- Information Display Errors
- Noise
- Crack in the oil pan!
- Fog Light Problem
- rust or just brown crap lol
- In need of assistance
- Changed Fuel Filter. Car won't start. Need Help!
- problems with my 2.2 lt
- Northern Ohio Service quality warning
- HELP---->p2135
- what happened
- Back fire question.
- Car runs better in open loop
- Two new tires per the dealer...
- So Dealer Refuses To Fix Car Under Warranty...
- Where is the outside temperature sensor located?
- Hurst Shifter Issue "Really Sloppy"
- damn headlights!!!
- A/C Sounds?!
- lowering question
- knock knock...
- Any one else have this problem?
- Raccoon = 2184.29
- Check engine light after the fan mod!
- Interior Light Issue
- Cant see when backing up
- AEM Intake, and now the car wont redline..
- Seat inserts interchangeable?
- so its come to this.... please help.
- Anyone had this problem???
- Clicking noise
- I need some help with brake lights
- I Need Help With My Sc Asap...
- Severe Misfires
- Rear window defroster connectors ripped off...
- SES, then randomly shut off....
- White smoke =bad???
- Front end shake
- STS is stiff from 1st to 2nd
- shift control lever housing for the manuel 2.2
- Whining in tranny
- Ignition Issue
- Unlimited boost?? Need help
- cylinder 2 misfiring
- $150 to change my air filter??????
- THE *CLICK*= 9 times at dealership?
- need advice and recommendations!!
- Vibrating over 70mph? Cheap a$$ tires...
- Cigarette Outlet Not Working
- Running Rich
- Clicking noise after letting off gas or making a jerky shift?
- Steering and suspension updates done to my 07
- Tapping/ticking from serpentine/drive belt tensioner
- Yo-Yo Tach and Car Dead
- no good
- Help with my tranny update 9/26 It gets more rediculous
- Help P0621
- Need Some Help... My Car is Weird
- Demolished a raccoon and radiator needs replaced
- clutch problem 2.4
- the rock tumbler where my supercharger used to be
- Has this happened to you??
- check engine light?
- Engine Vibrations Please help experts
- Sunroof (rough sound)
- ouch for the coby
- Need Help I think I am getting ripped off!
- Ring around sunroof switch finally fell off
- AC Clutch Engages, Buttons Work, Not Blowing???
- 2005 Cobalt LS 2.2l - 20k - Fuel consumption up, economy way down.
- Feeling vibration in foot pedal and floor board.
- Transmission Snaps
- need help bad with possible no fuel to engine
- A Problem
- Intercooler is Drinking Water
- Sunroof Trim
- LSJ coolant loss, engine coolant surge tank?
- P0171 Fuel Trim System Lean
- High beams+left turn signal=no lights
- My Car Hates me
- 50K maintaince to-do list
- Blown head gasket!!
- Dic ?
- Busted Antenna Bracket!
- 2.4L throttle response at low RPMs
- how much
- Blackcat custom gauge help.....
- 07 lt
- Door panel trim...
- Louder Exhaust & Bogged Out
- Problems, Dealer fixed warrenty work or not?
- CEL when cold
- Cars in the shop.
- Lost blinker sounds when installed new head unit... can i get them back?
- tapping noise?
- Idle prob may be solved!!
- steering wheel shakes under heavy braking
- Problem after removing #4 spark plug
- Power Steering
- Mysterious Rear Vibration Noise
- really annoying exhaust rattle
- Reverse lights don't work
- Mass Air Flow Schematic
- Many DTC's and No CEL
- I hate brakes!
- serpentine belt tensioner?
- In need of help.
- P0069 & P0103...
- Sunroof Issues??
- Holy Vibration
- P0300 - Misfire Code...caused by O2 sensor?
- Wierd knocking sound?
- e-brake+hill=broken spoiler
- Stage 2 Install: Brown and Brown Chevy (Main & Mesa Drive)
- Metallic "tick" when engaging 1st and reverse.
- Cruise Control
- crankshaft Position Sensor
- Strange Steering Problem
- Back to the dealership I go.
