- oil in m90 supercharger
- Passenger side grinding/rubbing noise
- hard clunk over bumps and while shifting!!
- Car moves when clutch is let out in neutral
- need help with codes p0172,p0455, and p0496 on a cobalt ss sc 07
- Won't start without jump
- Need help with ABS!!!
- Gauge cluster issues?!?
- Not sure of the problem
- Clutch ??
- New to replace master cylinder ASAP!
- Clutch not disengaging
- Taping sound around oil cap at idle
- Help with emissions testing
- speedometer help
- All Suspension Bushings
- Timing Chain Guide Fix
- car hesitates to turn off + P0496
- P0171 code SS SC
- Passenger seat airbag sensor
- help o2 sensor issues?
- O2 sensor #1 and AFR
- Engine Droning on highway
- Need advice from a (Transmission) Technitian ....Bearing Noise.
- Oil shooting out of PVC.!!!!
- Shifter ball bushing?
- Car Wanders and pulls hard to the left
- Power engine reduce
- Help car wont turn on
- Service Airbag soon
- LSJ dies while merging
- car won't start randomly one day please help
- suppercharger wont boost
- A/C HELP from people with experience
- Boost Leak Fixed!
- Tore down a little just a few questions..
- A/C clutch and Cooling fan PIDs
- LSJ: High IAT temps. Thoughts needed
- smoke at startup
- Easy and cheap fix for a P0420 code?
- I think my car was stolen/attempted to before I bought it...
- Two things: Highway swaying and sunroof button
- Cylinder 1 misfire, coil pack?
- LNF gearbox noise
- Idle bouncing when stopping
- Aeroforce gauge broken from box
- Rear End Bump Clunk Noise
- LSJ Jerking/Hoping and then Stalling out
- Steering Clunk when parked
- Intercooler pump problems
- Need help with valve spring tool
- Power Door Lock problems
- No start
- Wiring diagrams
- Hit curb, wondering about front end parts...
- Bad clutch master cylinder or air?
- Clicking, chain noise, and exhaust rattles?!?
- Fixing front end damage.
- ABS and ESC Lights on..
- WTH? Something funky with my SS/TC
- Drivetrain moving around. help!
- Need Help Please Anyone
- Dome light rattle...
- lsj sputter, down on power?
- Annoying windshield wiper issue
- Maybe need a PCM
- My engine's making a nasty knocking sound. Any ideas?
- cobalt won't run under boost
- Service Airbag
- Thermostat
- Rear Springs
- weird noise from lsj?
- Thick Sludge on Dipstick
- Wheelbearing-like noise
- Why is my boost so high?
- ? About my lights
- Bad Idle
- All front speakers randomly stopped
- Value Decision - Keep Repairing Or Sell/Writeoff?
- Is there a way to disable the passlock system?
- oil leak or fuel leak by filter area????
- p340, p341 codes
- lsj cooling
- P0304 code
- Suspension Creaking
- License plate light out
- rough idle at start
- First Date Nightmare
- Tempeture
- Some help plz
- Oil life
- Help w/ Gauge Cluster
- LNF Random Misfire, need ideas, dealer wouldn't help me
- Broken Washer Fluid Line
- Help!!! P0301 code!!
- Master cylinder and brake booster
- Car will not warm up!!!
- Belt issues? Need some help
- Whats wrong with my right blinker?
- Loss of Clutch after WOT
- Problems with second fourth and reverse
- Belt tensioner bolt lost for ever...
- Clutch pedal issue.
- from little problem to big problem. rear view mirror
- Blow off valve hoeses
- boost issues
- Oil Drain Plug Broke!!!
- 56k Miles - Bunch of annoying problems. Does this list of things to do seem good?
- missing exhaust manifold stud
- Aeroforce problem
- High idle after cleaning TB
- Car won't start! Don't think its the battery.
- HVAC fan
- timing issue
- sparks plucks
- Error codes
- Jerking, loss of power while accelerating, rough idle
- Emissions Test with GM Stage 3
- lost power
- P0102, p0171, p0300 - 09' lt
- Clutch pedal, loss of pressure
- lsj timing
- Replacing cruise control buttons on 2008 SS
- My breaks
- how to time an lsj
- High idle issue after cleaning throttlebody
- Grinding noise, cold start
- Lsj Misfire, cant go past 5000 rpm in 3rd or 4th gear
- Misfire, 3rd & 4th gear wont go past 5000 rpm
- Cel p0411
- lsj not turning on
- 05 LSJ Bank 1 too lean / low boost
- Weird sound from front driver side wheel well...
