- Cold start problems
- Auto Start
- Traction light
- How the heck do I get the battery out???
- Help
- are my struts blown..?
- 100k mile warranty.
- WOT Box Problem
- open the door, map lights stay off?
- 100k mile tune up
- car wnt start? but it turns... help please :)
- Important news about your breaks
- Question?
- need help...
- NEW Battery/Alternator...Charging system Issues
- ss/tc weird issue as rpms raise up
- P0231
- Flex-pipe on exhaust
- Foglight Issue.. Help!
- Blowing fuses like no other
- What does this code mean?
- fuel somethin something help please!
- Thermostat Location on LSJ - HELP ASAP!!
- 07 ss/sc battery dead
- Brake grind
- Clicking sound in steering column w/ video
- Wipers stopped working
- Flashing CEL / Smells like rotten eggs
- TWM Bushings install and problem with my PERSONAL shifter assembly (pics)
- Stage 2 help!!!
- Car running too rich!
- replaceing front fenders
- Squeaky HVAC fan?
- Boost Gauge Location
- snaped my cv axle
- oil change...
- Inspection Failed. Need Advice
- Power Steering seems lose
- HID High Beam Never Works
- Gen 3 headlights HELP..
- lost acceration
- check engine light help
- whats wrong with my car???
- 60# injector idle problem...need help please
- exhaust leak
- Power steering message and tach jumps
- help with OTT stage 2
- master cylinder question
- Chirping? Blower Motor?
- GM Comes Through!
- Help Now Please. Rear Capilers
- maintenance schedule
- ticking sound ,blower???
- Update: Broken Downpipe
- Parking Brake... Broke?
- Missfire Question
- Battery Issue.. HELP!
- Brakes locking up only in reverse.
- Rear Rotor: Sliders Binding?
- broken downpipe :(
- eng power reduce mesage!
- DTC P0621 and 622????
- Airbag Light
- Suspention Nois
- Help with stock stereo
- leaking fuel
- help! possible draw in electrical
- Brakes Rubbing After Rims?
- Door Won't Close Sometimes..?
- Stupid Question...Where is my MAF Sensor
- Pot hole + 80 MPH =
- Exterior Door Handle just broke
- Problem....
- Car struggles then dies
- Reverse lights problem
- Very urgent question: Fogs
- K sport coilover....fail
- hard shiftin in 2.4 plese helppppp!!!!
- Front end Issues with 06 SS/SC
- SS logo over glovebox?
- halo led ?
- fog lights won't turn off
- Changing spark plugs
- Volume down switch on steering wheel wont work
- Bumper Cover and Absorber Broken :(
- Steering goes "clunk" when I turn
- Any help please
- 2007 AEM FIC install help!
- HELP!! lights aren't workin
- T/C light.
- dead battery or something else
- Bummer...
- Exhast rattle: Help
- Help!! Part Name?
- Issue When Getting Gas. (Car revs weird after filling)
- suspension problem?
- Power steering?
- noise i think i figured out.. what do you think?
- Possible prob?..maybe?
- no sound from radio
- Flashing CEL
- confused and dead ended
- Only 4PSI
- 06 SC wont boost over 4 PSI
- unknown sensor with nothing attached
- Boost gauge acting funky
- Reverse lights not lighting up...
- flashing CEL
- Cabin Air Filter
- Aftermarket seat problem
- need help!!!! computer reset???
- Power steering calibration?
- Unfixable exhaust leak?
- Changed the headlights... its not locking in
- Corsa Exhaust problem
- Air Leak Help?
- Stock SS/SC running lean after oil change?
- Battery light on
- Kindof offtopic, 4x4 Question?...
- Shifter not lining up
- WT... The Economy gauge goes nuts
- Codes P0068 & P0069
- No start @ 11.76 volts?
- errrr, da$% NO STARTS..
- wow sound from engine
- In need of new shifter boot bracket
- many problems ?
- Door Adjustment?
