- What should I do?
- Interior trim question
- Looking for a DD to go with s/c or t/c
- Considering a used 2.4 SS sedan. What to look for?
- High Mileage 05-07 Cobalt SS;s
- Lug Nut Question (Extended or Not - ON SS/SC rim)
- Installed HID kit, flickering problem!
- Beware of tin foil on OIL
- Quick Question
- My car has gas...
- Hid question
- Exhaust and CAT Question
- houston 2 denver road trip with 106k on the odometer
- more info on the recall about the detent pin in the ignition switch
- GM loaner car
- I need a professional opinion
- Accidently painted over threads. Help?
- Thankful for my SS
- Need advice on how to remove something
- Colder Plugs
- A Sad Sad Day. TIME FOR A NEW COBALT!
- Anyone got a zzp intake tube for sale ?
- Gm expands recall to 08-10 cobalts
- Now that I am no longer a broke college kid....
- Accelerator Pedal Pinouts
- anyone bitcoin?
- What is your #1
- **Best sedan tails ever!!!**
- Saab similarities
- Quality cv axles
- Will lsj suspension
- Half sized radiator?
- What new mods do I want?
- Idle loud engine noise / rattling
- 2007 ss/sc cold air intake
- Powell Front Trans Mount
- Thoughts
- armrest fitment issue???
- Should all Cobalt forums join into a class action lawsuit against GM?
- Civiv Si > Cobalt SS Turbo > Lamborghini Gallardo LP 570-4 Superleggera
- Parts identification in the trunk! Help!
- Boost gauge
- New Cobalt Owner :)
- GMPP muffler
- Headlight Seal
- I am looking for unbiased advice
- Who's Cobalt?
- Coolant level sensor. Where is it at?
- Returning from deployment soon, car hasnt been started
- Need to reprogram remote!?
- Coolant system change up
- looking for a muffler replacement
- New ZZP Header Installed w/pics
- Did you replace your ignition before this big recall?
- What size are the manifold to head studs?
- Exhaust help!!
- Changing Transmissions
- 2.2 blown motor
- Valve cover bolts
- Cobalt SS Turbo right for me? HELP!
- Gauges
- Has anyone Plasti-dipped their interior pieces?
- 200k LE5
- Almost at 200k! What to replace??
- Snapped exterior handle
- removing side molding
- Headlights
- My brother's new car
- stepping on gas pedal makes weird noises?
- 2007 SS/SC Production Dates
- supercharging tips and help?
- center console/ armrest
- Different rear sedan turn signal?
- Cobalt SS for sale??
- more power
- Idle
- question about child car seats.
- Retro headlights
- Free time. Need ideas!
- Cobalt Recall - Ignition Switch - (2014)10 yrs later
- Tsb 3562c
- can i get your experties help real quick
- Static from aftermarket headunit?
- I had it comming..
- Fs/ trade
- new rims
- Powder coat rims cost?
- K&N Reusable oil filter
- factory alarm?
- Help a brother out?
- So long
- Is this a good deal?
- Supercharger
- cobalt support
- funny tx2k 14 video
- recall related
- intake manifold
- Bye Bye Cobalt
- cranking in neutral?
- 20 inch rims?
- Clean roof
- Im back :)
- I locked my keys with the car on jack stands and running......
- Gotta question
- Clutch
- Aftermarket Fuel Rail for LSJ
- what is item #908 in this intake manifold assembly
- LSJ Airbox bolts
- Back bumper grill
- Please Read! Need help/advice ASAP!
- does anyone have any tips on cleaning up laminova cores?
- fuel rail
- Synchro Grind?
- ATI OD or UD? NBS delete or no?
- Best halogen headlight bulbs
- lsj radiator hose
- Low Rise Or High Rise Spoiler ?
- Mod please delete.
- Buying a 08 cobalt ss tc tomorrow??
- Stock Auto Trans
- pod gauges
- Ignition recall
- couple questions
- thoughts on zzp exhaust for lsj
- Rear springs
- final headlight/hid question
- Quick ?
