- Window motor problem.
- Fuel Filter
- power source?
- IC Pump not working, Damaged supercharger?
- popping sound/exhaust? worried?'
- Loose outside mirror glass and loose fender.. UGH
- Need help P2135, P2176, P0121
- Low Coolant with full coolant...
- Seat belt reminder !!!!
- Trunk ajar? Alarm going off
- What do you guys think????
- cant find this part
- knock from bad gas
- 06 ss/sc 60k maintenance
- bad o2 sensor 2.2
- need help, fog lights and gauge
- Wheelwell and rocker panel rust
- shift linkage !!!
- Help
- Knocking
- 09 LS cruise control Mod question
- N2MB Wot Box
- Miss-firing bad running help.
- Wheel clicking
- Dead car
- cel p0100 plus dealership issues
- vibration under load
- Bluetooth mic problem?
- Oil overfilled?
- Cruise control, A/C, and info screen not working
- Acceleration Surge
- Clutch slipping after break in
- Engine Power reduced again!!
- Tighten axle nut didnt fix clicking
- Brake piston sticking or wheel bearing going out?
- Brake Fluid Leak: E-brake mechanism suspected
- key stuck in ignition
- p1133 after ZZP LT header
- Service air bag!
- Just Installed GM Stage 2 Why only Hitting 13psi Boost?
- Keyless Entry woes
- HELP! only boosting 2lbs. WOT
- voltage...
- does your LNF misfire when pressing brakes?
- Bunny Hopping!! it's madness
- water pump/timing chain
- belt tensioner install
- Clock resets?
- PCM or ECM??
- Non Cobalt Trouble Codes
- Egnition key stuck in "ON" position
- need some help please
- Air Conditioning Problem
- Need OEM Weatherstripping
- If this green thing was not threaded in the whole way...
- Water In trunk??
- Ky clutch problems.
- lnf running rough...
- Hit a raccoon..
- Suspension Noise and Odd Idle
- Hit a pothole. Need help!
- Strange fuel pump/filter issue
- GM Stage 2 Installed and Now there's a CEL!?
- Steering Wheel Controls - Help
- Florida tuner?
- small banging noise under car
- My Cobalt ss engine overheated ?? pliz help
- Check charge system?
- Bad MAP Sensor
- Installed K&N drop in today and....
- Turbo????
- Want to see something nasty?
- car keeps slowing down on the strip really bad
- 05 cobalt belt tensioner / pully chatter
- Back on the road. well almost... HELP
- Clutch Pedal / Gas Pedal Vibration.
- Swapping superchargers
- "Reduced Engine Power" Message.
- Wet carpet? and wet headliner
- Scraping noise?
- Lost orientation of strut mount help please
- blower motor
- Bypass Valve Sticking
- Thermostat done?
- Code p0010
- P0420
- Brake Booster Sensor part #
- Keyless remote
- Here's one for you....
- no 2 4 r
- Any SOLVED misfiring issues out here??
- wideband numbers...
- Water getting into my car
- gen 3 headlight Help anyone
- Unlock switch
- Help!!!!!!!!!!!!
- lnf wheel hub in an lsj
- Problem with aeroforce gauge
- Quick question
- timing 2.4
- Avg. Idle readings?
- car shuts off and turns back on while driving!?!?!?!?
- Cylinder 2 misfire. & other ?'s..
- Loud clicking/tapping noise under dash...
- 09 LS over heating??? help please
- Noise when backing up
- Flapping/Knocking noise under acceleration
- Cobalt down
- wideband
- inner fender problem
- Electrical problem? help please
- Electrical issues with accessory on the ignition
- I broke my car :(
- P0230 help
- Time to get my car in the best shape of its life!
- ***Key Snapped Off in the Ignition!***
- Idling at 20AFR? and misfire
- MPG question
- jacking up car
- tb cleaning and rough idle
- Warranty Work
- AC Recharge - Need help!
- a noise I cant find where it is coming from
- Possible Throw out bearing? Doesn't move..
- p0107 and p0122 need some help THANKS :)!!!!!
- fuel rail valve
- problem with hids
- AC controls quit working
- Car wont start heeeeewwwwwwwllllppppp
- Fuel Leak
- onvent solenoid and fuel tank pressure sensor colors
- Need Help!!!!!
