- 2.4L engineering disabled/Pwn Reduced throttle body
- 2.4L engineering disabled/Pwn Reduced intake manifold
- "engine pwr reduced"
- Car jerked while giving it half throttle
- New MAP sensor, but still throwing P1182..? Not sure what else to do..
- MAF sensor, limp mode, and much more!
- LNF Frying ECMs...
- Right rear speaker won't work - Help!
- 2005 SS Front End Problem/Shaking
- help needed
- 2008 front right turn signal won't blink
- Clicking Noise every time I shift? WTF
- P0087 Help
- 07 LSJ p1133 ,p2a01 wont go away?
- Brake lights and brake code
- Radio & Satelite Radio issue.
- Electric Lock Trouble
- Electrical problems during rainstorm!!
- Intercooler Pump Bracket to Engine Block Bolt Size
- Car when letting go of gas
- clicking when braking and turning?
- Random P0335
- Is this weld a sleeve?
- Supercharger coupler bad?
- California Emissions on PA Balt
- Serious problems
- Just threw code p0100
- Cost at meineke for weld
- Vacuum boost high
- power steering, ignition, gauges?
- Cleaned Throttle Body... Now Throttle is Hanging
- Steering column keeps going bad - GM Blames Pedders
- Catalytic Converter Cleaner - Emissions
- Threw a P0171 code today
- Horrible shifter rattle
- Cool rattle, listen here!
- Front Bumper License Plate Holder Holes
- ac delco plug
- Bumper and hood! Replacement parts!!
- 2008 lt
- Clutch pedal squeaks and groans when depressed and released......driving me insane
- Ss sc spits spudders and floods when starting
- Power problems need help DESPERATE
- steering kind of hard...
- Help with HIDS!
- Weird humming noise
- help my car over revving when driving
- Vibrating/noise that varies with speed
- Is this normal? (Axle shaft to AT transmission)
- There are 2 pressure sensors for the MAP? Follow up for the P1182 Code
- P1182 code... OUT OF IDEAS!
- electrical problem
- p0171 from bad TB???
- Help with 3 codes!!!!
- dash problems
- Rebuilt engine...no start...no clue, please help ASAP
- Cranking Issues
- New mods new problems
- Engine Rattle
- strange noise
- Another Recall
- Turn signal not working
- Installed TVS now car surges and then dies
- Blue Smoke and major misfires at idle
- Bad cold starts?
- Moderate Vibration under gas pedal/front end clunk? HELP!
- e-brake cable snapped.
- Loss of power?
- Fuse
- Lnf turbo life
- Charge for warranty work?
- Lower drivers side weather strip
- Brake light cruise control
- ebrake wont release
- Code 1174! :(
- lsj idle problem
- SSSC gas mileage/power problem
- dash wire harness
- Constant problem with car
- shifting issue
- fiberglass resin o cold side end tank?
- electrical problem ?
- 2006 L61 overheating
- 2.2 rebuild help
- Need Mature Help!
- No boost pressure after NLS
- Here's a new one
- 2010 Cobalt SS Coupe turbo LNF strange issues sunroof, steering, clutch
- turbo LSJ stuttering. HELP!
- Help me avoid the stealership
- major drivability issue
- Mysterious rattle / 2 years strong
- Chain Guide Bolt Damage ?
- 2006 SS/SC new intercooler pump and intercooler problem
- Help Please.
- Heat exchanger How-To?
- LNF promblems...
- help
- Clutch problems
- My Car died and wouldn't start, until 5 mins later??
- Cleaned the TB!
- looking for tip on wet sanding/reclearing headlight lens
- Factory Alarm Problem
- No Boost/ P0101/Limp Mode
- Vibrating brake pedal in LNF
- Blowing Fuel Pump Relays?
- Throwing mad codes
- engine rattle
- heater/ac problem
- Motor replaced, Secutiry light, no crank
- limp mode
- Hub/Bearing or Axle?
- CEL on for months then turned off?
- Loss clutch liquid
- small issue
- valve train noise only above 4000 rpm video
- Car sounds like it's lobing..
- Air sensor
- Oil cooler on block
- 2008 cobalt ss turbo brakes
- shift linkage
- ***URGENT*** Car started by itself
- ss sc idle wierd
- Uh-Oh Oil Change Issue......
