- Key not turning forward at times, and does not release from ignition
- Fuel line
- High Idle? (Steady number.)
- P0122 and p0223
- 07 ss/sc electrical problems
- LSJ: creaking and squeaking while running
- 2010 cobalt ss turbo tranny fluid 5 speed?
- 2006 cobalt ss Rad fluid disappearing
- Viper Security Installation
- 2006 Cobalt LS gas tank leak
- 05 2.2L Cobalt Wont Start
- Cant pass emmisions 08-15-16
- Battle with too lean code. HELP
- Engine code: P0651. Engine power reduced
- E brake cable clamp question
- TPMS reset without keyless fob
- P0132 and weird cold start issue
- 2005 Cobalt 2.2 no start (machine gun)
- Ebrake cable broke
- Lnf tranny question
- Loss of Power @ 4000 in 3rd/4th/5th Gear
- Misfires, KR, possible loss of power? HELP!
- new super/TB, idle issues
- dashlights on then off power steering out then dies needs jump
- 09 SS/TC Not much boost and a P0130
- Vibrant Header Install Went FUBAR, Need Your Advice
- New car, lots of codes
- Need to replace clutch but..
- Problem: O2 sensor cable is 1/4 inch too short!
- Engine knocking help
- Oil leak
- Getting p0033 code after I replaces the solenoid
- Possible coolant leak locations
- A/C condenser questions
- Quality Replacement Part companies?
- Intake air temp reading -40°
- Knock noise when in lower gears
- Misfires, Engine Codes, Violent Shaking, Oh My!
- Help no start
- Lsj searching for idle
- Car not starting, no spark
- Need a new IC Pump
- Whats this plug???
- Oil consumption - Where is it going?
- Boost limited to 18psi, whacky AFR, no codes
- engine swap kept the trans. Now wont stay in first
- 07 ss with some problems
- Need help LSJ-T MAF pegging on initial throttle
- No boost
- Buy or pass
- Harmonic balancer
- Repair lsj flex pipe
- Coolant Problem
- Clutch pedal vibration
- Rust on coupe trunk lid
- LNF mega problems maybe pcv/head gasket
- Keys in trunk, trunk release button won't work
- Fuel leaking
- Humming sound at higher speeds
- 2.2 L61 PCV operation with LSJ intake manifold/supercharger
- P0017, P0341, P0340 help!!!!!
- 06 SS issues
- Sunroof rail guide connector replacement
- Supercharger whine not audible?
- trans/clutch??
- Oil Disappearing
- Bad Thermostat, Water Pump or Worse??
- Oil Pressure Light Flicker
- 2009 Cobalt SS temp spikes
- Blower Motor Bad??
- Need to dry the passenger side
- J body supercharger swap HALP
- Help! !!
- Woops wait until its in gear!!!!
- Code help
- Rear windows suddenly won't roll up or down
- Random running rough
- 2009 Cobalt SS Cranks a While, Fires, then Dies Immediately.
- OTTP Short Throw shifter issue
- Vibes in steering wheel
- Code P0171 - No MAF found?
- "Pop" noise driver side
- Trunk Ajar
- Brake Noise
- Limp Mode Light - Rough Running
- traction control light
- Ignition Control Module (ICM)
- Cooling Fan Question.
- 09 SS Oxygen Sensor Help Needed
- 05 Cobalt SS PCM vs 06 Cobalt SS PCM
- ZZP PCM flash sticker on the back
- Blower Motor Fan Speed Issue
- Too fast turn lights blinking
- Single "clunk" only when turning in reverse. Never happens twice.
- Help ! Ss/tc problem !
- SC Oil Eaton M62
- Timing Chain? Help!!
- 2009 SS power Window won't go down
- Extremely slow crank
- Random Misfires
- 2006 2.0 lsj oil pressure relief valve help
- P0010 & p0011
- High pressure in clutch pedal during 3-4 shift
- Supercharger coolant leak
- Rebuilding the Saab F-35 transaxle
- Balance shaft guide bolts..
- Rough idle
- Can't figure out how to get the refrigerant in the system
- 06 Cobalt
- Trouble codes P0069 P0121 P1101 P0068 after sc rebuild
- Engine Rattling/fluttering after cold start
- lsj head?!
- Car pops and jerks when I let off the gas
- Boost gauge install messed up my car help!!
- Every Valve seat leaks? Weird
- Cobalt SC P017 Rich
- Diagnose this front-end noise
- Bent valves?
- Engine code after header Dp
- Help CEL on trouble codes intermittent idle issue
- Engine Rattle At Idle Only
- Engine change
- ZZP Stage 2 LSJ 2.0 Decreased Power / Misfire
- High IAT2 on friends TVS
- P0340, P0341, P0017 with starting issues..