- Steering shaft vibration and noise question
- help! major issues
- In the shop.....again.
- Some members hearing a clicking noise
- my car is bleeding :-(
- Problems with alot of things
- Warranty Work!
- help: need to find a new h/e pump
- Burning smell
- Problem:Loud noise on acceleration
- bumper space
- weak wheel studs.....
- Vibrating/Pulsating Brakes
- Power Windows
- squeaking noise
- man!!! i hit a curb!!!
- missfire at idle
- smoking
- CEL just came on
- Torque specs
- 2.0 ss/sc Problem
- Paint Chipping wheels not covered?!
- Smelly AC and Fans?
- This Is Bullsht
- Who here does their own car maintenaince/service
- low coolant light
- Problem with A/C controls
- Sunroof rattles?
- Axle replace
- Need cobalt ss s/c outer tranny casing HELP.
- Car Going To Shop
- CV axle
- windsheild trouble
- Problem: Rear passenger clunk on 07 LT. Advice?
- Emergency Brake Snapped
- Humming Noise
- Code P1187
- Bent my wheel....
- SAI problems
- Engine Power
- sunroof track broke
- clunking noise at speed...
- fuel pump
- Broke Tranny!
- Service airbag light..
- Trans. Problems
- Car wouldnt start at first now runs very rough
- need oil help quick
- Big Problem Help Pleaseeee
- clutch needed
- clutch needed
- Friend is stuck at the dealership... they want to void his warranty.. HELP
- Bad, news and problems with my SS/SC
- Car started doing weird stuff today.
- Steering Column
- problems going into reverse?
- This problem may be a new one....
- Grinding sound at start up!
- Anybody Have This Problem
- Car won't start
- RPM's going up?
- oil cap came off.
- need help asap can't get into reverse
- p1128... wtf is it!! lol
- Blown motor guys...
- Engine Power Reduced
- jesus....
- Awful knock!!!
- Door Handles???
- warranty?
- Vibrating Door Handles
- Water on the passnger floor
- Need Part Number
- Po420
- Dealer refusing to fix an issue described in a TSB
- P0016 Crankshaft Position
- dumb question
- Everyone Read Warning about upgraded axles!!!!
- i need help
- auto light problem
- 4th Visit To Dealer In 3 Weeks.
- Void Warranty
- POP noise while deep into first gear...
- Has anyone popped a stage2 motor
- Need to call GM, anyone have contact info?
- A ticking noise in the engine at idle...
- P0101 Mass Air Flow (MAF) Sensor Performance ECM
- Headlight Low Beams Do Not Work
- Front Bumper Messed Up
- driver side headlight..
- 5th gear and strange idle.
- damn transmission
- Popping sound
- The clunking/grinding noise...solved?
- coolant problem
- Chevy Cobalt Horror Story!!!
- Car seats...
- Car is running very stange, anybody have any ideas?
- what do you guys think is the problem?
- has anyone cracked thier side skirts?
- 2006 SS/SC - LOUD TICKING. CEL Running Rough
- trans area click noise
- wtf now....
- Going in for service, many things
- paint chipping off interior door handle.
- guys i really need help!
- Hit a HUGE pothole
- Manual tranny fluid change
- Got a problem
- Broke my sunroof...
- RPM acting up
- Condensation in my headlight
- Warranty questions - Problems
- HP Tuners and Stage II
- First Thing to Break, what to do? HELP (good story too!)
- car stalls on small bumps
- Another Quick Headlight Question
- Strange tick any ideas
- Quick Tail Light Removal Question
- ECU problems, flashing lights galore!!
- post nitrous install car won't start. throttle body not actuating.
- Body Control Module
- dtc-p0121=put ur foot in it
- Is my trans. about to go out???!
- wipers
- Better/more effecient engine cooling
- rolled my cobalt LT or well it tipped over
- need to find a TSB
- boost drop after relocation to New Mexico HELP!
- Stumbling at 5500 rpm, full throttle
- weird idleing
