- Sunroof, A-pillar, Passenger floor leak....
- 3rd brake light stays on
- Eng Pwr Reduced
- a few issues after header/dp install.. questions..
- Crappy cold starts
- 09 SS/TC Steering shake/vibration
- loud rear end...
- Engine Stalling
- Warranty Question
- Steering wheel vibrating/shaking
- steering wheel "lights" when the headlights are on: volume lights out
- New clutch but still grinds??
- So my shifter knob came off in my hand today...
- 50 amp fuse by battery blown
- Oil Life % DIC and new ECU problems
- roll pin issue
- Anyone with Access to junkyards with wrecked 05-07 Cobalt SS/SC's ??
- GM Wont pay for rental!! *rant*
- help!
- Dealer left my moon roof open in a horrible rain fall.
- New 09 SS totaled?? :(
- P0171 with these mods
- Mendral exhaust...
- Rattling sound.
- Rear Caliper Wont Compress
- p0300 with a twist
- shift cable broken and LOUD noise upon start up
- Newbie Question
- Clicking noise in steering ..
- Issues with my lights at night!!help please.
- Question for all 4 door cobalt owners... Any trim model
- Idle Problem???
- Clunk Noise On Shifts
- Car Won't Move (Feels like E-Brake is engaged)
- Air in lines?
- googly gauges?
- Color of visors, 08 cobalt SS??
- Alternator Pulley Bearings Blown???
- numerous problems
- Ventilation temp. changes from hot / cold automatically ...
- wierd noise
- Losing power and a clattering noise from engine bay
- Does my strut look blown out?
- Help: brake light not working.
- Power Steering
- outside temp not showing
- well well eng pwr rdced
- [B] Knocking noise coming from the engine[/B]
- ems fuse keeps blowing
- got a code yesterday
- 4th cylinder back fire code?
- Headlights shut off with blinker
- Supercharger Noise Question
- Couple questions bout maintenance and one problem
- 2 Problems, need some opinions.
- Spark plugs ...
- paint peel
- Thump in the trunk
- Boost Problem
- whats the problem?
- P1182 code
- Cat Converter FAIL
- Wheel bearing issues??
- mechanic says I need a new engine.
- transmission problem i think NEED HELP
- Headlight Problem, Need Help ASAP
- Headlights wont turn off!!
- No radio
- O2 Sensor P1133 Problem
- Car won't start- tries to crank but doesn't
- 2 interesting codes
- dealership and warranty issue questions
- clutch problem =(!!!
- Skirt help
- Side Skirt and door.
- A/c
- What Could it be?
- No power at OBD2 or front lighter port
- WOT Box problem!!!
- Supercharger oil
- head gasket?
- Why is it so hard to take off the lugs
- Soft Clutch Pedal
- Led Map Lights
- Hit Bump and Cobalt Stalls OUT? why?
- 1st gen halo ring went out....
- HID Problem
- Car wont accelerate turning left??
- Removing the headrest?
- Turn Signal Noise...Speaker? uhh...
- Catless DP, extremely rough idle?? anyone else with problem??
- Oil Life % DIC
- Rattling over 3k rpm?
- Power steering fail!
- Problem Starting
- Tranny?
- air bag light
- question on roters and pads
- wtf do i do about these t/c brakes
- Startup/idle really rough, then dies
- Sparking fuse!?!
- Throwing a P0017 - Details on my Experiences Recently
- helped install a system, but car wont start?
- I need help ASAP!
- Several q's
- stage 2 hub tool #
- Center console rattle found...and fixed.
- Springy stick
- Anyone know how to remove this interior piece?
- Broke radio cable!!! Need some help!
- 04 LSJ Need help car goes into limp code
- Good Mechanic in San Bernadino area?
- Air recharge submit#2
- Some quick help
- loud squeak
- LSJ DOWN!, need the experienced guys for this one serious probs
- Fuel filler neck Flapper Valve
- annoying door handle rattle
- Knock Knock!
- buzzing noise
- Opinions on blown out/dying cat
- Lucas oil Stableizer
- Another P0171 thread
- Rattle from Trunk
- Engine ticking ...
