- CEL woohooo!
- More Carbon
- 2.2 ls misfire with cel
- Drivetrain Pop!!!
- black smoke
- A/C question
- Stage 2 Problem!
- New Day New Problem...
- SO...WTF did i spend all this warranty $ for?
- Engine and Transmission: Immediate Action??
- Need Help Quick!!
- rattle at idle.
- shortie antenna replacement
- CompuStar alarm starter question
- need second opinion
- 2.2L Question
- F'n SWEET!!
- fog light bulbs
- Repeated park lamps fuse blown
- More Sunroof Problems
- ECM Fried
- Interior door handle
- A/C Stops Working
- Battery Problem?? With my 2.2
- different trunk problem
- Shifter clunk...
- Blinking Air recirculation light?
- Airbag Problems
- FLAT on a Flatbed
- Trunk leaks
- windshield wipers
- This is new, need some serious help
- ss/sc screwed up
- Cracked engine mount
- looking for a specific post???
- Radio Volume going up when I accelerate!
- Stock tires on 06 SS/SC any problems?
- cigarrette lighter not working
- SS SC Running Issue-Strange Problem
- seat removal...
- Brake squeal sound?!?!?
- cracked winshield
- 2.4 SS Sedan Rear Bumper Part #
- mp3 playback?
- Low RPM rattle, Gear Knock?
- Castrol Syntec 5W50 for ss s/c
- Flickering Boost Guage
- shifting from 1 to 2 smoothly
- Cd Err + Lock Issues
- supercharger oil
- Help!!!!
- fogging
- Cel
- Oil Filter ? while i have a little oil leak...
- ive had it
- Spec 2+ clutch problem
- Edmond's 2005 TSB list
- Car wont start HELP!
- 06 SS/SC right front tire rubs
- 15,000 mile check up?
- TSB rattling rear deck?
- Changing Oil on the SS/SC
- This Blows......
- SS/SC Seems to run 2 hot during normal driving...
- ss/sc shifter problems
- Dont know where else to put it
- 2 worries
- Stage 2 upgrade questions
- Partial list of 2006 Cobalt TSB's Technical Service Bullitens
- Key Stuck in Ignition
- Problem Heaven - SAFC-II Not worth it anymore
- Cruise Control
- Clutch or motor stumble
- Please HELP
- Would anyone know how to get GUM off car paint?
- Roll Pin Failures
- Stock 05 LS shifter problems
- Im Fastly Becoming The Warranty Warrior
- GM Defect screws me
- New owner...a few questions
- 2.8 problems
- Stain on Leather
- problem in front end
- for those who replaced a clogged cat please watch this vid
- 2300 and the driver Axle is retired!
- Damn GM!!
- Key stuck in ignition
- Problems all of a sudden
- anyone have an LED prob...
- Warranty question... need help!please!
- Gas Guage Issues...!
- leather seats
- axle
- Clutch Pedal WTF!?!?!
- .... CEL as soon as I reached 10 000km
- battery
- Radio Controls and headlights?
- Sunroof Rattle
- clutch slipping- how to prevent
- Heres what caused my limp mode
- Vibrating Wing
- Transmission Gone at 13000?
- Injen cai
- moisture on halo projectors any ideas how to fix?
- Limp Mode!!!
- Brake problem or not?
- Sunroof button, Soft Touch No Longer Works
- Dealing with GM... Anyone did this before??
- Sunroof Trim Piece!!!
- Problems with a STOCK SC ?
- Sunroof switch and Volume up button ...
- neighbors' kid backs into me
- XM Radio Reception
- Brake Pad!!
- Help Fast.........
- Clicking noise
- VIDEOs for "Dreaded Supercharger Noise"
- You can't tune my car
- t.s.b
- Code P2127 on my rental?!? Now what?
- injen install HELP
- What happened to my car?
- Clear Coat
- Outside Temperature Reader
- Odometer and Speedo off by ~4%
- paint warrenty
- quick interior question
- Rachet sound in Clutch Pedal..
