- Steering Problem
- anyone in the fredericksburg, va area! need help
- body kit installation estimate question??
- 15,000 miles
- Motor mounts coming loose????
- Warranty wheels
- Abuse??? I Think Not
- wreck the bolt
- Help Me Please!!
- No temp reading.
- Vibration in foot pedal.
- I need some help from you Ion guys
- Does your cobalt SS do this?
- XM/GM Tech Question
- Bucking and CEL
- Front end Hops
- gas smell in oil
- car is down again!!!!!!
- Major Problem.help Please
- rpm jump
- flutter shifting into 2nd and 3rd
- ice possible?
- Sub Problem Fix
- New Problem
- i have a slugish problem through mid range accel
- 2007 Cobalt SS 2.4 Suspension squeaking
- Remote car starters
- Car Punches the Gas WITHOUT my Foot
- wierd rpm jump issue
- Vibration in gas pedal
- Dumb questions i know. But help!!
- Dealer won't install Stg2 because of Liablity!?!?
- Auto Locks Problem
- CV boot replacement?
- Brakes
- clicking/ ticking coming from driver's side wheel, possible CV shaft?
- Cruise Control
- Battery is dead! need help again!
- Strange Vibrating....?....
- Car will not start!! PLease help!
- Another problem to the list..(cat burnt)
- Dash is rattling
- Brake Problem
- Driver Side Fog is seriously messed up
- BATTERY for SC hard to find???? WTF
- check engine light
- Installing Exhaust tip
- Water leak under rear seat
- Battery went dead??? opinions please
- Weird Intermittent glitch.
- Cruise control is glitching
- Weird issue
- hid in projector problem GRRR
- Rust on bottom of valve cover
- trans leak
- Popping Front Suspension
- Vibrations after Sportline Install
- CEL (yes i scanned it and have details!)
- To Everyone who had problems with Rotors
- wierd knocking noise
- 2nd gear
- Problem With Tranny?
- Belt Slippage
- Axle/Drivshaft Problem.
- clicking/popping noise on accel?
- Reprogram keyless entry
- help fast please brake light out!
- Another annoying problem!
- Really Annoying
- p0171
- no power?
- startup creeking vid
- Common Problems with cobalts (Everyone Please!)
- needed a new steering colume
- Broken Exhaust Pipe(?)
- Car Stalled????
- Trunk Sensor
- New Owner-wrong manual?
- blown supercharger
- Oil pukeing out
- Does the cold lean out my car?
- do we do this in the winter?
- Engine Power Reduced. I drove over 200 miles with it on!!!
- I have the worst luck with cars
- How many have or have had these problems?
- Problems with Projectors...
- Hard start when cold?
- Door lock switches inoperative
- hid
- limp mode
- 2.2L Aeroforce Gauge
- Alarm Problem
- Is 2nd gear "going"?
- GM caliper service
- first dealership warrenty experiance, not impressed
- CEL, and premature Fuel Cutoff @ 6500 rpms??
- Self inflicted door damage..
- Garage Damaged Rim
- 3k Miles Black oil????
- 1st oil change? SS/SC...
- squeeky wheel, wtf
- car wont let me out
- i gots a problem
- $1000 brake job??
- USMCFieldMP has a Problem
- cracking sound
- DTC question?
- Problem with Halo Projectors
- Going swimming in my cobalt!
- Help me
- Missing clamp on the booty
- serious problem
- How Many Quarts???
- Oil change at the dealer....what a joke!
- Busted Stud
- Exhaust rattle/squeak?
- sh!tty accident repair
- Shop changing my oil
- Turbo Timer Wiring Help
- car not starting need help asap!!!
- Spark plugs fouling
- problem with my lights
- Clunking/Tapping on passenger rear?
- Car not starting
- HID not working.
- The squeak of annoyance.
- I got engine PWR Reduced
- Location of Fuel Filter on SC/SS
- Aftermarket Lugs and Wheel Studs
- Engine Jolt?
