PDA
View Full Version : 2.0L LSJ Performance Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. ahhh, another dumb question
  2. Lil Help W/Spark Plugs????
  3. Question: performance stage 2/2007
  4. overheat maybe?
  5. Almost done installing, last Q
  6. header
  7. Exhaust
  8. Need Help With Engine
  9. o2 simulators
  10. Doors!!!
  11. a stupid idea?
  12. Need Help!!!
  13. Need Help!!!
  14. UGHHHH launch help?
  15. Magnaflow Muffler
  16. Intakes with NO CODES on stock 06 SS S/C.
  17. Injen intake
  18. Installed GMPP exhaust, got a question
  19. Chilton and Hanes manuals
  20. Need a Tuner around Palm Beach or Miami!
  21. CEL for lean?
  22. Blew up my car!!!
  23. Starting my 2.8"/50lb project soon: suggestions!
  24. GM dealer says there is no 7k rev adjust on stage 2 kit?
  25. ebay intake
  26. Near void warrenty caused by K&N CAI
  27. Magnaflow Muffler
  28. what is better?
  29. Need a Tuner!
  30. Heat Exchanger Options
  31. Better Gas Mileage after CAI?
  32. Victory_Red_SS' project gets closer.
  33. Stage 1 Flash
  34. i feel dumb asking but what is the G85 package?
  35. Oppinion Best Bang for your Buck
  36. water/ meth question!!!!!!!
  37. Water/Meth Injection Questions
  38. 8x1.25mm pitch threaded rod pulley, Stage II help please...
  39. Back in a loaner
  40. HP tuners
  41. couple of 2.0 ?'s
  42. Blower Wine vids anyone?
  43. 3.0" Magnaflow Cat
  44. Gauge install help
  45. anyone know who sells aftermarket guages for ss/sc!!!
  46. CA front mount HE/Dual pass intercooler plate
  47. supercharger question
  48. E-Brake Cable Flies off!!
  49. What size exhaust?
  50. Where can I get the eaton m-90 Supercharger online?
  51. Aftermarket Syncros
  52. GMPP Stage 2 are they 42lb injectors
  53. Winter rims and tires
  54. I need suggestions on mods............
  55. GM Performance Air Intake Kit
  56. CF Injector cover
  57. Dyno Graph I/E/Stage2
  58. CA TRACTION BARS vs Ingalls Torque Damper
  59. huge delema with my twincharge kit!! what do i do?
  60. water meth kits on e bay.
  61. Intake Help... I know this is getting old...
  62. Vibrant Header
  63. has anyone had their warranty voided for...
  64. 2.7 Inch = Failure
  65. Warrenty or No Warrenty?
  66. 2.7 Pulley
  67. Cobalt SS/SC with BOV?!?!?!?
  68. difficult decision...
  69. New Toys
  70. good hp tuners info.Long.
  71. For those without cats.!!!
  72. Spark Plugs For This Set Up?
  73. centri vs roots vs turbo
  74. Cobalt Addiction Down Pipe
  75. CA stage 3 vs Intense Stage 3
  76. Oil Change Confusion
  77. 2.0 valve cover gasket ....is it re-useable
  78. Cold air intake help
  79. Cold air intake help
  80. Performance hi-flow resonators?
  81. Dezod Exhaust Problems!
  82. straight pipe?
  83. dp question
  84. Air Intake on E-bay
  85. Just Installed Stage II (Install Thoughts)
  86. 50lb injectors on 2.8" pulley
  87. Whipple or Turbo?
  88. B@M 2.0 shifter to 2.4
  89. What size is the stock pulley
  90. Stock exhaust & down pipe
  91. GMPP S2 help!!!
  92. pully choice help..
  93. Technical Question
  94. GM Upgraded Aftercooler
  95. Muffler Question
  96. Hi flow cat
  97. Magnaflow Question
  98. Winter Driving
  99. needing a lil help!!
