- Heater Core
- Losing Coolant
- Help!
- fast blinker
- White/Yellow Slimmey oil in Catch Can ...Help!!!
- problem with gas gauge
- Car out of Bumper to Bumper Warrenty need "do-it Yourself" help "Vent Tube"
- fan making noise
- ignition module
- electrical help please
- Sun roof bezel broke, AGAIN. Now warranty is up.. Read
- Engine rattle
- So i guess i need a new top end.....
- Exhaust Issues...
- Problem since day 1
- Losing SC coolant. not normal right?
- P0111 and P0116 along with 2000 RPM idle??
- Cruise Control Button Gets Stuck
- hurst short throw frenzy
- Expert Opinions - Clutch Pedal Stuck on the Floor
- Need Help with Noise
- HID lights not coming on?
- Check Engine Light HELP
- Gasket Leak/Vaccum Leak
- My car ate my key!
- Heeelp Maf Issues
- Power Loss I cant find a reason.
- HELP! Headlight wiring issue..
- Unreal, I have an 07 and the battery is already dead!
- exhaust hitting rear subframe/crossbeam
- after market tach hook up
- Low Coolant
- 2008 Ss/tc Black Smoke Help!!!
- My setup's reliability
- Dash Light Icon Question
- Why Are The Tc's Breaking Soo Much???
- wtf is this noise!
- got water in the intake
- Blower noise
- LS4 TB installed...codes
- How To Take Out A Scooby (WRX)
- Passenger side clunking
- Cig Lighter Plugins not working
- leaking valve cover
- Air leaking from the flex pipe
- codes cleared but..
- low coolant
- 2009 SS brake...
- 09 ss/tc tranny light flashing......
- sunroof rattle
- Fujita can kiss my arse!!!
- Synchro problem?
- 2007 LS w/n Crank - CEL Stays On w/o Key
- problem with evap system
- How much are you paying for an alignment at the Dealer?
- National Backorder!!!!!!!!
- 2nd major problem on my 09 ss
- Changing coolant
- Defective Continentals
- charging system light 2008 SS/TC
- Keyless Entry remote?
- Replacing a gasket
- WTF happened?
- Airbag light? HELP!
- Transmission Reinstall?
- leaking from valve cover?
- headlight wiring help needed!!!!
- warrant cancled???
- F23 / F25 Getrag Transmission Design Flaw Petition to General Motors.
- girlfriendss car
- Need PARTS help
- Turn Signals not automatically cancelling...
- Key Fob/Remote Start question
- lnf 2008 cobalt ss t/c cold start issue
- Coolant temperature sensor part # ????
- Oil Pressure Light
- I've had enough.... Not getting the SS/TC...
- How do you disable the factory anti-theft lockdown???
- LNF help!!
- getting bad vibes
- 2009 Cobalt SS Lemon - I need support please!
- need 2.4L intake manifold kit help!!!
- Need help with wideband ASAP!!
- Start problem on a redline
- Cruise Control
- Noob question -- Jerking upon release of pedal
- Wiring Diagram 2005 Cobalt
- Door locks not unlocking
- Trunk Leaking
- TC issue/problem
- Power steering out after owning for one day :(
- 2008 SS/TC Problems watch out!!!
- Not a balt but...
- Rod Bearings
- P1101
- Help. Disconnected black cable behind glove box
- First "problem" with SS/tc Battery FIXED!
- Interceptor doesnt power off?
- Need service instructions for Cabin blower
- Questions for my turbo Build??
- Engine Oil in CAI
- Clunking noise from driver side rear
- 06 ss/sc warranties??
- Still Throwing CEL's
- My car problem :(
- Problems under acceleration in ss t/c
- Vibration Issue
- Hesitation and backfire
- please tell me
- Water damage!Please Help!
- Damn Cobalt
- Blower motor clicking / Axle bearing whine
- Service manual?
- Washer fluid and door locks ?
- I'm Fed up, someone please HELP! (IDLE Problem) 2.4SS
- Boost Problem 9psi???