- The clear coat is like coming off my trunk
- My clutch dunzo?
- no manual need help
- car f*$&*d
- Driver's side low beam out, high beam works
- Some Problems...
- battery not charging
- squeaking noise in front
- painted headlights now fogging?
- anyone else having problems with there 2007 radio?
- Right....so to the dealer I go
- Problems with my 05' SS/SC
- Starting
- Regular Maintenance
- How to find an exhaust leak?
- 2005 LS Wind noise / warranty question...
- lookie lookie
- Wheel Alignment Specifications
- Really bad stiff clutch
- Cobalt SS Supersharged No Start
- cruise control button on steering wheel
- Wheel & steering issues Warrantied !
- GMPP Intake Filter
- 07 LS Transmission problems
- Ecounter With The Stealership
- i need help from the parts gurus
- Ok I realize this is a dum question for denny
- Maybe A solution to my jumping idle
- air temp sensor
- Please help, Im getting pissed at my car.
- gm slotted rotors ... confused
- HackAbuse's Car is Down
- Car Feels hesitant and struggling
- WTF is wrong with this thing
- whats wrong with my car???
- Vent controls stuck
- CEL with dezod downpipe
- Mass Air Flow Sensor Locaton
- Engine Power Reduced, HELP!
- Clutch slip is the best!!!
- Cold = Noisy Clutch Pedal?
- Problem with ignition... maybe???
- Clunking?
- Help! Getting a lot of codes...
- Warranty Problems
- Wheel alignment data - ?
- My leaking exhaust (VID)
- Emissions Light
- clutch troubles
- List of problems.
- Wind noise from the sunroof....
- Fans
- half a bolt stuck in the header 3bolt flange side
- The Wheels? Should I request a new set?!
- Snapping noise in door
- little problem.
- Wawa gas (DANGER!)
- transmission click/rattle
- High idle after engine is warmed up...
- Is this a problem?
- Static sound when pressing gas. ss/sc
- CEL throwing all sorts of codes for 4 sensors
- Noises from my clutch pedal
- Trouble shifting into gear?
- getting transmission replaced with 12,000 miles on my Cobalt SS/SC
- Rattling from Drivers side front
- dirty maf, dirty o2....what are the symptoms?
- Dtc P0171 ?s about it
- Studs
- Getting headlight out?
- Cavalier owners help ?
- Clutch Pedal Play
- Cronic Ignition problems in the cold
- Not boosting..any ideas?
- front struts leaking
- RPM flutter/bounce? 2007 2.2L, 4T45E..
- So my powersteering motor is dead...
- fried my cat :(
- Cobalt Puked!
- 10 lbs boost max
- overheating
- mist setting on wipers
- problem
- Is the clutch covered under the powertrain warranty??
- How long are factory brakes lasting?
- some little problems in my idle, need some help!
- Fucillo Chevrolet of Nelliston FTMFW!
- Question about interior rattles?
- customer concern@work
- Well 1 year and 2 months and my first issue shows up
- DLC no power - Tech2 will not turn on
- that clicking sound from the drivetrain
- Coolant temperature/fan question
- The car pulled a superman then acted wierd
- Need Lighting Help
- Half shafts "Popping" noise
- Backpressure on stock 2.4 / stock limitations of exhaust
- Low Coolant Light
- plug question
- Hid Lights Question?
- progress rear spring problems PLEASE HELP IM LOST
- need help
- clunk coming from rear end
- stage 2 pulley bolts?
- help please
- The AC
- jerks and more jerks
- Cel
- Fuel pump issues when filling
- Warranty?
- Gages wont light up ><
- engine wont start
- shifter popping out of gear! help!
- Cel
- Weird CEL???
- Dead Radio
- P1128???
- Handbrake re-balancing?
- How to change an air filter on a SS/SC
- Metal shavings coming out of exhaust?
