- Any GM techs out there? p0128 and "---" Temp readout
- Does this sound right?
- ac houseing and heater core seal leaking water on passenger side floor in car
- New Battery - Car Still Won't Start
- FU#$kin GM!!!!!
- grinding noise
- Rubbing noise?
- New Clutch slipping
- Steering assist motor question
- AEM Wideband help!!!
- limp mode after 4000rpm
- Vibration/Noise while turning...
- Car running different
- need some help with p0171
- Need help cant pinpoint problem P0492 code with fuel up problems
- Code reader Help PLEASE
- Check engine light!
- Any way to INCREASE gap between door and dash?
- GM's +Aftermarket tunes....Diesel warranty procedure
- Turn signal in rear not working?
- Fuel leak
- Spark plug out at 18,000 miles?!
- intake PM
- Engine Problems
- Rattle from engine!!!
- Brake help....
- look ma, no brakes
- cobalt wont start/run
- Ticking.
- HID problem
- I have the best luck - Rock thru windshield..
- Oil and Fuel
- Locked out First Gear
- I hate my HIDs...
- Lame... My fuel gauge died
- WTF is going on methanol stays on and idle is messed up
- heat exchanger hose size?
- Hahn Downpipe Question
- Reduced Engine Performance- P0520, P2135, P1681
- Trunk Release button not working and Cig. Lighter
- check engine light
- O2 Sensor
- LSJ poppingout of 1st and 2nd!
- having warrantyissues?? READ THIS!
- Switch Issues
- "Service Air Bag" after new steering wheel install.
- PIC 104 race fuel caused P0090 code?
- noob hid help
- High IAT2
- water leaking on driver side
- Trans fluid?
- Electrical Problems
- LNF code P0087. Cars in Limp Mode. Help plz.
- Problem with new zzp triple gauge pod!
- low coolant wtf?
- 06 2.4L non supercharged traction control & check engine lights
- Grr Please Help. I Think Im in need of a new rocker
- Car runs really rough underboost Help Plz
- HELP: Bypassing passenger airbag
- Lemon!
- Question for GM Techs
- Newbie
- P1182 & p1183
- Whats our Scan Protocol
- tie rods fail at 20k?
- Interior Noise
- airbag problem
- Recharge air?
- cat problem
- LNF problem when NLS 1-2. Possibly Spark Plugs? Help plz
- Tps eng pwr reduced
- Car running Rich HELP!!!
- tail light problem
- big problem
- car keeps goin into limp mode
- A 2.4l COBALT
- im empty!
- ss/sc sloppy idle & air leaks??
- RPM Slow To Drop Between Shifts
- Think i got a lemon
- need help oil in gas
- oil in gas
- fuel filter need help
- Gas gauge jumpy??
- chipping on rear quarter panel.
- turbo kills ac?
- Anybody's E-Brake not working??
- Cant get my wing off
- Whiney noise when steering?
- Funky Electrical Problem?
- 2009 SS/TC Shifter problems
- 2.2L L61 Fuel Issues
- battery problems.
- radiators??
- P0420 code.
- dash vent rattle
- temp no longer shows up on gauge cluster
- Help!!!
- having problems with a left turn signal
- pissy passenger window! insight anyone?
- i cant see that much light from my right headlight
- 5/60k Powertrain Warranty Information for the 05 'Balts
- car shuts off at complete stops
- Broken Key
- Clunk noise when shifting hard into 2nd
- po171, supercharger gasket?
- Cobalt DTC list
- Cobalt All :RPO codes
- intermittant/persistant MIL
- Several Problems
- Loss of fuel???
- Terrible idle with A/C on
- car wont start help!
- electrical problem or just a fuse?
- Ticking Noise under the hood
- water coming in thru the windshield or passenger's side door?
- sputtering idle?
- how do u fix
- Rattle noise in engine?? Please help.
- lemon!
- 06 cobalt ss p1174
- radiator fan won't shut off
- PI: LNF- Intermittent DTC P2261
- TSB: Ignition Key Difficult to Remove
- exhaust
- Fans come on after car is off?
- Electical problem?
- Front-end Clunk over small sharpe bumps...Steering Rack??
- boost gauge and wipers not working
- grinding?
