- problem car stay running after key is remove from the switch
- Gauges glitching
- Boost Problems
- Intercooler pump hose
- cobalt ss 2007 supercharger code p0300 problem
- 06 LSJ, low voltage lights pulsing at mid-high RPM?
- Help Removing Charge From Throttle Body!
- Random gain/loss of Peak SC Boost Under WOT
- Help identify sound
- P0033 Code Trouble
- P2105 Code Help: Throttle Actuator Control System - Forced Engine Shutdown
- help with bolt size PLZ
- Replacing Exhaust Pipe
- [09 ss] White smoke pouring out of exhaust
- a/c compressor/Radiator fan come on with heat
- MAF issues. Low boost. 2009 SS
- 2010 Cobalt SS blows BCM3 fuse
- What coolant are you using?
- 2006 Cobalt Rumbling Sound
- 2006 Cobalt AC Condenser
- Sunload sensor
- BCM Programming Issues
- Whining noise increases pitch with RPM
- Issue with overheating
- 09 LS cooling fan gremlins
- Ran through puddle car instantly died
- P0299 underboost but everything seems fine
- PCV hose
- No Cruise & High RPM
- Rusted out rear frame, no supporting metal nearby
- New to me LNF issues
- Weird tick/knock only above 3k rpm
- 2008 LE5 P0171B code
- No crank no start
- 09 Cobalt SS Rear Disc Clicking Noise
- Catalytic Converter Advice
- Rear Brakes Creaking, Just Changed Brake Pads
- TRANS 2 fuse blows when key turned on
- Busted gas tank strap
- RPM Guage Not working
- F35 No Reverse!
- Electrical issue
- Someone “steer” me in the right direction!
- Dashboard warning messages gone crazy!
- Check Engine light after oil change
- 07 Cobalt SS Supercharger Leaking Oil
- Running lean, please help.
- ZZP Timing Chain Guide for LNF (2.0) - anyone every install this? Any reviews?
- Stock 05 SS P0335 help
- Can someone tell me where this leak is from? CV axle shaft seal or Output shaft Seal?
- Power Windows/Side Mirrors/Lock Button Not Working
- Cv axle problems
- Steering Wheel Won't Lock
- Blown head gasket or cracked block/sleeve?
- Throw out/slave dying??
- Antitheft
- Assist: 2010 Chevy Cobalt Power Steering/Speedometer/Gear Issue
- car startd but sputters and dies after a few seconds
- Cold Weather = Engine PWR Reduced / Engine Disabled
- 06 Cobalt SS powersteering message
- A-Pillar RPD Display Not Functioning - Safe Mode
- 2005 TPS/APP/BARO+Misfire
- 07 SS/SC sudden stall while driving and no crank
- 2005 SS no crank, no start
- Trying to figure out wiring, plz help!!!
- 07 ss problems after engine swap
- Fuel rail leak????
- 06 SS/SC won't start
- Starts, high rev and then dies
- No power steering
- Need help identifying and locating cut wires..
- E Brake cable compatibility
- Alignment issue after replacing struts
- o2 sensor issues
- Red fuse in trunk next to battery
- 08 cobalt lt I'm just a confused girl
- 2.2 Mysterious Misfire
- Steering knock after suspension work
- How Did You Disable the SRS Airbag Light After Installing Racing Seats And Harness?
- Resonating nose
- Ac problems
- 05 Cobalt....cold missfire...
- Passkey issue??
- Inconsistent engine whine
- 2005 L61 engine wiring harness
- Fuel Conditioners & Cars that have been resting
- Is the AC condenser supposed to fit tight against intercooler heat exchanger?
- Serious bogging issues help!!
- Water pump
- No crank LNF - crank relay doing weird things - PLS HLP!!
- Cobalt SS won’t start
- Electrical problems
- Car won't engage
- New LDK motor BLEW!!!
- Oil leak from block
- New SS Owner HELP!
- How to idler pulley
- any GM techs still here? (BCM XM/cell codes)
- P0017
- Rear fuel line leak(09 LNF)
- I forgot to check the crankshaft position before removing timing parts...
- Help
- Door lock actuators
- Boost climbs to 12 psi and then drops to make less than 5
- MANY bad gaskets, i want to track down cause.
- 2007 cobalt brake signal issue.
- Shifter Cables Replacement
- 09 SS New Clutch Problems
- NEW 08 Lnf it has some issues need help plz
- O-ring size?
- Clutch adjustments?
- Power steering Cobalt vs HHR vs Equinox almost same?
- No spark on 2006 SS Supercharged
- Changed o2 sensors car won’t start
- Second gear no boost
- Starter cranking without key turned
- Cobalt LT2 08 milkshake.
- 06 SC, Addressing various issues before spring
- LNF Brembo pad lube questions
- Help with alarm, vats ?
- Anyone using this Prestone antifreeze/coolant?
- 05 2.2 Rough Idle
- Pproblem with ZZP dual-pass endplate
- Different part numbers for Keyless remote
- P2101 with other issues combined
- Help
- lost key, need help
- Upgrades
- "Eng Pwr Reduced" but no CEL or codes???
