- stutter at 3-4k rpm???
- Dying turbo?
- optima batteries
- 06 SS oil service reset - simple question
- cylinders dead
- LUGS SNAPPED OFF! WTF ADVICE?? pics inside
- 2.2 Coolant 50/50 question
- Car doesn't start/Turn Key and nothing happens
- ottp heat exchanger question
- Tranny problem, ne1 else have this?
- Door won't latch when being shut
- EBC green stuff pads
- sc bolt got stripped
- MAF which way does the arrow point?
- Help me out with quick question...
- Front End Noise?
- Fuse Box Part Number
- Candi module
- new car battery
- GF crashed the 'balt, with pics
- Steering column/ Cylinder Ignition
- 06 Chevy Malibu Steering column replacement
- Please help door won't open
- Help me pass emissions!!!
- weird vibration and noise.
- Where can I get these?
- Odd noise from the front
- service brakes soon
- Steering rack gone bad??
- Possible Rear Main Seal Leak?
- P0420
- aeroforce interceptor first!!!!!!!!!!!!!!!!!!!!!!!
- Seven Error Codes
- knock at steady throttle.
- Question about 2.2 brakes.
- My gas is Leaking???
- How do I stop my AC from coming on when I have it set to foot?
- TC trans issue
- Blinker on a 07 2.2L Coupe
- p0622 Generator ???
- Cracked accordian flex pipe!!??
- If anyone could solve this puzzle that'd be great
- weird knockin noise
- SES light and no cruise. HELP!
- 05 2.2 will not start... any help?
- Electrical Issues.
- Broken Door Handle!
- HELP! Car died
- Electrical problem??
- car is stuck on!! running outta gas!
- Car wont start! Help plz
- Auto dim mirror fuse
- WOW what a situation
- Drive by wire problem?
- Interceptor doesn't work
- Exhaust Problem... Any Ideas?
- Fit and finish/ build quality issues.........
- I just lost my dash lights. Brand new '10 SS Coupe, 1700 miles.....
- Bye bye Auto Tranny :(
- Center Console removal help
- Hood Latch Sensor Replacement
- Transmission Fluid Change on TC
- Weird Problem
- Gas Gauge messing up?
- Vacuum Test indicating worn valve guides??
- Road Noise
- what size nut on sway endlink?
- help
- Take apart tail lights?
- Hissing noise under low acceleration
- Cf trunk and cruise control
- Question about clutch install covered by warranty or not?
- DRL Problem!!
- Service airbag light
- Engine Noise
- can you help me, help someone else??
- Not running smooth until warmed up, checked all normal stuff...
- gm parts direct
- ? about CEL on my brother's Cobalt 2.2 LT, SAI problem
- HID problem
- Why would a srvice tech spray my tranny mount orange?
- Horn wires?
- Intake manifold removal?
- I think my BCM went bad
- Performance Problems!! Help!!
- anyone know what the part number is for this?
- A bit of a delema
- Headlight Issue
- Wierd Problem developing
- Fog Light trouble
- Supercharger belt squeaking?
- No turbo power and Engine light
- Weird noise in by right front tire.
- Coolant flush? how do you do this?
- Brake Pedal Problems
- P0017 code help please
- Got a letter today about 09 ss/tc key cylinder
- ABS & TC Lights on at same time...
- P0131, rough idle, bogging, no power. Help!!
- Clutch slipping?.. maybe?..
- Need help asap message on heads up guage
- gas station = won't idle.
- Water leaking around back window???
- Who has broken the mounting things off the bottom of thier headlights?!?!
- frozen shifter problems
- Another idle question...
- new car question
- 2.2 to 2.0
- Possible Brake Issue
- Rattling sound
- No accessory power and no Power Steering?
- Quick Question about Cobalt SC idle...
- Fuel Filter
- coolant leaking.....
- Coolant leak...
- Blower Surge...
- sunroof problem
- Weird Idle Issue
- Boost Bypass Solenoid
- Why are dealers f***ing dumb
- Sunroof won't close!!!! NOOOOOOOOOO!!!
