- AEM Uego Pegging 10
- Computer took another shit
- exhaust rattling
- Squeak
- Whining noise on acceleration @40 klms
- Cobalt cruise control 2009
- Help with BCM on my '05 Cobalt
- squeaky noise and abs light??
- Motor Swap, HELP Codes
- Door lock actuators....
- Headlight Problem
- Tune file Locked?????
- cel problems/ horrible mileage
- bad resonator??
- flickering lights
- PO420 code
- moisture inside car
- Lack of Power 4500+ RPM
- Throwing a few codes. HELP
- starting problem
- P2135 help!
- Driver Door Won't Open
- finding a map sensor
- What would cause this?
- exhaust problem
- Car just Stalled
- O2 sensor
- car wont start(ottp stage 2)
- Everyone's help is needed ASAP
- Dealer f***** up the trunk release button!
- Warranty Transmission Swap?? Should I go for it??
- Rear-ended and need help
- cruise control problem
- shot/leaky struts
- another fuel related promblem >_<
- 2.4 Crank Case Relearn????
- Cold Air Intake = CEL?
- whats going on?
- Ignition Problem
- fuel pump issues HELP!!
- fuel pressure promblem
- headlight issue
- Help!
- timing chanin jump teeth!!!!help
- Shifter noise
- Premature Rear brake wear
- Cracked Trans, Broken Axle Seal, Destroyed Hydraulic Slave Cylinder
- Knocking in steering wheel
- Loud Noise at Low Speeds 06 SS/SC
- Removing Licence Plate Bracket
- New Engine as well :D
- P2178- Question
- New engine
- Bouncing, shuttering?
- Fuel leak
- Boost Gauge not working.
- 30k Miles/ Fried Altnerator/ 800$/ WTF?!
- power steering
- 5th gear
- help with dp
- monitor readines issues
- Annoying tire pressure sensor...
- Issue after header install
- Tire noise or something worse?
- Help please!!!
- Driver's side front parking light
- car shakes HELP!!!!!
- switchback led prom
- quick ?
- Please help :( waterpump problem
- HELP!!!!! coolant leaking...
- Battery problems?
- Weird sound and Hesitation???
- stalling in an automatic?
- Weird exhaust noise with new intake
- Popping noise when accerelrating and deccelrating
- Battery issue?
- 1990 honda accord tail light problems... expert needed
- help with relay harness and hids
- Porous block? blown head gasket? we'll see..
- OBD monitor reset time?
- Help/advice
- headlight wont stay on
- Ext warranty + sunroof?
- Please Help, codes, rough idle, high idle, barely starts, vac leak?
- Throttle Body Cleaning - idle air passage?
- P0341 and P0130
- P0300 on 2.2 random misfire HELP
- Stuck in Park (Please Help)
- P0107 & P2187 Irritation
- Bucking problem at 50% throttle
- Don't know where to start
- third brake light out
- Throwing three codes...HELP!!
- Temprature Guage
- headlight wiring help
- problem with stock radio help pkease
- Possible boost issue on SS/TC
- 07 ss/sc new codes thrown(and some old)
- please help diagnose exhaust noise (acceleration only)
- weird brake problem
- code p0100 and p0102 + boost problems
- Sunroof Noisy
- Problem?
- ignition
- '05 SS jumping time again....
- low vacuum
- Replaced head unit, car will not crank.
- Cel p0420
- OnStar Red Light..
- 05' Cobalt won't start HELP please
- ball hone
- Limp Mode
- check engine light flashing
- Boost Gauge Backlight
- O2 Sensor Help - P0054
- noisy shift linkage
- Smacked Exhaust, Now Slight Airy Noise..??
- Clutch master?
- oh the issues i have...
- Oil Cap Spacer?
- How To Run Seafoam On Cobalt..
- CEL Galore!
- Axle Problems
- cel just came up help???
- Read, lots of vibration while coasting in gear
- Big Issue with TPS and O2 sensor codes.
- How do I remove the EVAP canister vent solenoid?
- Power Steering Wheel HELP
- drive cycle
- why duraflex!? why?!
- Possibly IC Pump Going Out...?
