exhaust and fuel economy
  102. Clutch
  103. Dual Pass Help!
  104. Feels slow again!
  105. Anyone bought from smoothflow Pulleys?
  106. exhaust question
  107. Going back Supercharged!
  108. difference between clutch slip and driver error
  109. one big headache
  110. Injen intake
  111. Killer Chiller questions!!!!
  112. muffler help
  113. The infamous turbo swap on the LSJ
  114. need help and input. throwing a code
  115. Best cooling mod for Stage 3, opinions please.
  116. Wheres the TVS dynos Or SLIPS
  117. High Flow Cat vs NO Cat
  118. Bad Coil Packs???
  119. Fuel Rail Pressure?
  120. p0068
  121. no cat spark plug de fowler
  122. Catch Can
  123. Is there an AC Eiminator kit for our cars?
  124. GM Stage 2 and 3 AFR
  125. Rpd Unit??
  126. Fuel pressure
  127. recommended supporting mods for 2.7 or 2.6 pulley
  128. Interceptor dual or single?
  129. I think something broke...
  130. resonator help please
  131. launching with the wot box..
  132. CTI 3in exhaust vs OTT 3in exhaust
  133. plugs
  134. UEGO power from factory boost gauge
  135. whatever happened to someone making a new intake manifold?
  136. cobalt owner with no knowledge
  137. MSD Ignition on the LSJ help needed
  138. exhaust ?
  139. Flowmaster Super 44 Muffler HP Gain
  140. 2.8 pulley with 60s = more hp than with 42s?
  141. how much power from lsj
  142. car running too rich
  143. Want to know...
  144. cams............
  145. Clicking Problem
  146. Waste Gate
  147. catch can help
  148. Sh*t
  149. Fuel pump ? + other ?
  150. Ok we got a problem
  151. Map/ Baro sensor
  152. TVS Vs. Hahn level V
  153. pulley puller
  154. Crankcase relearn$?
  155. Help! Question About Header/DP
  156. where to get pistons?!?!?!
  157. timing chain issue
  158. Limit Boost in First- Stage 2
  159. Please recommend me an intake...
  160. gmpp ported header
  161. removing laminovas
  162. Lean Code P0171
  163. Funny happenings cruising at 65- 80ish mph
  164. Resleaving 2.0 LSJ
  165. Possible for computer to limit boost?
  166. rain, whine not loud, cold weather?
  167. Camming cobalt
  168. Malibu Solid Control Arm bushing?
  169. Turbo Build: The Disassembly
  170. TVS Installed
  171. Changed pcm car wont run?
  172. Changed psm car wont run?
  173. Do me a favor.. Knock on your bypass actuator...
  174. Greddy Catch Can
  175. Code from GM kit
  176. choking aggressively when accelerating
  177. intake question
  178. Need help
  179. compression and the TVS
  180. Anyone have production numbers (number of SS/SC's made?)
  181. Tvs Install Help
  182. cool website for used auto parts.
  183. Engine at 90,000 miles, when do I...?
  184. Painting my header/dp
  185. ecu swap question
  186. Loco's Build
  187. Intense PCM........
  188. exhuast question
  189. Check engine light help.....
  190. 3 in intake
  191. Inverted clutch switch
  192. 8000 rpm
  193. can you put gm stage 1 ecu refkash on #42 lucas injectors
  194. Hahn Racecraft Stage V turbo build and more!!!!
  195. Whats wrong with my clutch?
  196. Predictions for the ZZP Twincharge Cobalt?
  197. Race Gas?
  198. Please help! (wot box trouble)
  199. Very weird boost problem.. READ!
  200. downpipe best price/place
  201. Resonator Help
  202. supercharger oil
  203. LSJ Goal 270 whp Suggestions!!!
  204. Stage 2 ECU Flash
  205. problem
  206. Rear O2 sensor clip removal
  207. Raw intake...
  208. air intake help
  209. Erratic Idle
  210. Dynoed today!
  211. which short ram??
  212. silencer holes PICS
  213. S/C silencer holes question
  214. LS4 Throttle body install
  215. gear oil
  216. CEL after CAI
  217. 06 SS S/C Problems
  218. Intercpetor scan gauge
  219. Intake
  220. help me find a part please
  221. 2.4, or 2.0?
  222. gm clutch
  223. what is the best filter out there?
  224. whats the difference
  225. saab mani
  226. Want launch control for your LSJ? (no boxes or wiring required)
  227. Header/Gasket
  228. anyone have aftermarket cam?
  229. catalytic converter question
  230. Parts help please!
  231. Those who have/had AEM UEGO ....
  232. Methanol question
  233. ZZP twincharge or TVS?
  234. Idle problem fixed
  235. It came today
  236. Pulsar spark plugs
  237. 160 degree thermostat
  238. headlights idea and performance gain?
  239. Megan Racing Exhaust
  240. Stock Heat exchanger
  241. ecu ready monitor question
  242. Heat Shield
  243. 77.9 Pulley = 3 inch
  244. I feel like such a ricer for asking this (OTTS1 q)....please forgive me :lol:
  245. Tensioner pulley.
  246. Replacing clutch, master and slave, and flywheel?
  247. Cel
  248. cammed cobalts
  249. iat sensor ?
  250. duel pass endplate ?