- holy wow...lots of problems
- need some info
- Oil leak near cam sensor
- e-brake broke when i pulled up
- Cel
- 2.2 transmission problem?
- maf sensor problem need help asap
- control arm bushing?
- BCM:does it matter the model
- sc conversion problem ;/
- Need help asap
- Blew a fuse.now "service airbags" & steering is locked??
- Heat/Air ticking noise
- 815?!?!?!
- Check engine light
- Quarts of Oil Needed
- P0130 CEL Help
- IC pump
- I have NO Brakes on my Balt
- hitting rev limiter @ 5k?
- Start up problems
- The MAF pig tail plug!
- Problems!!!@#$%%%
- Check System Charge... ?
- Clutch engagement noise/problem?
- Air Blowing on and off in Cabin, won't stop..HELP!!
- MAP/MAF correlation problem- PLEASE HELP!!!!!
- So I need the Supercharger coupler.....
- Problems!!!@#$%%%
- Need help with shifter cable!!
- need some cel help
- ZZP vs Eaton SC Coupler
- T/C light on and hard shifting
- Multiple Engine Misfires
- Steering Wheel Crunching Noise
- key fob problem
- outer door handles peeling
- second gear..
- Tire pressure warning light
- coolant flush for cobalt
- p0304 code
- i'm grinding 5th
- Warranty Question
- Exhaust blowout
- Trouble Opening Trunk, Rough idle
- Engine grinding noise at idle. Injectors? Supercharger?
- seafoam problem
- Low coolant, car shut off. Help
- Headlight problem
- Rough train tracks.... Car shut itself off!
- p455 p !?!?!?
- ESC/ABS light
- Odd issue
- 06 ss/sc fluctuating throttle/stall
- Another Leak..No Sunroof..No AC..
- interceptor shift light setup help
- ? about warranty work
- Door lock won't dis-engage
- Sunroof tilt not working
- Paint Peeling
- Throttle body cleaner?
- P0017
- Shifter linkage keeps popping off...
- Some help please!
- frustration- rattles
- Suspension knock over any sort of surface.
- Bad knock...bad spark plug story??? 56k beware!!
- Brakes still self-applying
- First dent
- CEL and Remote starter stops working
- Wheel balance issue with no pattern?
- Oil problem
- Power Steering?
- belt slipping???
- Oil change
- motor install help
- two problems please help
- No clue what's wrong with my 2006 2.0
- Serious Car Problems!! Help me!!
- clutch?
- Wheel bearing under warranty?
- ss 2nd gear
- Fuel line question
- New car Please help!!
- tired of it
- help me with my DD clutch please!!
- Finally opened up my transmission, found why 5th gear puked all over itself, question
- Car runs like crap when cold? Injen to blame?
- my dealer has no idea
- 1st gear and reverse
- Flex pipe cracked... dealer won't cover...
- This sucks but thanks to the dealership
- Won't let me in gear
- Fully synthetic oil necessary?
- I need new wiper blades...
- need exhaust gasket
- SS/TC - noisy clutch master cylinder
- Purge/Vent Solenoid Question
- I about had it, now the brakes?
- Low coolent
- tail lights help
- P0420
- New LNF PI: Oil Leak In High Pressure Fuel pump Area
- P0300 Random/Multiple Cylinder Misfire Detected?
- Service Airbag Soon Questions
- P0449 code help
- cam/crankshaft position, sensor b bank 1
- 2.0 t/c loud engine?
- Broken shifter cable
- need help!
- Can any body tell me whats wrong with my car.
- 2007 Cobalt SS/SC Engine Knock *video*
- Rear suspension rattle?
- weird sound when i reverse...
- Brake applying them selves... :(
- ss/tc low coolant...wtf???
- New LNF/LAF Timing PI
- Interesting Camaro Bulletin
- Clutch pedal
- steering wheel shaking
- Codes P2195, & P2096: Running lean?
- cars at dealer need a little help