- Code P2096 and 22419
- HELP! Headlight won't fit back into bracket...
- Car Won't Rev Past 5000 RPM
- sputtering noise while turning
- My Last Resort
- 120K on my 09 SS TC - What should I replace?
- Weird ass problem
- Do I Need A Crank Case Relearn?
- Left head light not working
- Driver Door Wont Open
- Please Help - I Broke My Handbrake
- Car is running like crap...
- Theft mode, won't start
- hid kit install fail help please
- Headlights burning out.
- ESC wacked out and MPH off?
- Do I have the right part number P0131
- Weird rattle during acceleration
- Well I'm lost
- p0017
- battery voltage bouncing
- Drivers side heated seat is always on
- Pretty bad oil leak in timing end LSJ
- Having O2 Sensor Issues.
- CEL Due to MAF
- Some type of leak o somethin
- Rattling noise ?
- Airbag? Power Steering?
- P0121
- Car cranks but wont start Help
- Car cranks but wont start. Help please
- Fluid swapping
- Add a circuit
- Possible Fuel Issue?
- car suddenly running full rich!!!
- New down pipe or fix mine?
- Help with injectors!!!!
- p0101 and low boost
- Air Condenser/ Cooling Fan
- Car wont stay running
- Cooling Fans pop fuses
- SS/SC Acceleration Problems
- Car won't idle
- Fast ticking noise while accelerating
- help with fuel lines
- Need Some Suggestions
- boost pressure stock?
- need help diagnosing!!!
- new pcm but no power steering/speedo
- Repair manual needed
- poor idle/gas milage
- need help from AllData. VVT actuators
- 2006 LSJ Tranny issues
- Areoforce Interceptor- Please help!!
- fog light wire under hood
- [Question] Cobalt Airbag Indicator and Power Locks
- cel?
- 2.0 LSJ bottom end failure
- Ah crap...
- P2138/p2135 help please
- 2004 corolla
- Cobalt fails me 2 of 2
- Snapped an oil pan bolt
- Violent Vibration! w/Knocking from front end
- Cruise Control wont work after clutch replacement
- Crap load of codes, o2 sensor issues?
- Leak down test results
- Need help on hid fog light installation
- Solution to gauge cluster going on and off?
- exhaust leak question
- Issues... Intake?
- GF's celica is doing some weird stuff! HELP
- Need advice on a mod and cel code
- How to replace dipstick guide tube?
- help please
- Ideas and brainstorm: p0087 and p0303
- 2009 Chevy Cobalt SS Cam Sensor Location?
- randon rattle
- Alarm Not Working
- 06 SS/SC gauges problem plus steering question
- Serious help needed 😔
- Stupid ABS light.
- Help!!
- Help.. Reverse Issue....
- Low Coolant light need suggestions
- "Trunk Ajar" but its not
- Coolant Temp High.....need help!
- 06 cobalt ss supercharged engine revving rapidly
- Pass. door goes "pop!", how/why?
- Problems with 06 cobalt ss/sc
- Vibration at 70
- Sunroof + Fuse box?
- Door Lock Stuck, Door Won't Unlock or Open
- Drivers side door handle
- Clutch pedal vibration
- engine codes help please
- HELP! Subaru Noise & P0303! URGENT!
- Most important maintenance ?
- no fuel pressure
- rusted strut lock, even with an impact, IT WON'T COME OFF
- please Help with P0171
- Heat went out, need advice
- boost problem!!
- Steering issue
- Can't go into any gears
- Weird RPMs
- Tie rod ends
- BCM issues
- hvac lights and mode selector doesnt work
- Car has a Weird jerk in 4th
- strange clunk
- STICKY left turn? Help
- Cali CARB EO - TVS -
- Ebrake failure
- 2006 SS/SC: Won't start
- So you guys wont believe how i got an oil leak
- AFR Gauge EXTREMELY Jumpy
- cracked exhaust manifold.
- Downstream 02 Sensor reading same whether in or out, needs to be replaced?
- How does this make sense?
- Idle Tick
- 06 LS idle/miss issue I can't figure out!
- Key Fob Part Number - Programming Help
- maf no signal
- Nearly 30% Fuel Trim!
- Door want open from inside or out