- Reduced engine power help!!!!
- Retro fit headlights
- Looking for mechanic DFW area 2006 ss 2.0lsj
- blew a tranny, now to pay up!
- Coolant Fan Relay 2, Code P0481
- Ticking Under Acceleration Please help!
- weird noise from vents
- Sensor Problems
- No Start, No Crank, P0230
- Replacing a LNF head gasket
- One headlight is very dim
- 09 LNF A/C Woes
- Block damage
- Compression test on coolant system.
- Coolant Leak?
- 08 SS vibrations at highway speeds - steering wheel and car shake
- Service ESC/Service Traction?
- Interior rear passenger side. Mysterious leak. HELP!
- Need a new ALT in my 2.4L SS, how many amps do i need?
- cobalt SS locksmith help
- Idling problem, car shutting off
- Installed long tube header, now having issues
- Detecting Trifecta Custom Engine Tune
- 09 ss turbo idle problem
- O2 sensor problems
- New guy here got some questions
- bad mis fire on 07 colbalt 2.0 turbo
- Voltage Issue ?????
- Seat Belt Buckle torx bit
- 10psi with 2.8 pulley?
- W active or W/O
- 07 ss sc just starting out
- Fuel filter quick connect clip
- Coolant in intake manifold. Possible causes?
- What is this manual window mechanism called?
- cam position sensor on LSJ
- P2229 Code Need Help!!
- Limp mode
- 2.4 SS SC Help!!!
- belt rubbing tensioner. stage 2 belt..?
- Help, burning coolant. No leak?.
- 3rd Slave cylinder in 1 year!
- engine hanging
- Steering column rattle; is gear upgraded?
- Flashing engine light
- Plug Gap
- Comparing data
- Engine Power Reduced problem
- P0442 and AFR all over the place
- e85 lsj falling on its face
- bad gas?
- Problems with trans
- Boost Problem in BFE
- 420 Catalatyic Coverter Code
- Two codes P0145 and P0446
- LNF radio in an LSJ without a VIN
- Spark plug #2 blowout on LSJ
- Brake squeal issue
- Spark plug cover bolt snapped in half.
- Engine seems like its hiccuping at idle.
- ESC, Traction and ABS Lights intermittent
- 2.9 pulley low boost
- fuel line replacement, then the fun begins
- Help! Check Engine, Oil Leak, Etc. 2006 Cobalt SS
- I need help! Random highway vibration
- Steering wheel rattle
- 07 Cobalt LT 4 Door Transmission Issue
- Codes P013E, P2100, AND P2101 on a new to me 09 TURBO SS
- Supercharged 2.2 WOT Issue
- Weird noise
- P0017
- Gmpp clutch chattering lsj
- Pressing the clutch in cranks the motor on????
- motor mounts
- 09 Cobalt SS Problems
- P0132 code
- Car Shaking at Red Lights
- 05 lsj not warming up
- New Clutch - No Start
- HELP!!!!!!!! Reset timing and car is cranking but not turning over.
- 06 lsj boost problem
- HID blackout after rain storm
- LSJ Timing Chain/Water Pump
- acceptable 2.2 timing chain slack between sprockets
- Difficulty Diagnosing Misfire and Random Limp Mode
- Crankshaft Position Sensor replacement w/HPT
- weird problem
- Quick question plz!!
- 2010 Cobalt ss/tc codes po300 po301 and po302
- Kissed a curb with my rear left tire...
- P0503 on 2006 LT
- Radiator Problem..
- MAF problems
- 08 lno won't start wierd displays no radio or interior lights
- Radiator Problem....
- Nls on southbend clutch
- turbo install problem
- No boost above 0
- No battery power to anything 08 LNF
- P1182 w/rough idle & negative timing
- P1182 even after replacing all sensors
- Cam actuators
- Weird SC whine on 2.9in Pulley at WOT
- No start.... Again
- 2008 ss p0017 issue
- Rattle from engine bay
- 08 chevy cobalt jumped time !
- 2007 getting locked out of gear
- Just Another Coolant Loss Thread...
- 2008 G5 GT no start
- Clutch slipping - replacement - bleeding - master cylinder
- Bad master cylinder?
- Need help Lsj won't start
- Bulb out, but electrical
- SC coolant pump Bad?
- Smooth riding suspension?
- Towing a trailer? HELP
- 2010 Cobalt SS/TC Sporadic Sputter
- Supercharger oil question. 3.4oz or fill to fill plug?
- Subframe bolts
- Giving up the Ghost?
- Thawing Parking Brake
- fuel pump harness pinout
- Lnf key fob
- Service Airbag light on