- OEM SS S/C Bumper ???????????????
- lsj tb on 2.4 manifold
- P0036 lsj
- Groaning Noise
- Help noise coming from right front wheel ?
- Brake Fluid Low
- SC no boost
- Where can I get a parking brake cable?
- Water under headlight SOS
- door hinges
- abs brake fluid ebrake light and gauges cutting off
- cant figure out how to change my tail light bulb
- Wipers not working
- oil in stock charge piping
- Please help!! Have all 4 cyl misfiring!
- autozone can't read my Check engine light
- Rough Idle at start up, then goes away
- fogs burning out!
- Pcm
- Throttle body
- quick question about headlight bulbs?
- Timing chain
- P300, P304 misfire
- Dented center cap on steering wheel
- transmition problems...fml
- General Motors needs to issue a recall on their Chevy Cobalt control arm bushings.
- P0204
- Keyless Entry, Tire Sensors Don't Work After Jumping Car
- my first engine power reduce...
- heated seats
- RPM floats when shifting gears
- Trunk release wont work
- Lost all gears! Help
- P0300
- Bye bye cobalt =[
- Running lean, have diagnostic specs! help
- Busted spoiler
- prob help!
- steering coloum fucked?
- Can someone help me?
- IC Pump Tips?
- Oil Dipstick
- Big problems. need help asap..
- Hid issue
- Can't drive...
- Stalled while parking (SC'd automatic)
- Couple Questions.
- Vibration in front wheels?
- sunroof button and trim piece vibrates so bad
- Cobalt SS Low coolant
- Confused and looking for help!
- My car is acting crazy! Please help!!
- scan tool.
- code help
- 2002 neon
- Advice please. Engine power Reduced P0068 CEL
- Hurst STS missing 5th gear
- gauge cluster, boost gauge, steering wheel back lights not on
- Problem
- Rear Defogger Not Working...
- Fuel on spark plug
- car starts vibrating at 80km/hr
- Exhaust Cam Solenoid Replacement
- Engine problems
- intake issues
- Bottom lip front/rear bumper
- keyfob replace
- Loose battery terminal
- my car isn't getting any spark
- HELP! jump starting car
- need help if u can
- 09 ss/tc with code p0089
- P2096
- ac condensor issue ss/sc
- Threaded screw thing behind door panel?
- Got codes...now what?
- Has anyone else had these issues? (Drive-ability Concerns)
- Tuned SS rough idle and more
- 08 ss/tc fans wont go off
- Shaking while under throttle
- sunroof grinding
- lsj - p0133 - p1133
- exhaust leak
- Bumper Cover Replacement (2008 Cobalt)
- Need help with TUNE...
- Your Experience with P0014
- What could cause my plugs to do this???
- HELP ME! 09SS chews up and spits out rotors on a regular basis? Advice?
- Sunroof uneven outside?
- Oil Life %
- Blower motor loud in my Cobalt?
- 3rd and 4th
- help removing fog light
- Air Leak
- clunking in right rear!???
- Clutch Pedal Position Switch.
- paint peeling
- See Anything Wrong?
- LSJ will not start.
- Knocking sound after car is off
- Oil everywhere! Need help please!
- temp concern
- parking brake lever
- 2006 ss/sc dyno
- Help!
- mass air flow question
- Goodwill replacement on Flexpipes
- check engine light is dim, can barely see it.
- Grinding noise under car
- Spark plugs issue?
- Evap system problems P0455 P0497
- tranny swap
- Removing Secondary Air Injection
- Ugh key wont come out
- po340
- My engine and dealer problems - Part 2
- My car won't be driven for 3 months
- Air filter question
- Cruise Control issues/questions...
- Steering knock/popping problem
- insuance question
- Rotation Noise..?? Help!
- abs light on, brakes not releasing, help please
- I need a Center Cap for 2009 16" Alloys
- vin number help
- Help with Codes
- What is included in a 30,000 mile service?
- 07 Cobalt Sedan door handle Part #
