View Full Version : Suspension
- brake flush question help please
- KW V2's on summit white sedan
- Dear brembo pin
- Tenzo R springs, Before and after
- Need help on brand
- Spring help
- Upgrade fe1 to fe5
- Brake dust shields. Any difference?
- Rear Coil Spring Upper Insulator
- Bwoody Traction bars
- what else do i need to look at in getting
- how low will nopi springs drop a ss
- SSC Springs: Before & After
- suspension type
- Alignment Recommendations
- Brakes Kit
- Engine Shield?
- FE1 to FE5 suspension swap
- opinions on coilovers
- question for the guys on coils
- Brembo Caliper Pin Kit
- H&R 5x110 wheel spacers
- Probably a weird question
- Rattling steering
- clunk noise when brakeing HELP
- 08 s/tc rear spring insulators
- bag it
- cobalt coilovers to slam
- Shocks and struts.
- Suspension Advice
- Where to get Strut Tower Brace in 2013
- Just Lowered my Cobalt....
- HELP! Suspension clunking and loose steering
- Gettin Blown Around...and not in a good way :P
- ZZP Rotors
- how low and stiff are you
- SSC and CM springs: the same thing?
- Stiff ride
- Rear wheel hop going around bumpy turns and stops???
- Suspension/springs: Powell or nothing?
- ball joint question
- Struts and springs or coilovers
- B&G s2 springs
- 05 redline/ss rear beam axle PLEASE HELP!!
- Are FE5 struts really worth it?
- Confused -_-
- May have found the source of my suspension noise! Link inside...
- B&G s2 lowering springs
- whine after changing struts
- Rear coil spring replacement
- Konis 20% off at TireRack
- Best Springs for my NA?
- Calipers
- Ss/tc rear strut on ls
- Do we know the cure for SS/TC brake cancer yet?
- Wheel adaptors
- EBC Rear Pad Issue
- Monroe shocks and struts?
- Cold morning sounds?
- Best coilover for a 2010 cobalt lt
- More Powell!
- Canuck springs
- Lowering Spring
- KW V1 pics
- Coilovers, and things that go with low
- Lower and lower ?
- base (ls lt) springs on a ss sc?
- H&R springs race/sport?
- New Megan Coilovers Released
- Potholes EVERYWHERE
- YYZv2 v Pedders v Stock SS/TC
- M2 performance lowering springs
- Should I get lowering springs in a bumpy area?
- Simple shock question
- yyz v.1 vs sportlines vs pedders
- grand am gt independent rear suspension swap on to J body
- Why are they lower rear spring seats important?
- Rear lowering springs
- Is it normal...
- Higher Spring Rate?
- Suspension Upgrade ( shocks, struts,springs)
- What's best place to purchase coilovers
- Stance Coilovers Custom Spring Rates
- rear wheel bearing
- D2 Coils leaking?
- getting yyz's, need 1 question answered
- Rear torsion bar needed!
- Hardcore car noob here, suspension question.
- Bc Coilovers, need to go lower
- front right braking problem ABS
- 2006 SS/SC FE5 Struts Replacement
- Front right suspension clunk **VIDEO**
- Rear brakes whine when cold
- Coilovers better than FE5?
- The dangers of replacing coil springs
- Finally own pedder coilovers
- Brembos went stiff
- FE5 struts and shocks vs KYB Excel G?
- ebay lowering springs
- FE5 Struts and Shocks with SSC springs
- Stock Brembo Pads
- Koni sport struts or Coilovers?
- Coilover bind
- Looking at Coilovers
- Steering Pulling Right.
- Do our cars have struts on all 4?
- Parking brake lever gone limp
- Steering wheel shake
- Replacing CABS
- 06 cobalt ss sc knuckle broke turning into sonic!!
- Couple of springs questions for the noob
- Coil spring issue
- Lowering springs
- question about pads
- Fixed my susp clunk. Something to dbl check.
- LNF rear brakes on LSJ?
- Better in the Long run!!
- Suspension Replacement time, Multi Use/Dirt roads
- quick question before fe1 to fe5 install
- weird silver groove on disc?
- FE5 parts on Ion Redline need some help..!!
- Need an alignment.
- KW V1 coilovers pictures?
- Brembo logo
- Worn out strut mounts?
- Cobalt SS stock suspension on ION sedan
- Anything wrong with GM rotors?
