- P0102 code and no boost
- 2nd Gear launch burning
- Auto Parts Warehouse
- LSJ idler pulley size or part number
- Cobalt problem need help
- Blowing fuses
- P0304 at 35k miles?
- Timing chain squeaking still after replacement
- Dont put washer fluid in your motor
- Any fellow Toronto people?
- Belt Tensioner Bushing Loose?
- Shifting issue
- P2135 Error Throttle/Pedal Position Sensor A/B Voltage Correlation
- Pedal issue
- Boosting to about 6 psi
- looking for a thought.?
- Help with P0172 running rich
- Confusing A/C issue.
- Cool Fan 1 issue
- headlight problem please help
- Stupid exhaust
- ENG PWR REDUCE 07 cobalt ss
- Knock sensor??
- Why You Shouldn't Run Your Car Low On Gas
- Tapered seat of gasket
- Handful of CEL codes!
- RPM Gauge Drop
- No idle after throttle body cleaning
- Need help please!!!
- TVS needle bearing replacement
- Miss at 2500-3k rpms
- Need help
- 2008 cobalt igntion swich
- Can I get belt locally?
- Cel p0571
- 2008 Cobalt SS/TC CEL/Oil
- Throttle problem maybe?
- seized motor or supercharger? 2009 2.2 G5
- Purple and black wire in front of driver side front wheel.
- 2009 Pontiac g5 (2.2) won't start
- Fuel Line Leak - Driver Side Rear
- Timing chain upper guide bolt broke
- Annoyances with my ss
- Intercooler pump fuse
- Squeaking when clutch out in reverse
- Wierd throttle issue after redoing intake manifold spacer
- No keys... what next
- P0449 gas filler tube
- Fuel Pulse Dampener
- Odd squeeky/rattle-like noise on startup
- LNF: Stumbling, rough and hesitent when cold
- Fuel pressure for 2.4?
- Someone smart please
- Frequent continue to crank with key released
- Starting and stalling (2.0LSJ)
- P0335 Crankshaft Position Sensor A Circuit Malfunction
- Power lag/misfire in 2nd gear
- engine light blinking and engine shuttering
- P1681 and P0171?? Zzp install
- Check eng P2101 and P2135 need help
- Overheating and a/c acting weird!
- Engine won't turn over. (sound file included)
- Balance shaft sprockets
- Zzp install-now eng per reduced on?
- 2.0 Turbo spitting poping with tune on
- Relearn? Need advice
- Need help!!! Excessif camshaft wear
- Throttle Control Actuator testing
- Check engine light and noise
- Heat Exchanger Issues
- Zzp install now I got a weird knock or sound? Need help
- Weird electrical issue
- Gas in oil?
- 2006 2.4 issues
- Dash and headlights randomly go out?
- water pump or intercooler pump?
- p0069
- Help p0172
- Cobalt
- Radio won't turn on
- Low compression 4th cylinder. Am I screwed?
- A Series of Unfortunate Events...
- car won't start. accessory works but not crank 08 TC
- where can i find this part?
- Hesitates when i give it gas?
- After market cams, p0017, tuning headache
- Engine Power Reduded
- Stuck throttle body
- Engine noise. Timing chain issue or??
- Trunk latch won't open remotely, 12 volt power sockets also stopped working...
- 2008 LNF Brake Pads Confused...
- Clutch Issue
- Please Help!!! Non supercharged motor in a supercharged car??
- Closed loop idle issue
- Anyone know what this possibly could be??
- Cold start misfire
- PSA: Hot engine & wires don't mix
- Vibrating, gritty clutch
- Loss of power. LNF
- Middle of a Rebuilding a Crashed Balt
- Aftermarket radio problems
- 06 Cobalt not starting no clicking
- 09 Cobalt SS Starter Wiring
- Engine sputter
- Jessysmommy9
- no fuel pressure from fuel rail
- Need Part No. for Cabin Filter & Reverse Bulb
- SS S/C No Boost
- All Around Brakes
- 2007 2.2 cobalt cooling fan not coming on
- 2006 timing chain, how to check
- P0102 2010 tc :(
- Weird Engine Noise
- NEW Clutch Sensor Switch installation
- p0833 Yet again
- Code U0101
- No supercharger whine after
- P0172 Code 05 cobalt SS/SC
- Lower radiator insulator?
- Looking for some wiring diagrams throttle body and gas pedal
- Please help!! Need a part identified
- p0017 COMP Cams help!