  100. For those WITH water/meth injection
  101. What do you prefer 06 or 07
  102. Quiet Header/DP
  103. Looking for a header to use with stock DP - suggestions??
  104. when ur cars of, wat does u boost read
  105. aem wideband install
  106. Stage 3 "Bang for the Buck?"
  107. ARK DT-S Exhasut
  108. 2 thumbs up for gm performance catback
  109. Anybody try GM Stage 3 kit yet?
  110. Limited Slip Diff
  111. AEM Cold Air Gains??
  112. For those without water/meth injection.
  113. Should i get Extruded Honed Performance Exhaust Manifold
  114. Bolt's on pulley removal
  115. GM STAGE III Kits now shipping from CRATE ENGINE DEPOT GO NUTS!!!!!
  116. TWINSCREW, need help with unit ID (Will This work?)
  117. Need Help
  118. Hitting the Rev Limiter to Hard-
  119. pistons and rods
  120. Question about warranty
  121. Pulley removal probs
  122. Dyno results for 2 pass intercooler plate???
  123. SAFC2 Question
  124. GMPP performance exhaust
  125. Does a Bad Clutch = Loss of power?
  126. Stage 2 Dyno vs Stock... Before and After
  127. Spark Plug question
  128. Dynoed the cobalt
  129. 05-07 Stage 3 has been released
  130. HELP! Tuning Question
  131. Check your FUSES!!!
  132. K&N Drop in
  133. What header/down pipe should i get?
  134. SS S/C = NO Start Help!
  135. SS S/C = NO Start Help!
  136. SS S/C = NO Start Help!
  137. Mini AFC 2.2
  138. fujita hookup question need some help
  139. Thermostat and other torque specs
  140. GM performance vs touring
  141. 108 Octane boost
  142. Help! Vibrant Header Install
  143. Which Clutch to use with a Stage 3?
  144. Ordered Stage 2
  145. A few things..
  146. need exhaust help
  147. Anyone change their fuel filter yet?
  148. so you asked for them
  149. J-Body PErformance 2.0 Camshafts
  150. Speeds at redlines
  151. Ss/sc
  152. Black Rotors?
  153. Proof Staged Kits Does Not Void Warranty?
  154. new exhaust
  155. SS/SC concerns?!
  156. goign to the track help
  157. Impotance of a DP
  158. nherbst 2.7
  159. Need help choosing correct pistons for my build
  160. GM Stage 3 Install Questions
  161. Stage 2 w/2.8" vs. Stage 3
  162. PCM Swap
  163. (HELP!) Logging with the AEM wideband
  164. GM stg. 2 v.s Intense stg 3
  165. Hesitation in 2nd gear!!!!
  166. Pacesetter Full exhaust????
  167. drop in filter
  168. fluidyne heat exchanger
  169. Is anyone else having issues with the stock NGK's ???
  170. fidanza flywheel
  171. cai and exhaust
  172. Hahn downpipe, how much$?
  173. Looking for 2.5 pulley
  174. Will an 05-06 K&N CAI work for an 07?
  175. GMPP Catback!!!!!1!
  176. Santa came early!
  177. Possible help (not fix) for our clutches
  178. GM Stage 3 pulley
  179. gear promblems?
  180. What running lean will do to your stock mahle pistons!
  181. Muffler...what type has good flow but not super loud!
  182. Check out this Desired Customs Ion RL
  183. sswweeett 2.9 pulley
  184. What Gauges Do i get for my ss s/c
  185. CA heat exchanger
  186. 1 Stage Colder Plugs
  187. High perf GM cams?
  188. air box upgrade?
  189. Xtc front mount cold air intake?
  190. Stage 2 cost??
  191. hard launch
  192. I need a tune!!!!!!
  193. In relation to air box mod
  194. New toy.....
  195. SAFC - neo
  196. tuning on a stock 2.0
  197. Back from Stiegemeier
  198. shifting.
  199. anyone use CA stage 1?
  200. Good price on Exedy Clutch?
  201. $1000 to burn
  202. has anyone dynoed B4 and after GMPP Exhaust with stage 2?
  203. hp tuners
  204. MAF Tranz?
  205. pulley power
  206. what to buy?
  207. How much do you all love your cobalts??
  208. AEM Wideband 250 shipped!
  209. AEM dryflow cleaning
  210. Free Mods for SS/SC
  211. Turbo SS
  212. Dropping the supercharger
  213. Mystery clutch noise...
  214. Boost leak?
  215. Four door SS?
  216. Wheel Hop = broken exhaust
  217. New to the cobalt ss/sc
  218. Are The Tog Headers And Good?
  219. Meth Questions
  220. Oil madness?
  221. injector questions
  222. My next mod
  223. Official LSJ build guide (**sticky please)
  224. 300whp
  225. HAHN header?
  226. GM Stage 3 parts avail.
  227. diamond racing pistons
  228. Twincharging
  229. Carbon Fiber Intake?
  230. Electronic Cut Outs
  231. i got a qucik question!!
  232. GM Stage 3
  233. wondering about boost
  234. ARK N2 exhaust system for ss/sc
  235. Removing STG 2 Pulley
  236. honing stock LSJ exhaust?
  237. Pics Of My Twincharge Kit!! Enjoy!
  238. pulley puller rental? Buffalo NY
  239. Drop in K&N filter
  240. Do people really buy this junk?...
  241. DC SPORTS Catback Exhaust
  242. P0102 with New intake...how to fix?
  243. Lean CEL W/ Intense 3
  244. Questions answered?
  245. Vacuum..?
  246. HP and Tq with all the GMPP stuff?
  247. HP and Tq with all the GMPP stuff?
  248. Just installed gmpp exhaust
  249. sky redline engine swap
  250. 2.5" pulley or 2.6" pulley that is the Question.
