- Abs
- 07 Cobalt Coolant
- Check Charge System Problem
- Only get 5 psi
- LNF p0451 p0496...
- (2.2l) Excessive oil leaking from valve cover pcv
- LNF: Dancing Gauges
- Serious Electrical problem--help please!
- where to buy seatbelt at??
- Cel p2195
- Blown Headgasket
- Running Rich & Cutting Out
- Quick question about getting service
- Can I flash/reset TCM?
- Cel.. P0128
- Driver side seatbelt is locked up
- HELP! Got a P0140 CEL code
- Boost leak test, need help.
- Driver door lock problem
- 2006 Le5 Cobalt Loping
- Weird Electrical Problem
- factory shift knob removal
- Interceptor Question
- Help !! Acceleration issue
- Hard Shift 1-2
- Belt slipping? Clutch slipping?
- help noob with brakes
- lack of boost
- Spark Plug Gapping
- Front end rattle and clunk
- Belt Tensioner
- Charging Problem!! :( Please Help
- LNF NLS problems
- Misfire po300
- DP Leak
- 2.2l weird noise
- Warning! Brake Caliper Bolts...must read
- Part throttle hesitation/ stumbling
- Rear brake clunk
- No heat,
- Weird Intermitant Problem!
- air manifold
- any problems with burnt valves with 2.4 mani upgrade?
- Finally rid of traction control prob
- LSJ on a 2.4L
- Key stuck in ignition
- P0420 Code
- ABS light turned ON after new axle???
- Possible argument with Stealership??? Help!
- p0303 question
- Noise coming from 06 cobalt ss
- New timing chain tensioner not even a year ago
- Guide pins
- hesitation when in high rpm at full boost
- Oops
- CAI Install question.
- Need wiring diagrams asap!!!
- drivers side speaker
- What exactly is the dealer "Major Fuel System Service"?
- Trunk Gas strut/ hinge adjustment
- Bad cv axle? Help please
- problem after problem
- 2006 SS Cobalt Runs Horrible In The Rain!
- No reverse lights
- Whats this noise??
- Windows wont go down?????
- Tpms
- When you remove your gas cap...
- Looking for immediate Help!
- Sound from door panel. PLEASE help me
- please help..subframe and ither things
- Oxygen Sensor
- No Start!
- Anyone in or near Richmond, VA
- Horrible Misfire & Throws P0507
- Bunch of codes need some help here
- sputter when under load, please help!
- lnf sunroof leaks
- Code U0101
- installed stage 2 now car wont start help!!!
- Auto, reverse clunks when shifting
- Thermostat replaced, Code p0017, wont start after driving
- E-Brake problem...
- Light behind the Air conditioning knob went out
- With battery Disconnect, do we need to reflash stage tune?
- dual pass small crack help please
- Could this be the problem?
- Newbie question...
- Condensation, or worse?
- brake drum wont come off
- 06 LT Cobalt theft deturant issues
- Clutch engagement issues...
- Steering wheel vibration when braking not from warped rotor...
- Putting Stock Exhaust Back On QUESTION!
- Clutch master mounting tabs bent...
- URGENT: Car won't start help!
- Low boost, SC 2006
- e brake lever
- Broken Antenna
- slight vibration
- Whining noise from front of engine
- where to Dyno my balt?
- Codes P0013 P0014 P0128
- xcuse the knewbizm...
- Help door stuck
- engine power reduced/ traction control light on
- 05-06 to 07+ compatibility
- Driver Information Center Advanced Menu
- Vibration/drone in front end
- Gas Mileage / O2 sensor
- 07 ss/sc transmission input seal leak:(
- moaning/whining noise while autocrossing/ vid
- Slight shake and rubbing sound
- Dielectric Grease
- Gas gauge
- Wobble
- Where is the BCM Located?
- multiple problems with brakes
- Weird clicking noise from rear wheels?
- Transmission and the dealership
- Brake pads wont fit!!!
- oil life display (how true is it?)
- So it finally happened...
- Problem with an Injen CAI
- cobalt keeps dying
- 09 cobalt ss/tc turbo problems
- cam change gaskets?