- two issues.. please help..
- Water comin in rear passenger seat
- traction control and rain x questions.
- 09 SS/TC loss of power
- Torque Specs for Brake Caliper Bolts?
- Thank you extended warranty
- I hate when my car rattles!
- A/C Quandry (Too much r-134a?)
- problem installing foglights
- clicking noise, auto 2.4...
- Possible damage?
- TSB : Power Steering Inoperative
- Bad leak
- Wheel studs breaking...
- Second Cracked SS/SC Trans, Suspension Issues?
- Cam Question
- USB radio problems
- ??Some Prolems??
- Problem: Any Ideas?
- so i got alot of problem help please
- no air filter installed... wow.
- Injen SRI- Can I use K&N Oil?
- I need a new Hand Brake!!!!
- HID Help !!!
- GM PI :Wheel Center Caps Loose Or Missing
- WTF just happened to my car?
- 2006 SS/SC Shift Knob Top Fell Off...How to Fix it?
- B0085...? Where is the side impact sensor located?
- One of the Accessory Outlets Will Not Work!
- Body Control Module
- friends mustang has an issue
- Would water in fuel throw a code on a 2008 Sport 2.4l
- Warranty work
- Slow rolling windows?
- Broken shift knob...
- uggggg halos
- 3rd time is the charm, hopefully!
- Need Help With Cooling System
- Just Bought a used SS, possible worn clutch?
- P2444
- Power windows
- blown out foglights
- PIP: Hesitation / Stall Engine RPO LAF LAP LAT LNF LE5 LE8 LE9
- Infamous brake pedal squeak
- Help!!!
- SS/SC Rear Calipar Sliders ?
- My window is leaking.... I think
- ECM/Electronic Problem?!?
- Front end feels loose
- Hard start after the car sits for a couple days....
- 1st gear problems....AGAIN
- RPM issues
- Bogging When Launching
- PCV Line Snapped SS/TC, Help!
- Clunking Noise Fixed Under Warranty is back and worse!!!
- Woooohooooo
- Clanking sound when starting car from exhaust
- Anyone have to replace reverse light switch
- ZZP exhaust gasket question quicky
- Swirl marks in new SS/TC
- Dtc p1133
- HELP need advice
- Help P0300
- Problems with locks
- Boost Gauge dosn't move at all
- need help, no AC or heat!
- System incomplete/unready, NYS inspection help
- Any1 want to help me install my springs friday, I have beer...
- questions leading up to my spring install...
- Water on floor
- Trunck not opening with remote
- Exhaust leak
- TPMS Reset W/O keyless entry
- Help Needed with Side Impact Sensor for 2006 Cobalt SS/SC
- Power Window Fuse Keeps Blowing.
- Issue shifting to 2nd and 4th
- Odd problem
- car won't start...
- Cig fuse ???
- help plz! power windows will not go up!
- 2008 LNF Making a Odd noise HELP any suggestions? (NO its not the direct Injection)
- blow fuse i think
- Quick problem with keypad and settings!
- Header and downpipe question
- Need H.I.D. HELP!!
- 2.4 Exhaust Leak
- Random/Multiple Misfire
- problems with power steering
- Got back from the dealership
- Car cost me some poon
- Finally Roll pin PI
- AEM UEGO wideband sensor location
- GM employees
- find a/c condenser hole
- weir idle problems after getting gas
- Full Throttle Squealing Noise
- 2.4L - intermittent hard shifting and t/c light - no MIL - HELP!
- Coolant burining on 09 Cobalt LT
- Outside Thermometer?
- Knocking Noise..
- Squeaking Noise
- DIC service esc??
- Problem, need help changing bulb
- so i called gm today about a new facia
- new header, now coolant leaks
- Insurance for my new SS
- Popping noise rolling up windows...DIC says Airbag Needs Service
- Sunroof
- CEL came on
- #4 cyl misfire on 04 Redline LSJ
- I have a problem with my car...
- Buzzing in blower
- Removing fender to adjust hood
- trans noise after clutch replaced
- oil change
- maf readings stuck on stupid...
- please help correct my cel and t/c light issue..
- Supercharger, what to look for to tell wear?
- Alarm won't stop
