View Full Version : Suspension
- okay so i need new front rotars...where to go??
- winter
- brakes are very loose
- Help...
- Strut Tower brace and Rear ARB...
- Darn that Rusty Bolt
- Getting an Alignment
- Installed R1 Concept Premium Rotors
- for those with rear drums
- quality ride
- I got something from fedex.
- funny noise
- Wondering: Caliper Brake Covers?
- 09 Cobalt SS/TC Loud Screetch When Braking
- Brembo Swap LSJ
- would these fit
- do u need camber kits
- Brembo replacement rotors for 2.2? (rear drums)
- im worried my ishaft isnt connected right
- springs help
- Brake Cooling
- Lowered Car Clunk,Steering Rack Spacer Question
- need help with this part! picture inside,
- Strut bar ?
- Question reguarding Powder coating SS/TC brakes!
- What other cars share same hubs/knees with calipers?
- sleeve on coilover
- Lowering
- HELP!!! with install
- Bremo Front Brake tool needed
- ZZ Performance strut-bar/LNF Intake clearance
- koni cup challenge suspension
- adjusting ebrake tension
- e brake
- does this sound right?
- tire and service FAIL
- Look what came in the mail today
- anyone have a good estimate of how much the stock SS/SC springs weight?
- A-Arms Bushings... Stock or Aftermarket???
- sportlines.......
- Good price for Sportlines??
- Camber plates?
- lowred my car and need some help...
- strut stud snapped
- question about sportlines
- sportlines question
- Rear brace
- DO i really need a rear camber kit?
- pictures of stance and what you have installed
- Proper bleed/flush procedure for changing all four rotors/pads/brake lines?
- Suspension Problem
- CA K-sport 36 way Fully Adjustable True Coilovers?
- SS/SC spring problem
- brake help
- Caliper paint and B&G springs
- Lowering Springs and Corsa Exhaust
- I need struts....
- What can be done?
- Strut Bar
- H&R Noise
- Best way to lower the 06 Cobalt ss/na
- Question about brakes on an LT?
- i need some help....
- SS S/C Leaking Brake Caliper
- Sooo I need new brakes...opinions?
- Hawk HPS pads - mini review
- Tenzo vs Eibachs
- Converting SS/SC FE5 to SS/TC FE5
- B&G coilover help...
- Shock Torque Specs
- I think i got a ripped off on an Ingalls Torque Dampner
- help w drag bags
- Coilovers for my 2009 Cobalt SS/TC
- Odd Steering Problem
- Is $300 for rear lower control arm bushings a lot?
- Rotors/Conversion Dilema
- coilovers?
- Blown Front Strut WTTFFF
- TC Struts
- Strut tower brace or other chassis stiffening mods?
- Lowering a SS/TC
- Progress Springs
- Rear but no front?
- How do NON-SS struts hold up to Tenzo's
- coil overs or lowering springs?
- Coil overs or lowering springs?
- anyone ever shortened struts?
- Air ride kit, is it worth it??
- SS s/c with SS t/c springs??
- Steel braided lines worth the $ & trouble? & other brakes ??s
- happy wit sportlines ride and drop??
- bad cv joint? w/ pics
- Wheel Bearing Replacement
- looking for new endlinks
- official pro kit thread
- OTTP Hardcore Brake upgrade.
- 2.0 struts/springs on 2.2
- stupid tabs
- h and r or sportlines
- what springs should I get?
- What springs do I have??
- Will Koni fit on an 09 SS/TC?
- spring, strut, and coilover Q's for TC
- Z06 Big Brake Kit
- just wondering.
- Just put my progress springs on and,,,,
- Minor clunking?
- sportlines on 07 ls
- replacement brake rotors
- how should i lower the ss
- Installing all 4 brakes and lines..??
- tires are wearing in from the inside what might this be??
- CA Brake Kit Anybody..??
- New Pads and Rotors on the way!
- Traction Bars on a TC
- Installed KW2's on a 2008 SS/TC
- BC coilovers from MP whos got em?
- Lowering Springs Comparison
- Ideas and Help with a problem
- Painting Calipers and Drums...help me out.
- how to tell what kind of springs I have
- brakes are'nt pumping up properly...help!
