PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. running 2.7 and 60lb injectors?
  2. Difference Between 2.9 and 2.8?
  3. TQ specs on the Header and Downpipe combo
  4. Coming soon, the most elaborate Water-Methanol Setup ever!
  5. chainging to new oil
  6. snow curb no good
  7. problem want you opinions
  8. painting cobra h/e
  9. Cheapest place to buy methinjection?
  10. problem
  11. Fluidyne Radiator + Heat Exhanger
  12. need some help
  13. aem uego
  14. PCV Valve
  15. Watersoaked Air filter?
  16. fuel injectors..PLEASE READ
  17. Error codes...need some help!
  18. about meth
  19. options/ideas
  20. zzp wideband bung
  21. Weapon R long tube 4-2-1 header
  22. AEM Dryflow filter cover question
  23. Newb ? here
  24. Beware...zzp=cheap Stuff
  25. For Those With Widebands
  26. to those who have popped motors
  27. Thought about Stage 2 but...
  28. ebay heatexchanger ?
  29. How much boost do you make if the bypass stays open?
  30. Picked up a Cobra HE
  31. fujita vs injen intakes
  32. Cobalt Manual
  33. Question for you Motor guys
  34. Any good websites to buy performance parts from?
  35. ZZP header dp combo CATLESS
  36. Replacement high grade screws for Stage 2 hub
  37. Dualpass option "B" diagram
  38. Ehh boost gauge>?
  39. heat exchanger
  40. header = lower mileage?
  41. how do...?
  42. Pulling the engine..
  43. Straight Anwsers : Water Meth Injection
  44. LC-1 All Thats needed for Interceptor?
  45. So i've been thinking
  46. Went back to stock exhaust.
  47. what comptrssion ratio should i go for?
  48. Coolant used for our superchargers
  49. ZEX Hyperformance plugs. How cold?
  50. Nates 2.9 Pulley Installed
  51. AfterMarket Cams
  52. 282hp on scanforce does that sound right???
  53. Is anyone running a gutted cat?
  54. muffler or full exhaust?
  55. GM S3 100oct tune: meth instead of race gas?
  56. another little prob
  57. 600 to spend.
  58. Just installed my 42s...
  59. Check engine code....
  60. Nate's pulleys
  61. Sti Spark Plugs = LFR6A-11?
  62. LSJ Doctors Please Give Me Your Diagnosis
  63. gains from GMPP Header
  64. well crap........
  65. Pacesetter Catback for SS/SC?
  66. 60lbs on STG 2 Tune?
  67. 2005 SS/SC end of lease turn in soon
  68. Is there a CAI with no cel
  69. Injector Cover
  70. Got my new turbo manifold
  71. Taking the cat out
  72. hydrogen filled tires?
  73. profesional opinion
  74. cams
  75. Guage Face replacement???
  76. Option B ?
  77. In need of this wire
  78. 2.85/42s
  79. rebel autoworks stage kit group buy
  80. ss sc intake
  81. Pulsing 3rd gear at 90+ mph
  82. Help **urgent**
  83. Check Out My New Mod!!!!!!!!!!!!!!
  84. How far does your......
  85. looking for cams
  86. First Cat Now This!!! give me a break!!!
  87. Torque Spec for bolts on supercharger pulley
  88. What intake do you have?
  89. Catback question
  90. Best bang for the Buck
  91. best turbo kit
  92. New for me setup. Easy safe and good on gas.
  93. Has Anyone Bought A Pcm
  94. rattling question
  95. rod bolts
  96. It's like a totally different car!
  97. torqing manifold
  98. K and N intake
  99. stock ss/sc exhaust
  100. Ss Means "super Slip"
  101. DP on Stock Exhaust??
  102. need advice on getting the intake manifold off
  103. zzp header dp combo problem?
  104. For those that have had their car tuned..
  105. ZZP downpipe problem - wideband bung plug
  106. Exhaust
  107. Camshaft/Head Availability Update
  108. HP Tunner Questions
  109. Choose my Pulley size
  110. Spark Plug questions
  111. Feeling Pretty "Pumped"
  112. just ordered vibrant catback!!!
  113. Don't use the washers from ZZP with the header/dp combo
  114. meth inj on GM stage 3 100 OCT tune???
  115. where can i get a wideband?
  116. Just got my pulley!
  117. AHHHH Grinding
  118. Buying GM stage 2? PLEASE READ -Possible sticky?
  119. oil ?
