PDA
View Full Version : Electronics, Audio, and Video
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. speaker wire advice
  2. Need some help...
  3. Tweeter Replacement in SS?
  4. Power Inverter for PS2
  5. factory Nav
  6. Antenna Adapters...
  7. "Blown Speaker" Issue
  8. help!! custom made subwoofer grills
  9. XBOX 360 in trunk... Help...
  10. Amp recommendations?
  11. Backup Camera
  12. Help needed - middle of install GMOS_LAN04 and rewired front speakers
  13. what are the best subs for in a cobalt?
  14. Help on installing a Raptor Shift Light on a LNF
  15. gauge suggestion
  16. Problem with speedometer
  17. Need wiring help for a light
  18. HID Help
  19. 2nd sub?
  20. No turn Signal Clicker sounds after installing the oem deck.
  21. some of my other boxes ive made
  22. just need some quick help on wiring subs to an amp
  23. opinions wanted on brands
  24. Replacing rear speakers in my ss/tc
  25. What is wrong with my stereo install? Radio keeps turning on/off at random?
  26. My new box
  27. Cant play music videos/DVD's on p4000
  28. Front and rear driver side speaker wtf
  29. gauges help
  30. Not exactly car audio but...
  31. 09 headunit in a 07 car, how?
  32. Where do they sell pressure clips?
  33. Head unit help for my '05
  34. Custom Sub Boxes.
  35. Spedo doesnt work :/
  36. Dimming Problem
  37. How do I find my FCCID for my keyless entry(06cobalt SS)
  38. What's a Car Already With RPD To Do?
  39. Want New speakers just cant decide.
  40. opinions..upgrading subwoofer
  41. RE audio..
  42. factory nav/dvd player
  43. factory dvd player
  44. Please reply! Water ruining door speakers
  45. any suggestions?
  46. Jensen BT1611i
  47. Blowing the 10AMP Radio Fuse.
  48. box design help
  49. New nav unit, watch out Europe
  50. Double Door, Turn Signal Chime?
  51. amp/sub help
  52. AVH P3100DVD Questions
  53. OEM CD player skips
  54. Termometer
  55. New head unit.
  56. need a audio guru
  57. Clarion CZ500 on factory speaker and sub
  58. Bluetooth connection issues on your 08-10? look here
  59. TACH WIRE for remote starter on 09 cobalt LS
  60. DDM HID Kit Wiring
  61. Installing an avic d3 into 2006 SS... VSS?
  62. Suggestions?
  63. Hooking up a pioneer avic d3, is this the right harness?
  64. another HID problem
  65. Sub cuts in and out, clipping?
  66. IPOD with 06 SS/SC OEM Stereo
  67. Big 3 again lol
  68. Component speakers
  69. steering wheel question
  70. hids still flicker?! wtf!
  71. JL Audio Clean Sweep
  72. Subwoofer Wiring?
  73. im confused...
  74. Break In
  75. retrofit headlights
  76. I have this new HU and a color question...
  77. WHere do you put it?
  78. Big 3 question
  79. air bag weight sensor in passenger seat
  80. another HID thread
  81. Apparently im retarded, amp clipping need help!
  82. Headlight bulb
  83. Door Chimes & OnStar using aftermarket stereo and Lan04 harness
  84. Whats wrong with This
  85. stock boost gauge
  86. Blown Fuse Help?
  87. My HU is being retarded
  88. WOT box help
  89. New speakers.
  90. Driver side speakers front and back no sound
  91. Is it worth getting new speakers?
  92. Car Stero Setup Questions
  93. Weird Headlight Problem
  94. New Subs!
  95. Causes of muffled speaker/no treble?
  96. Battery Venting
  97. New Doube 1/0 ground
  98. please explain why fuse tap is needed?
  99. XM radio.. please help
  100. alternative to dynomat
  101. peel and seal??
  102. dynomat placing
  103. 2 way alarm/remote start /aftermarket locks + keyless entry install
  104. rear speakers 6x9
  105. Alt whine+Wiring question
  106. Anyone install the Isimple?
  107. new system
  108. Do I need a databus for alarm install?
  109. One Sub wont work
  110. SSA spectrum question
  111. Double stock subs...
  112. sound deading?
  113. Speaker works half the time?!?!
  114. help please
  115. Sub Enclosure Suggestions
  116. A few pics of the custom box I made...
  117. Aftermarket HU + External amp = do i still need to amp bypass?
  118. lets c ur head units
  119. NEED REPLY ASAP Wiring Interface
  120. AC and Defroster Panel Help!!
  121. installing sub and amp
  122. Help with aftermarket sub
  123. stereo set up
  124. aftermarket deck
  125. Working on a Project: Need Input
  126. 6x8s?
