- clutch ?'s...done a search.
- OK got a question
- Which Cooler..?
- transmission fluid
- exhaust header not lookin so good...
- issue with my filled motor mounts
- What to buy
- tuning/engine management??
- Anyone working on shift linkage issue?
- Replacement Transmission
- Will a 2.0 clutch fit the 2.4?
- Stock shifter boot
- F23 bleed valve
- My Hurst sts
- Hurst STS knob
- Stock clutch: how long has yours lasted...
- problem with 2nd
- question about 2.0 engine 4 sale
- P2101 Eng Pwr Reduced. Dealerships closed til Tuesday... troubleshooting.
- Automatic to Stick?
- just got 10% of my reverse back YEAH
- so, what fluid are you guys putting in your trannys?
- axle is done, need advice
- Newb question to manuals
- Anyone running a spec clutch on stock flywheel please post here
- Exedy Install Problems
- Bad clutch?
- Changing my automatic to a manual trans?
- Short Shift---Worth it?
- Still confused on changing LSD or whole tran.
- Trouble Installing My B&m Shifter
- Where to purchase the 4.45 Final Drive?
- clearing hurst knob
- reverse syncros
- So about my hurst..
- What cluch should I get?
- Snapping noise
- Just Changed Transmission Fluid and it is great MU3 F35
- Having clutch problems!!!
- New Transmission
- Help Asap
- performance clutch
- What The Heck Just Happened?!
- Drive Train
- Where have you guys mounted your tranny coolers?
- weak pressure plate?
- Slipping Clutch
- Some gears are harder to get in to
- Trans Question
- what size are the threads on a hurst shifter
- Factory Limited Slip
- auto trans dipstick
- Strange noise from drivetrain...
- Tranny Temp Gauge.. Useful?
- shift linkage cable
- total upgrade?
- Installing junker LSD tranny, suggestions?
- short throw
- Thinking about buying a Cobalt SS
- Power steering outage
- best clutch for my situation
- 5th gear sync bad
- Quick Question on 07 & 08 Cobalt SS Differences ...
- what trans to use
- Keeping everyone in the loop
- H E L P !!!!!
- Weak Axles?
- Help
- Mastershift paddle shifter system review
- After market hub
- 2.2 Short Shifter
- 2.4L manual with a slight 2nd gear grind
- Anyone ever broke stage 2 axles?
- Question about B&M shifter in 06 SS/SC
- Found this on ebay...
- help.. twm sts
- Need New Tranny!!!!
- HELP CV Joint Fell Apart.
- what type off clutch to get???????
- Dynoed the Harrop, Broke it at the track
- Hurst Short Throw
- When making over 300hp. what tranny ?
- making f-35 tranny hold up more power ?
- LSD installion into a non G-85????
- Hurst Shifter Shift Knob
- What Clutch to Get If I Need One
- Tight Shifter
- Tight Shifter
- clunking noise. Tranny mounts maybe?
- replace throw out bearing/bleed system
- clutch wont grab
- cams...
- clutch pedal has no pressure
- 2.2 flywheel
- Stock TC Clutch Type?
- price of clutch install
- throw out bearing
- has anyone replaced axles
- Exedy hyper single grinding noise
- 6 speed conversion
- Exedy initial impressions.
- shifter
- help!!!!
- Need Help ASAP
- How To Shift With An Auto 2.4?
- B&M shift plus question...
- Replacing tranny pan
- Hurst STS Knob ??
- Ls Sts
- short shifter
- SS/TC shifting 1st to 2nd noise
- Leaking transmission from axle seal
- b&m shifter
- Please Help!
- Shifter Question
- 4 to 5 lug conversion
- Hurst STS
- Big Problem Need Help!!!
- Stock clutch tq capacity
- Rear Tranny Mount HELP!!
- Good tansmission oil?
- 2.2 auto trannys
- Stock Tranny
- 1-2 Shift "thump"?
- Shift+
- tracton control
- clutch on the 2.4
- Slicks or Street tires? What's best for driveline durability?