- o2 sensor connectss to nothing?
- o2 Sensor wires missing?
- Battery is dying with no parasitic drain
- Need advice...
- F40 swap
- Turbocharged cobalt transmission issues.
- 2006 Cobalt SS Low Mileage No Crank
- Need some help with diagnosis and repair plz
- theft light on car wont start
- Radio comes on but no sound from any of the speakers.
- Cyl 3: 0 compression, leakdown showed nothing
- Help : 09 Cobalt SS makes no boost
- Squeaks
- How to perform a parasitic draw test with the battery in the trunk?
- What do the numbers mean?
- BKR7E Plugs on a not yet modded 2.0 SC
- 06 SS/SC Front End Clunk Fixed
- I think I installed the wrong component..
- Where do I locate the grounds on this thing?
- No Power steering/cruise control or horn
- 06 SS, Steering wheel button issues and intermittent cruise
- LSJ part melting beside engine with two hoses coming from it, what is it? (pic)
- 05 Cobalt 2.2 L (vin F) valve cover grounding issues
- '10 ss o2 sensor won't reach zzp 3" downpipe
- Traction Issue
- Rough acceleration, hard starting, backfiring
- Strut Mount Issue
- My son's weird Cobalt issue
- Advice: 06 Cobalt SS supercharger engine stopped on highway
- 2006 cobalt won't start. PLEASE HELP
- lsj timing chain guides
- Clutch issues?
- Car misfiring after 5000rpm
- System too lean bank 1 problem please help!
- LNF 10 PSI Boost
- Water leak
- Worst Spot for a Dent
- ‘10 2.2 lt cobalt engine troubles
- BCM replacement?
- Help fan stay on
- 2010 lnf overheating only with heat on
- No Overdrive
- Water Leak
- New maf and the engine won't run
- Long detailed 07 cobalt s/c chain reaction problem
- Car has power but won't start.
- It is incredibly difficult to put it into 1st gear..
- Where or how to obtain shifter bushings?
- How do I fix my shift arm?
- Rough idle/surging, misfire, throttle actuator position performance.
- So many wires..
- Tire rubbing seriously bad.
- intercooler issues
- About to test my MAF sensor for code P0102 'low frequency'
- Bled all new clutch parts, still an issue
- Cam Position Sensor Timing
- Wot Box launch control
- 2007 Cobalt SS 5 speed manual transmission fluid level
- 06 Cobalt SS/SC no start no crank (engine will not turn)
- Headlights Dim
- Throttle cutting out on the highway
- Need help
- Is Chevrolet trying to rip me off?
- 05 LS Coupe No longer starts P0340
- Boost problem
- Are there Cobalt SS Wiring diagrams publicly available?
- Clunking from transmission
- P0102 code popped up
- Problems After Cleaning Throttle Body
- Lightweight flywheel misfires
- Multiple sensor codes - potential ground issue?
- Shoulder Harness Guide Replacement
- Sleeve replacement labor hours
- Running rough with a weird twist
- 2010 Cobalt SSTC p0236 and Boosting Issues (and P2178, P2188)
- 2009 Cobalt SS/TC Heat Issue
- Rear Fuel Line Replacement
- Rear End Suspension Noise W Video - What is it?
- Windshield wipers
- 2006 ss Colbalt help please
- Please Help - Cobalt SS Supercharged Question with Video
- 2008 lnf p0238
- Engine support bar Harbor Freight
- 2006 cobalt REDUCED ENGINE POWER
- Easier steering to the left
- O2 Sensor Problems
- 2006 SS clutch master cylinder bleed troubles
- Leak, Sensor, Tune, WHAT
- 2006 SS SC Question
- Cars bucking over 12psi and 3/4 throttle
- Help! I changed the dead battery and now my anti theft system won't let me start!
- 2.4SC, 6psi boost?
- Radio has no power
- I think I screwed my clutch/transmission..
- Rear Caliper Mounting Bolt
- Brake pads rubbing on rotor issue
- P0017 plus valve noise
- TPMS Issue
- Wastegate rod adjustment help
- Turbo to manifold causing car to lose boost?
- Is there a common failure point on O2 wiring harness
- Alarm won't disable, but car starts fine
- Sturdier Fuel Pump?
- Need new transmission
- LNF Valve Cover Seepage
- Power Steering gone after new radio
- Need help with codes - P0106,P0101,P013E!!! Please
- P0100
- I need a new clip and hose for my clutch, but I can't find the clip.
- Car sputtered to a stop. Now it won't start, major electrical issues!
- LNF Sputtering at WOT in boost
- Closed throttle surge.
- No Crank No Start
- Fan blower works on 1 2 3 but shuts off on 4
- Help! Error Code - P013E
- 06 cobalt no start no crank
- LNF timing cover leak
- Leaking coolant from bell housing
- rack and pinion is moving
- Fuel Injector Issue?
- Dash/elctrical
