PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. reverse grind issue?
  2. seafoamers... problem?
  3. Trouble shooting enine codes (turbo swap)
  4. new exhaust making strange sounds
  5. opinions on a guage
  6. Need Opinions guys!
  7. Squealing problem?
  8. Hid
  9. Spark blow out?
  10. Spark Blowout, Gapping Recommendations for 2.8" Pulley BRK7e's
  11. Not Sure What To Do
  12. A/C Problem
  13. P0172 rich code !!! MAF ?
  14. Anyone tune near worcester or providence, boston?
  15. Cobalt ss SC problem !
  16. LS4 questions
  17. Help! Rattling Noise!
  18. Anyone in Hampton roads Va (roll pin help)
  19. Cobra H/E worth it or not??
  20. Holy crap can't get roll pin out to save my life
  21. Identifying LSD
  22. looking for opinions
  23. weird sound after turbo swap
  24. pcm flash question?
  25. Help Please!
  26. heat exchanger question
  27. Need help routing hoses for factory H/E
  28. Ordered full ZZP Exhaust
  29. Stripped a torx bolt, and having problems with the Stage 3 Install...
  30. Option B help
  31. The Correct Way to Add Intercooler Coolant?
  32. Can A Moderate Build Get Me To 250HP?
  33. Dual Pass Option B
  34. 06 SS/SC Performance upgrade help!
  35. NE Indiana thread(fort wayne area)
  36. Southeast Ohio mechanic or knowledgeable ss/sc owner needed!
  37. Question about downpipe performance
  38. OTTP Stage 2!
  39. How long to bleed air from heat exchanger?
  40. looks like i have to replace the headgasket
  41. pulley belt problems
  42. is there a how to for changing the timing chain?
  43. Problem with dual pass install
  44. Front Mount H/E Bleeding Air from Intercooler Coolant System
  45. Question... stock blower...
  46. Upsetting dyno day
  47. corpus christi tune
  48. Header and Downpipe
  49. is there a HOW TO for installing ttr trans mounts?
  50. Stage 2 Question
  51. Problem/Question regarding PCM and new injectors.
  52. Virtual Dyno Readings
  53. How long did Intercooler Pump work after banging on it to refresh it?
  54. Quick question regarding lower blower sensor...
  55. what the difference and which is better
  56. Anyone else had this problem????
  57. possibly twincharging...
  58. 07 lsj e85 questions
  59. Trifecta now offering GMS3 OS on 05' IRL
  60. Vibrant header + GMPP Catback? (Sound problem)
  61. Running a little rich stock?
  62. Intense Racing Tuning
  63. Surge tank
  64. Camshaft Position HOW TO????
  65. Having an issue with a couple CEL's (P2122 & P2138)
  66. Loosening the tension on the belt- Help?!
  67. LNF motor mounts
  68. How to make own dual end pass?
  69. meth nozzle size...i have searched
  70. trouble on cold starts
  71. hid issues
  72. LSJ GMPP stg 2 problems...
  73. Zzp cai problems
  74. Heat Exchanger Fans
  75. Bouncing rev/possible tb issue?
  76. 3 Inch Pully Belt Question?
  77. My review on the phenolic
  78. Does the LSJ require valve ajustments?
  79. Cobalt SS/SC
  80. Guess my Dyno numbers, WIN $5
  81. Phenolic spacer with TTR Turbo Intake Manifold
  82. Need your help and opinions please.
  83. Holy crap! Went from stock to 2.8" pulley with actually working intercooler, insane!
  84. 2.25 exhaust yay or nay
  85. Misfire, Empty, Stall... 05 LSJ Turbo
  86. Bank 1 too lean code??
  87. misfire, running rich at wot and stalling
  88. hydro locked... or not
  89. Intercooler coolant level bounces up and down filler tube while bleeding?
  90. Cylinder 4 No Compression
  91. HELP! P0606 after stage 3 kit install on LSJ
  92. Threading plastic nipple into H/E
  93. Tuner in Clearwater FL area
  94. do i need an option b setup?
  95. Spark Plug advise.
  96. SC boost?
  97. Please Help, Got two of four bolts on H/E, need advice, thanks!
  98. Throwing some cel's need help to fix the problem
  99. CEL After Sea Foam, Common?
  100. UPS came today....
  101. ZZP Stage 2 installed today.
  102. Will an hp tune void a carmax extended coverage warranty?
  103. Transmission Rattling
  104. down pipe question
  105. Ticking noise coming from water pump area?
  106. Damn, got ripped off, hoping to salvage my stage kit anyway. Advice please.
  107. AC Compressor Clutch Not Engaging
  108. Advice for Getting Belt Over SC Pulley? (Hands are destroyed!)
  109. vibrant header dp combo
  110. Review: Ingalls Torque Damper
  111. wtf?
