View Full Version : Drivetrain
Pages :
10]
13
14
- I really need help....:(
- Clutch install, now has leak
- Quick question on the GMPP clutch upgrade.
- When tuning the auto trans, is this normal?
- Tuning auto tranny
- Limited slip differential
- anyone know
- Limited slip diff not working
- Rear Subframe
- Which shifter for my 08 SS??
- axle help please
- tranny mounts.
- cavalier same as cobalt st shifter?
- rear wheel drive
- PCM Part number 09 Cobalt SS
- auto 2.2 ion hard shifting need help
- crashed my car..got all new parts..
- question OTTP rotated mounts
- Clutch Issues.....Need Help
- clutch chioce help
- Short Throw Shifters
- 07 ss wont shift into reverse
- wont go into gear
- Smoothest Shifts Ever!
- need a tranny
- Smooth Driving - Outrageously Slow 1-2 Shifts?
- Problem with trans tune - T/C light stuck on
- Where to buy a ...
- Spec Clutches/Flywheels Package Deal - July '09!
- ACT clutch release for Cobalt SS/SC
- tranny fluid questions
- 2.0L trans fit a 2.4L
- Tranny and Engine mount install
- Those that have the spec 3+ clutch, come in!
- Engine Mounts and Solid Tranny mounts
- Engine/Transmission mount question...
- clutch kits on ebay????
- Transmisson/Shifting Problem
- Master Clutch Cylinder
- Standing on a Red Light
- What clutch do i get for my mods?
- Limited Slip
- Help! simple question
- stg 3 clutch no pedel pressure at all
- whats the difference in mounts?
- shifting problem
- Weird rubbing sound when I turn, any idea's?
- Slave Cylinder/TOB problem
- ss/tc clutch
- rotated tranny mount 1/4 mile improvements?
- shifter
- clutch problem
- who is good with transmissions?
- stupid ? please help
- Car does not like to go into reverse?
- rear beam axles
- Help with ZZP's Stage 2 axles
- 1,3,5 feeling funny going in
- having some clutch issues (suprise, suprise)
- at the shop need to know what gear oil to buy asap
- rotated tranny mount stage 1
- Good news!
- clutch break in.
- Dealership replacing clutch....quick question need help!!
- axel is messed up
- Got new upgraded auto tranny installed with 1 issue.
- Need Some Help Guys, In a sh*tty situation!
- Muffler Search
- Clutch
- Problem during transmission fluid change
- how do you remove axle from intermediate shaft?
- need help fitting axels please!
- new throw-out bearing junk
- b&m shift enhancer
- intercooler diagram
- need input asap
- Possible clutch problem?
- 3.5 v6 into cobalt?
- need new ic pump
- Auto Hard Shifting.. HELP..?!
- IC pump helpage
- royal purple tranny fluid any good
- need a trans
- speed limiter
- overdrive?
- Let my buddy drive my balt.. bad shift, should I be worried
- Differences between 4t40 and 4t45 for use in cobalt?
- How do i modify my B&M to be shorter...?
- 6 speed automatic
- Type of exhaust
- Shifter calbe issues
- My axles and/or differential are going
- getrag f23 rebuild guide
- GM Ecotec clutch upgrade kit
- clutch question
- have to replace axle need help
- 320whp/340torque Clutch Recommendations Please?
- transmission problem!?!?!
- changing 4 lug to 5 lug
- Procharger!!!???
- transmission problem i think.
- new clutch?
- Clutch Upgrade
- odd startup or driver error?
- paddle shifters????
- shifting in auto
- clutch help
- Quick question please help me out
- Clutch
- Am I making the right decision about my new torque converter?
- Short 2nd gear in automatic
- Clutch Recommendation "PLEASE HELP"
- Help!!
- Clutch problems
- zoom clutches
- This might sound dumb
- ss/tc shifter
- Gearbox??
- Sudden soft clutch pedal
- flywheel ??
- Throw out Bearing / Slave Problems (Defective?)
- throw out bearing
- throw out bearing
- throw out bearing
- WTF is this green liquid
- will i snap an axle...