- what aftermarket brakes to get
- quick question
- Good vendor to get brakes from
- Lowering your car?
- Need Help For The Rotors
- steering knuckle question
- 06 Cobalt ss 2.4 need help with spring choices
- Progress Springs on the TC!
- Control Arm Bushing???
- Coilover Adjustment question!
- Alignment Problem
- Any advantage to a more aggressive front allignment on a SS/TC
- Best lowering springs?
- painting calipers
- Tein Suspension
- Coilovers Installed....well Kinda
- SS/TC strut ???
- Adjusting the e-brake?
- Alignment Question
- Mushy Brake Pedal
- NEW B&G Coilovers, Pillowball Camber Plates, and Endlinks from Gravana!
- Dealer Help NOW!!!
- Warning! - Caliper Slider Bolts
- conversion kit for rear brakes
- KYB GR2's - where to buy?
- FE3 Cobalt Suspension same as G8 Suspension?
- H&R Springs
- Rear anti-roll bar?
- has anyone ever bought these brakes before?
- Suggestions On Break Pads & Rotors?
- sportlines?
- TC Stock Struts
- uh oh!
- Sportlines one side lower than the other? Help..
- B&G Suspension Camber plates and Adjustable Sway Bar endlinks now available
- street sport industries?
- Eibach Sportlines?
- Help !!!!
- lets start an offical slammed thread .......
- Should i drop
- help
- Rear rake problems, i got answers...
- LS With Sportlines? will it work?
- quick question
- KW2 Coilovers
- 2009 Cobalt SS rotor size?
- monroe shocks and struts
- converting your bolt pattern
- Monroe Strut Mount?
- I need help
- GM replacement rotors
- more 09 suspension ?'s
- Coilovers To Last Forever Huh?
- Suspension Setup Help
- Which coilover should i go with?
- Feeler Pillow Mounts And Camber Plates
- HELP PLEASE! Rear caliper piston won't go over new pads
- B&g
- coilover alignment specs
- stage 1 axle question?
- EBC rotors and pads
- H&R Springs (Handling)
- axle help??
- ZZP axles.
- replacement axles??
- H&R Springs
- Rear Caliper Piston help ASAP!!!
- Loud thumping when turning
- Rotor Comparison: OTTP Hardcore vs. SS/TC
- Eibach Sportline springs?
- Installed H&R springs today
- Ksport Coilovers - GT Pro Damper System
- Anyone selling any low mileage FE3/FE5 shocks/struts for cheap?
- FE5 suspension question?
- Friction Masters
- torque dampener
- POLL- What springs to get?
- Big Calipers - Cobalt, Redline
- Brake information
- Replace shock
- Where to get swaybars.
- will 08' brembro calipers fit on an 06' ss/sc
- sounds like crap
- strut mounts
- Suspension right?
- SNEAK PEEK: OTTP Harcore Big Brake upgrade!!!
- adjustable tubular control arms
- K Sport coilovers
- REALLY NEED HELP BY 2PM central
- Question...
- Tokico HP or D-spec strust out yet?
- will these fit?
- Eibach Vs Progress?
- OH SNAP!!! Its been done!!!!
- Whats the Best brake kit for my 07 2.4l
- Show me pictures please!!!
- eclispse vs cobalt in handleing
- new springs...
- Floating feeling
- front sway bar
- Interior body brace?
- how much lower does a lipkit make your car
- Koni yellow inserts question
- thinking about giving my car a drop
- Just made the purchase - MR Coilovers
- whos got a pic of this?
- My car has the shakes
- Anyone interested
- FE5 on an ls align???
- eibach alignment kit
- CF Brake calipers?
- Scraping Issues..??
- have lowering springs, need advice on sway bars...
- coilbound sportlines?
- Basic Replacement Struts..??
- Coilover help!
- Anyone have any lowering springs they wanna sell?
- Vibration in the front.
- Part Number Needed (SS/TC F/L Strut)
- post you coilover pics please
- ksport or megan coilovers
- Factory satelite radio PTY all the time???
- Front and rear Sway bar Q&A
- What tires make the least road noise?
- What am I doing wrong? Rotors..
- Help with megan coilovers