- 09 ss/tc brake replacement issues
- poly rear beam bushings?
- Cobalt LT not centering
- Camber Problem
- Sway bar endlink
- Suspension Issue - clunk noise and sinking
- DC Sports strut bar, Same for base model and SS?
- Rear Brakes
- Stance Coilovers Issues, Please Help!!!
- chevy cobalt ls air ride
- My Powell YYZ Install pics and Comparison
- Wobble/vibration
- brembo brake help
- NEED HELP Something feels loose in front end
- Powell YYZ v.2 before and after pictures
- Stainless Steel Brake Lines, G5GT/SSNA/SSSC
- Yet another suspension thread.
- From Coils Back To Struts/Shocks Question
- Having to replace pads: HPS, Ferodo or Carbotech?
- LNF struts/shocks on SSNA/G5GT?
- Stock Suspension for sale..
- best shocks for lowering
- Rubbing sounds, no rubbing
- Craigslist FTW
- KYB vs FE5 shocks n struts
- Coilover question
- Homemade rear sway bar?
- Best Comfort Coilovers
- Coilovers in the winter
- Am i dumb or.....
- Time for new shocks.
- Cobalt SS/NA 2.4l Strut HELP!!
- Lower Control Arm Bushings
- CX Racing Coilovers?
- Whats the most Comfortable Ride Setup?
- Bleeding ABS brakes
- steering colum
- best suspension set up
- Need Help with Popping After Lowering Springs!!
- Stance coilovers vs stock ls-SS suspension
- Wheel Bearings.
- End links didnt fix clunk :(
- Lower COntrol Arm bushing came apart
- 2008 struts 17426 miles need replacing?
- HOW TO for front lower front control arm bushing change??
- rear sway bar + rear tie bar TOO MUCH?
- what kind of brake pads?
- stock rear shock specs
- Part Numbers for OEM Brembo Pad's/Rotors
- Please Help! need p/n
- Power stop rotors smaller? ss/tc
- Steering Rack to Tranny Mount Clearance
- Replaced brakes, have squeek now
- Front end rattle???
- confused about sway bar bushing
- Need to replace away bar end links help?
- Moog Outer tie rod ends
- Lowering kit question
- Rear Struts..
- Sway bar endlink rusted to stud.....
- Moog End links
- ss/tc oem shock compatibility
- Alignments
- sway bar
- What do I have?
- Horizontal CAB install
- Eibach springs
- Will these fit?
- what size tiers with eibach sportlines
- Front left wheel bearing assembly sensor reset?
- Just changed control arm bushings but...
- best springs to lower my 09 cobalt ss/tc
- Need help with Breambo asap
- 2.2 4 lug calipers....
- KW V2 or Stance GR+ for handling
- Another Spring Thread
- Should I get Pedders of Powell springs?
- Thumping sound when wheel turned all the way.. Please help
- Springs!
- Koni Yellows?
- need new rotors
- pedders
- lowest springs for ss/tc
- 16+ way adjustable, mono tube options
- shake shake shake
- lowest drop coilover, cheapest price
- sway bar vs control arm..
- Brembo pad/rotor replacement...
- Pedders to yyz springs
- new coilover option..
- Trouble removing lower strut/knuckle bolts? Am I missing something?
- Rear Camber
- Powergrid End Links
- Powell HC sway bar vs. XXX sway bar
- oily front struts
- SS/SC how low do you go before you axle bind
- Evaluating SS/SC brake combos, OEM vs. Aftmrkt
- Ksport lowering spring question
- Please suggest replacement rotors/pads for SSTC
- parking brake cable snapped???
- Cobalt SS NA Springs
- strut question for lowering 2.2
- Installed CM springs (pics)
- Ion FE-2 sway bar
- FE5 w/ Traction bars or ZZP LCA?
- sway bar endlink issues, help
- Converting 05 base cobalt to 5 lug
- Possible Pedders Problem on 2010SS?
- Qucik question brakes
- baer brakes kit
- how do you prevent breaking axels?
- Sway bars...(front)
- Wobble when braking?
- coil over opinions
- 09 ss/tc
- Removing Heatshield
- Tein S.Tech 06 SS
- Suspension gurus chime in and help me out!
- Strut/Spring life and shock question
- FE5 or Moog LCA's?
- back to stock, loose rattling all over front suspension...HELP?
- OTTP Rear bar
- fe5 shocks with fe3 springs