- Grinding when shifting into reverse?
- Gear indicator, neutral safety switch? F35 5-speed manual
- The Dealer...
- torque converter for 4t45e
- Axle Seal
- TC brembos on an SC
- Question about clutch
- automatic to manual swap?
- Clutch install help
- new clutch!
- Does an aftermarket shifter reduce OE sloppiness?
- Did my cousin mess up his transmission?
- Throw out bearing??
- What type of brake fluid do we use
- Gear oil
- Grinding (please help...)
- What trans fluid should I use in my new built tranny?
- Removing transmission cables?
- upgrading clutch what else needs to be replaced?
- stalling issue?
- need advice on clutch install, is it worth it
- clutch slipping
- 7000 RPM (noob question...sorry guys
- Automatic Trans Fluid Change
- New syncros are starting to grind or whatever
- how long you get out of your clutch?
- Clutch install issue
- How to tell if tranny has lsd?
- How Long and other helpful tips
- 07'SS/SC Clutch Question?
- Blew the automatic transmission today :(
- 09 clutch in 06 car?
- hurst short throw help!!
- wheel studs
- clutch problems
- how to break in new transmission
- clutch bleed
- Warranty Coverage and Problems
- automatic drive axle upgrade?
- smokey clutch
- Buying a new clutch.. Any suggestions?
- steering wheel swap help!
- Clutch after 154000km's of hard driving
- Clutch and Motor oil!!!!!HELP!!!!!
- Extremely noob clutch/manual question
- New Clutch Help
- how to eliminate wheel hop
- Ott Axles!!
- 2nd gear grinding
- B&M Shift + ????
- Rev-match
- time for an upgrade
- LSJ trannie on a LE5
- clutch and clutch disk help
- hittin a wall
- Clutch problems need input
- cosmo racing short shifter??
- mounts
- Trannie mounts, engine mounts, and axles oh my
- F23 Fluid Compatability
- Slave/TOB
- front end is shaking
- Trying to find axles for my 06 cobalt ss G-85, but no luck any help?
- Pass side axle broken??
- vin code help
- Upper Tranny Mount Help
- "Syncro Saver"
- Shifter Help Please!! ASAP
- Need a f35 tranny
- have a clutch question
- Need a Clutch Master Cylinder?
- Noob Question, Clutch Install
- Transmission is making weird/grinding noice
- Reducing poly mount vibrations
- Twm Short Shifter Indecision.......
- Help!
- Clutch question
- tranny cases
- Spec Stage 2+ better flywheel needed
- spec stg 2+
- Got the clutch replaced
- NLS for stock only???
- 2009 SS/TC clutch pedal squeaking/loose
- stock clutch ss/tc
- I need help!
- HELP!!clutch install
- Which Clutch.. CM Stage 3 or Spec Stage 2 or 3
- 2nd gear not engaging when NLS
- clutch questions
- 09 no lift shift = broken shift linkage
- Needing Brakes
- Motor mounts/transmission mounts
- Clutchmasters Stage 3
- clutch is slipping (what clutch should i get?)
- Polyurathane Tranny Insert
- Clutch Problem HELP
- lookint to replace my clutch
- Car is jerking while cruising or accelerating
- Stupid clutch question..
- Replacing the Clutch
- Looking for your advice on making my Sedan Sleeperbalt.
- Loose gearbox
- how much different is...
- SS S/C Sachs Clutch Kit
- F23 2nd gear issue, anyone had to battle to get this fixed?
- TMW Hard to get in reverse
- Axle Fail!!!
- clutch
- exedy oem clutch miles??
- clutch issue - any ideas?
- Need Help Please!!!
- spec stage 3+
- still problem with new clutch kit installed (pics)
- reverse is not workin
- Reverse Motor mounts!!!
- i can move my shifter in a circle????
- Cold Start transmission whine
- looking for new clutch any ideas?
- Spec clutch problem!
- what gearbox oil? for ss s/c
- Clutch Fluid DOT4?
- TWM Short Throw help
