- parts #'s for rotors
- major 06 ss problems for me! HELP
- clutch woes
- Cel light came on today
- Check engine light
- General Motors recalls 98,707 Chevy Cobalt sedans
- factory wheels
- Trunk Locks
- coolant gauge not reading?
- WTF? Got a ghetto "Hyper-Blinker"
- popped my dipstick what do you think?
- A Girl I know back home .. (Tire Prob)
- HELP..!! Lost Tach..?
- cobalt addiction dp rusting....
- Locked my engine up tonight warning for those wanting 2.7
- oil change
- exaust mid pipe way too low for my liking
- exhaust
- Brake and acceleration problems-Help
- SS/SC Downpipe Broke...
- Fuel Filter ?
- small problem with door panel
- In The Shop 2 Times This Week
- Installed new guages and reading some knock
- Letter to the Prez
- My car's suspension is f*cked up!
- Stock shifter questions.
- Stock clutch questions.
- hood alignment
- i hate my cobalt
- Squealing brakes
- Ugh...
- Dealer Stage 2 install: Bent pulley and a burnout
- Problem with shift light on aeroforce
- Help with Aeroforce install need help now!
- WTF?? Engine light!!
- OBD-II Fuse
- HELP!!! CAr Wont Start Jsut Clicks
- Driver's door won't open!
- When to chnage oil
- Fan noise
- Corsa Cat Back Breaks!!
- Flat Tire! but wheres my crowbar????
- UPS Claim
- antenna keeps comming loose
- Possible Boost surge?
- NEED HELP!! My car is loseing BOOST!
- No Cell Just This Code Need Help
- clutch gone at 3900 miles
- rough idle, and lights and gauges dim
- Since this got locked
- Stenghten my AXLES!!
- Engine Blew: two pistions got punched
- You know I'm getting pissed off...
- Car hard to start
- Engine Shutdown while driving last night
- Finally got my car back
- no cel but i have this code
- crankshaft position sensor?
- paint on wheels coming off 18in ss wheels
- intake gasket
- Boost Bypass Actuator Part Number
- Oil life meter
- warranty w/ rental car ?
- break system
- WTF my car sucks!
- Out of the blue.
- throttle position %
- Steering Wheel Controls
- Aftermarket Headunit
- Battery Question
- new k&n intake = new problems
- Initial Gas Mileage
- Onstar microphone leaking water???
- Sunroof tracks shattered
- Rattttttttle
- normal exhaust sound?
- Question with the Interceptor Gauge
- Headlight problem
- nothing fixed
- CEL & Gas capp DIC Warning....
- couple 2.2 problems
- Need part number asap
- 2nd gear hiccup
- Car died after down shit to 3rd goin 75mhp
- CEL from CA downpipe
- Burning Smell/Knock
- white smoke
- Rev limiter
- Clunking noise??
- CEL... help
- hood problem
- Broken Wheel stud
- dip stick issues
- strange noise when clutch pedal is pushed.
- GM Extrude Honed Manifold
- Gm Extrude Honed Manifold
- 2.2 5 speed Tranny
- Help with wiring halo projector headlights
- Wiring
- Axel clunking - took it to dealer
- HELP!..leather seats
- IAT2 readings bouncing around???
- infamous wheel hop tranny problem
- Supercharger Warranty
- Hesitation
- What's up with Cobalt-Addiction
- Car shuts off randomly. 2007 ss SC
- Alarm Install
- My drivers side door won't open
- leakage?!
- 2.2 Hard start and rough idle no power
- squeeky
- Huge problem HELP PLEASE
- Bad gas mileage and cel.
- only 3psi on GMSC?
- My FIRST MOD!
- Should I be Worried??? BENT RIM
- it all started with a leak
- Rattle noise?
- For Those of you
- shorthrow install question
- HELP!!! noise from sterring..
- power every thing conversion
- WIERD Clutch Problem- It may be easily fixed?!?
- Parking brake broke(manual)
- My Cobalts Clutch is Dead? kinda long read sorry :)
- nonwarrantied grooved rotor help
- Airbag Rattle
- Wheel hop....then
- Humming from front passenger
- Suspension clunk: response from GM
- Cracked stock DP today
- Owned by a drain plug!
- Affordable Alternatives?
- few minor problems with my SS/SC
- Pcm
- Seats and Air Bags
- Pirelli Problems + Extended Warnity ?
- HELP! weird noise
- seized pass. door lock
- Cruise control
- Spec Stage 3+ fell apart
- Engine noise
- Heated seats are COLD
- WOW Do I Feel Dumb!
- new car, wierd issues?
- Brake Light Help
- GAS Milage
- Not sure if this is a
- Injen CAI and overboosting???
- 2nd gear Synchronizer went out.
- 2007 Cobalt ss Problems 2.0 sc
- HAHAHA......where do they find these guys?
- Chipped trim pieces
- computer...a little help
- in reverse strage noise
- Sagging Front Bumper
- Car won't start
- Down Pipe leak??? WTF
- Engine Power loss???
- tire tread
- Big Problem with Cobalt
- What do these codes mean?
- Foreign object inside SS/SC wing
- blower motor
- Wind Noise
- Supercharge noise
- Cel
- what is with our turning radius its shit
- question about my friends redline
- GM warranty observations and input wanted
- chevy sucks!!
- Quick Ingalls Question, I Think Its Broke
- Still Waiting for my SS
- rant... its almost time to trade in
- Cold Temp = Low Coolant
- HELP! Loud grinding metallic scrapping noise!
- Passenger Rear Door
- vibrating when braking
- Oh!!...Never Again
- Century 3 Chevrolet (pa) Bad Service
- Axel Swap
- Lean On a 2.2
- Engine Light & TC Light...
- tocking noise
- Weird Problem
- Header VS warranty
- Trans / Clutch Clunking...
- brake rotors and brakes complety f*cked up after 9500 miles
- p0171 fixed
- Dead battery?? ...even better...
- Frozen washer fluid lines??
- Got my new engine installed
- AFC Neo
- Clutch burning, the how tos
- Car problem
- chirping noise from engine
- Problems...problems...problems
- Learn to Drive on Ice
- cracked manifold gasket
- Howto Check battery?
- So Many Problems, I Want My Car To Be Problem Free For Once
- key wont come out of the ignition
- Faulty Ground Info?
- Driver side window, weird noise
- got a bad fueling problem
- blew my engine
- Blew something on my engine
- Chevy dealers are soo CHEAP!!!!
- horrible day for the balt
- Right Turn signal+High Beams=No lights?
- no car sucks
- 9800 miles, Check Engine Light.
- Problem Down Gearing
- headlight wire question. help!!!
- AAHHH..CEL Again
- Belt Sqeak
- Engine light after 14 000Km?
- GMPP S2 pulley bolts
- Loud engine at idle
- GMPP intake install
- Warranty: problems with my car
- Catalytic Converter Going Bad
- Ingalls ED + Cold weather = noise.
- Service History
- well I got good news and bad news
- ATT. All Magnaflow Catback Owners
- CLUTCH probs HELP NOW!
- Skipping under accele.
- Tranny Whining on decel
- Stalling out then cel????
- passanger seatbelt?? lol
- Supercharger Broke
- Alarm going off....
- Too much boost
- Noise while downshifting/decelerating
- threw a p0503 this morning
- transmission probs
- Gonna need a new 2.0
- Car Died
- auto trans
- Engine Quirk
- Remote Start....HELP!!!
- Remote Starter issues
- Headlight beam alignment help
- Warranty info (2005)
- Need Help CEL !!!!
- key stuck in ignition
- My car got smashed into
