- My engine sounds like a diesel sometimes..
- Turbo? Issues
- Metallic rubbing/grinding noise when braking & turning right
- accelerometer sensor
- replacement oil cooler..?
- GM Dealer
- water on driver foot while driving
- Request for advice
- please help me with this sound!
- Leaky sunroof?
- 12797711 cooling bolt
- Ac problem
- Throttle body issues
- p0172 help?
- A/C is nice and warm in this nice weather!
- F35 Transmission Distribution Block Cap LOST!!!!!
- Any Front Brake Pads that Dont Spew TONS of Brake Dust?
- Oil in spark plug well
- Car died
- Funny smell
- hydraulic clutch problems
- I have a NEW CEL!
- interceptors not working
- Reduced engine power.
- Please help!2009 turbo issues/ rough idle/low boost/wild afrs/stuttering
- Brake pedal won't return all the way to top tosition
- GM at it's finest!
- Ticking noise during boost
- Door Paint
- power windows arnt working
- RPD No Boost Available
- door rust
- a/c compressor major problems/ eletrical
- Bleed the clutch?
- so called lifter tick
- 06 cobalt lt water leaking
- loads of codes someone help me find problem?
- Stumbling, random A/F ratios, low boost. Help please!!
- Promo : Buy 2 phones or ipad and get 1 free unit
- All over road when in throttle?!
- What is the deal with my afr?
- Badmab header problem with top nuts. Need help!
- 2006 supercharger problems
- random speedo jumping while sitting still
- 07 sc wont start problems help
- Clutch Clicking Noises
- odd OBD2 code
- Clutch Bleeding Question
- Starter Help!
- Insurance issue
- AC Stopped working
- sun roof
- Limp mode triggered by low revs taking off in first gear ? 2.0 LNF
- How to Clean Throttle Body
- never changed drum brakes
- My Headlights Won't turn off!
- Need LNF parts diagram
- Door handles don't engage.
- What maintainance does my car need and how much do you think it willl cost?
- Lots of work :(
- Low Boost,P0111,p0116,p1101 and p0172
- Installed TiAL Q BOV, Any way to make it LOUDER?
- high boost reduced power LNF
- throttle/boost/flutter issue
- Prob with the lnf
- Crazy Misfires
- Random small problem
- Throttle Position Error
- high IAT's....... what are the causes...?
- Vibration after 120mph?
- RPM's fluctuate when I turn on A/C at a stop
- ABS not working ?? changed from 5 lug to 4 lug wheel hubs
- Broken door handle
- Smoke from exhaust when boosting!
- Wiper relay causing major engine misfires
- How to add A/C coolant to 07 2.0?
- Fuel Leak? Part of recall or no?
- P0606+P2101 trouble...
- Weird sound (video)
- heater core replacement
- Misfiring/ backfiring around 5000rpm
- Brembo Brake Question
- Piston to bore clearance
- cel removal?
- need help....cel
- Leaking oil from intercooler Round 2
- Overcharging Issue on Turbo Swap
- Headlights don't come on. Hids installed
- Clicking Noise When Accelerating?
- loud clicking from behind dash "fix"
- Wipers aren't working
- SVC Tire Monitor not functioning
- does ANYONE know what caused my car to do this??
- I need help! I'm struggling! My car won't drive out of PARK..it wont start, either!
- rear trunk area rattle
- Yellow mayonnaise in oil catch can
- service esc
- knocking sound from behind dashboard
- its just not my day i got another problem now
- i have no clue lol i about got killed !!!!
- HIDs affecting radio? (lol wut)
- Car wont start need help!!!
- Clutch Issue (Sort of)
- Cabin fan don't work :(
- clutch or transmission problem??
- Loud ticking (video included)
- running rich, suggestions?
- T/C light and a hole in the exhaust...
- Reverse lights not working (not switch related)
- Putting in new seats
- Clutch Slip? IDK need help
- Getting nothing from the turbo
- cobalt ss sc boost problem?Need help
- Problem need help ASAP
- Coolant Temp Bouncing
- boost issues and limp mode on an SS/SC
- Oil spewing from intercooler
- failed inspection, throwing 3 codes
- LE5 Auto Trans Problem
- U0001 n P0218 code
- bypass valve
- 06 Cobalt ss/sc steering problem
- Boost Leak or Normal?
