- Is this an attainable goal?
- What is normal boost at idle?
- XTC FRONT MOUNT Cold Air Intake
- Stoker Kit?
- Gear ratios REDLINE vs SS
- Exedy Clutch!!!
- 2.5" Pulley and Belt Slip
- Dont know what to get
- Top Speed Fuel Cutoff???
- need the following
- Guess what just showed up from UPS!!!
- 2.8" Pulley
- Ever run in COMPLETE bypass mode?
- Help in choosing a muffler.
- Welcoming another Red 06' SS/SC
- Experienced Knock Need Help
- $4000 to spend
- Stage 2 Worth it?
- Anyone hear an actual availability on JBP CAI?
- Sunoco 94/10% Ethanol Problem- A Solution
- 2.8" Pulley Boys install
- AEROFORCE Interceptor Tuning Discussion "What readings have you been getting"
- intense Stage V
- Got the sportlines
- House of the SS automobiles (Cobalt SC and 70 Chevelle CONVERTIBLE)
- Header/Downpipe Combo
- Project Update: victory_red_SS
- Installing 2 new guages help?
- Diso some info on K&N intake
- Dyno Results pics inside 56K twidle them
- question about header install
- AutoStart feature you don't know about
- injen intake
- Anyone know if...
- K&N filter not fit tight in the air box normal ????
- Great Cheap "mod"
- ah theres the s/c
- 3.0 Pulley??
- you think legit?
- What octane gas?
- Resetting Oil timer?
- Should I be running a colder Plug?
- Pictures of LFP Extreme HE for Cobras...
- anyone have any info on those adjustable cam gears?
- Injector Questions?
- Considering Cobalt SS/SC...
- Need CAI FAST!!!
- Rumor - Warranty
- give me some advice here??
- head work
- stage upgrades
- Intense Header/Downpipe?
- boost problems?
- anyone w/g85 NOT have a sunroof ??
- Bosch Spark Plugs
- Free Zz Puller Rental ! ! !
- Pulley questions
- Stock Dyno
- Clutch brake in ?......HELP.
- Gm Stage 2 Pricing
- Will Pacesetter 2.5 exh. fit 2.0 liter SS
- tensioner help cobaladdiction.com
- gm stage 2 kit
- ZZP vs Intense Pulley Set Ups
- Intake Nightmare
- intense stg 5 0-6 and 1/4mi?
- Boost Gauge not working
- Blower Color?
- Twin charging....why?
- M90 to 2.0 adapter
- CAI Filters?
- nos
- grand am axles
- Shift point
- What happened?
- Blow off valve for Supercharger?
- front mount intake
- will hp tuners kill my warranty
- alky injection installed, less boost?
- Airbox Silencer?
- XTC intake install issues
- How much HP will I be pushing???
- 2.0 liter vs 2.4 liter
- Injectors q&a
- a/f gauge
- Gravana Offering 2.0 SC Headers
- dyno tune or hp tune
- Look at this rocket scientist on ebay...
- Why dont they.... (heat exchanger/aftercooler)
- will a tune fix....?
- Intake.....suchh a headache
- Up and coming company for LSJs!!!!
- 3" pulley ?
- here we go...
- Prices on full stage 2gm installed by gm?
- Pluging Boost Bypass with higher Boosts
- Columbus,OH! Anyone have a stage kit
- Which do you prefer as an upgrade?
- Lightning Force Performance HE
- Intense Stage 5?
- Intense STage 3 Lean Code
- What should I do? (Thread about Intakes)
- 2.8 Pulley only runnin 15Lbs
- Will my boost improve?
- Cobalt SS/Sc in Montreal
- Wiring
- Stage 2 in DC Area?
- Money well spent
- Just got HP tuners
- Will I Have Fitment Issues
- SS Supercharged Cobalt MAX!
- Stage Kit on e-bay.
- Just a pulley?
- Cobalt SS/SC Twincharger Update
- Anyone add a second stock heat exhanger up front?
- Found a place going to start making and selling stuff for the LSJs!!!
- Lean code
- Time for a clutch
- 6 speed manual why?
- looking for a weapon r longtube
- Kind of pissed........
- Stock Spark Plugs
- I Also Have A Question!!!
- i HAVE a question
- heeheeheeheeeee
- biggest rim size on ss/sc
- intense pcm case learn?
