- Radio issue
- Traction control, cruise control, auto locks not working
- Help with my antenna
- rough idle, only sometimes though
- 2001 nav
- magnaflow muffler problem
- Need help with fuel pump
- ABS light on....
- P0131 and p0171 nightmare!!!
- went to dealer today...not good news...
- Noisy muffler, not in a good way?
- Heater/A/C Blower Motor Squeels
- Headlight Bolt Size
- Issue with Fuel pump? Throwing code P0496
- Power Steering Assist Recall #10023
- Turn Signals Won't Shut-Off...
- Part # for rear bulb
- Traction Off and ABS indicators still on.
- car wount start help please!!!!
- low power
- Installed Stage 2. Goes into LImp mode HELP!
- Race Car Accident
- exhaust too loud! questions
- projercter help!!
- No success
- Tips, Tricks, and Info on the Cobalt SS
- Metric to Imperial Dash Info????????
- Turn Signal Wiring Harness?
- Help - Super Glue Removal
- Engine Stalling
- Exhaust Manifold
- SS/TC 2 CEL's
- P2187 (I think I see the fix)
- Power Door Locks not Responding, Have to Operate Manually
- exhaust leak?
- Strange ticking while braking
- check engine light
- clutch difficult to engage
- Keyfob for 06 ss/sc
- hit a TURKEY
- e-brake problem
- Fuel Pump Part #
- Radio problem
- Terrible terrible sounds....
- bad idle and check engine light question
- Rattle from sunroof on 2009 Cobalt SS.
- P0302
- stupid CEL/ Idle surge
- cylinder missfire
- Help quick question - Water in 02 sensor
- spark plugs
- Front bumper grille replacement?
- Help please!!!
- ss/sc started jerking real bad. help
- Steering: wandering above 40mph (DANGEROUS)
- wideband question
- Weird Idle- Crazy RPM Flare- Jerking while in gear....stall....
- Water in Intake
- shift cable on the ss tc
- In the shop
- foglight button
- Second Wire in driver side headlight
- Dumbest effin Boost leak test problem
- Can a cam or valves squeal ? PLEASE HELP!
- Looking for a part
- oxygen sensor?
- AC issue
- fuel guage reads backwards
- Shitty american made oil filters
- Key starts car, wont turn in doors or trunk.
- abs t/c and engine lights on
- Where does this go????
- Tail lights acting up
- Fuel Pump problem? Help appreciated
- Help! big problem
- squeaking
- scratch on glass?
- car trouble
- service airbag soon light, stays on for 2 sec, comes back 10 min later...
- Running really lean
- zzp header dp combo
- no traction or clutch sliping
- dont know why this is happening
- Door locks wont lock with remote or door buttons
- Tire rubbing
- check your temp sensor wires
- Am I missing something?
- More on the Cobalt/G5 Stop delivery
- Temp reading not working
- Part throttle surge?
- ok im sick of this
- A little smoke
- Anyone ever have this problem? AKA Haunted Stereo
- projecter help!!!
- O2 CEL's safe to ignore?
- GM Recalls Cobalts for Power Steering
- My parking brake is broken. i need your opinions
- P1516 code! Starts only 1/4 of the time
- security light on?
- Boost Gauge
- Gettin g a Tow
- Caliper Bolt Size
- Missfire issue
- help
- valve noise/cam lobe looks bad
- Spark Plugs
- Misfire question?
- Case learn with interceptor ...
- invisible "CEL" problems
- USB Radio (UUI) Device Compatibility (09-08-44-013A)
- Multiple Cylinder Misfire Problem
- Need Help!!!
- i need help whit my curse control
- Exhaust Rattle
- Moderate to Hard Acceleration issue
- Saftey Recall Notice certain 2007 models
- Power Steerting Problem
- can you adjust factory amp on sub on ss/sc
- outside air temp reading frozen
- Thumping when turning left hard, replaced CV axle, bearing and CABs
- If you have a Sunroof
- help asap
- flourecent yellow liquid under my car?