- Just purchased 2005 SS/SC and have some issues...looking for insight
- Hole in firewall!
- Hit cone, no boost, won't stay running.
- P0171 Too Lean Code
- DTC code
- horn issue
- Buying tips?
- Shifter assembly on 2.0
- Got a smell promblem
- glowshift wideband...please help
- Lc1-Innovate Wideband install
- Cleaning Air Filter
- Please Help With CEL Code P0011
- Please help with phantom noise..
- Service Air Bag
- weird noise....off road tires?
- Please Help! Salvage car repair my dad and I just started
- need helop
- Need help swapping my thermostat
- No Power, Unresponsive, No Boost
- General Motors=biggest POS company around. Warranties are being denied.
- car want stay running
- diagnostics came back, need your help!
- Mobil 1 5W30
- ss/sc front wheel studs...
- Help! - need info on replacing driver's rear turn signal
- Code P2135
- Shaking/vibration under acceleration
- Scraping/Knocking noise coming from cam sensor body
- water leaking in car when a/c is running
- Help head gasket leaking!!!!!
- Pulling under acceleration to the right
- Constantly under going transmission failure/looking for info on the lemon law.
- engine problem need advice
- Clutch Problem?
- Clutch problems
- Gen 3 hids, fuse blowing out for low beam?
- Need Evap Purge Solenoid Part # (LSJ)
- Major Puddle!!
- Low tire pressure?
- EPS FUSE (Electrical power steering)
- 05 throttle body?
- i need your help
- Starting trouble
- fan is always comming on
- windshield wiper control snapped off, how to turn off wipers permanently?
- Need help asap...... Sitting on side of road
- heat exchanger pump bad?
- Fuel pressure issue
- 07 with 2.4 little power in first or second. but fine in 3,4,5
- Car s misfiring? Help!
- Pads/Rotors that will eliminate brake squeal?
- After adding a K&N filter my cobalt went to shit.
- Still having starting issues
- "BRAKE" Light and "BRAKE FLUID" Hard Turns and Short Stops
- 05 Cobat wont start sometimes
- Speedometer not working
- Engine removal
- lug nut stud snapped...
- random starting??
- LSJ Turbo Losing Power after 6,400rpms
- i need a picture of . . . . .
- Noise when turning sharply at slow speeds
- t/c problem and cam sensor problem
- lsj not boosting correctly
- where to tune a apexi safc 2
- key stuck in ignition and car won't turn off
- clutch bleed issue solved
- i was down almost 3L of oil
- rear is scraping tire over bumps
- passenger presence system
- Turbocharger not working
- Transmission issues... HELP! please.
- Much needed help.
- Just got GM stage 2 installed....question
- 3 CEL codes. P0300,p0420,p0496
- GM voiding my warrenty over hahn CIA
- Anyone ever had their bumper broken by a tow truck?
- P2431 Anyone know how to fix it
- Rear brake and tire sensor issues not fixed
- What wire to tap/where to get a good clean tach signal for a widow switch?
- Choking on gas
- Tranny Acting Up...
- brake squeek
- my 07 transmission keeps breaking
- busted flex pipe?
- Gauge Cluster problem...
- 2006 SS Supercharged Coolant Leak. HELP!
- gen 2 projectors help please
- Is this 1 or 2 codes
- High/low beam issue
- Good Price?
- e brake works all of a sudden
- Steering Wheel Shakes while going over bumps
- P0133
- Help!!!!
- Traction control light on (rough shifting)
- door wont open
- coolant temp display and a/c
- Both brake blubs replaced twice in 1 month. 3rd is fine
- Car unlocks itself!?
- Ignition key stuck in igntion???wtf
- Power window problem
- Rear Wheel Rusted to drum brake
- car shuts off
- Door panel clips
- Hole in intake manifold... can here air creeping in through it.
- Cat Recall can anyone input my vin...
- clutch slow engaging?
- weird noise in 1st n 2nd gear
- Relay ticking
- intercooler pump
- air coming out of the intake
- Start Up Idle Issue
- intermediate shaft installation
- A/C compressor
- Havent Posted in a while... Back with a problem for you all. Guage cluster short?
- is hydrolock under warranty?
