PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. S/C ported/TB Ported
  2. Header install this weekend, have a Question
  3. p0171
  4. How much S/C oil do you use or prefer?
  5. best intake?
  6. Nitrous or 2.8 and 60's?
  7. turbo swap
  8. How to clear the CEL
  9. necessity of case learn
  10. Stock Res....
  11. Simple muffler swap?
  12. Inconsistant boost
  13. Exhaust Question
  14. meth injection is just washer fluid??
  15. intense stg3 case relearn
  16. 60lbs/hr injector question
  17. Is low manifold pressure my problem?
  18. shift light... What am i doing wrong?
  19. Stock 2.0 LSJ Throttle Body Size??
  20. clutch
  21. supercharger maintanance
  22. H/E in series vs. replacement
  23. 60 lb injector harness??
  24. Downpipe question??
  25. what about DC exaust?
  26. 119 octane!!! WHAAAT
  27. difference between sport and touring
  28. Megan exaust!!!
  29. AEM vs Autometer
  30. Stage 2 help
  31. pulley question
  32. Anybody in NJ can do a Case Relearn?
  33. Tc Vs. Sc
  34. Supercharger bov's
  35. JBody Performance Vortex Header
  36. COOLANT question
  37. What size flex pipe?
  38. E 85
  39. what spark plugs to get for stage 2...2.8 pulley
  40. Cobalt SS intake problems??
  41. 2.95 Pulley Size
  42. clutch failing?
  43. can i use this intake for my turbo build?
  44. tuning
  45. Winter Driving and colder climates
  46. Stock Motor numbers with TVS?
  47. New mods for winter
  48. breaking up up top???
  49. 350Z vs SS/SC
  50. goin turbo
  51. What has 2 thumbs and FINALLY got Dylans RL to start?
  52. fac. down pipe 2.0+2.4
  53. Help! (Header/DP)
  54. Power Loss?? Please Help!!
  55. Larger idler pulley
  56. oil pump
  57. Help Engine Noise
  58. Corsa Sport???
  59. Downpipe ????
  60. Need some help with a Cold air intake
  61. What size gasket?
  62. ideal injector size available for 2.7" pulley
  63. exhaust, intake, tune??
  64. Which one is the Timing Chain Tensioner (PICS)
  65. question
  66. tensioner pulley torx bit?
  67. Rev limits on the LSJ
  68. GM Performance Cams
  69. gapping AUTOLITE - Autolite Iridium XP Plug ?
  70. Darn PO 420 engine code NEW cat needed!
  71. doing a case learn
  72. lowest iat2 you've seen
  73. Hanh staged turbo kits
  74. same old chit!
  75. intense stage 3, whats next?
  76. Intake Manifolds
  77. Is my clutch slipping?
  78. Anyone gut the cat in the factory downpipe?
  79. Victory Red SS?
  80. Want to do most effective exhaust mod...
  81. what kind of stage kit to pick
  82. i need a resonator
  83. Tranny oil??
  84. Tensioner +Pulley Config?
  85. Need info on 2007 SS/SC Exhaust system
  86. Sooo I think she blew...
  87. quick question for you other sc to turbo guys
  88. 2.75 on 42's
  89. downpipe/cat scrapping
  90. Does this timing appear to be set correctly?
  91. Exhuast Ideas
  92. CEL Help
  93. Blown Head Gasket ! Are Comitech BAD?
  94. Help me with this build!
  95. zzp Stage 1 ?
  96. Which Hahn Exhaust????
  97. bench dyno with phantomss Balt
  98. quick question
  99. clutch to buy
  100. can someone inform this guy?
  101. Cia Header nd Dp
  102. Lsj Alternator Bracket Part #
  103. Funny kind of
  104. stalled going down on ramp
  105. Need help understanding diff stg of meth
  106. My new 3" :)
  107. Bwalker Turbo Build......first Start...un Tuned
  108. Has Anyone Tried This Intake ????
  109. stage 1 or 2 meth kit?
  110. quick question
  111. FYI- Cobalt-addiction weekend sales
  112. Help! Broke a bolt & Can't find
  113. Cobalt Addition shorty header
  114. 60 lb. injector harness
  115. Tune?
  116. Megan racing drift spec catback exhaust
  117. PCM Part#?
  118. Injen DRY filter ???
  119. Injen Maitenace question
  120. who has the best canned tune?
  121. Gauge Pod Question.
  122. ott stage 1 pcm deal
  123. Vaccum lines From man to bypass to actuator
  124. Why I Don't Run An After Market CAI.....
  125. Exhaust Manifold#
  126. downshift into 3rd = stalling!!!???
