- 08 Cobalt SS Turbo hard shifting with no code
- A/C / Heater won't switch from Defrost to hand or feet vents
- 05 SS/SC not boosting
- Coolant temp guage not reading
- OEM Brake Calipers for '06 LSJ?
- bottomed out and wont start
- Couple of issues
- No crank troubleshooting
- Vibrant Downpipe Gasket Turning Dark Already?
- How to Tighten Top Bolt on Header Downpipe?
- Coolant or oil burning?!?
- Burning oil
- Man am I STUPID!!!!!
- Rear Turn signal issues Need HELP
- cobalt tc random complete power loss
- My speakers make a static noise when I use my blinkers.....
- Losing all boost at 5k
- Oil leak? And p2178
- Clicking sound from passenger side at full lock
- AAAHHHH Snapped the gas line
- Squeaky steering wheel
- Needle in a haystack
- Very modified cobalt keeps breaking CV joints
- Torquing bolts - loctite blue
- Doesn’t Want To Decelerate
- intermediate steering shaft
- P0420 code is back
- Cars throwing over 16 codes after intake cam install
- Trouble With Serpentine Belt
- Cobalt SS, what's this plug to to?
- LNF boost randomly drops to 10-12 PSI
- tester
- 2006 SC. What does this sensor connect to?
- Air flow hood/cover assembly
- Help!! New clutches wont engage
- How badly will stage 2 engine modifications hurt the engines life?
- No crank, no fuel, no cluster lights..
- Water pump replaced now bad head
- Oil starvation
- Doors are acting weird..
- Cobalt SS/NA running rich
- Low boost after intercooler pump change
- Car shut off, sounds weird now
- Electrical gremlins
- Losing coolant - oil level rising
- Reconditioning 18" rims
- Not building boost
- Rear wheel bearing seized
- Cobalt SS Engine bay wiring diagram
- Partial boost and whistle noise from turbo
- Fuel Pump Dealer Issue
- 06 passenger axle longer than stock?
- Need help finding bad ground, starter doesnt work
- starting issue
- Car shut off. Sounds way different now
- 05 2.0 sc P0017
- 08-10 service manual
- Copper Balt Blown Engine
- Brake rotors???
- Removed valve cover, now get Engine Disabled and won't start
- How to close sunroof with broken switch
- TVS 1320 info
- Intermediate Shaft Troubleshooting - HELP!!
- Replaced rack and pinion now steering clunking.
- Rust on frame near anti sway bars
- starter solenoid?
- Timing Chain Replacement- Problems-Need Advice
- header/downpipe fake cat weird noises
- TVS 1320 snout bearings
- Swapping fuel lines - questions
- Coil pack resistance #s
- HELP! Misfires in cyl 1 and 4
- Cobalt won't start after wreck
- Broken wire at base of seat belt
- Oil leak on timing cover
- p0103 p0171
- Recommended locking lugs and lug nuts?
- p2138
- 2008 Cobalt LS nightmare
- everything staying on until i open the door
- 2009 Cobalt SS rattle in neutral
- Rattle in my steering shaft
- 07 cobalt ss sc issues!
- Boost drop supercharger
- Turn over but no start
- Boost capping at 40kpa randomly
- Please recommend a borescope
- New or Rebuild?
- Speedometer only going to 20 mph on f23 swapped LSJ
- Car won't start
- Engine seized
- Burning coolent randomly around 199-205 temps
- Vacuum fluctuation and car shuddering
- Noise from engine
- Strange noise coming from engine/supercharger
- svc tire monitor without sensors
- Axle seal replacement
- Clutch rebleed then pop! Lsj
- Slight top end rattle when you give it gas. 06 SS/SC
- P0101 but have full boost
- 06 SS/SC detonation/predetonation?!
- Front sway bar install question
- P0338 wont go away help!
- Starter not engaging flywheel 2005 lsj
- Idle lope after installing 60# injectors help
- Squeak front driver side
- Changing axle seal on LNF?
- Check Engine Codes and issues
- Windshield washer pump issue
- valve cover to turbo line
- Cruise control
- Help cobalt running too rich
- 06 SS/SC vacuum lines messed up when purchased
- Traction Control off, CEL, Anti Theft and Power Steering after small accident
- couple issues
- Putrid smell while getting un"stuck".
- 06 cobalt ss no start
- Multiple misfires detected
- Bcm... Help!!
- P0340 before and after replacing sensor
- F35 transmission, I think I made a huge mistake!!