  112. Bad News Racing Deal of the Day- Bad Mab LSJ Header
  113. 2007 Cobalt SS INJEN intake
  114. misfire and ticking/rattling
  115. dyno numbers, quite disappointed
  116. Tune with no mods - worth it?
  117. Badmab header question
  118. new car, where is this hose
  119. gm performance division plate
  120. Stiegemeier Supercharger Mods
  121. Tuning in Southern NY!!!
  122. Will this pump fit the cobalt 2005 ss/sc?
  123. ZZP Stage 2 vs. GM Stage 2
  124. TVS & E85 suggestions and questions
  125. Accelerating issues..what do u guys think?
  126. head gasket replacement
  127. M62 - 2.4 Pulley shenanigans
  128. fuel gauge reading backwards
  129. Bleeding your new clutch?
  130. pointers?
  131. Weird grinding coming from engine
  132. Making my own heat exchanger
  133. My intake
  134. E-85 ?
  135. Meth Nozzle Placement
  136. Tune help VE LTFT scan -50?
  137. Stage Kit Tool
  138. problem with my car :( can you help?
  139. ZZP pcm help
  140. catless or cat
  141. lsj cams
  142. 2006 ss w/66k miles burnt valves
  143. Another Slobalt goin to ZZP :D
  144. $$Money to spend what to buy?$$
  145. Clutch/transmission
  146. option b question
  147. stroker lsj build
  148. HELP! No interior lights
  149. Torque Dampener and Engine Mounts
  150. Boost Issue?
  151. Need some help
  152. OTTP Canned Tune
  153. Fuel pump options
  154. pulling the lsj and putting in lnf
  155. Where the f is the oil filter lol
  156. option B tank - what to do?
  157. clutch problem/ engine problems
  158. 60lbs with ZZP Boost Reference Fuel Pressure System
  159. lysholm build from hell pt 1.5
  160. Pulleying down, opinion's needed.
  161. What to tap for boost port on meth controller?
  162. SuperChargedMA Project
  163. IAT2 seem high with these mods
  164. Best exhaust?
  165. Turbos, tuning and options
  166. Gauge?
  167. ZZP Blower Spacer ?'s
  168. Swapping out the LSJ for another LSJ - help?
  169. tranny
  170. Rough idle with A/C on?
  171. Autometer Boost Gauge T Fitting Is Junk
  172. IC pump?
  173. Year-Round tires
  174. Injen intake & corsa exhaust
  175. lsj cam question
  176. Option B Plug ?
  177. Most cost affective turbo kits for LSJ?
  178. Reverse Light Delete
  179. Stop the rattling!
  180. Anti fouler mod
  181. Idol bouces up and down when coming to a complete stop
  182. compression/head gasket/piston rings
  183. Best header/down pipe for me set up?
  184. Hose sizes?
  185. ZZP Battery or Autozone?
  186. ic pump meziere
  187. New Tuned PCM for 2.8 Pulley, Do I need Case Learn?
  188. Intercooler
  189. Please Help: Car's in pieces need to swap idler pulley
  190. Cleaning the LIM
  191. Shifting issues
  192. RAW Stage 1 Install Guide Anywhere?
  193. ZZP intake?
  194. p0098, p0480, p0532
  195. How Refined is ZZP S2
  196. motor swap question
  197. Make your own Option B Kit Cheaper!!!
  198. Power source for gauges?
  199. Help with timing tensioner/chain!!
  200. 2006 cobalt ss rough idle at startup
  201. Lost 2nd gear and 4th is sloppy but still there
  202. Heat exchanger sprayer
  203. clutch failing
  204. Quick Question
  205. Overheating problem!
  206. Performance Build questions
  207. 2.0 Ecotec motor cut out at full throttle.
  208. A little Help/Info
  209. lsj turbo swap from lnf
  210. zzp dual pass...leaks
  211. Cylinder head compatibility question
  212. Pulley size
  213. zzp pcm HELP PLEASE
  214. IC pump confusion
  215. 07 sc starting issues
  216. stroker 2.4 lsj
  217. ZZP DP and Catback
  218. people going to ced
  219. Heat gun + tstat = ???
  220. Short ram intake MAF location?
  221. methanol mixing from washer fluid
  222. Local hp tuners
  223. Can somebody get me a picture please
  224. Injectors
  225. Intercooler pump install
  226. Need some help
  227. Good Muffler Replacement for 07 LSJ?
  228. Gotta love ZZP
  229. help finding a supercharger pulley puller
  230. videos of ZZP Longtube w/ stock exhaust :) 0-100 as well
  231. ok i need some advice!!
  232. 3" Downpipe/Corsa touring
  233. ZZP Over Sized Tensioner help!
  234. 2006 Cobalt SS/SC belt squeal
  235. Corsa Cat-Back
  236. Car stalls with clutch engaged...
  237. Finally my car is not stock
  238. Fuel rail supercharger emblem
  239. knocking noise
  240. Spark Plug (PIC)
  241. stock 06 cobalt s/c vs. stock s2000
  242. pcm troubles, i think!
  243. Stage 2 on 154k Drivetrain?
  244. Post pulley/hub swap questions
  245. OMFG Someone help!!!
  246. Can't find a GMPP Exhaust
  247. zzp 3" exhaust review.
  248. tvs setup with 2.7 on stock internals
  249. cobalt ss sc boost problem
  250. zzp intake spacer