- Just had Stage 2 installed
- monza exhaust by pacesetter?
- Quick Exhaust Question!
- How restrictive is the stock catback?
- Seriously thinking about twincharging...thought on turbos
- Newcomer
- New GM Rotors?
- Newbie
- Most Power
- how many people got a cel with injen?
- GMPP cat back question
- Stage 2 Calibration/CARB Sticker Needed
- 06 black s/c ss wheels
- Who has GM Stage 2 in stock?
- I have GM Stage 2, should I go 2.8" or 2.7"?
- gm stage 2 or intense stage kits?
- New SS S/C Owner with Questions (Need Help)
- Is the shorter belt available from GM yet?
- 14.7 afr help
- SS instake question
- Question?
- Got hit...
- Installed 2.8" Pulley
- Need Help Removing CV shaft from Transaxle.
- Map 0-5V
- Trans problems
- help w/ T.P.S.
- What a difference 10 hours makes!
- Engine warmup
- I/E Stage 3 Dyno
- Does anyone know why....
- Stage 1 or Stage 2?
- K&n Cai
- GM Stage 2???
- these injectors plug & play (accel)
- magnaflow muffler
- What Parts Would I Need?
- Header, Downpipe & Cat Back
- HP Tuners Explanation?
- Bad grinding on left turns
- Stage Ii Let Me Down!!!!!!!!!!!!!!!
- Invalid authorisation code
- Intense PCM.....Has Problems
- This is like a whole new world
- SS/SC n00b questions.
- a little birdy has told me a turbo kit is coming...
- Dont Hate - Does 2.0L have intercooler stock
- First time Stick Driver...HELP!
- Has anyone done this??
- *BilletFlow Summer SALE*
- aem dryflow
- Valve Cover ?
- 2.8 question
- Oil Change
- 2.8" pulley boyz for GM stage 2
- shifting into neutral without clutch
- 15mm Open End Wrench not workin
- Powerslot Rotor Part Number?
- Drop in k&n VS full intake replacement
- Exhaust GMPP Tip question.
- Shut down procedure?
- anyone got a pic of the cobalt intercooler off the car
- sky trannie?
- Corsa Sport W/ Vibrant Header & Downpipe!!
- Exhaust Piping for $ale
- Questions
- Fast People in here (12sec or less capable)
- Injen CAI question
- Stock Injectors
- Pulley Swap NOW
- Walbro Fuel Pumps
- How long should the engine cool before spark plug change?
- 42.5 lb/hr Injectors Maxing Out
- Adjusting IFR with HP Tuners
- Muffler problem on SS/SC?
- m62 to m90..how about it INTENSE ??
- oil breather
- Another Dead Aeroforce Gauge
- Boost gauge reads wrong
- Incorrect PSI
- Questions on GM stage tune and 2.7" pulley
- 2.0 minus the supercharger
- Car died todAY
- Cel???
- so why are full length intakes so much better
- Adding exhaust to Stage 2 w/ 2.8 (Will it make a noticeable difference?)
- Boost gauge install
- tried to do a lil top speed run and...
- Stage 2 or wait?
- cleaning maf
- question on stage 2 and the gapping of the NGK?
- XTC and ease of covering it up
- ZZP downpipe leaking!
- CASE Learn prices
- Clutch Install Hours?
- Small issue
- Cobalt addictions 3 inch downpipe w/cat VIDEO
- 2.8 pulley and stage 2 user feedback please...
- what size pipe?
- Who can make adapters for us? (Pic inside)
- Whose Redline is this. Check out the Supercharger
- 2.8 pulleyboyz installed question...
- Pulley removal/Stage 2 question
- Need some POWR!!!
- K&N install query
- Installed Sparksss
- YAY!!! 42.5 lb Injectors Installed :)
- My 1st mod
- K & N Air filter
- Here we go again....
- Quick Question
- GM Stage 2 Install Prices
- gm accessory catback
- ZZPerformance Exhaust Section
- 3" Pulley
- What kind of fluid do our manual trannies use and how often should they be serviced?
- Black SS with Rksport
- Three step performance program
- Charge Air Cooling System - 3D
- Stage 2 + 2.8 + Colder Plugs
- performance
- AEM Wideband