- NOT starting up please HELP!
- Engine Power Reduced...Lots of Codes?!?
- Low boost, hissing under acceleration
- 2006 cobalt steering column question.,
- Headlamp Electrical Issue...
- Solution to P0068 and P1182?
- Sound when accelerating!?!?
- do i need a tune
- Bad Battery? VSS + Power Steering + More
- coolant temp sensor
- weird rattling noise under high boost
- broken mount?
- Rear Drum Howl and Squeal
- Engine light code P0446
- locating the starter
- 06 cobalt turbo charged please help
- Cancelling GMPP?
- Stage kit question
- Weird noise coming from supercharger
- Key issues
- Check Engine Lights!!!!!! Please Help!!!
- Need Help!!!
- Is this considered a low idle?
- Replaced fuse box and car won't start
- 2.2 Auto Stalling When Cold?
- Supercharger locked up? Not covered by warranty?
- did my wheel lock up.. or? coilovers..please help
- water from muffler
- crank no start after machine shop valve job
- gas meter not working
- Removed inter cooler, charge piping, and the intake
- 2.0L Supercharged engine clatter
- Hahn Exhaust Tip Hanging Low
- Cant change gears ! Suggestions please?
- Random oddities... all electrical
- Misfire @ high RPM
- rear clunk when turning left, Please HELP !!!
- Changing Coolant-- and now it wont start
- question please help!!
- Transmission
- brembo help
- Service Traction/ABS lights.
- Help with ball joint and knuckle not going back together
- low mpg
- Brake Fluid*Service ESC*Service Traction
- Suspension Issue
- High pitched noise from engine when driving
- clutch/tranny or what problems
- Clutch/Shifting issues
- cobalt tries dieing when pushing gas in park
- Steering wheel shake while Braking!!!!
- Tech Help Plz 05 Chevy Cobalt
- No brake lights/signal lights
- Milky Oil
- TPMS Light
- Compression???
- Wierd noise coming out from under the hood.
- p2188 cel
- Loud racket when I put it in reverse?
- grinding/chattering noise
- boost leak
- '09 SS Rattle just above steering column
- Wiring help please
- Car won't do ANYTHING
- Lost all Coolant in Reservoir, Oil Puked all over top of engine....
- Misfiring on multiple cylinders. Help please.
- Weird noise!
- Good Ole Stealership Run Around
- Service Air Bag
- Melted piston... lookin to go forged
- boost control solenoid
- non stop problems
- EVo mod or CF lip
- Anyone local with Tech2?
- Make my car whine!
- Help!!!!!!
- supercharger oil level seems low?
- zzp intake install questions
- intermittant start problems
- replace my gas tank.. questions
- Door adjustment
- Reliable GM Stage 1 upgrade for LNF in CNY
- air bag light
- Jessica wtf!!
- Cant build boost/exhaust flutter
- lifter problem
- aem or autometer wideband
- Drivetrain issue? Need help diagnosing [vids]
- please read my save you trouble too...High Idle after fuel induction service!
- cly 2 misfire?
- Check Engine Light help
- nasty looking gas leak. any idea??
- Help - Fuel Tank question!
- clutch issues, new
- Clutch problems need help
- Front Pads...Autozone?
- aem uego wideband doesnt read properly
- I dunno wtf....
- reduced engine power
- Idle problems, White Smoke. Help Please!!!
- Headlight Issue
- Handbrake broken
- Intercooler help - dealer's not honoring warranty
- How long do you guys go between oil changes??? Which is is most popular brand??
- bogging
- Rust warranty?
- Please Help!
- AEM Boost Gauge Question:
- senior cobalts
- 3rd gear pops out
- If something were put in my fuel, would I know right away?
- Rear drum hum/vibration
- remove ss and cobalt emblems
- Oversteer issue
- Dredded Pink Wire!
- Air Bag light on, HELP
- oil filter housing drainback issue / pressure loss
- Spontaneous combustion...
- Intermediate Steering Shaft Question
- Engine and TC lights sometimes ON!
- car just loses power
- ECS Active Problems