- BIG fix HELP!
- What vacuum line is this?
- Maintenance schedule?
- Cold start noise
- p0833 check engine help
- Driver/Passenger seat swap
- Battery reset: radio still remembers station presets
- door adjustment?
- ZZP adjustable tensioner
- BCM or TCM issue?
- Flashing check engine light with no noticable misfires?
- P0303 Help!
- P0128
- Idler pulley?
- Weird noise, can't figure out
- LNF Engine hesistation
- Hunting1961
- Thud from rear whne going over bumps
- Dual Interceptor gauge install now cruise control isn't working
- p0451
- Weird Acceleration Issue
- 09 Cobalt SS P1089 Code
- 2007 LSJ: WTH did the PO do to the engine(Pic)
- MAF CEL after 3rd and 4th gear pulls
- Laminova cores NASTY Dual pass end plate install
- Misfire and I'm at my wits end
- Anyone ever heard of this before?
- Need help asap
- Car Finally Gage up!
- P300 Stumbling
- Engine Change
- Rocker arm fell off
- Gaskets
- Antifreeze Suggestions
- New Cobalt owner with CEL.
- Stumbling and loss of power
- Engine CODES!!!!
- Not starting P0122 p0223
- Intermittent no fuel pressure when starting...
- Stupid Door Latches
- LNF knocking and falling on it's face at WOT
- Valve cleaning
- no power steering after working being done
- Vibration problem
- Brakes screeching
- Very hard starting
- borrow HP TUNERS ASAP
- LNF Cylinder 2 misfire
- Clutch bleeding issues with new everythinf
- No power
- Rough starting
- Timing chain replacement/pulleys ?
- 08SS Brembo bleeder cap/cover - part#?
- EVAP leak questions..
- Thumping Sound When Turning Right
- Exhaust Gasket
- Backfire problem
- P0442 and oil around throttle body...
- Changed wheels, no TPMS, but no alarm!
- Map sensor plug n play help!
- P0121 throttle body cleaning and high idle
- P0236 and P013E
- Idler pulley & tensioner pulley
- Need help
- New Oversized Tensioner rubbing
- P0236
- Cars gone into intensive care
- Check Gas Cap P0455 2.4
- Vacuum leak?
- Engine Sputtering when hard acceleration
- Oil leaking badly
- Acceleration is slowwww.
- Down pipe bolts snapped
- Back brakes
- Throttle body relearn and a custom tune
- Intermitten No start, No Crank, No click
- Vacuum tank delete
- Aftermarket Seat Help
- 2009 ss/tc need some help
- cobalt shuts off after a few minutess
- 2009 ss/tc
- LSJ motor blown, replacing with LNF
- 2010 Cobalt Ss/tc boost problem
- Possible transmission problem?
- Startup misfire
- Fuse Box
- 2008 SS Turbo Fuel injector
- 2006 2.4 Cobalt SC
- 2006 cobalt ss supercharged loose and sloppy shifter.
- Passenger side brake light and turn signal
- why so rich?
- 250mm Links on 08 LS update
- cobalt ecm
- Engine Rattle
- Boost bypass valve
- Cobalt wont run!!!!!
- I think my catalytic converter died on me tonight
- 5-6 PSI Max on WOT, NO CEL
- SS links on a 2008 LS
- Shift cable adjustment
- Any ideas?
- Lsj 2.0 throttle issues.. Like wtf
- Car won't start, ton of codes, don't know where to begin
- Holding pressure but still have a small leak
- How to reinstall ball joint to knuckle
- P0496 codes
- Strange Cold-Start Problem
- repairing lsj throttle body?
- Power bog on Acceleration/low MPG's?
- Help please!!!!
- Over cooling 06 ss sc in winter
- '05 LSJ, intermittent no crank no start problem
- Need A Stock ECU
- Did I blow my engine ?
- Hard Start After Sitting
- Abnormal Climbing/High IAT2
- Control Arm Bushing Replacement
- High idle after cleaning throttle body. How do I fix quick?
- Should I replace my timing chain & water pump?
- OBD2 codes coming up none stop!!! also have a magically missing sensor...
- Starting problems
- Drivers Side Headlight Out
- Brake light problems, staying on, switch replacement
- Help: Boost leak test results.
- 2007 LSJ idle issue with AC on
- Newbie! Bypass solenoid question
