- Underbody Damage
- Super Charger Removal ?
- sticky hinge
- My driver's side door WILL not open
- Interior door panel scratched- Help
- Windshield whipers
- smokes when shifting
- <-- Newb where to jack?
- squeaks :(
- engine light
- Brake fluid has crap in it?
- So i just got an oil change...
- Scraping in Front Corner
- Recalls
- cracked!
- CEL with CAI
- please help
- Jumpy RPMs in first gear
- Recaros are moving on driver side
- Transmission Whine
- E-Brake Sticking....
- Parking Brake Makes loud pop sound
- Help with Intercooler Pump
- tranny mount and harness
- misfire in cylinders 2/3
- Burning smell from GM Touring Exhaust
- Hesitation on stock SS/SC
- Possible brake issue
- Knock Sensor Problem?
- Bad Creek over bumps....
- Taking car to Dealership...
- help me out with this prob
- Fuse, circut, connectors, or computer?
- help: dip stick
- SS/SC Won't Start
- pulls to the left
- Problem once again.
- GM paying 187.00 per wheel for flacking
- catalitic converter coming apart
- WHAT the hell is going on?
- Pittsburgh area Help
- freakin pacesetter stuck to engine!
- Help! Roll pin broke again!! Need a how to on this!!
- Other car Issues!!!!!
- OBDII port power fuse
- threw a CEL need help
- high beams not working with projectors
- P0480- Rad fan on all the time
- Clunk noize in steering
- getting ready to hit 20k
- no cruise control
- Front Speakers
- Clogged cat troubles and dealership fraud
- clutch slipping update
- GM uses cheap aluminum
- Couple small problems
- had the car for 1 month
- Lost Intermediate/LOW gear, No Car Start, No Trunk Unlock
- Bent Throttle Body
- stalling
- Rattle from front driver side suspension
- DEAD Car HELP!!! PLEASE!!!!!!!
- Belt Screech HELP PLS!!!
- Serious RPM Issue/Power Loss/Popping Noise HELP
- turn signal
- Weird shit..
- WTF is P0171 system 2 lane bank 1 to lean?
- POWER STEERING and other Errors...
- GM techs respond on Warranty Issue ;)
- what to look out for when buying a used base model cobalt?
- TSBs
- Wtf, headlights not working..
- Ridiculous Gas Mileage!!!!!!!!!
- Stock SS pushing 13psi??
- Popping Noise
- Sunroof Problem
- 2800 miles and clutch is slipping!
- Shifting problems
- Dealer is recomending GM buy back my car
- OBD-2 Port No Workie! Please Help!
- Please Help!
- Driver door having problems opening and shutting
- Please Read!!!!!!
- Exhaust/Emission Leak Code
- ideling problems
- When in reverse weird NOISES!!!???
- Fusebox please help
- Valve tick???
- 2.4 SS/NA Gas Miliage
- Door handle clicking
- weird shaking at idle
- Clunking sounds from car
- First Problem
- Help!!
- Transmisson or Clutch problem PLEASE HELP
- Other problems with my brand new car
- warning
- code reader
- HELP needed: Halo Projectors
- Im Going To Blow Up My Dealer!
- those with melted lenses
- 2007 Cobalt already in the shop with bad MAF
- Squeeling/grinding/pissed...
- Intercooler Coolant Level
- threw 2 codes
- Clutch pedal travel.
- Need some suggestions
- Rapid Ticking Noise When At FUll Boost
- Rattle inside Cat/ Broken Driver's Seat...
- ignition key stuck
- Need help with a squeak
- Excessive crankcase noise on my LSJ
- I'm about to file the lemon law paper work for my SS/SC
- DTC's PO133 and P1133
- Why would a new CAI kick a CEL
- Shifter Problem. Dealer can not fix.
- 2.4 SS/NA 17" Polished Rim question
- Driver Side Speaker Craps Out Turns On, Magic!