- SS/TC Parking Brake.
- Air bag /wheel
- Squeeky clutch pedal
- tire pressure light stays on
- Front Brake Squeal
- Fuse box issues no start. help!
- Magnuson Warranty Act-
- ls 2.2 ENGINE RUNNING HOT
- Quick HID question
- GM LNF upgrade boost psi low.
- Auto-shifter lights on and off
- service air bag message
- 98 Grand Prix GTP Tune
- P0172 help?
- need help ASAP!
- Boost-By-Pass Valve Replacement
- Hello all, Quick Question About This Clicking or Fan noise when i turn my AC on
- Tired of misfires!!
- High-rise Spoiler Not "Solid"?
- dealership problem
- 2009 Cobalt LT - Tranny Problem
- Ghost rubbing noise and vibe
- HELP - spoiler problem
- P0107 comes on and off once a night
- Check engine light on yesterday off today?
- Major misfiring issue
- E-Brake wont work at all
- Cobalt Stalling, torque converter?
- engine power reduced
- P0433 & p2229
- Gentlemen... I need some help with GM warranty...
- New battery won't start help!
- Bad clutch disc?
- Electrical problems IDK
- tire wear
- Chevy Cobalt steering complaints under investigation
- Broken Piece off LNF Intake
- Weird Rear brake issue 07 cobalt ls
- e-brake not working solution.
- Help replacing shift knob
- SS/TC Rear Brakes.
- i need answers quick :(
- parts
- how to test maf sensor
- P0172 rich?
- Tranny leaking Fluid Please help
- im having electrical problems.. need help
- Fuel Pump??
- E-Brake
- No dash lights
- tb and intake manifold issue
- Help Backseats
- Help please, i messed something up
- LNF Intercooler Part #?
- WOnt stop misfiring?!
- DEAD Cobalt please help
- electrical issues
- transmission differential
- NHTSA reportedly investigating Chevrolet Cobalt power steering failures
- Random P0420
- CAN OBD II Scanner
- Issue with Aerforce Interceptor Gauge
- ESC Active
- Code P1682??
- Really need a SC 2.0 Head!
- Alternator/Water pump/AC Comp Bearings Bad?
- clutch related problem
- CEL P013A with LNF ZZP DP
- 350 miles so far
- AEM uego problems
- CLutch!
- Cel: P0128
- Many Problems
- Broken shift cable
- I've got issues
- new intake check engine lt now?
- Automatic Transmission Change
- Won't idle...
- bad mpg help please
- stock headlight help!!!!
- intake issue
- How much is too much?
- problem passing inspection
- General Questions
- car wont start :( HELP
- timing?
- Catalytic Converter Warranty extended to 10 Years !!!!
- 3 codes P0172, P0496, P2261
- p0603
- steering wheel rattling while braking
- fog light problem
- Rear o2 sensor
- o2 sensor questions
- Problems with an 06 SS/SC
- Rear brakes
- Serious Electrical Problems
- My RPM gauge not working ?
- G/F was right. Cooling fan not working... ECM?
- Help help help rough idel and p1133 code
- Aeroforce Interceptor HELP!
- A/C Rattle
- whining but no supercharger
- issues with supercharger.
- MAF Help
- Cobalt SS PCM
- Idk what this means
- Help!!! 06 ss/sc
- vibration issues. HELP
- 1st and 2nd gear 0 boost?!
- Cobalt stalling when Cold
- emergency brake not working, help please
- Random dead battery?
- Help ss/sc
- Need help and opinion
- Reverse light swith
- Test drove an 06 SS. rpms bouncing on start up and cutting out during acceleration
- Trouble with key remote
- Loud noise coming from the rear end
- CEL after stock DP replacement
- HID install issue
- Causes/Fixes for Misfires?
- Sunroof Lifter broken.
- windshield wash not working
- Low Boost When Cold / Possible Sticky Bypass Valve?
- strut bolt
- need help will this hurt my car?