  127. radar scaner
  128. new headunit help
  129. HID problem
  130. ECU help
  131. can anyone help with this problem
  132. Need Help With SWCI
  133. My new HU
  134. Amp help, strange noise
  135. battery help.
  136. Replacing stock sub
  137. Touch screen reciever?
  138. Aftermarket Amp with oem pioneer sub.
  139. RPM reading for shiftlight help
  140. Stereo NOOB here...need help/info!
  141. Replaced my Pioneer fronts with Infinity References
  142. NEED HELP...cd player says locked
  143. HID help
  144. Got it in..
  145. HU Grounding
  146. Speaker wire diagram???
  147. stock sub
  148. Need help trying power antenna install with factory radio.
  149. stock amp help
  150. Need some battery help!
  151. What went wrong?
  152. socket size?
  153. Opinion Needed.
  154. R vs. P
  155. Sub help..
  156. amp ????
  157. It Fits!
  158. E-60 Retrofit issues.
  159. will an 09 Factory Head Unit work in my 07?
  160. help picking cd receiver!
  161. Its not a Cobalt, but...
  162. SS/TC Factory Rear Sub Gain Adjustment?
  163. Damn it!!!
  164. Olympus OLM2412
  165. Stereo=Keyless Entry Issue
  166. Am I getting ripped off?
  167. Help With Head Unit Install
  168. Audio plans
  169. Rattling noise
  170. Speaker installation help
  171. I need help im going nuts!!!!!!!!!!!!!!
  172. Big 3
  173. EmpJJ Center channel build
  174. Amp question
  175. Pioneer 6500 Deck any good?
  176. Where To Mount Ballast For HID P&P kit
  177. Subwoofer help
  178. Ok Im stumped...
  179. New rear deck! pics* what do you think?
  180. Hardwire a radar detector
  181. Aftermarket hu help
  182. Alpine IVA-D100
  183. vibration
  184. help me out please!! hard wire h/u
  185. a guide for no the harness?!?
  186. New Subwoofer Setup..
  187. Car audio help
  188. Help H/O Alternator
  189. dvd
  190. Best Head unit?
  191. quick radio question
  192. URGENT Install Question
  193. )( radio in an 07?
  194. Which Harness to get?
  195. wiring head unit
  196. speakers
  197. Annoying Rattle on the Panel above Rear Seat
  198. installing aftermarket pioneer h/u
  199. After market Head Unit Install HELP
  200. i need help asap
  201. The New Scosche wiring harness'
  202. Amp/Sub help
  203. Jl w7
  204. which sub should i get
  205. stock pioneer amp in base cobalt HELP
  206. Wow.
  207. Will a single 4 ohms 10" sub works as a replacement for the stock Pioneer system?
  208. Aux input - Sound from only one speaker.
  209. Corvette loses it on the freeway
  210. invisicord install on 2010 ss/tc
  211. D.I.C in 2007 cobalt ls
  212. Car Audio Sub HELP!
  213. Need Help! Think my amp is DOA
  214. I need help asap
  215. help with steering wheel radio controls
  216. radio stopped working after pulling fuse
  217. Question about sub box fitment
  218. Amp problems
  219. Subs and Amp
  220. Disable Auto Lights
  221. i have a dash kit and harness for ss
  222. Rattle Elimination Tips and Tricks
  223. Tweeters no worky?
  224. Pioneer AVHP5000DVD
  225. Directed 689M
  226. Stereo Gurus: I Need Your Help.
  227. Blown speaker?
  228. Electrical help Needed
  229. Installing speakers and amp
  230. Beware of in-line fuse holders that aren't sealed...
  231. Sub in place of spare?
  232. installing my components
  233. 1/8 inch jack install in an '06
  234. Factory Boost Gauge Reference...
  235. Will the radio open ZIP folders?
  236. is it easy to hook up the aeroforce gauge?
  237. remote start problems
  238. Will this work
  239. Need help picking an amp...I'm a stereo n00bie
  240. Stinger Volt Meter Install
  241. 07 LS 25K - Heat Issues
  242. radio has no sound
  243. Pioneer 4100 wallpaper
  244. PAC uPAC-GMII iPod/HD Radio Interface...Anyone Rocking it?
  245. head units
  246. hey guys hows this.
  247. Short??
  248. fog dark spot, possible ugrade??
  249. Alpine type R vs. Other subwoofers
  250. help with head unit installation
