PDA
View Full Version : General Cobalt
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
  1. Auto to manual
  2. Vin # check - 09 SS Sedan
  3. Legality of no back seats?
  4. water....
  5. Key Fob
  6. Parking Brake Guide Tube, Non Existent?
  7. Direct replacement aftermarket turbo frame PT5557
  8. Sucked A Hole Through Air Filter?
  9. Bleeding f40 trans
  10. Turbo smoke
  11. Cobalt wont start
  12. Brake loss during warm up idle.
  13. F40 axle leak
  14. Purchasing a Used Chevy Cobalt
  15. Subframe cage nut replacement
  16. F40 swap help
  17. F40 trans fluid
  18. G5 GT turbo issues
  19. Cobalt SS/SC car cover recommendations
  20. Need some expert advice for DF Goblin build
  21. 12 Years of Ownership
  22. What do I do? 2.4 2006
  23. No start after a few cycles
  24. Interchangeable parts????
  25. Performance ignition coil packs?
  26. Knock Sensor Low Voltage 2.2 LAP
  27. Harness Bar
  28. Fabricated tubular crash bar and core support build
  29. Shifter bag size?
  30. Fuel issue
  31. How to avoid pinch weld rust
  32. LNF Rims
  33. My 2006 cobalt ss has an unknown tune an it misfires over half throttle or 20kpa boos
  34. 1st time at the drag strip today 08 cobalt ss with video
  35. Lower my cobalt
  36. Part # for Exhaust Manifold Heat Shield Studs
  37. where to buy cheap intake and intercooler piping?
  38. Timing Chain?
  39. Clutch stiffness
  40. Holley Hydramat - fuel pickup
  41. Valvecover & Supercharger Powdercoating Prep
  42. Make sure you check under your steering column for this!!!
  43. What is this sensor on F23 trans?
  44. Ottp short shifter
  45. Luk flywheel disappeared?
  46. Continental DWS 06 On Sale $99
  47. Cam cap/bearing bolts
  48. Built transmission for 08 cobalt 400whp
  49. Higher flow intercooler pump?
  50. Story of my nearly complete engine rebuild. Lots of pics.
  51. New Cobalt owner.. Can someone post pic of key fob??
  52. 07 SS Cobalt (supercharged)
  53. Trunk lock cylinder
  54. Need bigger exhaust??
  55. Fitment help
  56. One Headlight Very Dim
  57. Newer exhaust manifold on 2006 2.2?
  58. 3 spoke steering wheel swap on a 2005
  59. Selling Harrop TVS w Siemens 80# injectors 1900 OBO
  60. Removing dashboard, for AC evap
  61. 2010 Chevy Cobalt LT jumps/ shakes when cold
  62. Blend door actuator replace
  63. Winter tire setups
  64. Exhuast Recommendations, How To Keep Her Quiet
  65. 2018 Black Friday sales
  66. Replacement keys for 2008 Cobalt SS
  67. Supercharged 2010 LT le5 swapped
  68. Replacing automatic brake pedal
  69. downpipe bend
  70. Raio Help Again
  71. ABS doesn't work but no lights
  72. Front Wheel Hub/Bearing Part Number(s)
  73. Perfect Headlight Research
  74. 2006 cobalt SS 2.4 Part Out
  75. Question about Steering
  76. 05 cobalt ss sc to 07 cobalt ss sc
  77. upper radiator mounts
  78. Need help
  79. Delayed Locking
  80. Lnf motor in Ls body??
  81. Adapting nav. Screen from Buick/opel to cobalt
  82. Air intake help
  83. cam follower removal, is there a tool for it
  84. Doors lock/unlock by themselves
  85. Self Dimming Rear View Mirror/need wiring diagram
  86. ZZP 3" catback exhaust crack in muffler
  87. Anyone wants this?
  88. Is the fuel sending unit e85 safe?
  89. Koni on stock FE1 Suspension
  90. 2006 chevy Ss supercharger transmission
  91. Yellow Turbalt Sedan for sale in CT
  92. New exhaust question
  93. How do you remove the fenders?
  94. 09 ss tc
  95. Radio help
  96. 2008 Cobalt LS TPMS problem?
  97. LNF Tuner in the Atlanta Area
  98. Turn signal and hazard flasher relay location
  99. looking previous owner...
  100. Quick exterior door handle question
  101. Wish Me Luck (New Clutch Install)
  102. Antitheft prevents from starting car
  103. Wheel Bearing Recomendation
  104. What rotors do you recommend?
  105. Hydroshield for 3" ZZP LSJ CAI
  106. Shirt you guys might enjoy
  107. They are still out there... 16,000 mile 2010
  108. Anyone do a rocker panel replacement?
  109. Stud M10 1.25 M10 1.5
  110. Brakes question -
  111. Trade in value for your cobalt?
  112. Rear spring damper fix
  113. 1/4 panel availability
  114. 06 lsj cobalt ss issue. Please help!