- coilovers
- Cobalt SS 700hp?
- Heartbreaker
- 650whp ZZP Powered Ariel Atom
- Hood Deflector
- wheels and tires
- cobalt dash harness
- cobaltss for sale
- Clunk from front end when wheel hits center lock
- Driving myself mad looking for a SS lip
- Today I said good bye after almost 7 years!!!
- birth of the ultimate import fighter
- got links?
- cold idle temperatures....
- Going to look at a 2005 SS/SC tomorrow! Is there anything special to look out for?
- Wheel sensor
- whale tail wing owners, question for you
- would you do this to your cobalt?
- Carbon Trunk Owners
- Spare LSJ Supercharger - What to do?
- Picked up a new project today.
- Goodbye old friend...:(
- Flashing queston
- ZZP disappointed me big time! :(
- General Question .Cad file downloads via web
- Ghetto Top Gear Russia Cobalt Review
- Corsa Touring 14129 vs 14124?
- Brakes after raining
- Need help with clutch
- Electronic spoiler
- Separate black bezel from HVAC controls
- Fuel Filter
- Ghetto Door
- Would you be interested in automatic sunroof module?
- Thinking about a De-Mod
- Dose my tyranny have limmired slip option
- Shifting hard into 5th and reverse
- Is this someone on here?, Super clean
- Wingless
- What bulb would I need?
- How many miles until i need to change the timing chain tension bolt?
- sunroof
- LSJ or LNF
- OTTP Spherical CAB 12/16/13
- My beater 2006 Cobalt LT
- Well......got a new Cobalt
- dic controls
- Customized Headlights
- Update, possibly getting a new Cobalt
- Custom Retrofits or Catback?
- Heat/ac blower motor squeaking
- Heat/ac blower motor sound
- Let's talk coolant temps! (LSJ)
- What does this mean?
- Short shifrt or lowering springs?
- just curious
- Do I get tires or springs?
- hid noob
- Anyone know anything about this car in Houston?
- Football in rear for winter weather?
- Tune question
- longest lasting and brightest halogen bulb
- lower radiator hose diameter
- Cooldown Time
- Oil Pam Steel or Aluminium
- Wow!
- Silicone intakes
- Passenger airbag sensor
- So im confused
- Looking for exhaust advice
- I wish....
- Garrett turbo kit !!!
- How often
- questions about performance chips
- Knocking
- GM stg2 sc hub
- Been a while, totaled the Cobalt
- Question for LED tails
- Have you named your Cobalt?
- Unmolested 05 ss/sc only 6,800 miles. Garage Find
- Pics
- Remote fob...
- Need clutch!!
- Modified Cargo Rack Power wheels carrier!
- help, high coolant temp
- Shift Knob
- Hit & Run
- Making factory heated seats work in base model
- New 07 ss owner
- Need opinion on trade.
- Looking for some opinions here
- Plasti Dipped Rims.
- 4in lowering springs?
- Bought another ss
- coupe ground effects on sedan
- parting out silver 2006 2.4L SS.
- Goodbye cobalt :( (pictures)
- quick question about headlights..
- Retrofit: How to Fit Panamera Shroud?
- What's next? help? opinions?
- LSJ Parts/prices question
- cel eliminator
- I think the Cobalt is a very underrated car
- Is there a how to on removing a/c vent and/or dash pad
- Locked radio
- Cant decide
- catback exhaust
- Cobalt or 240sx?
- G5 rksport rear lip
- Check out this Ford wannabe Cobalt
- Possible to use the TC gauge on a different car?
- tuning in Pennsylvania?
- Fuel Problem???
- Lazy Balt forgot to shave
- While I was away
- Has anyone put a Big ss wing on a 08+ ss sedan?
- Ching Chong eBay Long Tube Header Review
- snow problem..
- Official cold start page?
- HUGE mistake.
- 2009 cobalt ls xfe 5-speed. computer code problem
- Best options for adding foglights to SS bumper