- coilover probleme
- Drive belt help
- clutch wont disengage?
- having rear pass axle assembly issues...
- 2007 g5 HID help
- timing chain ate through the upper guide
- Need some help with some codes.
- Having Trouble Removing Pistons from Brembos.
- Stiff steering after tie rod replacement?
- Cant start my car
- 2.4L SC; couple codes.
- 2009 2.0 LNF Airbag Light
- Timing chain, interesting
- Wierd problem
- 2.0 LSJ rattling engine sound
- WTF is this?
- Tire pressure sensor low or high performance
- '09 W/ Bad Fuel Leak - Not Covered Under Recall
- 06 lsj downpipe, intake, catback - no tune problems
- 2006 Colbalt
- Electrical Problems (tcm, ecm, bcm, wiring and grounds)
- Trunk release
- Dead alternator or battery?
- Cobalt SS wont stay running. BOOST leak?
- inlet hose coolant leak question
- help
- Throttle problem
- lsj boost issues
- LSJ very low boost
- Drivers door handkes dont work!
- lsj boost issues
- Transmission won't go into reverse after new motor
- 2009 LNF Fuel filter! SS-T/c
- Power steering intermittant
- Camshaft position sensor! No start! Help
- 07 ss/sc is dropping power but in a weird way...
- timing chain replacement, question about parts
- P0496 purge solinoid
- shift linkage won't work when very cold
- my car is getting up there in the mileage about to hit 100k
- Steering wheel gets hard when turning
- Pressure in coolent system
- Wth
- Reduced Engine Power but car runs fine.
- 2.0L LSJ 07 SS S/C Hesitation under boost
- Low oil pressure?
- LSJ Belt Tensioner Bolt Size
- Car wont start
- DRL's
- Is it me or is this a bad idea?
- Crank Chain Gear keyway groove on LSJ missing????
- problem about HID
- SC bypass
- Guage Cluster Failure or something else?
- Help
- Gauge Cluster Failure or something else is wrong.
- Car stuck after sitting overnight
- Warning about dealer timing replacement
- CEL help, P0101 and P0171
- horn not working
- Valves clack after new head.
- heat and air not blowing
- Trasmission/clutch problem? maybe
- 0010-P0013-limp mode
- Re: 60,000 mile maintenance Cobalt SS/TC
- O2 Sensor Code HELP!
- name that part!
- No boost ?
- Steering Column noise?
- Radio not turning off when door opens
- '09 ss gms1
- Do I have the wrong HID bulbs?
- Cruise control
- Bracket??
- Overheating Problem
- Blower STILL only works on #4
- Security light on
- Trouble starting low idle
- Upstream O2 in the rear
- Help
- Airbag light 2008 cobalt ss/tc
- Trunk Tumbler Not Moving
- I need a little help or a how-to link
- oil in coolant no coolant in oil.
- dealer wants to scrap the cobalt because of mechanical issues?
- A/C Compressor Pag Oil Type/Capacity for LSJ???
- rear brakes lnf: what if we ditched the spring?
- Boost Solenoid Hoses
- Leaky Downpipe Flex Joint?
- Problem with my 07 Lsj
- AC line replace help
- clutch swap
- Tensioner finally fixed.
- Starting and Dieing
- Idle Problem
- Engine Power Reduced
- Steering Clunk
- Cobalt SS interior Dome-light switch broke?
- Power Steering Problems
- Hissing/air hose noise from front end. Please help!
- Low Oil Level Sending Unit in LK9/LSJ Pan???
- Bad vibes
- No Power, won't Start
- amsoil oil vs mobil 1 syn
- heated seats not working
- p0101 and holding little boost.
- Few issues I'm having...
- Buying an ECM?
- wot pull then died....
- Cold start
- new member...need help with my 06 ss/sc
- Engine noises
- oem gm parts website
- clutch starter switch
- Retros randomly work/dont work
