- 2006 cobalt ss 2.0 sc running lean
- wheres this little red plug go?
- P0300 help
- Left Reverse Light Not Working
- Electrical issues? = no boost
- boost screen problem
- moved.. need help.
- Exhaust smoke
- CAI problem
- Cut off and won't start back
- Not starting after clutch job
- security light flashes once
- 2.0 LSJ Does Oil Have to Reach "Max" Notch or is In-between Min and Max Good Enough?
- Squeaking noise when turning wheels
- No Boost and CEL codes :-/
- Clutch pedal losing pressure
- Fast crank over
- Boost Issue's 09 Cobalt SS
- Bad Knock Sensor
- Car shut off while driving
- 2.4 ecotec oil leak!!!
- Any suggestions???
- Replacing 5th gear assembly, Help?
- Cv joints length part number
- What is this and should it be covered
- Key Fob or Door Lock Receiver?
- Axel question
- lnf no start rapid flashing cel, power steering message
- coupler to intecooler 08 LNF no boost :(
- rattle knock
- TAC Codes, Please Help!
- Seatbelt stopper button
- CV Joint help
- Mysterious noise?
- knocking?
- Ticking sound in 2nd gear at low rpm
- Radiator Leak
- GM Corperate.
- Replacing wheel speed sensor
- engine ticking?
- 2006 cobalt ss/sc idling problem in rain
- spark plugs question... again
- Cat problem?
- p0016 p0017 p0100 car wont crank, or start
- 09 ss rough idle, stalled out and wont even crank now
- Cat issues?
- Moog sway bar links?
- Engine Power Reduced
- loosing boost in M62 @ WOT
- Now I scared
- My car sounds like it has a blow off valve when it really has a bpv.
- will 2007 headers fit on a 2009?
- air bag light after key recall
- I need tail light help
- Moderate Jerking
- Hesitation, Stutter whatever you call it....
- P0011 & p0452 ss/tc 08
- Bucking, Lights and surge.
- Periodic death shake??
- P0449
- 09 cobalt ss p0101
- Cleaning Valve Cover?
- Engine Cranks but won't start
- Turbo/Supercharger Sensor
- Top end noise 2.2l
- Intermittent Clicking and Ticking from Motor
- HVAC Fan Speed Control Issue. Help????
- P0420 code on LNF
- ENG PWR Reduced Message
- Steering Wheel Replacement?
- BPS and TPS SES Codes- Need some help.
- Charging system
- Intercooler Piping T-Bolts
- LE5 Engine Blow Up! (Need Advice)
- Quick question what wire is this
- ZZP Bypass valve
- Check Charging System light
- Siemens 60's and random misfires
- lost my gm security bit
- Steering wheel jerks
- problems whit o2 sensors
- frozen shifter?
- Losing power at upper rpms
- Ac / heater problem:
- Oil in water
- Lsj reving problem between gears
- Question about an LSJ
- Frozen display on dash
- Cobalt lt noise diagnosis help (with videos)
- Coolant Question
- Help identifying part! (clutch related)
- problem code p0013f?
- CAn someone help me??????????????????
- Collant everywhere - Dangerous?
- problems after dual pass install
- Reverse lights don't work.
- Poor fuel mileage
- Problem with driver side front blinker
- ESC/Steering issue
- 05 LS - Electrical issues
- Codes on my LNF
- Oil leak coming from behind oil filter help!!
- P0016 and P0017
- Rear Twist Beam Bolt Questions
- 08 SS 3 bar map question
- High idle only while moving and warm
- 2006 cobalt ss problms
- issue
- Timing chain help!
- Running rich, poor idle, negative fuel trims smoke please help
- P2227 Baro Code on LDK - Help
- Front timing chain guide bolt fix
- Car violently shaking
- Electronics work, engine doesn't.
- P0451 and P2178 cel
- They didnt think about drivers while designing cobalt
- Suspension issues maybe ?
- Drivers door won't unlock :/
- Coolant in oil
- Sucked in water? Idle issue, lean. so confused
- front end clunk question
- service air bag....
- Door lock / anti theft system problem
- dic part
- HELP...Marbles Sound From Transmission...Video Inside
- Quick help really easy
- Timing guide bolt
- Fan and Code 480 & 481 works only with AC on
- Exhaust/Sound Issues
- air/fuel questions
- Help...lsj axle
- Supercharger making some noise at idle
- 2008 LT Transmission Control Module Problem
- Coolant loss?