  120. Am I the only one still waiting?
  121. Pulley Problems
  122. Stage2 Bolts
  123. does anyone have this
  124. dyno question
  125. p1133..popped it this afternoon
  126. powder coating
  127. Eaton Superchargers Modification Guide
  128. Exhaust/Header question
  129. ECU removal instructions for upgrading to stage 2
  130. buying stage 2
  131. B&M Short Throw Shifter
  132. ca front mount heat exchanger
  133. stage 2 on the way
  134. Hit something in the road need exhaust ASAP
  135. Any one w/ pics of Water/Methanol Injection system hooked up?
  136. Heat Exchanger needed?
  137. Best Stage 2 Pulley size??
  138. Brake lines
  139. forced to get an exhaust, ADVICE please!!
  140. Ported Head
  141. Time to build alittle
  142. Clutch
  143. Stage 2 and a CEL
  144. stage2 numbers ???
  145. For those with GM Stage 3
  146. Stock Boost gauge
  147. zzpheader and dp question?
  148. Help Me
  149. Were to start
  150. rebels kits
  151. in need of 2.0 alternator
  152. Wait im confused!?
  153. zzp exhaust
  154. Heat!!!
  155. Cam ?
  156. what am i working on today?
  157. aem uego
  158. h\e
  159. if you want a megan racing catback
  160. warranty question???
  161. H/E Bottle Neck Problem
  162. Tax Refund.
  163. Hurst Issues!!!!!
  164. Got my Magnaflow :)
  165. New Setup...what do you guys think?
  166. Diffrence from 2.9 to 2.8
  167. how much boost with...
  168. Dp question
  169. poping noise
  170. "best" canned tune
  171. 2.9" Pulley
  172. how much dex-cool
  173. Need Torque specs for everything head on up
  174. CA Heat exchanger HELP
  175. Anyone encountered steering side effect after TTR mount installation ?
  176. Pullin my motor tomorrow!!!
  177. bad noise?
  178. Questions about the TTR upper motor mount
  179. high temps!
  180. will new mods be worth it?
  181. Brown liquid in my CAI???? HELP PLEASE
  182. New LSJ performance parts!!!!!!!
  183. AEM Wideband
  184. Question for people who have got tuned or do tuning
  185. Help - DTC P0121, P0068
  186. Best header
  187. If I order the stage 2 from CED will It be under warranty?
  188. signs of rings or blown piston!?
  189. BKRN7E Spark Plug Question
  190. tune suggestions NJ Bergen county
  191. did an oil change about a week ago... and now
  192. coolant ?
  193. CA V2 stainless header
  194. Stage 3 computer with 2.8 and 60's
  195. Cheapest Place to buy 60#
  196. how much hp
  197. stage 2 vs stage 1
  198. supercharger lag?
  199. what is the diameter of the shaft on the sc?
  200. Can watch the gas gauge go down! Help!
  201. Stage 2 in N.E.
  202. Injectors at 110% w/ 2.9"?
  203. something is wrong with my car.
  204. hurryyy neeed quiicckk hheellppp
  205. Stage 3 question
  206. stage 2
  207. Which pulley?
  208. WoooHooo Uncle Sam Came Threw
  209. do 60's and a tune make a big diff...
  210. Muffler Replacement only?
  211. ran compression tonight
  212. a little update for the people who care
  213. short throw threading
  214. Newb DP/Header Question
  215. GMPP Installed!
  216. Ingalls ETD adjustment
  217. Need more power!
  218. low boost and lagging power intense stg 3
  219. For those of you that are running stage 2 with a smaller pulley.
  220. need hp tune in indiana
  221. cobalt ss supercharged vs mazda rx8
  222. what do you think it would cost to build a lsj
  223. Flowmaster?
  224. Front o2 Sensor
  225. Supercharger BOV possible or immpossible?
  226. Gauging Interest: Poll Insde Forged Pistons
  227. Looky Looky
  228. blow off valves
  229. Question!!1
  230. Got A Question????
  231. Ls1 Maf
  232. How Much HP
  233. TTR Mounts + Ingals Torque Damp
  234. Need Help Please
  235. coolant screw
  236. Downpipe with high-flow cat
  237. What to do/use?
  238. Car Died...Again
  239. Cheap 60#'s
  240. Stage 2 Pulley Tensioner PROBLEM!!!
  241. 300 hp build
  242. Crank Sensor Ring Info
  243. will this gauge work in our cars?
  244. Need Help!!!
  245. Who's modded and has to pass emissions?
  246. 2.0 turbo help
  247. WTB: ARP head studs and Cometic gasket
  248. Vin Code Look up
  249. Stage 2 program
  250. 60 that will plug into the stock harness