- gm slotted rotors for brake pulse problem
- car running poorly
- Dreaded Supercharger Noise
- Wheels SS Supercharged
- Brand New Car and ...
- Stage Kit Tsb
- Magnaflow Problem
- F-ing PISSED
- 2.2L Coil Died (not the first one to have it)
- Cruise control
- My first issue with my Cobalt...
- Problem with my Interceptor
- Headlight Relays
- Dealer & Stage II
- Car died!!!
- Easy Solution for brake pedal problem?
- Dear Journal, It's happening again.. What Do I do?
- issues continue
- Rattle....
- dry rott looking around dashboard?
- dealer going to put in new shaft
- ? Bleeding the SS/SC clutch ?
- different creaking noise
- ! Need HELP LSJ Trans Problem!
- Creaking noise?
- TSB # for idle problem
- Clutch Click Sound
- Tranny Help!!
- WTF now my check engine lights on,
- check engine light keeps going off
- Sound coming from window?
- help
- Major Problem!!!
- Engine light on?
- Has this happened to you, especially 2.0 S/C owners
- SS/SC Stage 2 Kit, belt blow out,,,,,
- Back in for paint issues again.
- Update on 2.4 cold start noise
- part needed
- TSB # for the AC Fogging / leaking
- anyone having this problem?
- car at dealership
- Rattle in the back
- If you have a clicking noise from the front end
- Rough Idle on 06 2.2L
- CEL at 1800 miles...
- where to insert the O2 sensor
- Sunroof Stuck and other Heat Related Issues
- *ATTN*if You Own A K&n Typhoon For The Redline Read This Thread!
- bad experince at city chevrolet in nc
- shift knob
- hello there
- new problems with sun roof
- rotor assembly
- Phoned GM Canada!!!!!
- power window problems
- Stage 2 Pulley trouble
- clutch positioning sensor
- Transmission Issues?
- front bumper
- Burnt Fuse, now in Service
- Wheels pelling please post your pic here !!!!!!
- Paint and interior
- power door locks (help)
- problems with cobaltss.net site
- Dead tach and no 2nd/4th gear power
- wiper blades ?'s
- Engine Trouble Again
- Low Coolant
- Clicking noise im probably just paranoid
- Intermittent wiper problems
- Well, I think the headgasket took a shit last night!!!
- Allignment?
- 2.4L Having difficulty starting (and shifter issues)
- Paint problem.....
- SS/SC's oil change?
- More Problems.. Damn Gas Cap
- xm radio
- supercharger burning up?
- cant fill my tank
- Car sounds like it has spurs going over bumps
- 2 DTC error codes....
- Cooling Fans And CEL...
- Just Dropped of my SS/SC at the Dealer..
- window crank noise
- Takin off spoiler sucks!
- Intermediate shaft steering thump
- P7X out of commission
- third brake light
- I Hate Gm And My Ss
- warranty visits
- Exhaust rattle at startup
- Fix for supercharger discoloration!
- New Replacement GRR
- Going into the garage tomorrow
- Anyone know how to adjust parking brake?
- Scary SC Noise??
- Wheels Peeling what i can do if my dealer doesnt want to cover it ?
- supercharger pulley
- Just an FYI to those having problems with Cruise Control!
- check engine light on!!!!
- P0335 Crankshaft Postion Sensor A Circuit Malfunction
- Gas Tank Flapper Fell Off
- TSB's
- 2.2 auto
- AC Making Funny Noises
- idiot lights flashed...
- Does anyone know ...
- Stage 2 Help
- My new TSB......Yay
- arm rest rubbing seats
- Recaro driver seat making a clunk noise.....
- Chipped Rim and cut tire
- These damn headlights!
- Guys: be careful with any CAI for 2.0SS
- Problem with '06 radio/cd player
- 2006 Cobalt SS - Sunroof Problems
- my tac went below zero
- Anyone....
- Hitting redline ...
- Dimmer Switch