  127. How much would you pay for hahn?
  128. LSJ Cam Question
  129. exhaust tips make a difference?
  130. Who Makes The Best 2.9 Pulley For A GM Stage 2 Hub ?
  131. Gauge Question
  132. a/f
  133. hp tune help
  134. stage 2 tune with 2.9 pully
  135. Question.
  136. Rear O2 sensor needed?
  137. Interceptor
  138. ZZP or Hahn turbo
  139. after everything i have a slight answer
  140. how to keep your lsj alive in the winter
  141. put on ingalls TD and everything seems noisier?
  142. GM Stage 2 With 2.8" vs 2.9" Pulley......
  143. LSD instalation
  144. question about spark plugs
  145. Help: Hooking Up Halo's
  146. Check engine lite. NO HIGH END POWER.
  147. Spoiler swap question
  148. Warrenty work
  149. clutch problem?
  150. For Sale
  151. Copper, platinum, or iridium plugs?
  152. instrument cluster gauge pod
  153. dual pass plumbing thoughts
  154. Cheapest Stg.2+ Clutch?
  155. OTT tune?
  156. safe to say I need a new IC pump?
  157. GM performance sport exhaust
  158. remove pully ?
  159. Going Forged...
  160. OTT stage one
  161. single to dual pass?
  162. RPM signal for meth/ shiftlight
  163. ported throttle body
  164. NJ tune?
  165. What do you think?
  166. what size inline fuel pump
  167. 2.9" finally!!!!
  168. 14.5 psi on stock pully cobalt ss sc
  169. How to convert drive by wire
  170. Methanol Injection Cobalts!
  171. Reacts like turbo lag in 3rd?
  172. Intercooler Pump???
  173. throttle body
  174. WOOOOOH another exhuast question!!
  175. Smoothflow Pulleys Group Buy!
  176. Best 3in Exhaust
  177. dumb kid at school
  178. 50/50 alcohol and water in the H/E?
  179. E3 spark plugs from pep boys?
  180. SS/TC Boost Gauge in SS/SC.........IT WORKS!!!!!!
  181. How small of a pulley?
  182. ordered a header and d/p today
  183. Has anyone seen this.... seems BA
  184. Wideband bung placement?
  185. Looking for a Part Number
  186. What Catted DP to get??
  187. Any Ideas On what Header It Is?
  188. requesting a faq on tvs
  189. OTT with 2.9?
  190. Okay two questions...
  191. shorter belt
  192. Iat2/intercooler pump question.
  193. solid motor mount
  194. roadrage06_dyno results
  195. quick ?
  196. upgrade intercooler pump, i have pics
  197. Calling all GM stage 3 LSJ's.....
  198. ZZ Performance Tune??
  199. Need some clarification
  200. Is g85 worth it?
  201. zzp stage 2 question?
  202. what tires to get
  203. Hi! Im New
  204. TVS Supercharger
  205. pipe/ catback question
  206. Has anyone seen this?
  207. car running sluggish
  208. SLP Loudmouth dual
  209. Exhaust issues
  210. 02 sensors.
  211. imposter heat exchanger?
  212. Stage 2 Kit question
  213. Heat Exchanger..
  214. water/meth boost activation switch
  215. RPM Bounce
  216. Header/Downpipe Question
  217. Just got 2006 2.0 couple of Q's.
  218. Bwalkers turbo build with pics
  219. DD Fiasco v 6.5
  220. Lightweight Wheels for SS/SC???
  221. jbp stg2 cam grind?
  222. OTT stage 1 installed!!!!
  223. Supercharger price
  224. Questionn
  225. erratic idle, car revving out in neutral
  226. What aftermarket intercooler pump?? My stock one is leaking.......bosch cobra pump?
  227. Some Turbo Questions...
  228. New parts for my car with pics
  229. Does this timing chain look like its ok?
  230. I lost 10 psi????
  231. 2.0SS/SC Mod Opinions
  232. A Cat plug...?
  233. Exhaust layout
  234. nitrous?
  235. tuning
  236. engine trouble
  237. replace megan reson with magna muff
  238. Moving to a 2.9
  239. Typical Stage 2 IAT2?
  240. All Lsj Owners In Here!
  241. K & N People question?
  242. Pully Size ?
  243. dash light question
  244. suspension ?
  245. Problems with WOT Box
  246. 3.1 pulley from zzp
  247. Solid Upper Motor Mount and Trans bushings
  248. Tach Hook up
  249. injectors 1000cc
  250. Light bulb change