- 2.0 runnin rich
- In Dash Monitor Problems
- im screwed, plz help electrical
- Check Engine Light On
- valve stem seals
- Hesitation/Backfire
- Reverse grind
- Need some help guys
- Chugging..
- Getting a clunking sound after installing 18"
- Knock starting out in 1st??
- Doors Don't Lock/Unlock
- Paint peeling...
- car randomly accelerates while at a cruising speed.
- starting noise
- Hiccup and P1183!
- Cruise Control Broken/shift knob
- need help getting stock radio bezel off
- car just dies!!
- Dang wind
- Random cylinder misfire?????
- engine noise
- sputtering after stalling out??
- Another Boost Guage Problem
- n00b question
- sputtering at a standstill?????
- Hid proectors and high beams>??
- Car in for maintenance. Cost?
- Wheel paint?
- rev limiter??
- Problems with overheating
- creaking from right rear passenger area
- another rattling thread sorry guys just need some input
- 14k Miles, What Service to Perform?
- My timing is off! Help!
- New car concerns...
- Don't Buy Injen Products
- No Sound.... wtf.
- Possible suspension problem, or is it normal?
- Engine sounds like a diesel??
- Stage kit owners!! tensioner issue
- Jump it the Check Engine appered
- My remote died.
- Getting pretty pissed off at my car
- Distortion in speakers
- Diag port not working
- Will GM Wash this off
- code reader
- rotors shot at 10k
- XM Radio help
- need help really fast with projector install
- cobalt addiction retune
- Clipped the curb on the Ice
- Car died at full throttle 1st gear
- Need Some Help About Oil Getting In My Intake
- Wierd Rattling noise.
- I need help from a GM tech
- Thermostat mixing valve failure
- Break in Period performance
- ABS and TC lights staying on
- Not a problem really a 17" rim question
- Squeak Squeak Squeak
- No coolant temperature =(
- The P0171 Club..
- Projectors hooked up but no blinker?!!!! plz help
- Too cold for factory XM?
- Headunit Help Please!!!
- Help Me Out Guys!!
- P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage -PCM
- Unknown Fluid Leak....HELP!!
- clutch problem?
- Boost guage problem!!
- Drivers Side Low beam keeps burning out
- Leaking Boost...I think?? Please Help...
- Fender Rubbing Pillar
- low rpm?
- BOOM... engine dies, HELP!
- brakkeeesss
- new motor
- Alignment... again.
- Wheel Hop Bulletin?
- battery dead (nothing left on)
- What the dealer did to my Car
- help ASAP!1
- Underhood caught on fire?
- ss/sc spoiler
- Another rattling thread
- 2006 Cobalt Recall - Fuel Injectors Cracking.
- Wind Noise....after 4 dealer visits
- 80 mph + rock wall = no air bags???
- door panel problem
- Another cobalt down. engine blown.
- 07 cobalt ls help plz
- Oil filter cap
- evap moniter not ready
- Blowing headlights
- Update to my broken axle story...
- stuttering....help??
- New Tires
- Blew my axles tonight...
- crazy rattle noises!
- Burned up silverstars
- reduced engine power light on all the time :(
- Blown Injector Fuse
- does anyone know how to change the angle of headlights ?
- 2 weeks 2 ignition modules!
- Last Car From Chevy.
- Better Buriness Bureau
- Exhaust Smells like paint thinner
- Rattle from underhood
- Major brake problem...
- Exhaust Gasket?
- Clutchmasters blows donkey dingleberries
- Battery Croaking?
- Brakes machined again!! 2nd time
- another cat shot
- compression test?
- rpm hesitation
- 06 LS 3rd gear grinding bad
- Help Me Cobalt Down!!
- Car dying when I slam on brakes...
- intake gasket is in
- huffines dealer in plano, texas what a Joke, will never buy a car from them again
- Misfire from intense injectors...
- Low speed brake squeaking
- FE3 Suspension Grinding noise!!
- Little Red light to the right of onstar button.
- boost problem?
- Look Ma no rust (GM replacement Rotors)
- intake manifold wont budge
- Driver Door WONT Open