- MAF sensor arrow
- no pressure in clutch peddle
- Funny Idea
- radio problem
- Need opinions
- 08 ss/tc noises and interior rattles
- Power steering? Malfunction,Deadly,Need a fix
- Aftermarket Headlight Issue..
- DIC Issue: Temp not working???
- Headlight Housings Wont Sit Right (help)
- Vacuum leak??? P0171 code
- needdd answer asap????
- 1600 Quote To Repair Scratch and Dent
- My ECU Is Possessed..
- Motor Blown? Cobalt Squirts.... Help!!!!!!!!!!!!!
- check engine code
- Humming/Buzzing Noise from Front passenger
- 08 SS sunroof rattle
- Random clutch slip?
- Turn signal issue?
- Mifiring Help
- broken axel
- clutch problem i think i dont know
- 4 Codes...died on highway
- should get it back monday
- locked ecu
- part number needed: cruise control switch
- Question about MAF
- Traction control on/off random
- dash rattle
- Trouble Starting?
- big power drain? help me?
- CD player is junk
- Hood strut rubbing against intake
- Intercooler pump???
- Multiple Electronic Problems...
- Does anyone know...
- anyone else have this problem
- 2nd gear grind everytime
- PLEASE HEL ASAP PLEASE!!! Can't get smoothflow hub on!
- Cobalt ss Problem????
- MPG Prob. & Detailed DTC Disctription Need Help
- ? on door panel
- GM techs... need bullitin number
- how many people have changed their sc oil and had problems?
- Scratched black door vinyls? (b-pillar)
- smoking on restart
- i think i got all the bugs worked out...
- dent in door
- F*************** Vibrations!!!
- both headlights out!
- Transmission seal leaking oil
- Well, got my car back from the dealership
- problem with rear defroster
- So, I've got a few things wrong..
- stering wheel locking please read
- Oil problem??
- passenger side power window problem
- Installing SS DP on 07 2.2
- need help quickly with bumper
- Bad MAF?
- Boost issues..Help quick
- Tune and Reflash Question
- Engine revs unneccesarily/nagging
- 07 SS/SC with Minor issue
- '06 cobalt ls blew up
- She's taking on water
- is there a trick
- Crack in flex pipe
- vvme issues
- hid issue
- Lost power to passenger headlight
- Gauges?
- Broke FLex Pipe.
- Check Engine Light - Lose Gas Cap - Code 455
- 06 2.2 failed MA emissions
- HID wont turn on
- Quik ??about tire size for my balt...
- I'm getting bad gas mileage?
- 2009 LT Coupe and Tire Sensors
- need help throwing exhst code
- bluetooth and iPod/usb playback
- strange problem on the 2.4
- Elusive Creaking/Squeaking FIX!!!!
- OEM Tire Problem. PLEASE READ!!!
- weird problem
- E-brake cable stretched 06 SS
- Shutter?..
- Dealer?!?!oh No!
- Anyone else have a problem with Gauge Cluster?
- F23 probs
- Fuel rail and injectors popping out
- P0496
- Axle click?
- need tq specs for the rod cap.. FAST! lol
- Help??
- quick piston ring help!!!
- Speedometer Recalibration
- MAF sensor question
- Outside temp is wrong
- 09 SS, Intermittent Surging on Acceleration
- car wont start
- cel and eac.. dealership problems?
- Rough/Vibrating Stops
- LSD....problem?
- Boost gauge Not working
- lighting issues
- Deleting Cats
- IC Pump Working Intermitently...
- Floor in back seat wet again
- How to tighten E-Brake?
- Hajek Chevrolet, missing bolt!!!
- Supercharger Problems?
- 2006 warranty?
- need help!!!
- Water On MAF help guys
- CEL code p0420...
- HELP!!!!! Engine Smells Like Burning. Not Good.
- keyless entry not working
- not shifting into first all the way
- two step and blinking cel
- Front Inner Fender Wells
- Supercharger BOV?
- popping out of 5th..
- Important Safety Issue: Please Read!
- Info. temp readout
- Self adjusting clutch?
- Bad Stumble at start
- Bad Mpg
- Help with clutch problem!