- Where is my brake fluid going?
- Growling/Grumbling noise behind firewall?2.2
- Diagnosing an issue on my 07 SS/SC
- Strange noise while driving
- grind noise
- My Heat Exchanger is leaking and I don't know what to do!!
- slight jerk while in boost
- HVAC Flapper valve
- 2ed gear grind.
- when i turn the sterring wheel i hear a click in the dash
- Car wont stay running
- Code P2187
- ENGINE/ TRANNY mounts for AUTO??
- Engine disabled engine pwer reduced help!!!
- LSJ Throwing P0449
- Installed AEM digital boost gauge
- Car will not start, theft light on after installing new head unit.
- Dragging Rear Brakes? Normal or no?
- 06 SS/SC bouncing AFR and KR
- 05 ss/sc xtra whine/whistle
- vibrations even sitting still
- Radiator Fan Housing Cracked
- awful exhaust sound
- Axel Going Out?
- Vibrating?!
- Some Issues.
- Turbo Flutter- 5PSI
- 09 SS Engine Ticking and P2178 System too Rich at Idle Bank 1
- Blown turbo or bad tune????
- clutch problems
- Turbo bad????
- 2005 Cadillac light issue,Help please!
- Cooling fan runs forever when car is off or on
- Are Ark Shorty Antennas any Good?
- remote question please help
- Steering Wheel Shake - YES, another thread
- Pontiac G4 2006 error codes P2135 and P0010
- Damn Clutch!!! wtf
- Anyone in Massachusetts, Inspection Issues!!
- High Rise Spoiler is coming off?!
- Bad Battery?
- Unreadable code after CAI install and rain
- Help please! Unknown leak
- TEMP issue Displays ---
- Running lean, new MAF sensor
- stupid factory alarm!
- car shakes taking off in 1st or reverse
- Car won't go into decel
- trying to perform a brake fluid flush
- keyless entry sensor
- is this normal?
- Coolant temps too low and fluctuating???
- Black Clutch Fluid
- Theft mode
- How to cure Fogging headlight?
- led taillights
- limp mode?
- Super annoying brake noise. I think
- How can you tell if you have bad Mounts?
- New igniton switch
- Cobalt SS interior light
- Intermittent P0420
- P0340, P0341, Cam sensor code..
- MAF DTC Codes
- Whacked fuel gauge
- Do I need a new muffler
- Weird sound....
- HKS compressor surge :(
- Po2228 & po507
- Window buzz
- hesitation
- Car runnnig rich and rough
- loud noise when backing up
- Synapse IC Crack!
- is my resonator bad?
- Steering hard to move
- Starting issue
- cleaning rims?
- Anyone know where this goes?????
- 2006 SS/SC loosing coolant is normal?
- stuck in the middle of no where P1516
- Stock HU - No display
- 2006 SS/SC headlight.
- tail light fuse
- 2009 Cobalt SS Air bag light
- Car wont start :(
- Electrical Problem? (Locking and mirror)
- Bov flutter
- Clutch pedal sticky/slow after a hard pull
- Front brake job, Clips? *Urgent
- Cracked Flex Pipe
- Canadian Lemon Law, Arbitration and CAMVAP
- Engine sputtering
- 07 Cobalt 2.2 engine temperature reading --- F
- intermidiate shaft length
- junkyard motor
- aftermarket tranny mounts for AUTOMATICS??
- 2.0L P0331 Knock Sensor Issue
- Downpipe problem
- need some advice
- Car is not running right
- Seized engine?
- Gearbox problems HELP!
- p2100 engine code??!!
- oil light problem
- Car wont start back up
- Shifter Dead - Roll Pin?
- Belt slipping....
- wheel bearing specs
- Any way to make exhaust higher?
- 06 Cobalt SS Supercharged Cluster issue
- Rotor replacement
- Um WTF?! My jack is stuck
- miss firing car won't run right
- snapped valve cover bolt
- Can anyone tell what part this is??
- porous block issue on 05 ss/sc
- P1681 + P2135 Works on VE
- check engine P2227 code
- Pleaseeeee help with serious clutch issue!!
- Annoying Vibration
- Sway bar end links!
- Rattling when accelerating?
- Goodyear okay spot to get coolant flushed?
- Help needed.! Defroster, recirc, ac not working!
- air duct stuck in my 09 lnf
- Boosting problem