- 2.2 overheating
- Help! Windshield Wipers Not Function Properly
- Hard Starting
- service air bag?
- Clutch Problems.. Help
- Fog light HID sometimes works
- Torque Steer, how to get rid of it?
- TSB Request :)
- help! noise from rotor
- rear coupe tailight blinker is out
- effing cracking fiberglass bumper! rawr!
- LSJ Bad engine noise - timing chain? or something else...
- Bad hub assembly..?
- Time for a new Water Pump?
- Tial bov problems. Please help
- radio issues?
- P2177
- electrical prob
- Will GM fix this?
- Fluttering/metal noise
- wont start
- Sc bearing
- how is this possible??
- Weird idle when cold
- Help, car won't start after replacing timing chain tensioner
- Is my motor hydrolocked?!?!
- Bogging when the A/C is on
- P0133 and P1133
- How much SC oil does the Harrop TVS use?
- Moisture in Headlight
- Tranny shifting hard ??? Please Help!!
- hight iat2 temp
- wheel not centered with my steering wheel
- power steering
- F23-M86 removal?
- 2010 SS/TC Flutter?
- Water?
- CEL p0100
- Sound shifting into first from neutral! HELP!
- 2.2 sc promblem
- messed up idle and car keeps running after i take the key out
- CEL from locked up Tranny?
- steering issue help
- IAT2's are all over the place
- Key stuck, ENG PWR reduced
- alternator on the way out?
- speedometer problem
- Help with P0068 - ENG PWR REDUCED
- Rough rough idle at cold start?
- ummm? trifecta tune wot surge?
- Clunking when accelerating
- Engine RPM increase out of my control
- good piping patern
- buying a cobalt, worried it has a problem, please help!
- p1112 p1113 BOOST LEAK
- Stage 3?
- WTF Plug Gap
- Car won't start
- LSJ clutch question..
- steering column and esa issues
- HELP!!!! Is this the right radiator? O'Reilly's says yes.
- P0420 and P0171 Need to pass smog soon!
- need help immediate
- Oil change intervals... oil life monitoring ???
- Cobalt 06 - LTZ - NO START - BAT OK - ALL LIGHTS ON ODOMETER SHOWS '-----'
- help!!!!! o2 may have shorted and replaced but diffrent codes
- Exhaust Problem?
- need a new clutch???noob again<<<
- where's this water coming from? (drivers floormat)
- New LNF rotors... any suggestions?
- New Clutch problem
- power steering intermittent! HELP ASAP!
- Halp It died
- still getting vibration in the front wheels
- Starting issue; battery?
- Clutch problems... quick question...
- FML!!!!! big problemm
- TC light is on, car is shifting hard.
- Question on check engine light?
- i got a problem I CANT EXPRESS MYSELF WITHOUT SWEARING locks and car beeps inside
- Are you tired of running low on oil even with Synthetic?
- 60k?
- loss of boost pressure..
- Engine Noise?...
- lower MPG after changing oxygen sensor
- dirt in engine help
- Code 2176
- my car got keeeyed!!!
- need a big hammer to get into 2nd gear
- ic pump (noob question)
- Tap Tap Tap Sound From Trunk Area
- ignition lock!??
- High Idle & P0171
- Squeeeekkkkk
- Mileage...
- need opinions
- help getting the pulley off
- How to replace evap purge solenoid valve?
- Has anyone had their dome light completely stop working9
- aeroforce interceptor gone blank?
- Car shakes while accelerating?
- Passenger door handle squeaks when opened. (exterior)
- car pullin to the left!!
- Clutch Rod Came Loose???
- Trouble reading outside temperature
- need help fast with bixenon retro install!
- Reverse lights wont come on HELP Please
- Car randomly shutting off....
- The Infamous Rear Brake Problem...
- clips on headlights??
- Weird squeak/rattle
- How do i get my turn signal to work on 4th gens w/ HIDS?
- Dead Steering Wheel
- DLC Won't work when I plug in OBD
- High pitched sound at WOT
- P0106 MAP Sensor
- Intermittent/Inconsistent Starting Problem
- Loud Ticking