- Sick of the Cobalt...
- Weird 4th gear speed limiter problem?
- Issue with Intermediate shaft install...I done screwed it up
- Video of my RPM jumping (3rd and 4th gear only)
- Serpentine belt (repeatedly) shredding
- whining noise in first gear (2009 ss/tc)
- Wipers stopped Working
- Fuel Gage Question
- Check engine light with new exhaust
- Holy crap this transmission!
- Safe to Say I've Isolated the Issue to the SC?
- Engine Cranks But Won't Start
- control arm bushings or something else
- 06 Cobalt SS P0171
- Radiator fan starts 3 minutes after starting cold car.
- P0420 and P0326
- New intake.. Bogging?
- P2261 cel
- radiator drain leaking???
- won't start hot
- Problem starting after refueling
- How to Replace Door locks
- 07 ss/sc steering
- weird clunk from the front end
- Help!!
- Exhaust Question
- STFT not changing on interceptor
- A little help needed. Evap codes
- Water pump or head gasket?
- ODB2 won't connect?
- Replacing Thermostat Yearly?
- RPM fluctuations, PO 300 PO 420
- NEED HELP, No power to injectors
- Tc abs ecm tire pressure lights all one. Help me fix it
- Absolutely Horrible Ride quality
- p2177? 0 boost.
- Supercharger Rattle/Rasp - Will this fix it?
- Vibrations After Changing Spark Plugs
- Engine Oil Spilled Everywhere?!
- P0300 Misfire And Running Pig Rich
- Noisy Water Pump LNF
- CAI Issues (Vroom, Vroom, Dies)
- LSJ Rattling (Not at Idle) When Not on Vacuum
- Stupid Electrical Problem - No Crank/No Start
- Cobalt decided it only wants to use 3rd and 4th gear.
- Need help on water pump
- 2007 Cobalt SS want start when it starts getting cold
- Incomplete Monitors- FAILED EMMISION COBALT
- Traction Control and Hard Shifting
- Exhaust Manifold Leak, Cheap Fix?
- Really high amount of Knock retard.
- Traction Control Light
- cold misfire under acceleration
- engine surges after tune (3x)
- RPM Issues when shifting
- Trans Scrubbing When clutch not engaged?
- Fluttering noise under load/boost
- LSJ smokes on startup and bucking in rain
- 2007 2.2 LS. P0171 + smell of gas in oil
- coolant temp
- Hp tuners
- Where to get...
- surge idle please help!!
- Urgent please help
- P1071
- Fuel Filter Update
- Radio or cobalt problem?
- MAF Location?
- brakes locking up
- please help!! (ion redline)
- Option b running backwards???
- Anyone have the LNF ECU pinout?
- intermediate shaft keeps breaking????
- I need a new stronger starter.
- Fuel Line Issues
- Limp mode The instant I hit boost
- Check valve bad??
- Clutch pedal limp on wot
- Rear Drum Grinding/squealing
- FYI - Headlamp Housing
- Low compression #4
- P0300 random misfire help!!! 07 lsj
- oil on supercharger?
- boost issues
- 2007 Cobalt LT Specific Steering Column Problem
- Exhaust rattle
- transmission question
- Axle riding condition- Quaife LSD
- Feels like transmission
- Cobalt SS TC Blower Fan Problem
- 1st Gear Lockout 2.4L N/A 5-sped
- Auto Shifter Issue
- just a question
- Engine knock or blowned gasket ??
- lsj major problems
- LSJ lazy, waaay too much boost. Help!
- Idle Problem
- Dearship says they cant fix my in warrenty LNF
- Rattle in the front suspension.
- Possible Laminova or o rings leak
- Whats this sound? (Video)
- How to program new key
- Pulley issue after alternator swap.
- bad rear end accident
- Need help with alternator please
- Power steering help !
- P0102, p0113, p0171 help!
- Recycled LNF engine- Check Engine Light
- Low Coolant?!
- Help with alternator swap please!
- P1516, p2135, p2138
- this damn car
- Turbo howl in vacuum
- no start after valve cleaning
- approx cost for a new Cat
- Intercooler coolant = white smoke