- fuel filter help
- Belt noise?
- Belt noise?
- Exhaust Leak FTL warranty issues...
- Rattle and Wind Noise: Loose Window?
- Boost Tubing.
- Clutch slip when raining?
- Help ASAP!!!
- Low Oil Pressure!!!!
- Sell GM there extended warrenty back?
- Flex Pipe Cracked
- Auto shifter problem
- bad news bout the balt
- Problem with install rpm gauge
- URGENT: computer is jacked..
- signs of slipping clutch?
- My RPM's are reving before i move...
- weird thud/pop sound from front end?
- 09' Cobalt SS/TC radio issue!
- those with p0455, quick warning
- 08 ss/tc with some problems
- Sluggish over 4000RPMs?
- The Rev
- check engine light
- tire pressure monitor problem
- Test drove an 08' that would't go into 5th gear
- it's raining INSIDE my door?!#
- Warranty Blocked?!?!?!? Wtf!
- Funky 10 second idle thing. Help?
- stock exhaust size?
- Driver door is finally stuck
- Trunk Lock Removal
- 2 codes and airbag light help.
- Exhaust leak help
- Problem with gear indicator on F35 5-speed manual?
- Steering Wheel Help!!!
- Car Just shut off
- 06 cobalt ss/sc stage 2 slips in 2nd
- 08-09 Intercooler drain valve??
- Bad air sound
- Poping noise in the front end.
- Rough Start after refill
- Loss Parking Brake.
- 15 psi max on 2.7" pulley
- Almost at 20,000 miles........suggestions on what service?
- Stuck Brake Drum
- squeak noise when i let off the brake
- Car jerks into reverse!!!
- Car shutting off 06 ss/sc
- engine coolant
- Bad brake noise
- SS/TC broken driver's seat?
- is it safe to drive in Limp mode???
- rear passenger window leaking
- I've had enough.
- anybody work at a dealership??
- Brakes - Horrible rubbing noise in reverse
- Cruise control out?
- *&$@*&@% i have a huge problem...
- only pushing 2.5 psi wtf?
- im an idiot, might have drilled in to gas tank/line
- P0420 Help
- Oil Leak! Please Help :(
- No Boost at 600 miles
- HELP! my car bogs out/shakes
- Some Problems (steering wheel, vibrations)
- weird thump
- Anyone's 2.2/2.4 shift knob fall off?
- missfiring issues
- Weird Wiggle
- Help Wrong Oil
- So... I did a bad thing
- weird noise, i dont get it.
- New Brakes
- Rear bumper replacement
- Brakes and the dealship
- Supercharger(i think) making a weird sound
- anyone else ever experience this??
- Clicking Noise when driving?
- misfiring....
- Another steering problem
- Windshield glass
- Key gets stuck in the ignition
- SS/TC reliability compared to SS/SC
- Hot Air Only ???
- mystery Misfire on all cylinders...
- Clutch pedal issue
- Hood doesn't sit flush...
- Grease Points
- Clutch Problem
- Grease Points
- Whats Your Ac Temp??
- Dealer Help NOW!!!
- DIC out of calibration possibly?
- 2.2 Burning oil?
- rear trunk lock
- Vibrant cat converter?
- i hit a bump pretty bad ( renous road in NB)
- LNF Leaks!
- headlights
- Those of you that have a Hurst STS...
- Problem
- Electric Power Steering Problem Solution
- I need help with rough idle can anyone help me pleeease?
- Misfire on LNF
- Need Help!
- How to lube up my shaft?
- New clutch
- Gotta Love the Stealerships!!
- folded pinch welds
- GRRRR Rotor problems!
- I'm an idiot!
- Spark plug is black in CYL 1
- Limp Mode AGAIN
- balts down this sucks.
- Squeeking Sound??
- quick question
- Looking to buy a 09 SS/TC. Any problems should be wary of?
- Weird Noise
- Dash bolt size????
- cai shield
- Brakes/Wheels
- Oil in engine bay. (Did some tests need help)
- F&$@*!G Door!!!