  115. How to post in Classified
  116. Paint or wrap
  117. TWM STS same for SS/SC and TC?
  118. Wing Deletion
  119. 3.0 Ecotec w/ 8spd Manual
  120. '06 SS Key Fob MYSTERY
  121. Seat removal
  122. Need advice on bpv
  123. Passenger door wont open...FFS
  124. Anyone here change their radiator support themselves?
  125. found good lookin deal
  126. No bypass valve or blow off valve temporarily okay or not?
  127. Old newbee questions....lol
  128. water pump (not supercharger) question
  129. Looking for info on this ss
  130. VIDEO: Removing The Master Cylinder / Brake Booster (Cracked Causing A P0171)
  131. 2008 cobalt pzev
  132. CAM or valve springs
  133. Authentic ZZP?
  134. 216k miles on the original clutch..
  135. How much power?
  136. VXDIAG - DIY tech 2
  137. Teflon LSJ Intake Manifold Gasket Idea
  138. Supercharge anything?
  139. DIY Cobalt SS??
  140. 2005 ss/sc help me track down my supercharger leak!
  141. Ion Highrise on Cobalt?
  142. Help programming key fobs using tech 2
  143. My flashers turn on when the flashers aren't on, it lasts about 20 seconds
  144. 2005 Chevy Cobalt SS Electrical problem
  145. Rear drum to disc conversion
  146. What are the top mods I should do to my stock Cobalt?
  147. Looking for opinions on ss/sc set up
  148. Steering Wheel
  149. lysholm 1600 question
  150. Won’t let me post in the classified section. I NEED TO BUY AN F35 TRANSMISSION!!
  151. Video - Removing the Underhood Fuse Box
  152. Cutting out under boost
  153. This is a longshot, but Im looking for my 2009 cobalt ss i used to own
  154. 08 Porous Block?
  155. Drove a 2010ss Turbo yesterday. Was sort of underwhelmed
  156. Fuel injector harness
  157. Trailering a Cobalt
  158. Vendor
  159. random resonator sizing question
  160. Spring build 2018!
  161. Cobalt coupe LT 5 Speed rarity?
  162. Rascally Wabbit Chin Spoiler Damage
  163. clutch pedal position and cruise control issues
  164. Coupe vs sedan
  165. 06 cobalt ls tranny cooler lines stud snapped off?
  166. Crate Engine Depot
  167. battery clamp issue
  168. Looking for VIN # help
  169. LSJ Interchangeability
  170. Meth Kit Question
  171. Electrical Issue
  172. Moog K201285 CAB
  173. Cobalt Trunk
  174. What's a 'weak' engine?
  175. Headlight wire harness
  176. OEM Auto trans cooler
  177. Still possible to buy a wastegate solenoid?
  178. 07 Cobalt speaker works, no turn signal noise
  179. Lil Blacky’s official TVS build thread(long post)
  180. Sitting low
  181. 09 cobalt ss vvt
  182. Need some lsj help
  183. Disable DRL 07
  184. Exhaust Recommendations
  185. Kobra takes a crack at retrofitting
  186. Cyber Monday Sale
  187. turbo xs shipping?
  188. Today’s Work: Complete Suspension Replacement
  189. Weird sound when revving car for first 30 seconds
  190. Black Friday Sales
  191. Tire Recommendations
  192. Low oil pressure
  193. What is happening?
  194. 389,000 Mile Cobalt SS
  195. Do I really need hood pins ?
  196. What is that padding stuff inside the splash shields in wheel wells?
  197. downpipe
  198. OEM SS wheels... Powder coated?
  199. GEN 5 Eaton M62 Rotor re-coating
  200. Terrible noise and shaking
  201. Need pictures of wastegate solenoid wire routing!
  202. LDK oil capacity
  203. Anyone know what exhaust system this is?
  204. Difference between LNF and LDK?
  205. Brembos on FE1 4-lug
  206. Do you know what this is?
  207. Help! Parts identification
  208. for fyi
  209. ISO font lip
  210. Cabin air filter changeout
  211. Climate Control Harness
  212. Ss engine cradle
  213. Bps shift knob thread size
  214. LSJ Long block weight
  215. 2010 Cobalt SS in town for sale - Realistic selling price?
  216. Noob question
  217. Pontiac G5 GXP
  218. Shaking and rattling at high speeds
  219. Cobalt Front Speaker Alternative
  220. Archived Codes (not current ones)
  221. Bumps and Tweeters
  222. Stock BPV or forge BPV?
  223. Was this a good deal?
  224. Solenoid valve
  225. fe5 one piece at a time
  226. Will these seat covers fit?
  227. Engine break in
  228. PE fail
  229. Calling anyone with damaged tjin trunks.
  230. Brake bleeding issue
  231. Stage Kit
  232. 06 Cobalt SS build
  233. Cam sensor code
  234. Which Shocks and Struts?
  235. Bagged bolt
  236. Happy Friday!
  237. Oil leak
  238. Zzp s3 he - out of stock
  239. 06 SS/SC codes out of nowhere P1516 & P2101
  240. Rear windshield "popped" this morning
  241. 07 Chevy Cobalt Ls (Sedan)
  242. Glowshift wideband air fuel gauge... HELP
  243. OTTP Long Tube Header
  244. Can't open door....
  245. New!! Questions for stuff I couldn't find proper answers to
  246. Short Shift Shift Knob Combo
  247. F23 Trans top mount bolts torque specification
  248. Bosch Oil Filter # 72215WS...
  249. 05 cobalt Lt exhaust size
  250. Shaking & vibrations.
