- steering shaft
- WTF is wrong with my temps
- stage 2 problem help fast
- Oil change poll
- Intermittant Tapping Noise
- meth problem
- car starts when it feels like it issue
- Concern/Possible Problem with Intercooler
- Lost all electrical power then it comes back on.
- Code after s/c swap
- please help
- rear breaks wear on angle
- The Clutch ISSUES continue
- big puff of smoke now weird noise help asap
- Front Brake Hex Socket Size?
- Coolant problem
- Lost Acceleration
- fuel injectors
- need help stage 2 belt
- halo problem?
- Engine power issue
- Car has problem starting after gas is put in.... help
- barley 5psi of boost
- cruise control not working??
- ebrake light on
- tensioner tool help! like asap lol this sucks
- Low coolant message & black soot
- engine pwr reduced (miss)
- Supercharger Bypass Valve Hoses
- Front End issues
- a couple of DTCs
- Filling Up Gas
- Excessive Road Noise
- Befor i go assuming
- Water in fog light housing anyone?
- Radio volume controls not working...
- shifting = cel
- Serious problems with "Reduced Engine Power" NEED HELP!
- clutch problem
- HID bulb burnt out
- brakes making noise?
- 44% oil, time for a change?
- Need Help!!
- 06 ls won't start?????????
- Trany light on...Car in limp mode
- aeroforce interceptor help!
- OTTP Stg3
- Bad Situation (what to do?)
- Exhaust Blew apart
- Strange A/C problem
- cracked oil filter housing
- Low Coolant & Air Intake Temp Sensor 1
- Broken shift trigger
- Strange popping when backing out of parking lots
- key won't come out of the ignition
- Cigarette / outlet fuse
- clicking?
- Stuck key self repair?
- Beep beep...
- I need help with knocking sound!!!!
- problems with cluster
- ss/sc clutch
- ottp
- Door locking issue
- 2006 Stock Cobalt/P0010
- Fan Making Noises
- ottp order gone sooo wrong
- massive boost leak? help appreciated!
- Engine rattle...timing chain???
- code 1174
- Overheating and smoke
- Reving weirdness and second gear hesitation
- Help lol
- '08 SS heater core???
- need help with halogen ring
- can i run 07 lowering springs on an 09?
- Need help with gen 1 healights
- Clutch is acting goofy?
- Trouble on Startup
- Help Please! Electrical Ignition Problem.
- Brake Fluid Warning Message..??
- help, my check ingine light is on p0171
- Hesitation and lurching under throttle. (wetness?)
- How messed up is this bs
- Secondary air injection system pressure sensor any help?
- 06 balt piece o junk....
- My wonderful Cobalt SS/SC experience *extreme sarcasm*
- Trying to teach my girlfriend how to drive a stick
- ecm pinout?
- barely avoided serious problems...
- Diagnosis: noise while turning wheel, need your help
- Oh no!!
- Ebrake problem...
- ESC Light ? being to low?
- P???
- Fuel Ran Brake?
- not bpv but ?.....help
- Thumping??
- ottp order and install gone bad
- Rear windows won't roll down.
- Suspension problems
- Something is still wrong
- service traction, brake lights stuck on
- Need Help CEL problem
- Unable to start
- Anyone replaced any of thier 09 SS/TC injectors yet?
- Burning Smell
- Need help with lights
- P0341 say whaatttt???
- P0128 wtf!
- Engin idles hight after heavy load
- brake noise please help
- Mystery air conditioning
- No clutch pedal need help
- gas gauge
- Supercharger problem.
- LSJ DP install throws code
- Cooling Problem
- High Beams won't turn on when stick pushed forward, but will when pulled back.
- front end clunking
- Bearings in the SC
- 2009 Turbo Misfire Code wont erase
- ._. why me...
- problem log
- ECU Swap
- Remote Start Doesn't work
- Tuning Q?
- Cold start 1st gear grind?
- Trunk only opens with keys, fuse is not blown
- fuel pressure
- What the heck is going on?
- Check engine light
- Ac help please
- Car Problems
- Car died after acceleration
- air charge cooler pump
- p0013 and p0130 HELP!!
- 16 at most
- Crank shaft posion sensor
- What is this? (on TC intake pipe)
- Help!!! Car has no power
- After GMPP catback install CEL!?
- Trouble starting and something leaking...
- Clunking
- Keep burning out gaskets
- first gear problem
- Fuel In My OIL! All started with misfiring under boost.
- headlight housing?
- clutch
- Car running sluggish+no boost.
- high pitched squeek any guesses?
- Engine creeking
- help with car with video.
- New TSB : Aftermarket tunes
- HID problem help please
- knock
- A/C cluster
- Onstar eats your battery?
- bad brakes cause light?
- Slight vibration/ shuttering feeling
- Broken Shift Linkage?
- Rear Brakes
- Timing Chain Tensioner BROKEN!!!!
- servise air bag
- 2005 SS big wirring problem please help
- Ac line ruptured - Chevy dealer says my fault...
- TVS boost problem
- E-Brake not working?
- tap noise
- Service tire pressure sensor... ugh second sensor this week
- a/c not working
- Help! P0102
- Radiator problems help please
- rear control arm bolt striped! help asap!
- Intercooler Pump Question
- thread/pitch for Header studs?
- air fuel ratio.
- P0131 and P2096
- downpipe studs
- boost problem, please help
- i dont think my car is running right!
- HID Problemo
- Broken Engine Mount Bolt
- Do Not Trust Certain Dealerships On RECALL!
- Is my catty going batty?
- Looking for Cobalt SS/SC people in my area!!!
- idol and exhaust problem....please help!!!
- clutch please help
- hid fog lights flicker. what the hey??
- aem a/f gauge problem
- How reliable is my Cobalt SS/SC?
- Spark plug blown from #2 cylinder
- Any1 get CEL's with full exhaust (2.4L)
- P0340, P0140 lots of very scary valve train noise!!!!!
- throttle body wiring help
- 'Battery Saver On' Question
- 2nd gear problem
- Hit a cat at 65mph
- recaros
- Headlight Problem
- Replace Front Bowtie /(Emblem) With SS
- They told me I overfilled my oil...
- Valve cover leaking oil
- drove my brothers civic last night and...
- Steering Rattle
- HID Help
- Help Squealing Rear Brakes
- Lose of boost when doing no lift shift
- change headlight bulb
- oil on top of piston?
- odd noise, mostly at acceleration
- new halo proj. headlight install
- Exhaust leak...help me find it
- transmission failure???
- clutch issues??????
- intercooler tank broke
- wont start after fill up
- Clunk sound over bumps, pulls hard to right when accelerating
- Electric Power Steering
- if my thermostat is stuck open is this what i need to buy
- white smoke after WOT
- Two CEL's.. One recurring, one new..
- Throwing code P0449
- Outside Temperature Wrong
- Key won't turn. Up shit creek.
- d.s. door problem
- hub not attaching?
- BAD Misfires, Need Help with this one!
- Replacing lifters
- Variable Cam Timing Solenoid
- Oil leak, turns into major overall(possible engine replacement)
- I need some help
- New exhaust, throwing Oxygen sensor codes???
- Too much coolant?
- Something just F upped on my 09 SS e-brake.
- P0128 code
- Back up light
- OBD II lean
- Can't take my key out of my ignition
- CEL problems......P1133, P0133, and P0136....
- Computer reset
- another P0455 code with more.
- boost control solenoid
- Fueling issue (maybe CDFP?)
- e brake problems
- gauge pod problem
- fuel rail problem
- 2 codes..
- Rich exhaust P0172
- Key fob for 06's 07's LSJ's