- Dash cluster back lights quit working randomly
- Airbag Light... HELPPPP
- Hesitation during WOT today
- Won't start after VC gasket replacement
- Front End Rumbling Sound
- Stupid PCV
- Ball Joint Pinch Bolt
- P0833 trouble code
- 06 cobalt ss non supercharged 2.4
- HELP starting Idle problems!!!
- Second Gear going bad?
- Where to buy quick disconnect tool for pcv line?
- Limp mode p0101 code, clutch issues.
- Reasons for 4psi
- Reliable Mechanic/Shop
- CEL problem
- Need help with CEL codes
- Engine reduced
- Shock Absorber Popped off while driving!
- ABS light code C0035
- banging on startup
- Loss of all power while driving
- Misfire at high rpms , under load , boost cut @ 5psi (lsj)
- LSJ ground wire locations
- Car doesnt want to come out of reverse
- Please help. New screaching noise while boosting
- Sludge
- Sludge
- (LNF) Won't start no fuel, have codes.
- Engine coolant temp
- replacing supercharger boost hoses
- My daily Cruze Eco MT has been getting shittier mpg than usual. Ideas?
- door wont open -_-
- Both rear brake calipers leaking fluid
- 2006, SS, 2.4, oil leak above starter below intake
- Car won't start has power
- 06 cobalt ss supercharged barely starts
- Clutch Slipping - SS/TC
- bogs and sometimes dies.
- 2007 Cobalt SS still wont start
- Fuel pump?
- I am very confused?? Why is my car only sometimes going into gear???
- odometer,dic & radio display not working
- Car quit working.... please help
- Need expert advice.
- 2007 cobalt ss 5 psi help!!!
- Looking for help with other car issues
- Sway Bar End Link Nut
- Intermittent no start
- 2006 LSJ engine per reduced.
- Car won’t start
- Throttle body
- Cobalt ss turbo leak
- no crank/no start, 07 SS/SC
- 09 SS - Timing Chain Broke?
- AC turns on when hot air is pointed to floor
- Cranks but won't start
- 06 LSJ Driving Itself In First Gear
- Cobalt LS P0017
- Starter Toast?
- Need serious help
- Bad fuel pump?
- Crank/no start; 06 LSJ
- 06 LSJ Problems
- Car trouble. Need help.
- Intermittent power steering loss
- 06’ Cobalt SS Tires
- Aftermarket sound system (stock pioneer) 07 SS
- Car chokes and back fires at full boost
- Jerking/No Acceleration!
- Broken intake rocker arms
- 2009 LNF just won't start after replacing a variety of parts
- Long cranking after fill up.
- Car died while driving today Really could use the help guys
- Clutch Slipping at high RPMs after oil change
- 06 chevy cobalt ss/sc
- Steering rattle over bumps and on gravel after ishaft replacement
- Engine Bogging Under Full Throttle or Something Else?
- Gear shift light indicator
- help please!
- Help!!
- Brief sputtering on cold startup
- 2007 Front End Clunking
- Pcm swap, CASE relearn?
- anyone heard this noise before 2008 2.0 lnf
- LSJ p0300 misifire detected! Help please
- Rockers are starting to lose paint underneath? por-15 time?
- Clutch very soft and grabs all the way at the floor
- Boost Problem
- Solenoid Valve leak??
- Fidanza flywheel sucks
- Boost problem?
- No crank , car will not start
- No crank , car will not start😐🤔
- Problems Accelerating!
- Cobalt/TC CEL P0243-Powertrain
- Power Reduced Mode
- "check charge sys"
- Bad hesitation shifting between gears
- Battery dying after new starter?
- Head gasket surface
- Option B PSI pressure test ?
- Shifter cable issue
- Mold on plastic and leather-Lost cause?
- Broke Flex Pipe on Vibrant Downpipe
- CEL after zzp header and downpipe install
- Fuel tank part broke, can I replace?
- Confused, need help please
- Burning oil while driving intermittently
- Throw Out Bearing? Or Transmission?
- White smoke no power
- Idiot lights, RPM, Speedometer and fuel needles
- P0137 After No Cat ZZP downpipe.
- Supercharger problems
- 2.0L suppercharged versus 2.2L natural aspirated
- 2006 lsj zzp stage 2 problem
- Boost leak?
- Cobalt LT 2006 P0135, driverside floor wet, accessory outlet
- Rattling in steering fix
- HID Headlights Stopped Working
- Weird Brake Noise after changing pads and rotors is this normal?
- HVAC Issues please help ( not ur normal ones)
- Emission trouble
- Breaking up in boost!!
- Can someone tell me what part this is ????
- Key fob quick question ?
- Car Alarm goes off even with FOB
- LSJ oil filter houseing, what goes here?
- No crank after engine rebuild