- Why does the f-23 hate me?
- 4T45 Question
- Transmission our clutch problems
- WTF Is Wrong With My Car? HELP PLEASE?!?
- Clutch Switch Broken??
- Clutch question, need help
- Downpipe
- How much fun?
- i lost 2nd,4th, and R...
- Clunking Noise comming from tranny?
- Trans Rebuild
- Cat-Backs for 08 SS/TC
- Master Cylinder for Clutch (part number??)
- why doesnt my car pull
- How-To - Custom Filled Third Trans Mount
- Just got my...
- 2k report on new dealer installed clutch ...
- B&M Shiftplus.... Yes or No
- has anyone seen or installed these?
- clutch
- Quick Shift Plus Question
- do short throws void warranty?
- Not getting fluid to the clutch?
- leaking clutch fluid
- clutch replacement
- Ordering my Centerforce DF
- How hard could this be?
- What clutch should i get??
- Turbo Tech Racing Solid Upper Engine Mount Photos
- I need help like you wouldnt believe
- Trans fluid weeping on top of case
- Anyone ever drilled their polyurethane trans. mounts?
- Ringine noise when letting out of clutch
- Transmission Wobble
- Clutch Install
- Pain in my @$$
- High rpm clutch pedal fade?
- Stage 1/2 clutch questions
- clutch DFX issues
- B&M shiftplus+
- Is my clutch dying??
- Couple clutch questions
- 4-Lug to 5-lug Conversion????
- Clutch not covered by warranty.
- My clutch, It wont come back =(
- Look what the cat dragged in..
- clutch
- :cussing: clutch help
- which short throw is better
- Centerforce DFX Clutch Review W/ Pics
- Driveablity Question for the Exedy HyperSingle
- Any supporting vendors?
- Clutch doesn't... work?
- Broken Axle shaft and ???????
- Clutch
- WHO makes the stock clutch for the ss/sc
- Centerforce dfx series
- Help!! Quick Question?
- fidanza flywheel or spec???
- general clutch question
- Slave Cylinder? where to get one?
- clutch question
- clutch
- Diagnoses Neede: Metal Ticking Sound
- COSMO short throw in an 08
- Throwout Bearing/Slave Cylinder?
- I need some help.
- Maybe A Problem???
- trans problem
- Issues with the drivetrain
- Stage 2 axles?
- what size is our shift knob?
- Post Your Aftermarket Clutch
- Gearing For the 1/4 mile
- for everyone with am flywheels
- how critical is a flywheel?
- Watched someone shift into reverse...
- L61 powered MONTE CARLO
- shift nob
- B&M shiftplus kit for sale
- smelly slipping clutch
- Stupid Newb Question
- Transmission Clunk
- Flywheel Question
- 2nd gear is destroyed
- Exedy Stage 3 Clutch
- clutch question
- Be wary of GM dealerships
- Fidanza Flywheel + GM Clutch = ?
- wheel hop
- shift nob
- Short throw + weird shifting feel.
- which clutch???
- axle going bad at 30K???
- Draining Trans Fluid Question
- Manually shifting an auto. Ok to do often?
- brake/clutch fluid?
- question during tranny fluid change - pics, 56K warned
- Why i wouldnt use this trans fluid?
- Pics of my Exedy clutch after 10 000
- Car Wont Go In Reverse...Help
- Tranny Oil
- blown axles
- Clutch bleeding issues!!!!
- Will a new clutch void powertrain warranty?
- Brakes: how long should they last? on a 2.4L
- Best Clutch!!!!!!
- How To Test Clutch Master Cylinder?
- B&M shift plus
- What parts?
- Bm shift +
- clutch install problems
- HHR Clutch?
- what do u think of this clutch?
- Axel Insatll Question
- shifting concern
- Damn STS linkeage
- Putting Car in Nuetral at stop light
- Stock LSD vs. Aftermarket
- is there any better clutch/flywheel package?
- Just installed B&M Shift+
- LT short shifter
